Bild på Philips senaste fjärrkontroll - Pronto Professional TSU9600
6 svar till detta ämne
Postad 29 August 2006 - 15:46
Minhembio
  • Minhembio
  • Nyhetsankare
  • 34 inlägg
Webbplatsen Remote Shoppe har presenterat en bild på Philips Pronto Professional TSU9600 som enligt rykten ska presenteras vid mässan CEDIA Expo i mitten på september.
Mycket hysch hysch har det varit kring denna produkt och Philips har under en tid kört en teaserkampanj för att bygga upp förväntningarna. Nu har i alla fall Remote Shoppe kommit över en bild som visar hur den faktiskt ser ut.
Några egenskaper som Remote Shoppe berättar om:
  • The Pronto Professional TSU9600 is an IR controller that will have "ultra-reliable wireless extenders, and more functionality for multi-room solutions."
  • The unit will be programmed with a new software called ProntoEdit Professional featuring:
    * The capability for an installer to separately store and manage the codes of the equipment he most frequently uses for a custom install.
    * The unit’s IR code learning capability has been significantly improved, offering an unprecedented 99.99% coverage.
    * A built-in Channel Wizard enables the creation of an extremely reliable channel macro, with only a few mouse clicks.
    * PC-to-Pronto downloading is accelerated by a factor 10.
    * WAV file compatibility is included for linking spoken instructions to a button.
  • The 3.7-inch touchscreen has an amazing 640 x 480 (full VGA) display, giving it a higher pixel density than any current touchscreen home control unit.
  • The display has a virtually unbreakable protective screen cover that eliminates a potential cause of failure in touchscreen devices.
  • Support for RS232, Power Sensing and other features expected of high-end controllers.
Remote Shoppe
Philips
Postad 29 August 2006 - 16:46
Unregistered47746e95
  • Unregistered47746e95
  • 1082 inlägg
Och vad kostar en sån pjäs då?
Postad 29 August 2006 - 17:44
Tomas_D700
  • Tomas_D700
  • Rådgivare
  • 5023 inlägg
Själv har jag inte sett några prisuppgifter ännu men med tanke på dess föregångare samt vad den verkar kunna prestera så är jag fullständigt övertygad om att den lägger sig någonstans mellan dyr och svindyr :)
Postad 29 August 2006 - 18:07
Unregistered25afe1a3
  • Unregistered25afe1a3
  • 1919 inlägg
Deras RC9800I var ju ingen hit precis men denna kommer garanterat att vara det, den ersätter väll
Philips SBC-RU980 - Pronto Pro NG som lanserades 2003 och denna lär inte vara billigare.
// Hifighost
Postad 29 August 2006 - 19:19
Unregistereda0ef723f
  • Unregistereda0ef723f
  • 3439 inlägg
Denna ersätter INTE RU980. Den har i dagarna "ersatts" av RU990 (som jag själv har beställt :) ). RF Extendern LI900 kommer den också att ersättas av LI910 (som jag också, hör och häpna, har på beställning).
Pronto Professional TSU9600 (som denna nyhet handlar om) kommer hamna på ett pris runt ca 20 k för den som är intresserad. Priset är inte helt faställt än, men jag har pratat med Philips om denna pjäs. Jag skippade den då jag var ute efter en mer upprätt fjärr. Sen är ju 20 k för en fjärr inga småpengar. Då är man nästan uppe i "Crestronpengar" (iaf för ett startpaket).
Postad 29 August 2006 - 19:38
Tomas_D700
  • Tomas_D700
  • Rådgivare
  • 5023 inlägg
Man kan ju alltid börja med fjärren och sedan spara ihop till resten av anläggningen. Man kanske ändå behöver den tiden för att lära sig hur den fungerar :)
Postad 31 August 2006 - 02:44
Unregistered76636631
  • Unregistered76636631
  • 1029 inlägg
haha
skulle bli lätt å övertala flickvännen om att slå till på en sån.. :)
