"Unknown channel"
3 svar till detta ämne
Postad 19 juli 2007 - 21:23
hakuna
  • hakuna
  • 291 inlägg
Hej. Jag har installerat senaste svns och tve3 men får inte igång kanalerna!
Jag har frågat på forumet men får inga svar...
http://forum.team-me...rks-t25661.html
Någon som har någon hint?
Är det något med mitt tv-kort (Hauppauge HVR-900)?
TV-Server Version: tvengine3-07-17-2007--01-21h--Rev15220
MediaPortal Version: MediaPortal-svn--07-17-2007--12-03-Rev15223
MediaPortal Skin: PM III
Windows Version: XP SP2
CPU Type: Intel Core 2 Duo E6400 2,13GHz S775 FSB1
HDD: Samsung Spinpoint V160
Memory: Corsair VS 1024MB DDR2 PC5400/667MHz 2x6
Motherboard: Gigabyte GA-965P-S3
Motherboard Chipset: Intel P965
Motherboard Bios: Award
Video Card: LeadTek 7600GT HS256MB DDR2/DVI/HDTV
Video Card Driver: nVidia latest
Sound Card: Realtek ALC883
Sound Card AC3: optical out
Sound Card Driver:
1. TV Card: Hauppage HVR-900
1. TV Card Type: DVB-T/Analouge SW
1. TV Card Driver: 3.3c
MPEG2 Video Codec: NVidia Purevideo
MPEG2 Audio Codec: NVidia
Satelite/CableTV Provider: DVB-T Boxer
HTPC Case: Deltaco LA-120
Cooling: Zalman 7700 CU
Power Supply: FSP 350w350PNFOEMATX 2.0
Remote: ATi Remote Wonder II
TV: Hitachi PJ-TX300 projector
TV - HTPC Connection: Supra DVI-HDMI 10 m
Hello.
First, my system consists of these PC:
1. Master server, no TV card, no client
2. Slave server, TV card, client
3. HTPC, client
I have a problem trying to watch normal TV. I get the error message "Unaböe to start timeshift. Unknown channel."
Here is what works:
- Watching TV with TV2.
- Starting TV server console and press "Preview" on a channel.
- Manually start timeshift and watch it on PC 3. (On PC 2 MP just closes down.)
What I tried:
- Changing between .ts and mpg
- removing DVB EPG retrieval
- no firewalls on the PCs
- Changing video codecs (nVidia, MPV, Intervideo)
Can there be some sort of user rights involved?
From the log
: Phase 1 - 2 ms - Done method initialization
2007-07-17 21:35:58.234356 [Warn.][MPMain]: TVHome.ViewChannelAndCheck(): Phase 2 - 2 ms. Done previous state management.
2007-07-17 21:36:02.600635 [Warn.][MPMain]: TVHome.ViewChannelAndCheck(): Phase 3 - 4354 ms. Done statring timeshif.
2007-07-17 21:36:02.600635 [Warn.][MPMain]: TVHome.ViewChannelAndCheck(): Phase 4 failed - 0 ms. Starting error handling.
If someone has a clue I would be really greatful!
/Niclas
Redigerat av hakuna, 24 juli 2007 - 15:41.
Postad 20 juli 2007 - 11:07
Unregistered79ba53d7
  • Unregistered79ba53d7
  • 44 inlägg
Vet inte om det kan vara till någon hjälp, men har du ställt in ditt tv-kort som hybridkort? Prova i så fall att ta bort sammanlänkningen och prova igen. Hybridinställningen fungerar tyvärr inte i tv-servern.
Se MediaPortals forum:
http://forum.team-me...nel-t23721.html
Redigerat av Unregistered79ba53d7, 20 juli 2007 - 11:12.
Postad 22 juli 2007 - 20:09
hakuna
  • hakuna
  • 291 inlägg
Jepp, det problemet visste jag redan om.
Och nej, det är inte i ngn hybrid, jag har tom disablat analogdelen då det inte finns några sådana utsändningar här i Bollebygd längre.
Tack ändå!
Jag har faktiskt inte testat att slå på analogdelen och ha den tom och inte i en hybrid... BBL.
Postad 24 juli 2007 - 15:40
hakuna
  • hakuna
  • 291 inlägg
Efter att jag fick veta att jag inte behöver ha TV Server på PC 1 (den utan tv-kort) och då satt PC2 som Master server så fungerar allt!
Att MP dog på PC2 löstes genom att jag ominstallerade FFDShow.
  • Kurben
    2024-05-10 10:24:33
  • Kurben
    2024-05-10 10:17:34
  • Kurben
    2024-05-10 10:15:28
  • Kurben
    2024-05-10 10:09:13
  • Bion idag
    DPC
    2024-05-08 09:21:33
