Får inte externa klienter att ansluta till mythtv
20 svar till detta ämne
Postad 02 August 2009 - 09:59
Quazzi
  • Quazzi
Får inte externa klienter att asnluta till mythtv.
Det känns som att jag sökt igenom hela nätet, även denna sida utan att hitta lösningen.
Jag kan ansluta med myth-frontend via localhost men ej via nätverket.
i my.cnf har jag tillåtit nätverket och ändrat bind-adress.
# The MySQL database server configuration file.
# You can copy this to one of:
# - "/etc/mysql/my.cnf" to set global options,
# - "~/.my.cnf" to set user-specific options.
# One can use all long options that the program supports.
# Run program with --help to get a list of available options and with
# --print-defaults to see which it would actually understand and use.
# For explanations see
# http://dev.mysql.com/doc/mysql/en/server-system-variables.html
# This will be passed to all mysql clients
# It has been reported that passwords should be enclosed with ticks/quotes
# escpecially if they contain "#" chars...
# Remember to edit /etc/mysql/debian.cnf when changing the socket location.
[client]
port		= 3306
socket		= /var/run/mysqld/mysqld.sock
# Here is entries for some specific programs
# The following values assume you have at least 32M ram
# This was formally known as [safe_mysqld]. Both versions are currently parsed.
[mysqld_safe]
nice		= 0
[mysqld]
# * Basic Settings
# * IMPORTANT
#   If you make changes to these settings and your system uses apparmor, you may
#   also need to also adjust /etc/apparmor.d/usr.sbin.mysqld.
user		= mysql
pid-file	= /var/run/mysqld/mysqld.pid
port		= 3306
basedir		= /usr
datadir		= /var/lib/mysql
tmpdir		= /tmp
language	= /usr/share/mysql/english
bind-address		= 192.168.0.11
# * Fine Tuning
key_buffer		= 16M
max_allowed_packet	= 16M
thread_stack		= 128K
thread_cache_size	= 8
# This replaces the startup script and checks MyISAM tables if needed
# the first time they are touched
myisam-recover		= BACKUP
#max_connections		= 100
#table_cache			= 64
#thread_concurrency	 = 10
# * Query Cache Configuration
query_cache_limit	   = 1M
query_cache_size		= 16M
# * Logging and Replication
# Both location gets rotated by the cronjob.
# Be aware that this log type is a performance killer.
#log		= /var/log/mysql/mysql.log
# Error logging goes to syslog. This is a Debian improvement :)
# Here you can see queries with especially long duration
#log_slow_queries	= /var/log/mysql/mysql-slow.log
#long_query_time = 2
#log-queries-not-using-indexes
# The following can be used as easy to replay backup logs or for replication.
# note: if you are setting up a replication slave, see README.Debian about
#	   other settings you may need to change.
#server-id		= 1
#log_bin			= /var/log/mysql/mysql-bin.log
expire_logs_days	= 10
max_binlog_size		 = 100M
#binlog_do_db		= include_database_name
#binlog_ignore_db	= include_database_name
# * BerkeleyDB
# Using BerkeleyDB is now discouraged as its support will cease in 5.1.12.
skip-bdb
# * InnoDB
# InnoDB is enabled by default with a 10MB datafile in /var/lib/mysql/.
# Read the manual for more InnoDB related options. There are many!
# You might want to disable InnoDB to shrink the mysqld process by circa 100MB.
#skip-innodb
# * Federated
# The FEDERATED storage engine is disabled since 5.0.67 by default in the .cnf files
# shipped with MySQL distributions (my-huge.cnf, my-medium.cnf, and so forth).
skip-federated
# * Security Features
# Read the manual, too, if you want chroot!
# chroot = /var/lib/mysql/
# For generating SSL certificates I recommend the OpenSSL GUI "tinyca".
# ssl-ca=/etc/mysql/cacert.pem
# ssl-cert=/etc/mysql/server-cert.pem
# ssl-key=/etc/mysql/server-key.pem
[mysqldump]
quick
quote-names
[mysql]
#no-auto-rehash	# faster start of mysql but no tab completition
[isamchk]
key_buffer		= 16M
# * NDB Cluster
# See /usr/share/doc/mysql-server-*/README.Debian for more information.
# The following configuration is read by the NDB Data Nodes (ndbd processes)
# not from the NDB Management Nodes (ndb_mgmd processes).
# [MYSQL_CLUSTER]
# ndb-connectstring=192.168.0.11
# * IMPORTANT: Additional settings that can override those from this file!
#   The files must end with '.cnf', otherwise they'll be ignored.
!includedir /etc/mysql/conf.d/
Något tips?
Postad 02 August 2009 - 11:03
frust
  • frust
  • 122 inlägg
Har du sätt local/master backend till 192.168.0.11 och inte 127.0.0.1 och security pin till 0000
Edit: ta bort bind-raden..
Redigerat av frust, 02 August 2009 - 11:55.
Postad 03 August 2009 - 07:50
frollic
  • frollic
  • 14167 inlägg
Precis som frust säger behävs inte bind-raden, då lyssnar programmet på alla interface.
har du lagt till att mythtv-användaren får ansluta till dbn remote ?
punkt 5 ...
http://www.debianhel...remotemysql.htm
Postad 04 August 2009 - 16:32
Quazzi
  • Quazzi
tack, ska testa när jag får möjlighet.
Postad 07 August 2009 - 08:46
Unregistered14c78076
  • Unregistered14c78076
  • 42 inlägg
Jag brukar göra det misstaget som frust påpekade att jag glömt ändra master backend i setup från att vara 127.0.0.1 till det "riktiga" ipnumret som backend har.
Vad händer annars om du ansluter med mysql klienten direkt från frontenden?
mysql -u username -p -h ipnr
Då borde du få någon hint om vad som är fel...
Postad 10 August 2009 - 15:18
Quazzi
  • Quazzi
jag har nu instalelrat om ubuntu på serverdator. När jag försöker ansluta från dator 2 med mythtv frontend så funkar det utan problem, däremot så funkar det inte att ansluta med XBMC som jag vill använda som frontend.
Postad 10 August 2009 - 19:52
par-joha
  • par-joha
  • 780 inlägg
Vad säger loggarna i respektive program när du försöker ansluta?
/ Pär
Postad 19 August 2009 - 14:12
Quazzi
  • Quazzi
Jag hittar ingen log för XBMC, men loggen för mythtv säger att det är fel protokoll.
2009-08-19 14:57:06.865 Connected to database 'mythconverg' at host: localhost
2009-08-19 14:57:06.875 New DB connection, total: 2
2009-08-19 14:57:06.877 Connected to database 'mythconverg' at host: localhost
2009-08-19 14:57:06.883 Current Schema Version: 1214
2009-08-19 14:57:06.892 Preview Error: Previewer file '/var/lib/mythtv/recordings/2053_20090819145704.mpg' is not valid.
2009-08-19 14:57:06.894 Preview Error: Run() file not local: '/var/lib/mythtv/recordings/2053_20090819145704.mpg'
2009-08-19 14:57:06.921 Preview Error: Preview process not ok.
			fileinfo(/var/lib/mythtv/recordings/2053_20090819145704.mpg.png) exists: 0 readable: 0 size: 0
2009-08-19 14:58:26.465 Expiring 0 MBytes for 2053 @ Wed Aug 19 14:57:04 2009 => Unknown
2009-08-19 15:00:01.898 Finished recording Unknown: channel 2053
2009-08-19 15:00:01.959 AutoExpire: CalcParams(): Max required Free Space: 3.0 GB w/freq: 15 min
2009-08-19 15:00:02.044 Using runtime prefix = /usr
2009-08-19 15:00:02.050 Empty LocalHostName.
2009-08-19 15:00:02.050 Using localhost value of server
2009-08-19 15:00:02.059 New DB connection, total: 1
2009-08-19 15:00:02.063 Connected to database 'mythconverg' at host: localhost
2009-08-19 15:00:02.065 Closing DB connection named 'DBManager0'
2009-08-19 15:00:02.069 Connected to database 'mythconverg' at host: localhost
2009-08-19 15:00:02.074 New DB connection, total: 2
2009-08-19 15:00:02.077 Connected to database 'mythconverg' at host: localhost
2009-08-19 15:00:02.082 Current Schema Version: 1214
2009-08-19 15:00:02.404 TVRec(1): RingBufferChanged()
2009-08-19 15:00:02.414 Finished recording Unknown: channel 2053
2009-08-19 15:00:02.441 AFD: Opened codec 0x9af6790, id(MPEG2VIDEO) type(Video)
2009-08-19 15:00:02.445 AFD: codec MP3 has 2 channels
2009-08-19 15:00:02.449 AFD: Opened codec 0x9af6d80, id(MP3) type(Audio)
2009-08-19 15:00:02.560 Preview: Grabbed preview '/var/lib/mythtv/recordings/2053_20090819145705.mpg' 720x576@64s
2009-08-19 15:00:21.594 MainServer::HandleVersion - Client speaks protocol version 8 but we speak 40!
2009-08-19 15:00:21.600 MainServer::HandleAnnounce Playback
2009-08-19 15:00:21.601 adding: desktop as a client (events: 0)
2009-08-19 15:00:21.604 MainServer::HandleVersion - Client speaks protocol version 8 but we speak 40!
2009-08-19 15:00:21.606 MainServer::HandleAnnounce Playback
2009-08-19 15:00:21.612 adding: desktop as a client (events: 0)
2009-08-19 15:00:25.676 MainServer::HandleVersion - Client speaks protocol version 8 but we speak 40!
2009-08-19 15:00:25.681 MainServer::HandleAnnounce Playback
2009-08-19 15:00:25.681 adding: desktop as a client (events: 1)
2009-08-19 15:00:25.685 MainServer::HandleVersion - Client speaks protocol version 8 but we speak 40!
2009-08-19 15:00:25.687 MainServer::HandleAnnounce Playback
2009-08-19 15:00:25.689 adding: desktop as a client (events: 0)
Postad 19 August 2009 - 15:18
frollic
  • frollic
  • 14167 inlägg
Låter som om klienten är väldigt gammal ....
Postad 19 August 2009 - 18:34
Quazzi
  • Quazzi
Ja visst gör det, men jag kör med XBMC 9.04.1
Postad 20 August 2009 - 06:51
par-joha
  • par-joha
  • 780 inlägg
Njae, det är XBMCs sätt att ta reda på vilket protokoll som MythTV pratar. XBMC ska efter det börja kommunicera på det sätt som MythTV vill.
Kanske kan den stora MythTV-tråden på xbmc.org vara till hjälp, t.ex. den här sidan:
http://xbmc.org/foru...9...der&page=42
Mvh, Pär
Postad 20 August 2009 - 17:21
Quazzi
  • Quazzi
ska sätta mig in lite mer i den STORA tråden när jag får tid.
Jag hittade loggen iaf.
18:17:52 T:2851077008 M:1540894720   DEBUG:
18:17:52 T:2851077008 M:1540894720   DEBUG: ------------------- GUI_MSG_WINDOW_INIT
18:17:52 T:2851077008 M:1540894720   DEBUG: Progress dialog
18:17:52 T:2851077008 M:1540894720   DEBUG: Load button-focus2.png: 0.1ms (bundled)
18:17:52 T:2851077008 M:1540894720   DEBUG: Alloc resources: 0.30ms (0.01 ms skin load, 0.06 ms preload)
18:18:02 T:2842684304 M:1540227072   ERROR: SetupLiveTV - unable to spawn live tv: Failed to setup livetv.
18:18:02 T:2842684304 M:1540227072   ERROR: CDVDPlayer::OpenInputStream - error opening [myth://mythtv:[email protected]/channels/20.ts]
18:18:02 T:2842684304 M:1540227072  NOTICE: CDVDPlayer::OnExit()
18:18:02 T:2842684304 M:1540227072  NOTICE: CDVDPlayer::OnExit() deleting input stream
18:18:02 T:2842684304 M:1540227072   DEBUG: Thread 2842684304 terminating
18:18:02 T:3049129872 M:1540227072   DEBUG: Playback was stopped
18:18:02 T:3049129872 M:1540227072   ERROR: Playlist Player: skipping unplayable item: 0, path [myth://mythtv:[email protected]/channels/20.ts]
18:18:02 T:3049129872 M:1540227072   DEBUG: Playlist Player: no more playable items... aborting playback
18:18:02 T:2862623632 M:1540227072   DEBUG: Running thread 2862623632
18:18:02 T:2862623632 M:1540227072   DEBUG: thread start, auto delete: 0
18:18:02 T:2871016336 M:1540227072   DEBUG: Running thread 2871016336
18:18:02 T:2871016336 M:1540227072   DEBUG: thread start, auto delete: 0
18:18:02 T:2871016336 M:1540227072   DEBUG: Thread 2871016336 terminating
18:18:02 T:2862623632 M:1540227072   DEBUG: Thread 2862623632 terminating
18:18:02 T:3049129872 M:1539416064   DEBUG: Load DialogBack.png: 7.7ms (bundled)
18:18:02 T:3049129872 M:1538371584   DEBUG: Load DialogFront.png: 7.5ms (bundled)
18:18:02 T:3049129872 M:1538297856   DEBUG: Load separator.png: 0.1ms (bundled)
18:18:02 T:3049129872 M:1538297856   DEBUG: ------------------- GUI_MSG_WINDOW_DEINIT
18:18:02 T:3049129872 M:1538297856   DEBUG: Progress dialog
18:18:02 T:3049129872 M:1539760128  NOTICE: CDVDPlayer::CloseFile()
18:18:02 T:3049129872 M:1539760128 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
18:18:02 T:3049129872 M:1539760128  NOTICE: DVDPlayer: waiting for threads to exit
18:18:02 T:3049129872 M:1539760128  NOTICE: DVDPlayer: finished waiting
18:18:02 T:2851077008 M:1539760128   DEBUG: Thread 2851077008 terminating (autodelete)
Postad 20 August 2009 - 18:10
par-joha
  • par-joha
  • 780 inlägg
<snip>
Om jag läser loggen rätt så försöker du där titta på LiveTV, korrekt? Kan du prova att titta på redan inspelade program?
/ Pär
Postad 22 August 2009 - 22:55
Quazzi
  • Quazzi
Japp, jag försöker titta live. Jag testade att installera XBMC på samma maskin som mythtv-backend går och där funkar det bra men inte på den dator jag vill använda ;(
Felkod från xbmc: (när jag försöker se inspelning)
23&#58;50&#58;27 T&#58;2843773840 M&#58;1764089856  NOTICE&#58; CDVDPlayer&#58;&#58;OnExit&#40;&#41;
23&#58;50&#58;27 T&#58;2843773840 M&#58;1764089856  NOTICE&#58; CDVDPlayer&#58;&#58;OnExit&#40;&#41; deleting input stream
23&#58;50&#58;27 T&#58;2843773840 M&#58;1764089856   DEBUG&#58; Thread 2843773840 terminating
23&#58;50&#58;27 T&#58;3049428880 M&#58;1764089856   DEBUG&#58; Playback was stopped
23&#58;50&#58;27 T&#58;3049428880 M&#58;1764089856   ERROR&#58; Playlist Player&#58; skipping unplayable item&#58; 0, path &#91;myth&#58;//mythtv&#58;[email protected]/recordings/1020_20090822234621.mpg&#93;
23&#58;50&#58;27 T&#58;3049428880 M&#58;1764089856   DEBUG&#58; Playlist Player&#58; no more playable items... aborting playback
23&#58;50&#58;27 T&#58;2860559248 M&#58;1764089856   DEBUG&#58; Running thread 2860559248
23&#58;50&#58;27 T&#58;2860559248 M&#58;1763057664   DEBUG&#58; thread start, auto delete&#58; 0
23&#58;50&#58;27 T&#58;2860559248 M&#58;1763057664   DEBUG&#58; Thread 2860559248 terminating
23&#58;50&#58;27 T&#58;3049428880 M&#58;1763057664   DEBUG&#58; Load DialogBack.png&#58; 14.4ms &#40;bundled&#41;
23&#58;50&#58;27 T&#58;3049428880 M&#58;1762025472   DEBUG&#58; Load DialogFront.png&#58; 13.2ms &#40;bundled&#41;
23&#58;50&#58;27 T&#58;3049428880 M&#58;1762025472   DEBUG&#58; Load separator.png&#58; 0.2ms &#40;bundled&#41;
23&#58;50&#58;27 T&#58;3049428880 M&#58;1762025472   DEBUG&#58; ------------------- GUI_MSG_WINDOW_DEINIT
23&#58;50&#58;27 T&#58;3049428880 M&#58;1762025472   DEBUG&#58; Progress dialog
23&#58;50&#58;27 T&#58;3049428880 M&#58;1764089856  NOTICE&#58; CDVDPlayer&#58;&#58;CloseFile&#40;&#41;
23&#58;50&#58;27 T&#58;3049428880 M&#58;1764089856 WARNING&#58; CDVDMessageQueue&#40;player&#41;&#58;&#58;Put MSGQ_NOT_INITIALIZED
23&#58;50&#58;27 T&#58;3049428880 M&#58;1764089856  NOTICE&#58; DVDPlayer&#58; waiting for threads to exit
23&#58;50&#58;27 T&#58;3049428880 M&#58;1764089856  NOTICE&#58; DVDPlayer&#58; finished waiting
23&#58;50&#58;27 T&#58;2826988432 M&#58;1764089856   DEBUG&#58; Thread 2826988432 terminating &#40;autodelete&#41;
23&#58;50&#58;32 T&#58;3049428880 M&#58;1764089856	INFO&#58; CheckIdle - Closing idle connection to mythtv backend 192.168.0.11
23&#58;50&#58;35 T&#58;3049428880 M&#58;1762983936   DEBUG&#58; SECTION&#58;UnloadDelayed&#40;DLL&#58; special&#58;//xbmc/system/ImageLib-i486-linux.so&#41;
23&#58;50&#58;35 T&#58;3049428880 M&#58;1762983936   DEBUG&#58; Unloading&#58; ImageLib-i486-linux.so
23&#58;51&#58;02 T&#58;3049428880 M&#58;1759813632   DEBUG&#58; SECTION&#58;UnloadDelayed&#40;DLL&#58; xbmc.so&#41;
23&#58;51&#58;02 T&#58;3049428880 M&#58;1759813632   DEBUG&#58; Unloading&#58; xbmc.so
Redigerat av Quazzi, 22 August 2009 - 22:58.
Postad 23 August 2009 - 16:58
par-joha
  • par-joha
  • 780 inlägg
<snip>
<snip>
Stämmer användarnamn, lösenord och ip-adress?
/ Pär
Redigerat av par-joha, 23 August 2009 - 16:58.
Postad 23 August 2009 - 19:33
Quazzi
  • Quazzi
Japp, det stämmer.
Postad 27 August 2009 - 17:51
psGandalf
  • psGandalf
  • 67 inlägg
I xbmc så skriver du in sökvägen till inspelningarna. Observera att detta inte är på mythbackend maskinen utan en lokal mapp där du har monterat backend maskinens mapp med inpelningar.
Postad 27 August 2009 - 20:26
Quazzi
  • Quazzi
även då jag försöker se live-tv?
Postad 28 August 2009 - 07:40
psGandalf
  • psGandalf
  • 67 inlägg
Enda skillnaden med en live tv utsändning och en inspelad i Mythtv är att live sädningen flaggas annorlunda och raderas snabbare. Så svaret är japp.
Postad 02 January 2010 - 14:02
maemmoth
  • maemmoth
  • 93 inlägg
Det kan vara klokt att titta vad brandväggen har för inställningar också.
Jag kör OpenSuse och jag måste i brandväggen lägga ett undantag för mythbackend.
Postad 04 January 2010 - 08:12
da_king
  • da_king
  • 258 inlägg
har du kollat rättigheterna på mappen som du har "mythtv" i på servern ?? hade problem med det förut fungerade ingenting.
vad skriver du för adress i xbmc till servern med kanalerna o inspelningarna ??
myth://anvnamn:lösen@serverip
    2026-09-23 18:09:20
    2026-09-23 18:08:13
