Just Cause 2
61 svar till detta ämne
Postad 30 March 2009 - 18:43
Unregisteredf64a5233
Über-Guru
14825 inlägg
zkgjc2cover.jpg 39.34K
0 Antal nerladdningar"A key element in the freedom that Just Cause 2 gives you is that there are no artificial barriers", explains lead designer Peter Johnasson. "You're free to go anywhere and you're free to try out any tactic in any given situation. Whatever tactic you choose, you can be sure that the only constant is action." Clearly, this sequel aims to offer respite from something we generally take for granted in other sandbox games: restrictions. Whether it's conveniently closed-off bridges or murderous cops who pop out of nowhere if you wander into the wrong region, we've become accustomed to such titles telling us what we can and can't do. This one, it seems, thinks different.
"That doesn't mean your chosen approach will prove successful in all situations," Johnasson continues. "Approaching a military base in a helicopter may not be the best idea if the base is heavily guarded by surface-to-air missiles. If you get shot down, maybe it's more effective to continue on foot rather than paying for a black market heavy drop." It all hints at the breathtaking scale of Just Cause 2. As with its precursor, it's all wide-open vistas and no loading pauses, but this goes even further - and not simply in terms of its GTA-rivalling list of cars (over 100), missions (over 50) and dual-wielded weaponry.
Approaching that aforementioned military base, for instance, might see you progress from lush forestry, over wide-open desert and finally up into ice-covered mountain tops. It's a David Attenborough series in 40 seconds. Throughout, the view distances are incredible: it's a huge and beautiful game world. As you get close to the base, you can either careen in close with your chopper, gracefully pirouette in with Rico's trademark parachute or do the Spider-Man thing with his almighty grappling hook. "Rico's move set enables you to do things that you can't do in any other game," reckons Johansson.
"The grappling hook can, for example, be used to quickly move around, pull enemies down from guard towers, suspend enemies under a bridge - or from a lamppost - or lift a car with a helicopter and use it as a wrecking ball. In combination with the parachute, the grappling hook enables you to do stunts you've never done before and you can experiment, finding your own tactics and play style. What happens if you tether two helicopters together, for instance, or try to pull down a presidential monument by dragging it behind a jeep?"
"Then we have the stunts, which we've taken several steps further and integrated them into pretty much everything you do. We've also improved combat and made it more challenging and tactical. At the heart of this are a completely new aiming system and AI that's been redone from scratch. Enemies now take cover behind objects in a dynamic environment, flank you, guard specific important areas or objects and they can also call for backup."
This new aiming system should hopefully reassure anyone who found JC1's simple auto-lock shooting a little deflating – you can target specific body parts for quicker, cleaner or more 'orrible kills. A headshot will take 'em out, but a knee-shot will cause all kinds of trouble, so there's plenty of scope to play to your more sadistic urges. There's a similar principle behind the cars – they're not much of a muchness, but rather specific tools for specific jobs. You wouldn't, after all, drive a sports car across a sandy desert, no matter how slick it looks, so find something with better traction.
  http://ps3.ign.com/a...7/967598p1.html
Redigerat av Unregisteredf64a5233, 30 March 2010 - 16:53.
Postad 30 March 2009 - 18:54
Transform
38138 inlägg
Oh, typ samtidigt som mig. Bra, spread the luuv
Glöm inte att läsa den artikeln som länkas till i slutet av artikeln du länkar till. Där hypar de det som f-n.
Postad 31 March 2009 - 18:05
Axxident
Axxident
578 inlägg
Verkar RIKTIGT bra enligt bilderna!  Grafiken är ju riktigt fin !  hoppas det blir bra .
EDIT: Kollade lite på Youtbe efter Just Cause (ettan) Och det såg lite orealistiskt ut  Hoppas att dom bättrar på det i 2an
Jag vet att youtube inte är det bästa ställe att kolla på trailers och sånt men Gametrailers.com funkar inte i FireFox hemma hos mig
Redigerat av Axxident, 31 March 2009 - 18:39.
Postad 31 March 2009 - 19:08
Transform
38138 inlägg
"Lite" orealistiskt? Huvudpersonen är ju en mindre superhjälte som tål raketkastare, kan volta med bilar, flyga helikopter under vattnet, surfa på jetplan, gå i enkamp med atomubåtar... Det kommer alltså inte ändras i tvåan, bara bli ännu mer galet och roligt Här, läs min gamla recension av ettan så blir du peppad https://www.minhembi...howtopic=146975
Postad 01 April 2009 - 10:37
Axxident
Axxident
578 inlägg
Haha! Ok  det ska jag göra Zoiler. Hann inte se så mycket av ettan på Youtube.  EDIT: Vilken fin och rolig recension du hade gjort Zoiler
Redigerat av Axxident, 01 April 2009 - 10:45.
Postad 01 April 2009 - 12:44
Transform
38138 inlägg
Tackar, erkänn du blev intresserad  ?
Postad 01 April 2009 - 15:27
Axxident
Axxident
578 inlägg
Japp  du fick mig Zoiler
Postad 01 April 2009 - 15:33
Transform
38138 inlägg
Haha, mission accomplished
Vänta bara, när Just Cause 2 släpps kommer man glömma av allt vad GTA4 och sånt heter
Axxident
Axxident
578 inlägg
Det får vi hoppas Zoiler  Har ganska höga förväntningar redan nu
Förresten när är release datumet? Hittade inte ett i IGNs artikel
Redigerat av Axxident, 01 April 2009 - 15:35.
Postad 01 April 2009 - 15:36
Transform
38138 inlägg
Det är ett tag kvar tyvärr. September 2009 var senaste budet jag läste.
Postad 01 April 2009 - 16:13
Axxident
Axxident
578 inlägg
Ok  Då är det ett tag kvar Men tänk positivt  Fram till September kan man lira vad man vill  Då kommer Just Cause 2 och det kan man köra till November för då kommer Modern Warfare 2
Postad 01 April 2009 - 16:15
Transform
38138 inlägg
Jo, den som väntar på något gott och allt det där.
Postad 03 April 2009 - 13:56
Axxident
Axxident
578 inlägg
Du har helt rätt
Postad 29 May 2009 - 08:42
Über-Guru
14825 inlägg
Postad 29 May 2009 - 11:14
MTD
MTD
393 inlägg
2010 är det som gäller nu.
Postad 29 May 2009 - 15:28
Axxident
Axxident
578 inlägg
Must have!
Postad 29 May 2009 - 17:48
D-J
D-J
656 inlägg
Men vafan!
Postad 29 October 2009 - 21:24
stabbe
stabbe
1569 inlägg
Postad 29 October 2009 - 22:21
VincentVegaSWE
VincentVegaSWE
844 inlägg
Detta ser mycket intressant ut! Som ett snyggare GTA. Hoppas det är minst lika roligt också.
Postad 30 October 2009 - 07:43
relg
relg
184 inlägg
Kommer ihåg wow-känslan när jag spelade demot till ettan, gav aldrig fullversionen något försök men 2an verkar bli ett "must have".
Postad 07 November 2009 - 16:00
wigtor
wigtor
58 inlägg
Det här spelet ser ju bara urläckert ut
Kommer lätt vara med och slåss som bästa spelet 2010.
Det ser ju ganska klart ut i filmerna så vad gissar ni på för datum?
Tror inte det kommer komma allt för tidigt för att släppa ett spel i januari är väl ganska dumt då man skulle kunna snabba på det lite och få ut det innan jul istället.
Postad 06 February 2010 - 23:32
Unregistered883bce2a
737 inlägg
http://www.eurogamer...cause-2-freedomBlir mer och mer hypad på detta spelet. Testade aldrig 1:an. Kanske är värt? Mars blir en galen spelmånad
Postad 04 March 2010 - 16:39
blooodshy
blooodshy
492 inlägg
Nu har äntligen en demo kommit till Just Cause 2...Så vad tycker ni? bra eller anus
Postad 04 March 2010 - 17:09
Widar
Widar
310 inlägg
Oh! Hade glömt att det släpptes idag, måste tankas! Tack för tipset!
Postad 04 March 2010 - 19:26
MUCC
MUCC
62 inlägg
Prövat demot i snart en timme. Blir inte ett köp. Visst var det snyggt och klyschigt men känns som om jag redan har spelat spelet och sen tröttnat på det. Precis likadant var det för mig med GTA4 vid release, såg riktigt roligt ut på videos, bilder osv men när jag väl hade köpt spelet och började spela så tappade jag omedelbart suget, helt. Tröttnat på hela det konceptet antar jag.
Redigerat av MUCC, 04 March 2010 - 19:29.
Postad 04 March 2010 - 19:42
blooodshy
blooodshy
492 inlägg
Blev inte så imponerad av demot, tyckte d var svår kontrollerat. Det var kul i 10 min....Kommer inte att köpa det!
Postad 04 March 2010 - 21:34
Unregistered32f0b602
3086 inlägg
Jag tyckte nog allt att det var lite småcoolt ändå......sköna moves man kunde göra med griparmen....
Postad 04 March 2010 - 23:02
kerren
kerren
2776 inlägg
jag gick från väldigt osäker på detta spelet till att vara helt 100 på att jag kommer att köpa det
Postad 05 March 2010 - 13:57
Hubbie
Hubbie
18 inlägg
Föregångaren var en riktig berg-och-dalbana. Vissa aspekter var otroligt imponerande och roliga, speciellt frihetskänslan av att ta första bästa jetplan. Andra var mer eller mindre horribla så som stelt kontrollschema, dålig känsla i vapen och allmänt opolerat. Får testa demot och se om detta är bättre, ser onekligen bättre ut iaf.
Postad 05 March 2010 - 15:44
Unregisteredd6957fbe
1625 inlägg
Tyckte att demot, förutom att det var för kort, var helt ok. Lite sladdrig kontroll men bra ös med mycket explosioner åt höger och vänster. Blir nog ett rea-köp om ett halvår eller så.
Postad 06 March 2010 - 20:11
bobby tex
bobby tex
107 inlägg
Har precis köpt en slim o första spelet var GTAIV som nog kommer hålla mig sysselsatt ett bra tag, kollade på denna demo idag oxå. Jag tycker nu handlar det inte så mkt om grafik o sånt längre utan tekniken finns där. Det handlar istället om att få till en bra spelmekanik vilket GTAIV inte riktigt har tyvärr o sen handlar det om att skapa bra multiplayermoddar vilket eg bara handlar om fantasi o kreativitet, möjligheterna är oändliga.
Då är det lite tråkigt att se att svenskarna inte ens försöker
Postad 07 March 2010 - 11:00
erlander
erlander
551 inlägg
Tyckte att spelet verkade riktigt bra. Hade inga förväntningar alls då jag tyckte 1an smakade kebabnisse.
Hade väldans skoj i 45 min eller hur lång tid demot var nu och blev arg för att det tog slut efter den tiden. Kan nog bli köp
Postad 11 March 2010 - 22:42
Über-Guru
12146 inlägg
har testat demot nu och hade precis hur roligt som helst  man känner sig ju heltuff när man hoppar från bil till bil. trodde först att kontrollen skulle va invecklad men det gick ju hur smidigt som helst. att kasta upp folk i luften med "repet" och sen skuta dom va också ganska kul
men ska jag va ärlig förstod jag inte riktigt vad det gick ut på,, gäller det bara att sabotera så mycket som möjligt eller och sen akta sig (eller skjuta) alla poliser som kommer? blir nog ett köp för min del
Postad 11 March 2010 - 23:06
lenko
lenko
290 inlägg
Det är bara en stor lekstuga!
Postad 12 March 2010 - 12:44
DanielSchenström
DanielSchenström
1102 inlägg
Jag antar att det kommer finnas en bunt storyuppdrag som i ettan och sen en massa sidouppdrag och kaosskapandet för att låsa upp nya prylar. Den som spelat demot för ettan och sen spelet märkte att upplägget var olika, och till och med miljön i demot och det riktiga spelet var annorlunda även fast det var samma ö. Misstänker att de gjort liknande här, istället för att låta en spela en bit av den faktiska storyn låter de en smaka på vad man kan göra.
Men målet för demot är att skapa en viss mängd kaos för att låsa upp två uppdrag varav ett är ett race. Man låser även upp extrautrustning som man kan få levererad till sig.
Skulle vara ett dag 1-köp om det inte vore för att jag inte hunnit fått min lön då. De två saker som jag föredrog från ettan var dess autosikte och fordonen kändes mer lättstyrda där.
Postad 29 March 2010 - 10:07
xdusty
xdusty
310 inlägg
Är lite småsugen på att köpa spelet, vad tycker ni som redan köpt det? Kanske man ska vänta tills det går ner i pris.
Redigerat av xdusty, 29 March 2010 - 10:08.
Postad 29 March 2010 - 13:49
Transform
38138 inlägg
Kommer en lång recension från mig idag i vilket fall
Postad 29 March 2010 - 14:36
kerren
kerren
2776 inlägg
förmodar att det regnar superlativ i den recensionen Zoiler
Postad 29 March 2010 - 16:53
Über-Guru
14825 inlägg
Körde demot men blev less redan innan tiden gick ut, känns som det inte är något för mig.
Postad 29 March 2010 - 19:31
Transform
38138 inlägg
Näää.. Just Cause 2Edit: Bjuder på en gif också
Redigerat av Zoiler, 29 March 2010 - 19:34.
Postad 29 March 2010 - 19:41
Unregistered1232
Unregistered1232
1892 inlägg
10/10
Postad 30 March 2010 - 16:49
Transform
38138 inlägg
Hmm, vadan detta svala intresse? Om ni inte tror mig hur bra det är så kan ni läsa Neogaf, de är rätt lyriska och många kallar det det bästa open world spelet någonsin Ni som har PS3 kan ju åtminstone slänga upp Youtube-klipp. Trodde det skulle vara fullt av såna här =P.
Postad 30 March 2010 - 17:06
kerren
kerren
2776 inlägg
zoiler det kommer det kommer jag ska köpa det så fort jag får tid har en lång kö av spel som ska klaras av först
Postad 30 March 2010 - 19:21
Transform
38138 inlägg
Det är tur att det blir "semester" i April då  . Bra med en lugn spelmånad så man hinner ta igen, har själv en del spel att klara av.
Postad 30 March 2010 - 19:52
kerren
kerren
2776 inlägg
ja det är tur att sommaren fins då det är lite tunnare med spelsläpp hur skulle man annars klara av dehär
Postad 30 March 2010 - 19:54
FluBBa
FluBBa
385 inlägg
Jag gillar det skarpt (polaren har köpt det) men jag har FFXIII o GoWIII o spela, men jag känner mig lite frustrerad och vill egentligen bara lira Just Cause 2.
Postad 30 March 2010 - 21:44
Transform
38138 inlägg
Gud förbude att man gör som man vill
"Tyvärr" är nog inte hela sommaren lugn, men just April känns väldigt piano.
Postad 02 April 2010 - 09:27
Widar
Widar
310 inlägg
Underbart spel. Blivit en 15-20 timmar än så länge. Görsketaskoj verkligen. Får hoppas att man inte tröttnar innan det är platinumdags.
Postad 03 April 2010 - 15:06
Transform
38138 inlägg
I JC2 börjar man gapskratta när man blir dragen bakom en moped http://www.youtube.c...h?v=EEIJ9QLxnNg
Redigerat av Zoiler, 03 April 2010 - 15:16.
Postad 03 April 2010 - 16:16
Über-Guru
12146 inlägg
haha såg verkligen dumt ut
Media & Mediauppspelning
Spelkonsoler & PC-spel
Playstation
Tonewinner 7300
Perlisten R18s
Philips Discoverer
Ny projektor!
