Samsung BD-P1400
749 svar till detta ämne
Samsung BD-P1400 (Blu-ray & DVD-spelare) 1 8.599998 (34) Inga priser
Samsung BD-P1400 Region AB (Blu-ray & DVD-spelare) 1 8.42857 (6) Inga priser
2 relaterade trådar
Postad 26 August 2007 - 21:30
Addex
  • Addex
  • 1902 inlägg
Samsung BD-P1400, Blu-ray Disc Player
Samsung's BD-P1400 lets you enjoy HD films and shows with a new level of picture customization. Advanced Blu-ray playback technology gives you crisp, clear images, while added picture quality adjustment lets you set sharpness and noise reduction to your liking. HDMI™ v1.3 lets you experience richer colors. Dolby® Digital Plus and Dolby® TrueHD compatibility completes the HD experience. It’s a perfect centerpiece to your media environment, providing the features you need for a fulfilling entertainment experience.
Bifogad fil  BD_P1400_stor.jpg   17.87K   0 Antal nerladdningar
Key Features:
Blu-ray playback at content native HD resolution of 1080p/1080i/720p
1080p/24fps/1080p/60fps
Selectable DVD upconversion (720p/1080i/1080p)
HDMI version 1.3, component video, S-Video outputs
Anynet+ (HDMI-CEC)
Dolby® Digital, Dolby® Digital Plus, Dolby TrueHD, dts-HD
MPEG2, VC-1, H.264, HD JPEG decoding
BD/DVD/CD playback
Stereo and 5.1/7.1-channel audio outputs (8 channel uncompressed, 7.1 analog)
Ethernet port
Coaxial and optical digital audio outputs
11-bit/108MhZ video D/A converter; 24-bit/192KHz audio D/A converter
BD Java
Price: $ 499.99 (5000.- i Sverige)
Mer info...
Samsung BD-P2400, Blu-ray Disc Player
You’re in control of the most detailed Bluray™ images with Samsung’s BD-P2400. With HQV and Full HD+1080p, you'll enjoy the truest image reproduction – just like the original HD video source. Featuring 32-tap adaptive up-scaler, the BD-P2400 offers brilliant Blu-ray image detail. Picture quality can be further adjusted – set sharpness and noise reduction to your preferences.
For superb sound, Dolby® Digital Plus and Dolby® TrueHD compatibility gives you next generation audio quality that completes the HD experience.
Key Features:
HQV video upconversion processing
- HD video (1920x1080)
HDMI digital interface (720p/1080i/1080p)
Selectable DVD upconversion via HQV processor (720p/1080i/1080p)
HDMI version 1.3, component video, S-Video and composite video outputs
Dolby® Digital, Dolby® Digital Plus, Dolby TrueHD, dts-HD, HR, MA (upgradeable by firmware)
BD/DVD/CD playback
Stereo and 5.1 / 7.1-channel audio outputs (8 channel uncompressed, 7.1 analog)
Anynet+ (HDMI-CEC)
Ethernet port
10-bit/108MhZ video D/A converter;
BD Java
Price: $ 599.99
Mer Info...
Båda ska tydligen vara profil 2.0 kompatibla.
Det kommer en hemmabioanläggning med inbyggd blu-ray spelare. Systemet heter HT-BD2 och har en uteffekt på 1100 watt med fyra stående högtalare, två mindre bakhögtalare, en front och en subwoofer. Priset på det här systemet är inte satt ännu, men är aktuellt för att släppas i Norden.
Bifogad fil  HT_BD2stor.jpg   19.27K   1 Antal nerladdningar
Källa: Prylportalen.se
Redigerat av Addex, 04 November 2007 - 15:14.
Postad 26 August 2007 - 21:44
Unregisteredf64a5233
  • Unregisteredf64a5233
  • 14825 inlägg
Där ser man. Verkar som att det inte längre är någon nämnvärd prisskillnad mellan HD DVD och BD-hårdvara om man ser till specen.
Postad 26 August 2007 - 22:15
Chris Ya
  • Chris Ya
  • 665 inlägg
Se där ja, verkar ju intressant. När landar dem i sverige tro?
Postad 26 August 2007 - 22:46
Undrar varför den billigare inte kan uppgraderas med avkodning för DTS-MA som den dyrare kan.
Postad 26 August 2007 - 22:49
Addex
  • Addex
  • 1902 inlägg
Nya generationens blu-ray-spelare från Samsung
[2007-07-13 09:30]
Bifogad fil  wide_pic_samsung.jpg   9.83K   1 Antal nerladdningar
Nu har Samsung presenterat sina nya blu-ray-spelare, BD-P1400 och BD-P2400. Nytt är bland annat HQV-processor och stöd för DTS-HD-ljud.
Nya BD-P1400 och BD-P2400 är uppföljare till Samsungs blu-ray-spelare BD-P1000 BD-1200 som funnits ute på marknaden en tid.
De nya spelarna har hdmi 1.3 som möjliggör filmuppspelning i 24 bildrutor per sekund. De har också nätverksport, Dolby Digital-, Dolby Digital Plus- , DTS-ljudteknik samt Samsungs HDMI CEC-teknik. Båda modellerna konverterar upp vanliga dvd-filmer till 1080p-upplösning och kan spela upp DVD-ROM, DVD-+/R, DVD-+/RW, CD, CD-R och CD-RW-skivor.
BD-P2400 är lite dyrare eftersom att Samsung utrustat den med en HQV-processor. HQV står för Hollywood Quality Video och är en teknik som sägs skala upp 1080i-video till 1080p med hög precision.
Spelarna kommer att börja säljas i USA i september och oktober månad. När de kommer till Sverige är oklart.
- Vi har ännu inte tagit ställning till när dessa spelare kommer lanseras i Sverige, berättar Erik Johannesson för Prylportalen.
BD-P1400 väntas kosta 549 dollar vilket är runt 3700 kronor. BD-P2400 kommer kosta omkring 599 dollar som är ungefär 4050 kronor. Vi räknar med att priset kommer fläskas på en aning när de väl kommer till Sverige.
Postad 26 August 2007 - 22:58
Unregistered9a177c31
  • Unregistered9a177c31
  • 1716 inlägg
Vill ha! Blir antagligen någon av dessa eller Samsungs kombospelare till vintern om nu inte priset hamnar på tok för högt.
Postad 27 August 2007 - 07:34
Jag tror det är 2400 som fått Joe Kanes "Quality check = OK" (vilket är mer än vad man kan säga om en HQV-spelare för ett annat format) vilket troligtivs innebär att den är rent ut sagt förbaskat bra. Nästan så man vill skippa spelmöjligheterna i PS3 för att ta denna istället. :rolleyes:
Postad 27 August 2007 - 08:12
khalnur
  • khalnur
  • 1668 inlägg
Jag tror det är 2400 som fått Joe Kanes "Quality check = OK" (vilket är mer än vad man kan säga om en HQV-spelare för ett annat format) vilket troligtivs innebär att den är rent ut sagt förbaskat bra. Nästan så man vill skippa spelmöjligheterna i PS3 för att ta denna istället.  :P
Typiskt att man som jag nyss köpt spelare nu när denna lurar runt hörnet. :) Är dock sjukt nöjd med min BDP-S1E, som tur är. :)
Postad 27 August 2007 - 08:40
khalnur>> Det är ju inte direkt så att BDP-S1E gör bort sig bildmässigt så det är nog inte hela världen (och för att en produkt i hans ögon ska få NOT OK krävs inte mkt, varav det mesta är osynligt för en någotsånär normal person). :P
Får nog tillfälle att fråga honom personligen nångång så jag kan höra med vad det är för mikroskopiskt som skiljer mot Sonyn - förvänta dig inget objektivt svar dock, Joe är anti-Sony så det bara sjunger om det. :)
Redigerat av pacman, 27 August 2007 - 08:41.
Postad 30 August 2007 - 13:10
Addex
  • Addex
  • 1902 inlägg
Första inlägget ändrat och en ny produkt är tillagd.
Postad 30 August 2007 - 14:00
Scrapanatchi
  • Scrapanatchi
  • 1061 inlägg
hur mycke lagrings utrymme rör det sej om? 1gib eller mer?
Postad 30 August 2007 - 14:05
Addex
  • Addex
  • 1902 inlägg
1 Gib är minimum.
Redigerat av Addex, 30 August 2007 - 14:05.
Postad 30 August 2007 - 16:18
necrio
  • necrio
  • 646 inlägg
Hddvd har väl fortfarande inte en enda spelare som klrar 1080p/24 eller har jag fel? och deras billigaste spelare klarar inte ens 1080p.
bluray är långt före. du får mycke mer video för pengarna.
Postad 30 August 2007 - 17:50
  • 6930 inlägg
Trots att jag är nöjd med Blu-Ray spelaren i min PS3:a så vore det skönt att ha en renodlad spelare utan en fläkt som stör :)
BD-p1400 verkar ju intressant och jag känner mig mer redo att skaffa en "vanlig" spelare nu när den verkar vara Profil 2.0 också.
I want it know :)
Postad 30 August 2007 - 19:35
Unregisteredf7bba9d7
  • Unregisteredf7bba9d7
  • 1113 inlägg
Just nu så klarar inte hd-dvd spelarena 1080p/24. Det kommer ett firmware i september som gör att Toshibas 1080p spelare klarar detta. I firmwaret kommer också stöd för att skicka hd-ljudformaten så att de kan processas i en receiver.
Postad 31 August 2007 - 00:01
LmnT
  • LmnT
  • 103 inlägg
Trevligt att dem lanserar en blu-ray-spelar till överkomligt pris. Förhoppningsvis sätter detta press på de andra stora tillverkarna att följa deras spår och kan få priserna att sjunka. :)
Postad 01 September 2007 - 10:07
Unregistered4e1812ee
  • Unregistered4e1812ee
  • 889 inlägg
Synd att Abt i USA (infolänken) inte verkar ta beställningar från hela världen inkl. Sverige...
Postad 02 September 2007 - 13:51
Addex
  • Addex
  • 1902 inlägg
Produktblad för BD-P2400. Där i bekräftas också DTS-HD Master Audio.
Postad 02 September 2007 - 18:45
  • 1716 inlägg
Båda spelarna skulle komma i November vad jag hört. Gäller det också Sverige eller är det USA som kommer först?
Postad 02 September 2007 - 21:46
Major Högberg
  • Major Högberg
  • 16 inlägg
Det rinner ur munnen på mig när jag läser specarna för BD-2400
Jag vill ha en nu!
Denna maskin kommer ha HDMI 1.3 och det har min LC tv också Samsung m86/40
Kommer jag behöva köpa en ny HDMI kabel som stöder HDMI 1.3, som säges klara högre frekvenser än tidigare versioner av HDMI?
sen undrar jag även om H.264 är ett annat namn för MPEG-4?
Postad 02 September 2007 - 21:55
Addex
  • Addex
  • 1902 inlägg
Nej om vi talar om korta avstånd, kanske om vi talar om längre avstånd.
Gizmodo gjorde ett test med "Monster Cable", läs om detta här..
Ja, H.264 är ett av namnen på "MPEG4 del 10". Ett annan namn är "AVC" Advanced Video Coding.
Läs mer här...
Postad 03 September 2007 - 07:52
Jag vill ha en nu!
Var har du tänkt hitta material som stödjer det hdmi 1.3, högst eventuellt, tillför?
Postad 03 September 2007 - 16:08
Unregistered0f33ff87
  • Unregistered0f33ff87
  • 88 inlägg
Tycker det har pratats mycket om BD-1400 på senaste tiden men man har ju inte hört något om bd-2400!
Är det bekräftat att den modellen kommer till Sverige? Isåfall när?
MVH Claes
Postad 03 September 2007 - 17:27
  • 14825 inlägg
Det börjar komma en hel del AVCHD videokameror med xvYCC (x.v.Colour), ett steg på väg i varje fall.
Postad 04 September 2007 - 10:49
morlock>> Sant och jag blir lätt avis på dem som vistas på sådana ställen där färgerna är så mättade och vackra att de inte ryms inom HD-färgrymden. :)
(förutsatt att man, när man kommer hem från semestern, har den LED display som krävs för att visa xvYCC på riktigt korrekt sätt)
(*) ärligt talat så är mättnaden inte hela poängen med xvYCC, förutom färgomfång kan det även ge mer detaljer i mättade färger, ett område där dagens HD-standard kommer lite till korta. Inte minst om det kombineras med Deep Color. Tyvärr är ju inte hdmi v1.3 nån garanti för att support (och då ens bra sådan) för xvYCC och Deep Color finns.
Postad 05 September 2007 - 20:02
lobo
  • lobo
  • 2842 inlägg
MVH Claes
Undrar oxå...... Var har Samsung gått in och bekräftat BD-2400? I pressrellen så är det ju bara DB-1400 som nämnsm är inte BD-2400 aktuell för den nordiska marknaden?
Postad 25 September 2007 - 10:21
THXcht
  • THXcht
  • 2340 inlägg
Själv köpte jag en BD-P1000 som en så länge spelare, men att byta ut den mot en 1400 känns ju lite fel eftersom den oxå känns lite som en så länge spelare. 2400 är ju en mer komplett spelare och den ska ju klara av allt man kräver idag som inte 1400 gör.
Så själv hoppas jag på att 2400 kommer till Sverige annars vet jag inte vad jag ska välja för spelare. Helst så vill jag ju ha en Pioneer men till de priserna så skiter jag i det.
Postad 28 September 2007 - 22:48
THXcht
  • THXcht
  • 2340 inlägg
Samsung BD-p1400/XEE.
Vad står XEE för? Är det en version som är reg A eller?
www.ney.se skriver att de har den i lager i alla fall.
Postad 28 September 2007 - 23:55
lobo
  • lobo
  • 2842 inlägg
Tippar på att det har att göra med tillverkningsland (försäljningsmarknad) då det är så med Sammys lcd apparater (tex. M86/87)
XEE = Samsung Nordic?
Finns väl även XEC och XIXEU som säljs "gråimporterade" i Sverige (lcd)
Rätta mig gärna om jag har fel, är inte 100.
Redigerat av lobo, 28 September 2007 - 23:58.
Postad 29 September 2007 - 09:46
THXcht
  • THXcht
  • 2340 inlägg
Tackar, då blir det nog till att beställa en sådan.
Postad 30 September 2007 - 16:30
Unregistered665b7df5
  • Unregistered665b7df5
  • 445 inlägg
Blir ngn av dessa modeller (regfri) på DVD uppspelning??
Postad 30 September 2007 - 16:41
Unregistered36883
  • Unregistered36883
  • 3680 inlägg
Frågan är ju om det går att göra/få Samsung BD-P2400 regionsfri...?? Isåfall kommer den göra succe med min nya Samsung PS-50P96FD full-hd plasma som kommer till mina ägor om ca 2 veckor...?? Annars blir det till att invänta första BD spelaren som man kan lösa det med...
Postad 01 October 2007 - 05:59
diabolo
  • diabolo
  • 3548 inlägg
http://wesleytech.co...r-canceled/380/
Postad 01 October 2007 - 06:31
Addex
  • Addex
  • 1902 inlägg
Synd men ändå bra.
Postad 01 October 2007 - 18:40
Chris Ya
  • Chris Ya
  • 665 inlägg
Synd men ändå bra.
Good news! Bättre att ta tillbaka den och göra en ny med nyare profil.
Postad 06 October 2007 - 13:03
  • 889 inlägg
Beställde precis en BD-P1400 regA från Swedisc. Har då sammanlagt spenderat ca 21 kkr för att kunna se båda HD-formaten... ;)
Postad 06 October 2007 - 13:12
hur många spelare har du ??
Postad 06 October 2007 - 13:50
Unregistered36883
  • Unregistered36883
  • 3680 inlägg
Känns surt att vara utan en BD spelare men ännu surare att man ska behöva köpa flera stycken från lite olika regioner om man har tänkt köpa filmer lite här och var.... :) Nä det blir till att vänta tills det dyker upp en regionsfri nångång i framtiden.... ;)
Postad 06 October 2007 - 14:33
lobo
  • lobo
  • 2842 inlägg
Är på god väg..... Har lagt 18500 på enbart bd än så länge och en beställning liggandes på en bd-p1400. Har inte tagit steget över till den mörka sidan än men det kanske kommer, inget är ju omöjligt.
Postad 06 October 2007 - 15:44
Chris Ya
  • Chris Ya
  • 665 inlägg
Jaså det blir en Samsung P1400 också?
Ser fram emot recesioner ;)
Postad 06 October 2007 - 17:21
  • 889 inlägg
Har EN HD-spelare, Toshiba HD-E1, köpte en Lumagen HDP videoprocessor (ca 12000) också samt en HDFury (ca 1000 kr, tar bort HDCP kodningen), allt för att kunna använda min CRT projektor med de underligt uppbyggda och HDCP-skyddade utsignalerna från både HDDVD o BD spelare...
Postad 06 October 2007 - 17:23
  • 889 inlägg
Känns surt att vara utan en BD spelare men ännu surare att man ska behöva köpa flera stycken från lite olika regioner om man har tänkt köpa filmer lite här och var....  <_<  Nä det blir till att vänta tills det dyker upp en regionsfri nångång i framtiden....  :)
Det lär det nog inte göra :( .... men kanske att någon lyckas hacka regionskyddet framöver :D
Postad 08 October 2007 - 12:55
JOEKO
  • JOEKO
  • 172 inlägg
BD-P1400 känns som ganska lagom som instegsmodell.
Nu är det bara att prioritera i budgeten!
JOEKO
Postad 08 October 2007 - 23:56
lobo
  • lobo
  • 2842 inlägg
Borde dyka upp som preorder hos fler butiker i det närmsta, Samsung Sverige har lag upp den med pris och datum (enligt min åf, Expert).
Postad 09 October 2007 - 08:11
THXcht
  • THXcht
  • 2340 inlägg
Ligger inte någonting på www.samsung.se, men det är kanske bara något som går ut till ÅF och inte almänheten.
Postad 12 October 2007 - 13:39
  • 889 inlägg
Nu har uppenbarligen Swedisc skickat iväg min BD-P1400, för det hade dragits 4175,34 kr på kortet. För en gångs skull kunnat dra nytta av låg dollarkurs... ;)
Postad 12 October 2007 - 15:51
PsychoCheF
  • PsychoCheF
  • 1353 inlägg
Bara undrar... det står att det är en amerikansk modell (på swedisc), så om jag fattar det rätt så kan du inte se filmer köpta i sverige med den om dom är reg kodade?
Vill man inte ha en svensk modell? eller har jag missat något?
Postad 12 October 2007 - 16:03
Addex
  • Addex
  • 1902 inlägg
Större utbud i staterna och du får nya filmer före och i Sverige, samt att Japan har samma region som USA.
Postad 12 October 2007 - 16:51
  • 889 inlägg
Just det... dessutom har jag o tänker importera en del som bara finns på DVD reg 1. De få blu-ray titlar som än så länge släppts exklusivt i EU, som t ex The Rock, verkar vara regionsfria.
Postad 13 October 2007 - 07:30
PsychoCheF
  • PsychoCheF
  • 1353 inlägg
Nu har uppenbarligen Swedisc skickat iväg min BD-P1400, för det hade dragits 4175,34 kr på kortet. För en gångs skull kunnat dra nytta av låg dollarkurs... :)
Finns det svensk text på importerade BD filmer? (tänkte på det stora utrymmet som finns att tillgå så borde ju all världens textningar kunna finnas med...
