Förstäkrare till basshakers
4 svar till detta ämne
Postad 10 November 2019 - 21:45
Irule
  • Irule
  • 275 inlägg
Fungerar detta till basshakers (BassPump III) tror ni?
https://www.wish.com...arch&position=0
Postad 11 November 2019 - 12:10
Irule
  • Irule
  • 275 inlägg
Sound Type: Amplifier Brand: lepai lepy 168HA Model: 168HA Item No: LP168HA Amplifier Type: HIFI amplifier Whether the stage: HiFi Distortion Rate: 0.01 (%) SNR: 75 (db) Impedance: 4-16 (Ω) Rated voltage: 12 (V) Rated power: 40 + 40 + 68 (W) Rated frequency: 20-20K (HZ) Specifications: Amplifier Model: LP-168HA Size: Height 4.2cm length 17.6cm width 9.9cm Peak power: 150W Rated power: 40W * 2 + 68W Power supply: DC DC12-15V (current ≥5A) Product Description: The product is the latest version of the authentic music camp Lepai LP-168HA 2.1-channel high-fidelity power amplifier, with a 5V USB power output, thick brushed aluminum casing, screws and body with black instead of the Torx screws more on the grade. The front panel: a power switch, a single knob to the left for low-frequency adjustment and loudness adjustment, three knobs control the left and right channel bass, treble, master volume, there is an AUX auxiliary audio input jack. Rear panel: 2 Cinch audio inputs, 8 clamp, then the above two groups left and right channel speakers, connect the following two groups with passive subwoofer, USB 5V voltage used for mobile phone, MP3, or other equipment, etc. charging Package include 1 x LEPAI LP-168HA 2.1Channel Motorcycle Car Audio Super Bass Audio Hifi Amplifier (Not include the power adapter)
Postad 13 November 2019 - 13:05
Frux
  • Frux
  • 970 inlägg
Den sägs kunna driva en passiv sub och har justerbart delningsfilter. 68W specad uteffekt för subben lär vara kraftigt överdrivet jämfört med vad man får ut i verkligheten, då det brukar vara så på sådana här kinaprylar. Men för en Basspump III kanske det räcker även om det bara blir halva specade effekten. I värsta fall så är det ju inte så många hundralappar i sjön. :) Jag hade nog inte försökt driva två st basspump dock.
Postad 13 November 2019 - 20:52
Irule
  • Irule
  • 275 inlägg
Jag ser att ljudia säljer basshakers med förstärkare och de rekommenderar denna:
Zachry CSW-55
Nya Zachry CSW-55 är en otroligt efterlängtad produkt, en basförstärkare i ett extremt litet och smidigt format. Zachry CSW-55 har strömbrytare, steglöst variabel delningsfrekvens och volym reglare på framsidan. Baksidan består av ingångar för ström, RCA och 3,5mm minitele. Högtalarutgången är av en röd/svart snabbkontakt. CSW-55 klarar med lätthet av att driva subwooferelement i storleken 5" till 12". Passar även mycket bra till att driva basspumpar/basshakers  i olika storleksutföranden. Uteffekt 40 W RMS i 4 Ohm.
Teknisk data
- Frekvensomfång: 30Hz - 250Hz +/- 3dB
- Volymjustering: Ja
- RCA och 3,5mm lågnivåingång
- Effekt: 40W RMS i 4 Ohm
- Impedans: 4 - 8 ohm
- Säkring: 3A / 250V
- Storlek (BxHxD): 216 x 67 x 156 mm
- Vikt: 1,8 kg inkl nätadaptern
Effekt på 40w?? Kinaförstärkaren är på pappret mycket bättre?
Postad 13 November 2019 - 22:34
Kinastärkaren är ju knappt användbar till enkla skrivbordshögtalare.
https://www.youtube....e&v=NIOpocpbXSM
  • Testar lite olika ljus på belysningen. Styrs med Home Assistant
    2026-09-23 18:09:20
    2026-09-23 18:08:13
