Här är loggen från clienten.
2011-Sep-13 21:51:08:
2011-Sep-13 21:51:08: ==============================================================
2011-Sep-13 21:51:08: Logging is started
2011-Sep-13 21:51:08: Info. Service mode choosed
2011-Sep-13 21:51:08: Info. Starting DVBLink service
2011-Sep-13 21:51:08: Info. CServerBase::UpdateSettings. Process priority set to 0x20
2011-Sep-13 21:51:08: Info. CBroker::Start - begin
2011-Sep-13 21:51:08: Info. CTcpServer::Run(): started
2011-Sep-13 21:51:08: Info. CBdaSinkInstance::Start. - 1 - Starting tuner \\.\DVBSMCEBridge1
2011-Sep-13 21:51:08: Info. CBdaSinkInstance::Start. - 1 - ChangeChannelThread started successfully
2011-Sep-13 21:51:08: Info. CBdaSinkInstance::ChannelThread. - 1 - ChannelThread started
2011-Sep-13 21:51:08: Info. CBdaSinkInstance::ChannelThread. - 1 - Do IOCTL_MCE_BRIDGE_CHANGE_CHANNEL_REQ
2011-Sep-13 21:51:08: Info. CBdaSinkInstance::ChannelThread. - 1 - request is pended
2011-Sep-13 21:51:08: Info. DVBLink Tuner#1: CNBClient::Connect. Connection to server: 192.168.1.17
2011-Sep-13 21:51:08: Info. CBdaSinkInstance::Start. - 2 - Starting tuner \\.\DVBSMCEBridge2
2011-Sep-13 21:51:08: Info. CBdaSinkInstance::Start. - 2 - ChangeChannelThread started successfully
2011-Sep-13 21:51:08: Info. CBdaSinkInstance::ChannelThread. - 2 - ChannelThread started
2011-Sep-13 21:51:08: Info. CBdaSinkInstance::ChannelThread. - 2 - Do IOCTL_MCE_BRIDGE_CHANGE_CHANNEL_REQ
2011-Sep-13 21:51:08: Info. CBdaSinkInstance::ChannelThread. - 2 - request is pended
2011-Sep-13 21:51:08: Info. DVBLink Tuner#2: CNBClient::Connect. Connection to server: 192.168.1.17
2011-Sep-13 21:51:08: Info. CBdaSinkInstance::Start. - 3 - Starting tuner \\.\DVBSMCEBridge3
2011-Sep-13 21:51:08: Info. CBdaSinkInstance::Start. - 3 - ChangeChannelThread started successfully
2011-Sep-13 21:51:08: Info. CBdaSinkInstance::ChannelThread. - 3 - ChannelThread started
2011-Sep-13 21:51:08: Info. CBdaSinkInstance::ChannelThread. - 3 - Do IOCTL_MCE_BRIDGE_CHANGE_CHANNEL_REQ
2011-Sep-13 21:51:08: Info. CBdaSinkInstance::ChannelThread. - 3 - request is pended
2011-Sep-13 21:51:08: Info. DVBLink Tuner#3: CNBClient::Connect. Connection to server: 192.168.1.17
2011-Sep-13 21:51:08: Info. CBdaSinkInstance::Start. - 4 - Starting tuner \\.\DVBSMCEBridge4
2011-Sep-13 21:51:08: Info. CBdaSinkInstance::Start. - 4 - ChangeChannelThread started successfully
2011-Sep-13 21:51:08: Info. CBdaSinkInstance::ChannelThread. - 4 - ChannelThread started
2011-Sep-13 21:51:08: Info. CBdaSinkInstance::ChannelThread. - 4 - Do IOCTL_MCE_BRIDGE_CHANGE_CHANNEL_REQ
2011-Sep-13 21:51:08: Info. CBdaSinkInstance::ChannelThread. - 4 - request is pended
2011-Sep-13 21:51:08: Info. CBroker::Start - end
2011-Sep-13 21:51:08: Info. DVBLink Tuner#4: CNBClient::Connect. Connection to server: 192.168.1.17
2011-Sep-13 21:51:08: Info. DVBLink Tuner#1: CNBClient::Connect. Connection to server is successful: 192.168.1.17. Local address: 192.168.1.212
2011-Sep-13 21:51:08: Info. DVBLink Tuner#2: CNBClient::Connect. Connection to server is successful: 192.168.1.17. Local address: 192.168.1.212
2011-Sep-13 21:51:08: Info. DVBLink Tuner#3: CNBClient::Connect. Connection to server is successful: 192.168.1.17. Local address: 192.168.1.212
2011-Sep-13 21:51:08: Info. DVBLink Tuner#4: CNBClient::Connect. Connection to server is successful: 192.168.1.17. Local address: 192.168.1.212
2011-Sep-13 21:51:21: Info. CBdaSinkInstance::ChannelThread. - 1 - reset ChangeChannelReqOverlapped.hEvent
2011-Sep-13 21:51:21: Info. CBdaSinkInstance::ChannelThread. Changing channel...
2011-Sep-13 21:51:22: Info. DVBLink Tuner#1: CNBClient::ChangeChannel. Channel is changed 10080000, client E1FC49C8-D0F9-41C6-8707-C934613F5A01
2011-Sep-13 21:51:22: Info. CUDPSession::Create. LIP, RIP, PORT: "192.168.1.212", "192.168.1.17", 61691
2011-Sep-13 21:51:22: Info. CBdaSinkInstance::ChannelThread. - 1 - Channel has been changed
2011-Sep-13 21:51:22: Info. CBdaSinkInstance::ChannelThread. - 1 - Do IOCTL_MCE_BRIDGE_CHANGE_CHANNEL_REQ
2011-Sep-13 21:51:22: Info. CBdaSinkInstance::ChannelThread. - 1 - request is pended
2011-Sep-13 21:51:22: Info. CUDPSession::RecvPackets. Receiving thread is started
2011-Sep-13 21:51:37: Info. CBdaSinkInstance::ChannelThread. - 1 - reset ChangeChannelReqOverlapped.hEvent
2011-Sep-13 21:51:37: Info. CBdaSinkInstance::ChannelThread. Changing channel...
2011-Sep-13 21:51:37: Info. CUDPSession::RecvPackets. Recvfrom is finished
2011-Sep-13 21:51:37: Info. DVBLink Tuner#1: CNBClient::ChangeChannel. Channel is changed 10430000, client E1FC49C8-D0F9-41C6-8707-C934613F5A01
2011-Sep-13 21:51:37: Info. CUDPSession::Create. LIP, RIP, PORT: "192.168.1.212", "192.168.1.17", 61691
2011-Sep-13 21:51:37: Info. CBdaSinkInstance::ChannelThread. - 1 - Channel has been changed
2011-Sep-13 21:51:37: Info. CBdaSinkInstance::ChannelThread. - 1 - Do IOCTL_MCE_BRIDGE_CHANGE_CHANNEL_REQ
2011-Sep-13 21:51:37: Info. CBdaSinkInstance::ChannelThread. - 1 - request is pended
2011-Sep-13 21:51:37: Info. CUDPSession::RecvPackets. Receiving thread is started
2011-Sep-13 21:51:47: Info. CBdaSinkInstance::ChannelThread. - 1 - reset ChangeChannelReqOverlapped.hEvent
2011-Sep-13 21:51:47: Info. CBdaSinkInstance::ChannelThread. Changing channel...
2011-Sep-13 21:51:47: Info. CUDPSession::RecvPackets. Recvfrom is finished
2011-Sep-13 21:51:47: Info. DVBLink Tuner#1: CNBClient::ChangeChannel. Channel is changed 0, client E1FC49C8-D0F9-41C6-8707-C934613F5A01
2011-Sep-13 21:51:47: Info. CBdaSinkInstance::ChannelThread. - 1 - Channel has been changed
2011-Sep-13 21:51:47: Info. CBdaSinkInstance::ChannelThread. - 1 - Do IOCTL_MCE_BRIDGE_CHANGE_CHANNEL_REQ
2011-Sep-13 21:51:47: Info. CBdaSinkInstance::ChannelThread. - 1 - request is pended
Det här inlägget har ändrats av mattemattias 13 september 2011 - 20:54
