Zen Micro & MediaPlayer10 Problem
Inga svar i detta ämne
Creative Zen Micro 5GB (MP3-spelare) 1 8.944444 (17) Inga priser
1 relaterade trådar
Postad 05 January 2005 - 12:58
reza666
  • reza666
  • 119 inlägg
Tjena,
Jag har lite strul med sync mekanismen för Zen Micro. Undrar om det är någon som kan föreslå en lösning på det ? Sen är det intressant o veta om det är fler som har samma problem ;)
Jag har även lagt detta på Creative's hemsida o eftersom det är rätt lång som har jag pastat in här nedan:
I have now managed to sync my Zen Micro with MediaPlayer10 and it works just fine.
What i have problem with is the fact that the sync only works one way. Let me explain.
Problem1
Whenever i remove a song from my playlist on the pc and sync then the list on the player (Zen Micro) gets updated ok and the song is removed (deleted from the player). But the problem is when i remove something from the playlist on the player then it will only be removed from the list and not deleted which is what i actually want (atleast there should be a choice for this in the menu)! Also when i sync with the pc afterwards then the list is not updated on the pc. The strange thing is that the list on the player is again updated according to the list on the PC!
Problem2
If i really remove/delete a song from the player (from the artist list it is possible to delete which is not so easy since you need to find the song if you have many songs) and again sync with the PC then the song removed is againg copied to the player!!! This is very annoying since you DO NOT want to sync according to the PC all the time and it should be smart and update according the last list updated or atleast there should be a choice like : update according to player's list or PC's list. But to assume you Always want the PC's list in your player is dumb. I have 800 song in the player and offcourse many are not so good so i want to remove them from the player as i listen and modify the player and i do not want them to pop up again the next time i sync!
PLEASE tell me if there is a solution to this problem or new firmware that solve this.
I am currently using the lates firmware (2.00.12) with the MediaPlayer10.
Hoppas ni har en lösning på det .
/R
