NuForce: Analog switching amplifier
6 svar till detta ämne
Optoma NuForce Reference 8 (Slutsteg) 1 9.166666 (5) Inga priser
Optoma NuForce Reference 9 (Slutsteg) 1 8.75 (3) Inga priser
2 relaterade trådar
Postad 06 November 2005 - 09:04
Unregistered67d97076
  • Unregistered67d97076
  • 101 inlägg
NuForce's slutsteg och förstärkare är baserade på analog switching teknik, som enligt tillverkaren skall vara mycket bättre än traditionella klass-D förstärkare, och dessutom bättre än förstärkare baserade på såväl klass A som A/B.
[quote name='http://www.nuforce.com/free-the-music.htm']Nuforce is not a Switching Digital Amplifier.
Switching Digital Amplifiers (commonly known as Class-D) were introduced some years ago. Right from the start, Class-D had enormous potential but some significant shortcomings.    For example, they have limited usable bandwidth, and they use a fixed sawtooth waveform to modulate an audio signal. This is a source of audio pollution, because the waveform causes inevitable jittering that can mask or corrupt low-level music signals.
         Instead of a sawtooth digital signal, Nuforce has developed and patented a naturally occurring analog modulating signal that flows with the music and adds no noise or jitter into the system.
         Rather than using imperfect off-the-shelf solutions, Nuforce has developed and patented a series of breakthrough advances that have unlocked the huge potential of switching amplifiers, without the problems that pure digital switching amplifiers have been unable to solve.
         In other words, the best of both worlds.[/quote]
Monoblocket Reference 9:
  • Nätdel: 350W
  • Effekt (RMS) 8/4/2 Ohm: 160W / 300W / 350W
  • Effekt (Peak 20ms hold) 8/4/2 Ohm: 338W / 676W / 1352W
  • Dämpfaktor: >4000
  • Vikt: 3,5kg
Länkar / Recensioner:// Fyllde på med lite mer information // alpha
Redigerat av Unregistered67d97076, 29 April 2006 - 02:07.
Postad 06 November 2005 - 22:27
Unregistereddcdbc111
  • Unregistereddcdbc111
  • 611 inlägg
Verkar vara väldigt intressant teknik i de där. Kul att någon vidareutvecklar klass D (som egentligen är rätt gammal teknik) med annan moduleringsvåg m.m.
Specarna var grymma, dämpfaktor över 4000 låter otroligt trevligt. Synd bara att kontinuerliga effekten inte ökar med minskande impedans. Fast det spelar inte så stor roll eftersom den dynamiska effekten inte är av den här världen.
Kostar dock en slant om man ska ha 6-7 st. till hemmabion och får Acoustic Realitys modeller att framstå som budgetalternativ :D :P
Postad 28 April 2006 - 21:32
tope72
  • tope72
  • 29 inlägg
Hej på Er
Tänkte bara berätta att jag nu slutligen har slagit till och köpt en Nuforce IR-7 för att driva mina Monitor Audio RS-6.
Håller på att spela in denna lilla digitala förstärkare och det låter väldigt positivt redan och jag vet att det kommer att bli bättre.
Har även tänkt att ta hem en cd Original 2008 mk. II för att se om det låter bättre än min nuvarande Sony DVD spelare.
Tänkte bara säga att jag är grymt imponerad av denna framtida teknik och är Ni intresserade av en förstärkare i 12000:- klassen så lyssna på denna lilla skapelse, risken är bara att Ni fastnar.
Jag hör idag röster som jag aldrig hört förut tex. därför är det bara att sätta sig och lyssna igenom skivsamlingen igen, nackdelelen kanske kan vara att skivor som är dåligt inspelade inte låter så bra men bra inspelade skivor låter alldeles underbart...
Finns det någon som har tips på bra inspelade skivor kan Ni gärna höra av Er, jag är allätare.
Ha det fint...
Postad 28 April 2006 - 22:25
Unregistered47efd78c
  • Unregistered47efd78c
  • 1554 inlägg
Grattis till en av de bästa integrerade förstärkarna på marknaden i rimliga prisklasser. För ca: 13k finns det absolut ingenting på marknaden som kan konkurrera.
Kan hålla med om att den är helt grym, vi har den hos oss numera och jag fastnar varje gång vi sätter på någon musik med den.
Postad 28 April 2006 - 22:44
Claatu
  • Claatu
  • 162 inlägg
Kollade lite på nätet, är drivningen av typ samma princip som exv Lyngdorf jobbar med (switching) ?
Den ser sjysst ut, men hur är finishen?
Nån som har en mätkub på den?
Postad 29 April 2006 - 13:05
Blind Guardian
  • Blind Guardian
  • 335 inlägg
Hade ett slutsteg varit akutellt hade jag slagit till på Ref9 idag, tyvär är min setup ganska komplett så jag får skjuta på planerna :) Blir ändå sjukt sugen...
Postad 29 April 2006 - 23:24
Perra1
  • Perra1
  • 2077 inlägg
Några snabba svar på dina frågor :)
Nej den är betydligt mer avancerad.... Man kan förenklat säga att Nuforce är ett "digitalt" slutsteg som är baserat på analog switchning.
Principen går ut på att de använder en effektförstärkt oscillatorkrets som kan moduleras av en audiosignal så att den producerar en förstärkt audiosignal som återvinns genom att man applicerar ett så kallat rekonstruktionsfilter.
Det är genom användandet av en högpresterande analog moduleringsteknik och vad som kallas ett "close-loop control" system som NPhysics alltså övervinner de vanligt förekommande begränsningarna i bandbredden över audiofrekvensområdet hos andra digitala slutsteg som använder sig av moduler med PWM (pulsbreddsmodulator) med fasta frekvenser.
NPhysics använder i NuForce Reference 8, till skillnad mot klass-D förstärkare, inte heller en artificiellt skapad sågtandad vågform för sin modulation, utan istället en egen vågform som förekommer helt naturligt vid högtalarterminalerna. Detta innebär inte bara att man helt eliminerar distorsion, utan också att den helt naturliga modulationssignalen som NuForce använder sig av inte tillför något brus i systemet.
Läs mer på http://www.component..._reference8.php
För jämförelser mellan olika teknologier så kan du kika här:
http://www.nuforce.com/amp-matrix.htm
Finishen är betydligt högre än vad som syns på bilder - det är IMO helt enkelt en mycket exklusiv känsla på stegen!
Till vad för nytta?? En mer ointressant sak att mäta är IMO svårt att hitta.... Nuforce har den högsta Damping factor (> 4000 vid alla audio frekvenser), en output (source) impedans som ligger nära 0 för hela frekvensregistret! Det betyder att Nuforce klarar att driva i princip vilken högtalare som helst, även under de mest svåra förhållanden.
Det finns dessutom mätningar som visar distorsion, inte bara vid 1/10KHz, utan för hela audioområdet och för hela effektregisret. Dessutom kommer varje steg med individuellt uppmätta protokoll för det unika steget... Det säger lite om den kontroll samt kvalitetssäkran Nuforce lägger ner.
Föreslår att du kika lite mer på http://www.nuforce.com/ för ytterligare information :(
mvh
/Pär
  • More is Always Better
    2026-08-29 18:47:07
