Type
Type Single-lens reflex digital camera
Lens Mount Nikon F bayonet mount with AF coupling and AF contacts
Picture Angle Equivalent to angle produced by lens focal length
(1.5 times when DX format is selected)
Effective Pixels
Effective Pixels 12.1 million
Image Sensor
Image Sensor CMOS sensor, 36.0 x 23.9 mm; Nikon FX format
Total Pixels 12.87 million
Dust-Reduction System Image sensor self-cleaning function, Image Dust Off
reference data acquisition (Capture NX 2 required)
Storage
Image Size (pixels)
Image area L M S
FX format (36 x 24) 4,256 x 2,832 3,184 x 2,120 2,128 x 1,416
DX format (24 x 16) 2,784 x 1,848 2,080 x 1,384 1,392 x 920
File Format • NEF (RAW): 12 or 14 bit, lossless compressed,
compressed, or uncompressed
• TIFF (RGB)
• JPEG: JPEG-Baseline compliant with fine
(approx. 1:4), normal (approx. 1:8), or basic
(approx. 1:16) compression ();
compression available
• NEF (RAW) + JPEG: Single photograph recorded in both NEF (RAW) and JPEG formats
Picture Control System Four setting options: Standard, Neutral, Vivid,
Monochrome; each option can be adjusted
Storage Media CompactFlash (Type I, compliant with UDMA)
File System Compliant with DCF 2.0, DPOF, Exif 2.21,
Pictbridge
Viewfinder
Viewfinder SLR-type with fixed eye-level pentaprism
Diopter Adjustment -3 to +1 m-1
Eyepoint 18 mm (-1.0 m-1)
Focusing Screen Type B BriteView Clear Matte VI screen with
superimposed AF points and framing grid lines
Frame Coverage Approx. 95% (vertical/horizontal)
Magnification Approx. 0.72x (50mm f/1.4 lens at infinity; -1.0 m-1)
Reflex Mirror Quick-return type
Depth-of-field Preview When CPU lens is attached, lens aperture can be
stopped down to value selected by user (A and M
modes) or value selected by camera (P and S modes)
Lens Aperture Instant-return type, with depth-of-field preview
button
Lens
Compatible Lenses • DX AF Nikkor: All functions supported
• Type G or D AF Nikkor: All functions supported
(PC Micro-Nikkor does not support some functions). IX Nikkor lenses not supported.
• Other AF Nikkor: All functions supported except
3D Color Matrix Metering II. Lenses for F3AF not supported.
• AI-P Nikkor: All functions supported except autofocus and 3D Color Matrix Metering II
• Non-CPU AI Nikkor: Can be used in exposure modes A and M; electronic rangefinder can be used if maximum aperture is f/5.6 or faster; Color Matrix
Metering and aperture value display supported if user provides lens data
Shutter
Type Electronically controlled vertical-travel focal-plane shutter
Speed 1/8,000 to 30 s in steps of 1/3, 1/2 or 1 EV, Bulb, X250
Flash Sync Speed X = 1/250 s; synchronizes with shutter at 1/320 s or
slower (flash range drops at speeds between 1/250
and 1/320 s)
Release
Release Modes 1) Single-frame (S) mode, 2) Continuous Low-speed mode, 3) Continuous High-speed mode, 4) Live View mode, 5) Self-timer mode, 6) Mirror-up mode
Continuous Shooting Speed With Rechargeable Li-ion Battery EN-EL3e:
1-5 frames per second in mode, 5 fps in mode
With Multi-Power Battery Pack MB-D10 with batteries other than Rechargeable Li-ion Battery ENEL3e or AC Adapter EH-5a/EH-5: 1-7 frames per second in mode, 8 fps in mode
Self-timer Electronically controlled timer with duration of 2, 5, 10 or 20 s
Exposure
Metering TTL full-aperture exposure metering using 1,005 pixel RGB sensor
Metering System 1) 3D Color Matrix Metering II (type G and D
lenses); Color Matrix Metering II (other CPU
lenses); Color Matrix Metering (non-CPU lenses if
user provides lens data)
2) Center-Weighted: Weight of 75% given to 8-, 12-, 15- or 20-mm circle in center of frame, or weighting based on average of entire frame
3) Spot: Meters 4-mm circle (about 1.5% of frame) centered on selected focus point (on center focus point when non-CPU lens is used)
Metering Range 1) 0 to 20 EV (Matrix or Center-Weighted Metering), 2) 2 to 20 EV (Spot Metering) (ISO 100 equivalent, f/1.4 lens, at 20°C/68°F)
Exposure Meter Coupling Combined CPU and AI Exposure Modes 1) Programmed Auto (P) with flexible program, 2) Shutter-Priority Auto (S),
3) Aperture-Priority Auto (A), 4) Manual (M) Exposure Compensation ±5 EV in increments of 1/3, 1/2 or 1 EV
Exposure Lock Exposure locked at detected value with AE-L/AF-L
button
Exposure Bracketing Exposure and/or flash bracketing (2 to 9 exposures
in increments of 1/3, 1/2, 2/3 or 1 EV)
Sensitivity ISO 200 to 6400 in steps of 1/3, 1/2, or 1 EV; can be set to approx. 0.3, 0.5, 0.7, or 1 (ISO 100 equivalent) EV below ISO 200, or to approx. 0.3, 0.5, 0.7, 1 (ISO 12800 equivalent), or 2 (ISO 25600 equivalent) EV over ISO 6400 Active D-Lighting Can be selected from , , , or
Focus
Autofocus TTL phase-detection AF, 51 focus points (15 crosssensors) by Nikon Multi-CAM 3500FX autofocus module; Detection: -1 to +19 EV (ISO 100 at 20°C/68°F); AF fine tuning possible; AF-assist illuminator (range approx. 0.5-3 m/1.6-9.8 ft.)
Lens Servo 1) Autofocus: Single-servo AF (S); Continuousservo AF ©; Focus Tracking automatically activated according to subject status, 2) Manual focus (M) with electronic rangefinder Focus Point Single AF point can be selected from 51 or 11 focus points AF-Area Mode 1) Single-point AF, 2) Dynamic-area AF , 3) Autoarea
AF
Focus Lock Focus can be locked by pressing AE-L/AF-L button or by pressing shutter-release button halfway (Single-point AF in AF-S)
Flash
Built-in Flash Manual pop-up type; guide number of 17/56 (ISO 200, m/ft., 20°C/68°F) or 12/39 (ISO 100, m/ft., 20°C/68°F)
Flash Control
1) TTL flash control with 1,005-pixel RGB sensor; i-TTL balanced fill-flash and standard i-TTL fillflash available with SB-900, 800, 600 or 400
2) Auto aperture (AA): Available with SB-900, 800 and CPU lens
3) Non-TTL auto (A): Available with SB-900, 800, 28, 27 or 22s
4) Distance-priority manual (GN): Available with SB-900, 800
Flash Sync Modes 1) Front-curtain sync (normal), 2) Slow sync, 3) Rear-curtain sync, 4) Red-eye reduction, 5) Red-eye reduction with slow
Sync Flash Compensation -3 to +1 EV in increments of 1/3, 1/2 or 1 EV
Flash-ready Indicator Lights when Speedlight such as SB-900, SB-800,
SB-600, SB-400, SB-80DX, SB-28DX, or SB-50DX is fully charged; blinks after flash is fired at full output
Accessory Shoe Standard ISO 518 hot-shoe contact with safety lock
Sync Terminal ISO 519 standard terminal Nikon Creative Lighting System With Speedlights such as SB-900, SB-800, SB-600, SB-R200, or SU-800 (commander only), supports Advanced Wireless Lighting, Auto FP High-Speed Sync, Flash Color Information Communication, modeling flash and FV lock; built-in flash can be used as a commander
White Balance
White Balance • Auto (TTL white balance with main image sensor and 1,005-pixel RGB sensor);
• Seven manual modes can be preset with finetuning; color temperature setting; white balance bracketing: 2 to 9 exposures in increments of 1, 2 or
3
Live View
Modes Hand-held mode: TTL phase-detection AF with 51 focus areas (15 cross-type sensors) Tripod mode: Contrast-detect AF on a desired point
within a specific area
Monitor
LCD Monitor 3-in., approx. 920,000-dot (VGA), 170-degree wideviewing-
angle, 100% frame coverage, low10 temperature polysilicon TFT LCD with brightness adjustment
Playback
Playback Function Full-frame and thumbnail (4 or 9 images) playback
with playback zoom, slide show, histogram display, highlight display, auto image rotation, and image comment (up to 36 characters)
Interface
USB Hi-Speed USB. Video Output NTSC or PAL; simultaneous playback from both the video output and on the LCD monitor available HDMI Output Supports HDMI version 1.3a; Type C mini connector is provided; simultaneous playback from both the HDMI output terminal and on the LCD
monitor not available
Ten-pin Terminal 1) GPS: NMEA 0183 (Ver. 2.01 and 3.01) interface
standard supported with 9-pin D-sub cable and GPS Cable MC-35 (optional)
2) Remote control: via Ten-pin terminal
Power Source
Battery One Rechargeable Li-ion Battery EN-EL3e Battery Pack Multi-Power Battery Pack MB-D10 (optional) with one Rechargeable Li-ion Battery EN-EL4a/EN-EL4 (battery chamber cover BL-3 required) or EN-EL3e, or eight R6/AA-size alkaline (LR6), Ni-MH (HR6), lithium (FR6) batteries, or nickel-manganese (ZR6) batteries
AC Adapter AC Adapter EH-5a/EH-5 (optional)
Dimensions/Weight
Dimensions (W x H x D) Approx. 147 x 123 x 77 mm/5.8 x 4.8 x 3.0 in.
Weight Approx. 995 g/2.19 lb. without battery, memory
card, body cap or LCD monitor cover
Operating Environment
Temperature 0-40°C/32-104°F
Humidity Under 85% (no condensation)
1.jpg 117.8K
2 Antal nerladdningar
2.jpg 88.69K
1 Antal nerladdningar
3.jpg 97.59K
4.jpg 79.54K
5.jpg 77.83K
nikon_d700___nikon_d3.jpg 47.17K
0 Antal nerladdningar
2626160590_27767c398e_o.jpg 376.73K
0 Antal nerladdningarFotosidan har klämt lite på den redan http://www.fotosidan...cldoc/19197.htm
Redigerat av Martin, 01 July 2008 - 07:48.
9
Nikon D700 med funktioner från de stora & storlek från de små.
12 bilder
15 filmer
