Blu-ray eller HD DVD?
7496 svar till detta ämne
#6501
Postad 24 April 2007 - 19:42
Unregistered992
Unregistered992
1687 inlägg
Så du menar att Crank och The Descent inte har PiP?
Hör inte till saken, det kan bli bättre... Man KAN lägga samma film 2ggr på BD, en med och en utan PiP rutan, i och med detta så kommer man runt problemet med secondary video decoder. Upp till filmbolagen hur dom vill lösa det, vänta eller göra som Lions Gate.
Har Crank o The Descent IME, BDlive?? ..det var nyheter för min del, tack för upplysningen
PiP, inte Live. EDIT: Hur många HD DVD filmer har "live"? 0... 1 kommer till sommaren ja, men inte direkt impande många
Redigerat av Unregistered992, 24 April 2007 - 19:43.
#6502
Postad 24 April 2007 - 19:47
diabolo
diabolo
3548 inlägg
PiP, inte Live.*
EDIT: Hur många HD DVD filmer har "live"? 0... 1 kommer till sommaren ja, men inte direkt impande många *
* http://en.wikipedia....ki/Blu-ray_Disc1.1 (mandatory November 2007) What is typically referred to as "Profile 1.1" (but is more formally known as "Final Standard Profile") adds a secondary video decoder (typically used for picture in picture), secondary audio (typically used for interactive audio and commentary) and capability of supporting a minimum of 256MB of local storage (for storing audio/video and title updates). Compliance with this profile will be mandatory for player models introduced to the market after October 31, 2007[1], but existing products will be unaffected. No players compliant with this profile have been announced or released. Some profile 1.0 players may be upgradeable via firmware update to profile 1.1 if they have the appropriate hardware. When software authored with interactive features dependent on Profile 1.1 hardware capabilities are played on profile 1.0 players some features may not be available or may offer limited capability (i.e. director commentary may provide only audio rather than audio and video). Profile 1.0 players will still be able to play the main feature of the disc, however. [edit] 2.0 (BD-Live) Profile 2, also known as BD-Live, adds network connectivity to the list of mandatory functions and increases mandatory local storage capability to one GB. No released players have been announced as compatible with this profile. However it has been speculated that the PS3 will be upgradeable to this profile *I alla fall de är på G med officiella press releases för HD-DVDs del + att specsen har varit klara från day one
Redigerat av diabolo, 24 April 2007 - 19:52.
#6503
Postad 24 April 2007 - 19:58
Unregistered992
Unregistered992
1687 inlägg
PiP, inte Live.*
*http://en.wikipedia....ki/Blu-ray_Disc
Översatt till sanningen: BD-J har inget med det hela att göra, folk är extremt förvirrade och förväxlar profilerna med mjukvara vilket är helt fel, HD DVD visste att om dom skulle få ut PiP från början så skulle det kunna vinklas rejält i media och ge dom +poäng kortsiktigt, vad som inte tas upp är att Secondary video decoder(PiP) i HD DVD bara klarar av 480i med riktigt låg bitrate(skalas upp) Medans BD väntar på att kunna köra PiP i samma spec som vanliga video delen(1080p@40mbps)
Dom som köper en BD standalone nu kommer inte att kunna kika på PiP, dom kommer dock kunna göra allt som 1.1 spelarna klarar vad det gäller BD-J. Nästa år när alla gamla spelare är utbytta mot nya så kan man knappt få tag i en 1.0 spelare längre, då finns det bara 1.1 och 2.0 att välja på, ooooooj vad strul för konsumenten
Nä detta är så extremt överdrivet, tror jag ska spara den här texten och klippa in det varje gång någon tar upp detta, vissa ser ju ut att gilla old news som är vinklade.
Kan bli att man får vänta lite när man inte vill begränsa vissa funktioner för mycket
Redigerat av Unregistered992, 24 April 2007 - 19:59.
#6504
Postad 24 April 2007 - 20:01
diabolo
diabolo
3548 inlägg
Tyvärr dina tolkningar o sanningar har ingeting med verkligheten o göra
#6505
Postad 24 April 2007 - 20:05
Unregistered992
Unregistered992
1687 inlägg
Rätta gärna detta åt mig om jag har fel: " Secondary video decoder(PiP) i HD DVD bara klarar av 480i med riktigt låg bitrate(skalas upp) Medans BD väntar på att kunna köra PiP i samma spec som vanliga video delen(1080p@40mbps)"
#6506
Postad 24 April 2007 - 20:07
thetias
thetias
2965 inlägg
Jag uppenbarar mig här för att frälsa Razter & Diabolo från ondo...
Ske min vilja...
Nu tager vi varandras händer och förenas med en HD Combospelare...
Amen...
Vad hände med Hoff? Varför tog du bort bilden?
Det var dags att visa mitt sanna jag.
#6507
Postad 24 April 2007 - 20:11
diabolo
diabolo
3548 inlägg
"Secondary video decoder(PiP) i HD DVD bara klarar av 480i med riktigt låg bitrate(skalas upp) Medans BD väntar på att kunna köra PiP i samma spec som vanliga video delen(1080p@40mbps)"
Precis, väntar O nu en artikel som är intressant o har o göra med ämnet...visst old news men fortfarande aktuell Don't Get the Blues - Say No to Blu-ray Opinion from the Editor-in-Chief of DVDTOWN.com
The headline may seem strong, but I really feel it is time to put my foot down. When you are an early adopter of any new technology, you are used to losing a few dollars now and then, and you expect a few errors. When Microsoft promised that Windows Vista was the most secure and easy-to-use Windows yet, we realized that it would still have security issues and that it might not be that much easier to surf the Web compared to their previous program. We all know this and accept it.
The same goes for the new HD formats. We knew that they were not perfect and that the companies behind them had to iron out some bugs. What we did not know and should not accept is hardware that may not be compatible less than a year after it is released. For a format to succeed, it is important that it has a set of mandatory features, something with which hardware and software must comply in order to receive a format's logo. This gives consumers peace of mind and the security of knowing that when they buy a movie with, say, a DVD logo, it will play in their DVD player.
Toshiba has been good in issuing firmware updates for their players to make sure they are compatible with future HD-DVD releases. You might believe this is the case with Blu-ray as well, but no. Recent comments from the Blu-ray camp indicate that they have yet to complete final specifications for the interactive component called Blu-ray Disc JAVA (BD JAVA). What this means is that when the specifications are finally decided upon in late October, 2007, one's Blu-ray player bought before that date may not play parts of future Blu-ray releases. Imagine the confusion in a store trying to figure out if one's machine will play a specific extra.
HD-DVD knew the importance of a strong set of features from the get-go, and they had their mandatory features ready from the start. They made sure that every HD-DVD player had an Internet connection (which is not required by Blu-ray), allowing easy updates of the player and opening up exciting on-line features that we will see on HD-DVD releases this fall. Their interactive layer, called HDi, has also been in place from day one, and we have already seen it in various releases. "Batman Begins" and "Miami Vice," for example, showcase picture-in-picture and the possibility to make one's own scene-selection menus. Warner Bros. recognized the current limitation in Blu-ray technology and decided not to release titles with interactive features on Blu-ray before they knew what to develop for. These titles include things like "Batman Begins," "Poseidon," "Troy," and the upcoming "Matrix" box sets, which are HD-DVD exclusive for now.
I must draw a conclusion from all this: Don't buy Blu-ray. Not before the Blu-ray camp have finalized the format's specifications. Not before the manufacturer will GUARANTEE 100% compatibility with future Blu-ray releases. If you don't want to buy HD-DVD, either, that's fine. Wait. Enjoy regular, standard-definition DVDs. For now, however, the only safe and sensible HD choice is HD-DVD.
#6508
Postad 24 April 2007 - 20:15
diabolo
diabolo
3548 inlägg
Offtopic:Lånar ett inlägg från AVS Blu-ray player: $900 Blu-ray movies: $25 each Forcing unfinished technology on the unsuspecting public: priceless
Redigerat av diabolo, 24 April 2007 - 20:15.
#6509
Postad 24 April 2007 - 20:20
Unregistered992
Unregistered992
1687 inlägg
Precis, väntar
[b]Opinion from the Editor-in-Chief of DVDTOWN.com
Och denna är lika skräp som förra gången den postades, jag skrev hur det ligger till men dom har inte återkommit, shocker
#6510
Postad 24 April 2007 - 20:22
diabolo
diabolo
3548 inlägg
Och denna är lika skräp som förra gången den postades, jag skrev hur det ligger till men dom har inte återkommit*, shocker
Vilka skulle återkomma??
#6511
Postad 24 April 2007 - 20:27
Addex
Addex
1902 inlägg
IBM/Levono R61 ThinkPad with Blu-Ray in JulySo basically the story is The T61 and R61 are coming with planned availability dates of the following:
May 2007 for initial rollout of the widescreen 14.1" versions Models with NVIDIA graphics and Microsoft Vista 64-bit or XP Pro will be available July 2007. Models with 160 GB (5400 rpm) FDE hard drives will be available July 2007. Models with Blu-ray DVD burner will be available July 2007.
#6512
Postad 24 April 2007 - 20:28
Unregistered992
Unregistered992
1687 inlägg
dvdtown, och nej, du behöver inte komma med nån kommentar som "ja, för dom läser ju på minhembio  " Tänker du lite så förstår du nog vad jag menar.
#6513
Postad 24 April 2007 - 20:30
diabolo
diabolo
3548 inlägg
O varför skulle de återkomma?? Henning Molbaek skrev det han tyckte var rätt(O rätt var det) så
#6514
Postad 24 April 2007 - 20:32
diabolo
diabolo
3548 inlägg
Laptop med HD-DVD brännareHär är en spännande laptop-nyhet från svenska datortillverkaren Zepto. Znote 6625W har bland annat HDMI-utgång och hd-dvd brännare som tillbehör. [2007-04-23 14:53] Znote 6625W är en laptop med helt klart intressanta specifikationer.
Datorn kommer med en 15.4 tums WSXGA-skärm med 1680 x 1050 pixlar, Intel Centrino Pro processor, 1 GB ramminne, bluetooth 2.0, 512 MB Nvidia GeForce Go 8600 grafikkort, stöd för DirectX 10 och 802.11a/b/g/n trådlöst nätverkskort. Ovanför skärmen sitter en inbyggd webbkamera för videochat. I framtiden kan modeller komma som har möjlighet att ansluta till Internet via turbo-3G, berättar Magnus Jönsson, på Zepto för oss.
På baksidan sitter en HDMI-utgång samt en DVI-utgång och sist men inte minst kan man som tillval få en inbyggd hd-dvd brännare. Inte dåligt.
Priset på Znote 6625W varierar efter hur köparen konfigurerar datorn vid köpet. Vi vill nog inte veta vad den kostar med hd-dvd brännaren. Zepto berättar för oss att datorn kommer kunna levereras någon gång nästa månad.
Znote 6625W har några av de intressantaste specifikationerna vi sett på länge i en bärbar dator, och verkar vara en riktigt het speldator helt enkelt.  Fina grejer
Redigerat av diabolo, 24 April 2007 - 20:32.
#6515
Postad 24 April 2007 - 20:33
Unregistered992
Unregistered992
1687 inlägg
Skriver man en artikel så borde den väl innehålla lite mer än bara sin egen åsikt? Han skrapar inte ens på ytan, varför är BD's PiP försenad? Vad är skillnaderna mot för den i HD DVD? Är det exakt lika? Osv osv...
#6516
Postad 24 April 2007 - 20:37
diabolo
diabolo
3548 inlägg
Så han är HD-DVD biased enligt dig
#6517
Postad 24 April 2007 - 20:40
Unregistered992
Unregistered992
1687 inlägg
Eller så vet han inte vad han själv skriver, vore kanske bäst att läsa lite fler artiklar från samma person innan jag kan ta ställning till det. Det bästa hade varit ett svar på det jag skrev dock.
#6518
Postad 24 April 2007 - 20:44
diabolo
diabolo
3548 inlägg
Vill du lägga ut det du skrev? Inget måste, är bara nyfiken
#6519
Postad 24 April 2007 - 20:46
Unregistered992
Unregistered992
1687 inlägg
Nä jag har det inte kvar, om dom av någon konstig anledning skulle svara så kan du få se dock
#6520
Postad 24 April 2007 - 20:48
diabolo
diabolo
3548 inlägg
Ok, skicka den via PM...när du får svar
#6521
Postad 24 April 2007 - 21:27
Unregistered992
Unregistered992
1687 inlägg
Wal-Mart Names HD DVD the Winner
Mja han kan ju alltid drömma iaf
Rob Enderle cites Bob Crabtree who cites "AVS Science Forum." - Translation...with this thread the rumor has gone a full circle.
Redigerat av Unregistered992, 24 April 2007 - 21:27.
#6522
Postad 24 April 2007 - 22:10
diabolo
diabolo
3548 inlägg
#6523
Postad 24 April 2007 - 22:38
diabolo
diabolo
3548 inlägg
Razter, jag har en fråga(  ), när kommer Sin City på BD o HD-DVD??
#6524
Postad 24 April 2007 - 22:40
Unregistered992
Unregistered992
1687 inlägg
Det är här vi skippar 4 inlägg av tjafs och hoppar direkt till din poäng, hittat en studio i europa som distruberar den eller?
#6525
Postad 24 April 2007 - 22:47
diabolo
diabolo
3548 inlägg
Nej bättre, Canada Alliance Atlantis HD-DVD exclusive http://www.ofdb.de/v...=film&fid=72886 http://www.uneporte....antis_a796.html de har filmrättigheterna/distribution i Canada
Redigerat av diabolo, 24 April 2007 - 22:51.
#6526
Postad 24 April 2007 - 22:54
Unregistered992
Unregistered992
1687 inlägg
Ingen aning om när den kommer till Canada men vi borde väl se datum för BD släppet snart.
En fråga diabolo, hur väljer du filmer mellan formaten? Låt säga att Disney släpper denna som High-bitrate AVC/VC-1 med 24-bit PCM ljud, och canada släppet får låg bitrate VC-1 med dd+. Väljer du fortfarande HD DVD'n eller tar du BD'n?
Detta är en seriös fråga, vill bara veta hur du tänker
#6527
Postad 24 April 2007 - 22:57
diabolo
diabolo
3548 inlägg
En fråga diabolo, hur väljer du filmer mellan formaten? Låt säga att Disney släpper denna som High-bitrate AVC/VC-1 med 24-bit PCM ljud, och canada släppet får låg bitrate VC-1 med dd+. Väljer du fortfarande HD DVD'n eller tar du BD'n? Detta är en seriös fråga, vill bara veta hur du tänker
1 Pris 2 Bildkvalite 3 Ljudkvalite 4 IME, Live funktion osv Nöjd med svaret?
#6528
Postad 24 April 2007 - 23:01
Unregistered992
Unregistered992
1687 inlägg
1 Pris
2 Bildkvalite
3 Ljudkvalite
Nöjd med svaret?
Jupp, förvånad att priset stod högst upp bara. Hur stor skillnad kan det vara mellan filmer? $5? Bättre bild och ljud borde väl ändå komma före
Redigerat av Unregistered992, 24 April 2007 - 23:01.
#6529
Postad 24 April 2007 - 23:07
diabolo
diabolo
3548 inlägg
Jag är en fattig människa  ...  ...lite seriösare nu, bildkvaliten kommer först, ljudet kommer på andra plats o extra kryddor som PiP, Live osv är mindre viktiga för min del.
Redigerat av diabolo, 24 April 2007 - 23:11.
#6530
Postad 25 April 2007 - 00:18
Addex
Addex
1902 inlägg
Trevligt med ett ärligt svar.
#6531
Postad 25 April 2007 - 00:19
Addex
Addex
1902 inlägg
#6532
Postad 25 April 2007 - 00:37
diabolo
diabolo
3548 inlägg
Amazon.com listar kommande filmer...
Addex...  du vet ju att det inte finns några date releases för de filmerna + att de flesta kommer på HD-DVD också Men why not HD-DVD lista med kommande filmer http://hddvdformat.b.....0DVD Software
Upcoming Feature Films on HD DVD April 24, 2007
Eternal Sunshine of the Spotless Mind (USHE) Failure to Launch Special Collector's Edition (PHE) The Nutty Professor (USHE)
Universal Studios has confirmed the following HD DVD titles due in July:
Shaun of the Dead Billy Madison Cat in the Hat Dante's Peak The War (1994) The Wedding Date The Bourne Identity In Good Company Streets of Fire Nutty Professor 2 Scent of a Woman Darkman Sea of Love Deliver Us From EvaMay 1, 2007
Alpha Dog* [TrueHD] (USHE) The Hitcher (2007) (USHE) Dreamgirls 2-Disc Showstopper Edition (PHE) View all cover artwork here.
May 15, 2007
The Fountain (WHV) Battle of the Bulge (WHV) The Road Warrior (WHV) View all cover artwork here.
May 22, 2007
The 40-Year-Old Virgin Unrated Special Edition* (USHE) Flags of Our Fathers 2-disc Special Collector's Edition (PHE) Freedom Writers (PHE) The Complete Matrix Trilogy* [TrueHD] (WHV) The Ultimate Matrix Collection* [TrueHD] (WHV) Letters from Iwo Jima [TrueHD] (WHV) Mission: Impossible Collector's Edition (PHE) Mission: Impossible 2 (PHE) The Skeleton Key (USHE) Smokey and the Bandit (USHE) View all cover artwork here.
May 29, 2007
The Big Lebowski (USHE) Dragonheart (USHE) The Frighteners - Director's Cut (USHE) Lost In Translation (USHE) Midnight Run (USHE) The River (USHE) View all cover artwork here.
June 5, 2007
Coming to America - Special Collector's Edition (PHE) The Cowboys (WHV) Norbit (PHE) Rio Bravo (WHV) Trading Places - Special Collector's Edition (PHE) June 12, 2007
Black Christmas - Unrated [TrueHD] (Weinstein) Born on the Fourth of July (USHE) Breach* (USHE) Bruce Almighty (USHE) Daylight (USHE) Harsh Times [TrueHD] (Weinstein) Liar Liar (USHE) Monty Python's The Meaning of Life (USHE) Sneakers (USHE) View all cover artwork here.
June 26, 2007
American Me (USHE) Being John Malkovich (USHE) Bulletproof (USHE) Freedom Vol. 1 (Bandai) Hustle & Flow (PHE) Mallrats (USHE) Meet Joe Black (USHE) Mystery Men (USHE) The Watcher (USHE) View all cover artwork here.
July 3, 2007
Blood Diamond*^ (WHV) The Untouchables Special Collector's Edition (PHE) The Warriors Ultimate Director's Cut (PHE) July 24, 2007
The Contract (First Look) Newly Added! The Host / Gwoemul (2006) (Magnolia) Newly Added! *****
Upcoming Music/Concert/Misc HD DVD Titles Release List
April 24, 2007
Planet Earth: The Complete Collection (2006) (WHV/BBC) June 19, 2007
Blue Planet IMAX (WHV) *****[/B] » Klicka här för att visa spoiler - Klicka en gång till för att dölja den... « Coming soon...
2001: A Space Odyssey 300* American Pie (Unrated) Alexander Revisited: The Unrated Final Cut (2007) Battlestar Gallactica (TV series) Blade Runner (1992 Director’s Cut, Blade Runner: The Original U.S. Theatrical Cut, Expanded International Theatrical Cut & Blade Runner: The Final Cut) Blood Diamond Brazil The Bourne Ultimatum* (2007) A Clockwork Orange Cat People Dawn of the Dead (Unrated) Dead Silence (2007) Deliverance Dirty Harry Collection (Dirty Harry, Magnum Force, The Enforcer, Sudden Impact and The Dead Pool) Erin Brockovich Evan Almighty* (2007) Evening Eyes Wide Shut For the Love of the Game The Goonies Hamlet Harry Potter & The Sorcerer's Stone* Harry Potter & Chamber of Secrets* Harry Potter & The Prisoner of Azkaban* Harry Potter & The Goblet of Fire* Heat Heroes: Season One Hot Fuzz (2007) The Island Inside Man The Jazz Singer King of California Lock, Stock & Two Smoking Barrels L.A. Confidential Meet the Fockers Music & Lyrics Natural Born Killers North by Northwest Oceans 11 Oceans 12 Patch Adams Poltergeist Special Edition Pride & Prejudice Quo Vadis The Reaping The Sopranos (TV series) School of Rock The Shining Slap Shot Star Trek (Feature films/TV Series) We Are Marshall The Wizard of Oz Zodiac2001: A Space Odyssey Announced by Warner Brothers for December in France. Not yet listed.
300 Announced by Warner Brothers for September in France. Not yet listed.
Band of Brothers Announced by Toshiba for 6/27/2007 in Japan. Not yet listed.
Blade Runner Announced by Warner Brothers for September in France. Not yet listed.
Blood Diamond Announced by Warner Brothers for September in France. Not yet listed.
A Clockwork Orange Announced by Warner Brothers for December in France. Not yet listed.
Crash Announced by Manga Spain for Quarter 1 in Spain. Not yet listed.
The Dead Pool Announced by Warner Brothers for October in France. Not yet listed.
Dirty Harry Announced by Warner Brothers for October in France. Not yet listed.
El Cid Announced by Filmax for Quarter 1/2 in Spain. Not yet listed.
The Enforcer Announced by Warner Brothers for October in France. Not yet listed.
Eyes Wide Shut Announced by Warner Brothers for December in France. Not yet listed.
Harry Potter and the Philosopher's Stone Announced by Warner Brothers for November in France. Not yet listed.
Harry Potter and the Chamber of Secrets Announced by Warner Brothers for November in France. Not yet listed.
Harry Potter and the Prisoner of Azkaban Announced by Warner Brothers for November in France. Not yet listed.
Gangs of New York Announced by Manga Spain for Quarter 1 in Spain. Not yet listed.
The Good, The bad, and the Ugly Announced by Filmax for Quarter 1/2 in Spain. Not yet listed.
The Goonies Announced by Warner Brothers for August in France. Not yet listed.
K-19 Announced by Filmax for Quarter 1/2 in Spain. Not yet listed.
L.A. Confidential Announced by Warner Brothers for September in France. Not yet listed.
Little Buddha Announced by Filmax for Quarter 1/2 in Spain. Not yet listed.
Magnum Force Announced by Warner Brothers for October in France. Not yet listed.
Music & Lyrics Announced by Warner Brothers for October in France. Not yet listed.
Natural Born Killers Announced by Warner Brothers for June 4th, 2007 in UK/France. Not yet listed.
Ocean's Eleven (1960) Announced by Warner Brothers for December in France. Not yet listed.
Ocean's Eleven (2001) Announced by Warner Brothers for December in France. Not yet listed.
Ocean's Twelve Announced by Warner Brothers for December in France. Not yet listed.
The Piano Announced by Filmax for Quarter 1/2 in Spain. Not yet listed.
Poltergeist Announced by Warner Brothers for September in France. Not yet listed.
The Reaping Announced by Warner Brothers for October in France. Not yet listed.
Saw Announced by Filmax for Quarter 1/2 in Spain. Not yet listed.
Saw II Announced by Filmax for Quarter 1/2 in Spain. Not yet listed.
The Shining Announced by Warner Brothers for December in France. Not yet listed.
Sudden Impact Announced by Warner Brothers for October in France. Not yet listed.
The Wizard of Oz Announced by Warner Brothers for December in France. Not yet listed.
Zodiac Announced by Warner Brothers for September in France. Not yet listed.Happy times
Redigerat av diabolo, 25 April 2007 - 00:41.
#6533
Postad 25 April 2007 - 00:46
diabolo
diabolo
3548 inlägg
Magnolia to Unleash 'The Host' on HD DVDHide the children and pets! Magnolia Home Entertainment plans to let the Asian scare flick 'The Host' loose to feast on HD DVD this summer. Though 'The Host' has enjoyed only a very limited theatrical release in the U.S., it has quickly earned a reputation as the biggest cult horror flick the genre has seen in years. Magnolia says it will bring the ode to classic monster movies to HD DVD on July 24. No specs are yet available, though the preliminary info from the indie distributor indicates a special edition, so we look forward to at least some supplemental features. List price has been set at a suggested $29.98. Magnolia currently has no word on a comparable Blu-ray version
#6534
Postad 25 April 2007 - 00:48
Unregistered992
Unregistered992
1687 inlägg
Du glömde det här: "H owever, given that the majority of their past releases have ultimately been released on both formats, a Blu-ray announcement may be forthcoming."
#6535
Postad 25 April 2007 - 00:50
diabolo
diabolo
3548 inlägg
"However, given that the majority of their past releases have ultimately been released on both formats, a Blu-ray announcement may be forthcoming."
"may be" inte säkert alltså
#6536
Postad 25 April 2007 - 00:52
Unregistered992
Unregistered992
1687 inlägg
Som 99% allt annat vi diskuterar menar du?  Nä det blev jävligt vinklat att inte inkludera den sista delen
#6537
Postad 25 April 2007 - 00:56
diabolo
diabolo
3548 inlägg
På vilket sätt?? "MAY BE" gör ingen skillnad  ...Magnolia har inte sagt något om Blu-ray releasen så Magnolia currently has no word on a comparable Blu-ray version
Redigerat av diabolo, 25 April 2007 - 00:56.
#6538
Postad 25 April 2007 - 01:13
#6539
Postad 25 April 2007 - 01:14
Unregistered992
Unregistered992
1687 inlägg
Magnolia currently has no word on a comparable Blu-ray version. Hm... Få se nu, släpper Magnolia på BD öht? Dom kanske inte har släppt något alls och väljer enbart HD DVD? Magnolia currently has no word on a comparable Blu-ray version. However, given that the majority of their past releases have ultimately been released on both formats, a Blu-ray announcement may be forthcoming.Ahhh, dom släpper på BD men dom har inte sagt något om denna, den kommer nog senare... Så gick mina tankar, och jag är antagligen inte ensam  MAO så utelämnade du en viktig del...
Redigerat av Unregistered992, 25 April 2007 - 01:14.
#6540
Postad 25 April 2007 - 01:18
diabolo
diabolo
3548 inlägg
Fortfarande inga garantier att den kommer på BD
#6541
Postad 25 April 2007 - 01:21
Unregistered992
Unregistered992
1687 inlägg
Nä men det är fortfarande en vinkling, och nej, du behöver inte svara på det här, drygt att bolla fram och tillbaka hela tiden.
#6542
Postad 25 April 2007 - 01:29
diabolo
diabolo
3548 inlägg
<{POST_SNAPBACK}> may be
#6543
Postad 25 April 2007 - 05:05
Addex
Addex
1902 inlägg
#6544
Postad 25 April 2007 - 07:13
diabolo
diabolo
3548 inlägg
snälla gör det
Why not  ...Money makes the world go around, the world go around, the world go around...hänger ni med nu grabbar
#6545
Postad 25 April 2007 - 07:51
Addex
Addex
1902 inlägg
snälla gör det
Härligt, Universal blir då snart neutrala.
#6546
Postad 25 April 2007 - 08:36
Unregistered989
Unregistered989
456 inlägg
jag väntar på vad Oprah har och säga om saken
#6547
Postad 25 April 2007 - 10:44
5366 inlägg
Ännu en release där HDDVD står för de bättre specarna, på Bild codec samt Ljud bitrate men bracke ger samma betyg tycker det verkar skumt  , ännu en fullpottare på bild iaf... http://bluray.highde...dreamgirls.html http://hddvd.highdef...dreamgirls.html
#6548
Postad 25 April 2007 - 12:59
Unregistered992
Unregistered992
1687 inlägg
Lite mer Wal-Mart: As has been reported here (and everywhere else) Engadget got ahold of a press release, apparently from Chinese manufacturer Fuh Yuan, indicating that Walmart had placed an order for 2,000,000 HD DVD players, which was then later retracted due to an odd translation, leading some to think that Walmart was instead ordering Blu-ray players. What remained odd was that no press release was ever issued by Walmart, the HD DVD or Blu-ray promotions groups, or anyone else who would be involved. Fuh Yuan also failed to clarify this "story" and industry "insiders" posting on internet messageboards had no idea what was happening.
A CED Industry Newsletter that was posted in the news section here, is now apparently reporting the following:
Sources we queried who are familiar with HD DVD licensing and Chinese OEMs were flummoxed by the reports. Neither Fuh Yuan nor Great Wall appear on any rosters of DVD and HD DVD licensees. Our search of major English-language newspapers and news services in Taiwan, China and Hong Kong didn't turn up any reports on Fuh Yuan or Great Wall or the purported deal with Wal-Mart. From translations of the Fuh Yuan announcement we've seen, it was part of a ramp-up for an IPO the company will launch in July.
And now Engadget has posted a retraction of the earlier article here
The biggest news to hit the format war in some time hit last week with word that Wal-Mart and China's Great Wall corporation struck a deal to bring inexpensive HD DVD players to market. While this is would be great news for all HD fans, we were left a bit worrisome by the translation dispute between the two camps. Just to make sure we had our facts straight, we updated the post and contacted HD DVD to get the full story. While the HD DVD camp reminded us that they have inexpensive players from China on the way, they weren't able to confirm any "specific reports relating to Wal-Mart". It seems to us that if this were indeed true, that the HD DVD camp would be the first to trumpet its significance to their success in the format war. As much as we all want inexpensive next generation HD disc players, we will just have to wait for something more official before we hold off on our purchases waiting for Wal-Mart.
So, who knows what's going on with this? As much attention as this has gotten, it really doesn't bode well for the integrity of Engadget that they've essentially retracted this story twice: once to say it "might" be Blu-ray players, and now a second time saying the whole deal might not exist.
Could this release have been the optimistic writings of a pre-IPO Chinese company that HOPES to get enough money in an IPO to produce HD DVD players, which they THINK they can make very cheaply, and that they HOPE to sell to Walmart? That's definitely a different story, altogether. http://www.avsforum....&
#6549
Postad 25 April 2007 - 15:17
diabolo
diabolo
3548 inlägg
Lite mer Wal-Mart: Denial is a defense mechanism in which a person is faced with a fact that is too painful to accept and rejects it instead, insisting that it is not true despite what may be overwhelming evidence. The subject may deny the reality of the unpleasant fact altogether (simple denial), admit the fact but deny its seriousness (minimisation) or admit both the fact and seriousness but deny responsibility (transference). The concept of denial is particularly important to the study of addiction. http://en.wikipedia.org/wiki/Denial
#6550
Postad 25 April 2007 - 15:28
Über-Guru
12561 inlägg
Trevligt
Övrigt
Off Topic
