Huvudspecifikationer, Pioneer DV-868AVi
• HIgh-Definition Multimedia interface
• i-link Digital Audio interface
• 216 kHz / 14-bit Video D/A Converter
• Legato Link Conversion Pro and Hi-Bit
• Dual Pure Cinema Progressive Scan for PAL / NTSC
• Speaker Management and DVD-Audio Bass Management
• Playback Discs DVD/SVCD/VCD/MP3/CD/CD-R/CD-RW/DVD-R/DVD-RW/DVD-AUDIO/SACD/SACD MULTI
• Dual System (PAL/NTSC) (Video output) Yes
• 192 kHz/24-bit D/A Converter Yes (6 ch)
• Built-in Dolby Digital Decoder (5.1 channel) Yes
• Built-in DTS Decoder Yes
• Built-in MPEG Decoder Yes
• Built-in SACD Decoder Yes
• Hi-bit Conversion Yes (Front L/R)
• Legato Link Conversion PRO Yes
• Local regulator for Analogue Audio Yes
• Dynamic Range Control Yes
• Bass Management Yes
• Delay Adjustment Yes
• Pure Audio ON/OFF
• Video Features DV-868AVi-S
• PureCinema Progressive Scan: PAL/NTSC Yes/Yes
• Component Frame DNR PRO Yes
• Super Fine Focus Digital Filter Yes
• User Video Memory Modes Yes
• Video Adjust Yes
• Video Signal D/A Converter 216 MHz/14-bit
• Resume Function (Stop Key) Yes
• Remote Control Unit Jog & Joystick, illuminated
• FL Dimmer/off Yes
• Terminals: Euro-SCART 1 (In/Out), 1 (Out), RGB-Y/C Video Output (on Euro-Scart), HDMI Video Output 1 (with Two-Dimensional Resolution Expander Videoscaler ic), i.LINK (IEEE1394) 2, Component (Y, Pb, Pr) 1, S-Video Output 2, Video Output 2, 5.1-Channel Audio Output 1, Audio Output 1, Coaxial Digital Output 1, Optical Digital Output 1
• Total Harmonic Distortion 0,0008%
• Signal-to-Noise Ratio 118 dB
• Dynamic Range 108,8 dB
• Power Consumption 19 Watt
• Dimensions (W x H x D) 420 x 109 x 279 mm
• Weight 5,7 kg
• Pris:
https://www.prisjakt...=3616&type=.png
https://www.prisjakt...=3617&type=.png
MVH Peter.M Moderator
Hej.
Vet ni om något seriöst test på denna spelare.
Eller kan ni.
Är ute efter nytt.
Redigerat av Unregistered242bf02f, 30 mars 2006 - 00:25.
