Press-release - Nikon D300s
18 svar till detta ämne
Nikon D300S (Systemkameror) 3 9.375 (7) Inga priser
1 relaterade trådar
Postad 30 July 2009 - 08:45
Ponisch
  • Ponisch
  • 2525 inlägg
Länk till press-release
Nikon UK announces the D300S, a camera to broaden the possibilities for today’s creative image makers. The D300S brings HD movie capability, a faster frame advance rate of 7fps and dual CF and SD memory card slots to offer new opportunities to explore creative imaging.
Built upon the widely acclaimed D300, the D300S incorporates the same DX-format 12.3 megapixel CMOS sensor, professional 51-point autofocus system and commended EXPEED image processing in a discrete compact body.
Robert Cristina, Manager, Professional Products for Nikon Europe, comments: “The D300S is designed for today’s generation of creative image makers who will benefit from a combination of brilliant stills and the creative potential of video capture. The DX format has the advantage of lens magnification, compact size and affordability making the D300S a really exciting package for anyone looking to take their photography to another level”.
Capture and Edit HD Movies in stereo
The D300S comprehensively extends DSLR HD movie capture by adding external stereo sound input, autofocus capability and premieres in-camera movie editing. External stereo microphone support adds more realistic sound when shooting movie clips, and a new dedicated LV button makes switching between stills and movies easier than ever. In-camera movie clips can be edited by simply selecting the start and stop points during playback. Also, the new Type C HDMI interface enables editing to be carried out on an HD display if desired.
Dual slot storage media
For the first time in this class, the D300S offers the choice of dual storage media standards; CF (Compact Flash™) and SD (Secure Digital™) with options to manage how the camera records data to them. For example, one can elect to store stills to one format and movie clips to another.
Faster shooting, outstanding quality
The D300S captures images up to a blistering 7 frames per second without requiring any additional battery pack. The optional MB-D10 pack makes 8fps possible as well as improved vertical shooting ergonomics.
The camera inherits the groundbreaking imaging technologies from the D300 such as Scene Recognition System with 1005 pixel RGB colour metering, and class-leading autofocus performance from the 51-Point Multi-CAM3500 autofocus system, which together deliver accurate autofocus, auto exposure and auto white balance control. The EXPEED image processing system delivers Nikon’s acclaimed image quality criteria of rich accurate colours, smooth skin gradations, exceptional detail with the minimum of noise, with all of the flexibility of Nikon’s exclusive Picture Control system to manage the ‘look and feel’ of your work.
Intuitive ergonomics
Significant improvements have been made to Nikon’s renowned ergonomics with the adoption of the same multi-selector to that used on the D3 series and D700 with the centre button ideally located for triggering movie start and stop. The D300S also features a Quiet release mode for discrete photography by allowing the user to manage the mirror return manually. The dedicated Info button simplifies displays and short cuts to commonly used settings, and the built-in pop-up flash diffuser covers 16mm wide-angle field of view.
Practical performance
The 3 inch 920K dot high definition TFT monitor offers excellent image playback and movie composition support. One can also display the Virtual Horizon level during movie shooting if desired. A variety of in-camera processing tools now includes an image resize function to process RAW files to one of four pre-set dimensions to enable to do more in camera, and less on the PC.
More than just an ‘S’
The D300S comprehensive feature set is designed for anyone who is serious about the future of their photography. It proposes much more than the simple ‘S’ suffix might suggest to cement a unique position in Nikon’s comprehensive DSLR range with a practical blend of creative options, professional technologies, compact size and affordability.
Nikon släpper även D3000 och två objektiv - 18-200/3.5-5.6G ED VR II samt AF-S NIKKOR 70-200MM F/2.8G ED VR II
Redigerat av Ponisch, 30 July 2009 - 08:50.
Postad 30 July 2009 - 08:56
Hamsteren
  • Hamsteren
  • 1697 inlägg
Finns på svenska också :)
Nikon lanserar D300S, en kamera som breddar möjligheterna för dagens kreativa bildskapare.
D300S har HD-funktioner för film, en snabbare bildmatningshastighet på 7 bilder per sekund och dubbla kortfack för CF- och SD-minneskort som ger nya möjligheter att utforska kreativt bildskapande. D300S bygger vidare på den hyllade D300-kameran och har samma CMOS-sensor i DX-format med 12,3 megapixel, professionella autofokussystem med 51 punkter och bildbearbetningskonceptet EXPEED i ett diskret och kompakt kamerahus.
Robert Cristina, chef för Professional Products vid Nikon Europa säger: ”D300S är utformad för dagens generation av kreativa bildskapare som vill kombinera fotografins briljanta stillbilder med videofilmens kreativa möjligheter. DX-formatet har både objektivförstoring, en kompakt storlek och ett överkomligt pris, vilket gör D300S till ett riktigt spännande alternativ för alla som vill utveckla sin fotografering”.
Spela in och redigera HD-filmer i stereo
D300S utökar HD-filminspelningsmöjligheterna för DSLR avsevärt genom upptagning av externt stereoljud, autofokusfunktioner och filmredigering i Premieres i kameran. Med den externa stereomikrofonen blir ljudet till filmklippen xmer realistiskt, och en ny särskild LV-knapp gör det enklare än någonsin att växla mellan stillbilder och filmer. Filmklippen i kameran kan enkelt redigeras genom att start- och slutpunkt väljs under uppspelningen. Med det nya gränssnittet av typen C HDMI kan du även redigera filmen på en HD-skärm om så önskas.
Dubbla fack för lagringsmedier
För första gången i den här klassen kan D300S erbjuda dubbel lagring för mediestandarderna CF (Compact Flash™) och SD (Secure Digital™) med möjlighet att välja hur kameran ska spara data på dem. Du kan till exempel välja att lagra stillbilder i ett format och filmklipp i ett annat.
Snabbare tagning, utmärkt kvalitet
D300S tar upp till 7 bilder per sekund utan att några ytterligare batterier behövs. Med tillbehörsbatteriet MB-D10 som säljs separat är det möjligt att ta 8 bilder per sekund, och det ger även en ökad bekvämlighet vid fotografering i lodrätt läge.
Kameran delar den banbrytande bildtekniken med D300, till exempel systemet för motividentifiering med 1 005 pixlars RGB-färgmätning och oöverträffade autofokusprestanda från autofokussystemet Multi-CAM3500 med 51 punkter, som tillsammans ger exakt autofokus, automatisk exponering och automatisk vitbalanskontroll. Bildbearbetningssystemet EXPEED åstadkommer Nikons hyllade bildkvalitet med rika, exakta färger, jämna hudövergångar, fantastiska detaljer och ett minimum av brus, med Nikons exklusiva och flexibla Picture Control-system för att få den rätta känslan i bilderna.
Intuitiv ergonomi
Avsevärda förbättringar har gjorts i Nikons välkända ergonomi genom användningen av samma multiväljare som hos kameror i D3-serien och D700, som har en mittknapp som startar och stoppar filmen. D300S har även ett tyst läge för diskret fotografering genom att du kan styra spegelåtergången manuellt. Infoknappen förenklar visningen och har genvägar till ofta använda inställningar, och den inbyggda, uppfällbara blixtdiffusorn täcker ett 16 mm brett synfält.
Praktisk prestanda
Högupplöst TFT-monitor på 3 tum och 920 000 punkter ger en utmärkt bildvisning och underlättar komponering av filmer. Du kan även visa en virtuell horisont under filmtagningen om du vill. Bland de många bearbetningsverktygen i kameran finns nu en funktion som ändrar storlek på bilderna så att RAW-filer bearbetas till någon av de fyra förinställda storlekarna, vilket innebär att du kan göra mer i kameran och mindre på datorn.
Mer än bara ett ”S”
D300S omfattande uppsättning funktioner är konstruerad för alla som ser seriöst på sin fotoframtid. Den har mycket mer att bjuda på än vad det enkla ”S”-tillägget antyder, och intar en unik ställning i Nikons omfattande DSLR-utbud med en praktisk mix av kreativa alternativ, professionell teknik, kompakt storlek och överkomligt pris.
D300S finns i två utföranden: AFS DX NIKKOR 16-85mm f/3.5-4.5 VR och AF-S DX NIKKOR 18-200mm f/3.5-5.6G ED VR II.
Postad 30 July 2009 - 10:07
kinjon
  • kinjon
  • 1015 inlägg
Skönt att de har slopat det här med megapixelrace och håller sig kvar på sin utmärkta 12,3 mpixare.
Postad 30 July 2009 - 10:14
Ponisch
  • Ponisch
  • 2525 inlägg
Tycker jag med!
Någon som vet varför Nikon släppte ett andra 70-200/2.8 VR? Var inte det gamla bra?
Svara gärna på detta i tråden om Nikon-nyheter där diskussionen om objektivet får fortsätta: Länk
Redigerat av Joakim, 30 July 2009 - 10:45.
Lade in trådhänvisning
Postad 31 July 2009 - 15:42
Joakim
  • Joakim
  • 3956 inlägg
Nyheterna i D300S var en aning snåla. Jag tycker att de hade kunnat passa på att optimera bildkvaliteten en aning, trycka in smartare brusreducering för bättre ISO-prestanda eller vad som helst. Om det "behövs" kan man väl diskutera, men det skulle förlänga livet på den och göra den litegrann intressantare.
Postad 31 July 2009 - 16:03
Drey123
  • Drey123
  • 1960 inlägg
Kan hålla med uppgraderingen känns väldigt snålt, några knappar från D700 och filmfunktion i runda slängar.
Postad 01 August 2009 - 21:46
wirran
  • wirran
Håller med synpunkterna ovan men trots dessa så blir ju D300 med "S" klart mer intressant nu. Var lite mer inne på D90 innan men nu får man tänka om lite. Någon som tror/vet att denna kamera också har den irriterande begränsningen i inspelningstid under filmning?
Postad 01 August 2009 - 21:55
Joakim
  • Joakim
  • 3956 inlägg
Nikon skriver...
Maxlängd för film: 5 min. (1 280 × 720 pixlar), 20 min. (640 × 424, 320 × 216 pixlar)
Så ja, tyvärr samma begränsning.
Postad 01 August 2009 - 22:54
Drey123
  • Drey123
  • 1960 inlägg
Känns som en helt onödig uppgradering.
Postad 01 August 2009 - 22:56
wirran
  • wirran
Så sorgligt och sniket av Nikon som ta mig sjutton borde nöja sig med hur mkt pengar de faktiskt kommer tjäna på varje såld D300S :(
Vad är det för mening med de nya extrafinesserna filmningsfunktionen fått nu?
SNIKET e ordet.
Postad 02 August 2009 - 07:43
Unregistered124686ac
  • Unregistered124686ac
  • 11229 inlägg
Nikon skriver...
Tycker inte att det är någon större begränsning. Har själv filmat en del med filmkamera och av kanske 50 timmar film så har jag nog inget klipp som är längre än några minuter, man ska ju andas lite också ;-). Filmen gör ju sig bäst med korta klipp på kanske 10-30sekunder som man sedan klipper ihop. Den största begränsningen är väl minneskortet, 5minuter film är 2GB, på ett normal-SD (4GB) betyder det 10 minuter om man nu inte tar några kort. Många och stora minnen behövs.
Om filmning via systemkamera har en framtid, så borde kameratillverkarna bygga in SDD diskar i batteripacken eller sälja lösa diskar som man dockar fast som typ en batteripack på kameran
Edit:
Kom ihåg en sak till med min korta filmning med systemkamera D5000, en kamera är tuuung (även om min ändå är ganska lätt). Det är inte så lätt att med fri hand hålla kameran mycket mer än en minut.
Redigerat av Unregistered124686ac, 02 August 2009 - 10:45.
Postad 12 August 2009 - 13:21
Unregistered6214acfd
  • Unregistered6214acfd
  • 440 inlägg
Löjligt dyr
Postad 12 August 2009 - 13:23
Explorer45
  • Explorer45
  • 4558 inlägg
Får hoppas att den sjunker till runt 14k så den blir en riktigt vass konkurrent för de övriga märkena.
Postad 13 August 2009 - 16:25
Walkir
  • Walkir
  • 1812 inlägg
Dollarn har rasat en hel del nu, så det är inte omöjligt att kameran kommer ned i 14000.
Just nu tycker jag att D700 känns som mer kamera för pengarna.
Postad 13 August 2009 - 19:14
Ponisch
  • Ponisch
  • 2525 inlägg
D700 har alltid varit mycket pengar för kamera!
Eller vänta nu, var det inte tvärt om? :)
Postad 13 August 2009 - 19:33
Drey123
  • Drey123
  • 1960 inlägg
Tyvärr höjde många av kamera tillverkarna priserna pga av dollarns uppgång men det var en konstant höjning inget som kommer att göra kameran billigare vid eventuell nedgång av dollarn. Alltså priset är inte valuta relatera tyvärr.
Vissa av kamera märkena valuta justerade bara vilket medför att deras priser kommer sänkas, Nikon är inte ett av dessa tyvärr.
"Vad jag fick förklarat av en kmaerahandlare"
Postad 13 August 2009 - 19:37
Joakim
  • Joakim
  • 3956 inlägg
Har de gått och blivit en aning stöddiga månne? Inte utan anledning förstås, de gör väldigt bra ifrån sig nu, men ändå...
Postad 13 August 2009 - 22:07
Unregistered8947db47
  • Unregistered8947db47
  • 278 inlägg
enda som låter vettigt i mina öron lite smått är två kort platser..filma med en systemkamera..nejtack....men jag har ju redan D300 så jag är nöjd iaf. "gammal" kamera med små uppdateringar med så högt pris..
Postad 17 August 2009 - 19:00
Inte ekonomiskt: Dagens Industri
