Útgarðaloki,
Jag mailade till Silicon Image och efterlyste stöd för RGBs tidigare i höstas. Här är deras svar.
quote:Hello Gustaf,
Thank you for your feedback. You are not the first to bring up the RGB/S issue and we are
taking an active look at being able to handle it in future products. Since this format is not
common in the US it did not occur to us to add it until people from Europe started bringing
it up recently. Hopefully, if iScan Ultra is successful, we can justify a new version to manage-
ment in the near future.
The only other solution I can think of for now is to see if there are any colorspace converter
boxes in the market. So, you take your interlaced RGB/S into the colorspace converter which
outputs YCrCb which then goes to the iScan which outputs YPrPb or RGB/DVI.
Best Regards,
Ron
Tyvärr ser det ut som om vi får vänta ett tag men frågan är i alla fall väckt.
