* Officiell Tråd - LG-42PM1M / LG-42PM1MA *
2184 svar till detta ämne
Postad 20 December 2005 - 10:44
Kurben
  • Kurben
  • 348 inlägg
Här diskuterar vi allt som rör de här modellerna
Specifikationer:
Display
-Display Plasma
-Picture Size: 42 inch
-Picture Format: 16:9
-Resolution: 1024x768p
-Brightness [cd/m²]: 1500
-Contrast ratio: 5000:1
-Response time: Less than 1 micro secund
-Viewing angle [H°/V°]: 170/170
-Pixel pitch (mm): 0,897 x 0,675
-Supported signal: PAL, Secam, NTSC, HD, VGA-SXGA
-Colors (R,G,b.) 10Bit (1,07 bil- 1024 shades of each color)
-OSD Language: SE,DG,NO,FI,ENG
-Picture: XD Engine,XD Engine 2
-DCDi: Faroudja DCDi
-Progressive Scan: Yes
-Color Temperature Control: Normal, Warm, Cool, User, Automatic
-Picture Control: Dynamic, Standard, Mild, User,Day,Night
-Aspect Ratio Correction: Spectacle, Full, Orginal, 4:3, 16:9, 14:9, Zoom
Sound
-Sound Type: NICAM A2
-Audio Output: 15W x 2
-Sound Control: SRS, Flat, Music, Movie, Sports, Speach, User
-Speaker: Option, Item number AP-42SA
Functions
-PIP (picture in picture): Yes (Flexible size)
-Twin Picture: Yes (Flexible size)
-Screen protection: ISM/Orbiting/White wash/Inversion/Normal,
-Timer function: Yes
-Zoom: Yes, 0-300%
-Auto Off: Yes
-Key Lock: Yes
-Pivot (Vertical Display): Yes
-OSM Rotate: Yes
-Termostate operated fans: Yes (Fan les in horizontal position)
-Auto/Manual Config: Yes
-Screen Adjust: Yes
-Multi Screen solution (2/4/9 screens): Yes
Connections
-PC in Analog: 1 (D-Sub 15pin)
-PC in Digital: 1 (HDMI with HDCP)
-Monitor out: 1 (D-Sub 15pin)
-Control: 1 (RS-232c) 1 (IR Jack)
-S-Video: 1 (D-Sub 9pin) + RCA audio
-Composite RCA: 1 (RCA) + RCA audio
-Component (Y/Pb/Pr): 1 (480i/480p/576i/576p/720p/1080i) + RCA Audio
-Euro Scart: 2 (Full scart)
-Antenna (Analog tuner): 1
Dimension
-1066x650x97,5 WxHxD [mm]
-30 Weight [Kg]
-100-240V, 50/60Hz
Warranty
Repair and return 2 year
Redigerat av Martin.M, 25 July 2006 - 11:29.
Postad 20 December 2005 - 23:01
oibmeh
  • oibmeh
  • 115 inlägg
Varför har ingen hittat denna Plasma förut?
Är det exakt samma panel som i PX5R/PX4R?
Jag kör Comhem-box + Xbox, mao får man högupplöst
för ungefär samma peng som en PX4RV. Klart intressant ;)
Om man kollar på LGs hemsida är den inte listad under TV/Plasma
utan man måste söka på produkt för att hitta den. Verkar som dom
försöker styra denna plasma mot offentliga installationer och inte
hembio. Om detta är samma panel som PX4/5R så är detta en mycket bra upptäckt :(
/oibmeh
Postad 21 December 2005 - 08:42
Kurben
  • Kurben
  • 348 inlägg
Ja det är exakt samma Plasma som PX5 och PX4 fast utan tuner och högtalare...
En annan fördel är att om man har ett eget företag så kan man köpa denna som monitor och därmed köpa in den som "kontors material" vilket gör att man kan dra bort 65% av priset ;-) men sådan kreativ skatteplanering överlåter jag till andra.
Om man vill se den på LG's hemsida så får man gå in under monitorer och inte tv apparater.
Dessutom så räknas inte detta som en TV med allt vad det innebär med tv licens att göra, fördel för en del kanske?
Postad 21 December 2005 - 08:58
greveriff
  • greveriff
  • 1984 inlägg
Nån som ett ett pris på den än ?
Postad 21 December 2005 - 09:09
oibmeh
  • oibmeh
  • 115 inlägg
https://www.prisjakt...ukt.php?p=76101
Det verkar som om Webhallen får in ex. den 28/12 :(
/oibmeh
Postad 21 December 2005 - 09:11
Kurben
  • Kurben
  • 348 inlägg
Den finns på prisjakt. överst på listan med LG plasma, men jag kan inte koppla den till den här tråden? verkar vara något fel på forumet.
Här är en direkt länk: https://www.prisjakt...ukt.php?p=76101
18 830:- är lägsta priset på den just nu!
Postad 21 December 2005 - 10:14
mangeP
  • mangeP
  • 369 inlägg
Det här e PRECIS vad jag letat efter!! Inga högtalare, ingen tuner, men alla ingångar!!
:wacko: ;) :D :D
Postad 21 December 2005 - 10:21
kribban
  • kribban
  • 3037 inlägg
Är det någon som vidarutveckla hur detta fungerar? Min fru har eget företag så man blir ju lite nyfiken :wacko: ;)
Postad 21 December 2005 - 11:03
Kurben
  • Kurben
  • 348 inlägg
Om din fru köper skärmen för sina "egna" pengar, alltså pengar som hennes företag har betalat arbetsgivar avgifter och skatt på, som hon själv dessutom måste betala cirka 32% inkomstskatt på och sedan 25% moms..
Lite svårt att förklara men köper företaget tv'n så går man förbi alla skatter. Men tänk på att företaget måste ha tillräckligt stora vita inkomster för att täcka upp avdraget.
Prata med en revisor...
Postad 21 December 2005 - 13:19
Kurben
  • Kurben
  • 348 inlägg
LG verkar ha lite olika specar på denna angående vissa detaljer, här är specen direkt från hemsidan:
Display Plasma
Picture Size [inch] 42 inch
Picture Format 16:9
Resolution 1024x768p
Brightness [cd/m²] 1500
Contrast ratio 5000:1
Response time Less than 1 micro secund
Viewing angle [H°/V°] 170/170
Pixel pitch (mm) 0,897 x 0,675
Supported signal PAL, Secam, NTSC, HD, VGA-SXGA
Colors (R,G,:wacko: 10Bit (1,07 bil- 1024 shades of each color)
OSD Language SE,DG,NO,FI,ENG
XD Engine XD Engine 2
DCDi Faroudja DCDi
Progressive Scan Yes
Color Temperature Control Normal, Warm, Cool, User, Automatic
Picture Control Dynamic, Standard, Mild, User,Day,Night
Aspect Ratio Correction Spectacle, Full, Orginal, 4:3, 16:9, 14:9, Zoom
Sound
Sound Type NICAM A2
Audio Output 15W x 2
Sound Control SRS, Flat, Music, Movie, Sports, Speach, User
Speaker Option, Item number AP-42SA
Functions
PIP (picture in picture) Yes (Flexible size)
Twin Picture Yes (Flexible size)
Screen protection ISM/Orbiting/White wash/Inversion/Normal,
Timer function Yes
Zoom Yes, 0-300%
Auto Off Yes
Key Lock Yes
Pivot (Vertical Display) Yes
OSM Rotate Yes
Termostate operated fans Yes (Fan les in horizontal position)
Auto/Manual Config. Yes
Screen Adjust Yes
Multi Screen solution (2/4/9 screens) Yes
Connections
PC in Analog 1 (D-Sub 15pin)
PC in Digital 1 (HDMI with HDCP)
Monitor out 1 (D-Sub 15pin)
Control 1 (RS-232c) 1 (IR Jack)
S-Video 1 (D-Sub 9pin) + RCA audio
Composite RCA 1 (RCA) + RCA audio
Component (Y/Pb/Pr) 1 (480i/480p/576i/576p/720p/1080i) + RCA Audio
Euro Scart 2 (Full scart)
Antenna (Analog tuner) 1
Dimension 1066x650x97,5
WxHxD [mm] 30
Weight [Kg] 100-240V, 50/60Hz
Warranty
Och här är specen ifrån deras PDF:
42PM1M
Sound
Sound Type NICAM Stereo
Audio Output 15Wx2
Sound Control Flat/Speech/Movie/User
Speaker Option
Functions
Inversion/Normal
Timer function Yes
Zoom Yes, 0-300%
Auto Off Yes
Key Lock Yes
OSM Rotate Yes
Termostate operated fans Yes (Fan less in horizontal position)
Auto/Manual Con^g. Yes
Screen Adjust Yes
Connections
PC in Digital 1 (DVI-i)
Control 1 (RS-232, IR Jack)
Composite RCA -
1080i/HDCP) + RCA Audio
Antenna (Analog tuner) -
Dimension
WxHxD [mm] 1210x645x97,5
Weight [Kg] 30
Power
AC input 100-240V, 50/60Hz
Consumption 350w
Warranty
Repair and return 3 years
Postad 21 December 2005 - 13:32
Kurben
  • Kurben
  • 348 inlägg
Ja la även till LG MZ-42PM12X vilket är den äldre Plasma monitorn som är likadan som PY10 men utan tuner och högtalare. Faktiskt dyrare men den är väl på väg bort nu..
Postad 21 December 2005 - 13:50
jesusjussi
  • jesusjussi
  • 58 inlägg
Sen måste man vid en skattervision kunna styrka att det verkligen var till företaget man behövde monitorn, annars eftertaxeras man.
Postad 21 December 2005 - 13:59
Kurben
  • Kurben
  • 348 inlägg
Precis... Men en monitor kollar dom nog aldrig upp, det är ju vanligt kontors material. Däremot om du köper en riktig TV då kollar/frågar dom..
Postad 28 December 2005 - 15:12
LuddeNo1
  • LuddeNo1
  • 27 inlägg
Det verkar som om Webhallen får in ex. den 28/12  :D
/oibmeh
Var ser du den infon??
Postad 28 December 2005 - 16:21
oibmeh
  • oibmeh
  • 115 inlägg
Info från deras hemsida vid tid för inlägget.
Nu har dom ändrat till 2006-01-04 (preliminärt) :D
/oibmeh
Postad 28 December 2005 - 20:12
greveriff
  • greveriff
  • 1984 inlägg
Ska köpa en ny plasma innan slutet på februari, den här eller lgPx3rva ligger bäst till just nu. Lite bökigt utan högtalare, men det kan jag ta om priset är lägre än de andra högupplösta modellerna från lg.
Postad 29 December 2005 - 09:57
ralnar
  • ralnar
  • 484 inlägg
Är det verkligen utan analog tuner? I specen står ju under Connections:
Postad 29 December 2005 - 14:24
erik h
  • erik h
  • 366 inlägg
Nån som har koll på om den finns inne nånstans för vettig peng? Hur funkar det med avsaknad av tuner och högtalare för en teknikanalfabet. Är det svårinstallerat? Om man ändå tänkt skaffa dig.box och surroundanläggning kan man väl strunta i att köpa en skärm där sånt är inkluderat och spara ett par kronor?
Postad 29 December 2005 - 14:26
kribban
  • kribban
  • 3037 inlägg
Japp :angry:
Postad 29 December 2005 - 17:39
maind
  • maind
ralnar: Det betyder bara att det finns en antenningång för en analog tuner.
Jag har för övrigt beställt mitt exemplar idag. Återkommer med mer info när jag fått den.
Postad 29 December 2005 - 19:45
greveriff
  • greveriff
  • 1984 inlägg
maind: Varifrån beställde du?
Postad 02 January 2006 - 16:29
Kurben
  • Kurben
  • 348 inlägg
Maind: Har du fått den ännu? Skulle vara kul med lite "hemma bilder" så man får se hur den ser ut i verkligheten.
Snart kommer jag också att beställa en, tror jag kommer använda Webhallen, smidigt för mig att hämta den i stockholm.
Postad 03 January 2006 - 11:37
erik h
  • erik h
  • 366 inlägg
Nån som kan tipsa om andra strippade skärmar som ändå har trevlig upplösning, bildbehandling osv?
Postad 03 January 2006 - 12:54
dalaleif
  • dalaleif
  • 21 inlägg
Panasonics 42PHD8 resp 50PHD8 är bland de mest omskrivna på några andra forum.
Postad 03 January 2006 - 13:12
erik h
  • erik h
  • 366 inlägg
Hmm, nån som har tips om några som är snäppet billigare eller är PM1M helt enkelt den mest prisvärda skärm man kan hitta i den prisklassen (dvs runt 20'kr). Jag kan inte förstå varför inte alla hoppar och stampar av glädje över den isf. Det måste finnas många som inte är intresserade av att betala för analog tuner. Vill man nödvändigtvis ha ett par inbyggda högtalare för att slippa mecka m surroundanläggning vid tv tittande kan man ju köpa ett par LG för typ 1600kr och ändå komma "billigt" undan.
Eller missar jag något?
Redigerat av erik h, 03 January 2006 - 13:13.
Postad 03 January 2006 - 14:05
Kurben
  • Kurben
  • 348 inlägg
Jag tror att majoriteten blir avskräckta bara av att ordet monitor används istället för tv..
Jag själv har en tendens av att överskatta andra människors tekniska kunnande och börjar smått vänja mig..
Tror faktiskt att det är så enkelt.
Men för oss som fattar vad det innebär så är det ett kap, minst sagt!..
En sak jag undrar över är hur fjärren ser ut? någon som har sett den?
Hoppas att Maind hör av sig när han fått monitorn så han kan visa lite bilder...
Postad 03 January 2006 - 14:35
erik h
  • erik h
  • 366 inlägg
Jo. Det jag själv fick höra när jag började kolla upp sånt här var ungefär att "när de säljs utan tuner och högtalare är det tänkt att de ska användas som monitorer och det påverkar såklart bildbehandling osv". Låter egentligen logiskt och jag har haft svårt att släppa det där. Eftersom man inte har tid att åka runt och jaga skärmar över hela stan så blir man tyvärr alltför beroende av andras åsikter. Nån som vet om den här finns inne i nån butik så man kan kika på den?
Postad 03 January 2006 - 15:55
Kurben
  • Kurben
  • 348 inlägg
Alltså, om du tittar på en PX5R eller en PX4R eller en PM1M med en box kopplad via scart eller en dvd via komponent eller en dator via HDMI/DVI, m.m m.m så är det exakt samma bild på alla modeller, inget och då menar jag INGET skiljer dom åt då. Samma bildkretsar kommer vara aktiva då.
Så vill du se hur en PM1M ser ut i bild så kolla in närmaste PX 5/4 R som inte kör via analog tuner så ser du hur det kommer se ut...
Postad 03 January 2006 - 16:02
erik h
  • erik h
  • 366 inlägg
Ok, låter logiskt... Nån som vet var jag kan kika på någon sådan i Sthlm?
Postad 03 January 2006 - 17:48
nexuz6
  • nexuz6
  • 41 inlägg
Kolla på Reference Audio på Götgatan... dom har en px5r du kan titta på...
Postad 03 January 2006 - 18:02
LuddeNo1
  • LuddeNo1
  • 27 inlägg
Enligt LGs hemsida så har PM1M högre Brightness cd/m2 (1500) än PX4R, PX5R (1000), enligt specar, så nån skillnad kanske det är på panelerna??
Postad 04 January 2006 - 00:21
maind
  • maind
Den som väntar på nåt gott...Jag lägger upp bilder så fort jag installerat plasman på väggen. Nån som kan rekommendera nåt bra väggfäste btw?
Postad 04 January 2006 - 07:55
Kurben
  • Kurben
  • 348 inlägg
Har också lagt märke till det, men enligt LG själva så ska det vara samma panel, tror mer att det är ett fel i specen, det är ju inte sällan det inträffar speciellt när det gäller kontrast och brightness värden..
Här är en länk även till ett norskt forum läsa vad Oeyvind har fått för svar från LG:
LG tråden på avsforum.no
Men om det skulle stämma att brightness verkligen är högre så borde även den faktiska kontrasten vara högre.
Maind: Trevligt att du fått hem den! Nu väntar vi med spänning på bilder!
Hur ser fjärren ut? Antar att det saknas knappar med siffror?
Redigerat av Kurben, 04 January 2006 - 08:58.
Postad 04 January 2006 - 10:22
nexuz6
  • nexuz6
  • 41 inlägg
Föjler det med nått bordsstativ?
Postad 04 January 2006 - 13:54
Unregisteredde0a2c45
  • Unregisteredde0a2c45
Jeg sjekket litt mer med LG ang. denne skjermen, og fikk følgende svar:
Dom korrekta måtten på 42PM1MA är 1066x650x97,5mm.
Väggfästena är samma.
42PM1MA som vi tar in till Norden har en analog tuner med 1500 sidors text minne . det finns en version utan tuner då heter den 42PM1M.
Ps. nu finns den på vår nordiska hemsida under display produkter
Det er altså analog tuner innbygd i modellen som importeres offisielt, men de fleste har vel uansett ikke behov for denne. Veggfeste eller bordstativ følger ikke med som standard, men er samme som på tidligere modell.
Og ja, som noen skrev over, bildet skal bli identisk med modellene PX4/5. Samme bildebehandlig og specs.
Noen som vet når den kan leveres? Tenker på å kjøpe her i Sverige dersom det går raskere.
Øyvind
Postad 04 January 2006 - 14:01
Kurben
  • Kurben
  • 348 inlägg
Oyvind: Maind har tydligen redan fått sin.. Nu väntar vi bara på lite bilder och åsikter från honom.
Iövrigt så måste man beställa den, verkar inte som om någon butik har dom på lager. Men dom levereras nu.
Postad 04 January 2006 - 14:28
Rosetwig
  • Rosetwig
  • 45 inlägg
;) '- oj oj oj oj oj ' ...jag kan knappt vänta på allt godis angående denna skärm. Jag tycker detta är ett av de bästa alternativen jag sett på länge. Högupplöst märkesskärm till detta pris, kom igen nu leverantörer ;)
//Jonas
-fast i denna tråd för ett tag framöver :P -
Postad 04 January 2006 - 15:22
greveriff
  • greveriff
  • 1984 inlägg
Japp, ett par hyggliga intryck sen är nog en beställning från webbhallen på g tror jag.
Postad 05 January 2006 - 10:05
AndyB
  • AndyB
  • 25 inlägg
Vad skiljer 42PM1M från PM3MVA? Den finns också på LG hemsida som ny.
Postad 05 January 2006 - 10:14
kevinergo
  • kevinergo
  • 185 inlägg
42PM3MVA är lågupplöst.
Postad 05 January 2006 - 10:23
kevinergo
  • kevinergo
  • 185 inlägg
Är 42PM1MA HD-ready? Sannolikt är den väl det eftersom den baseras på 42PX5R, men det står inget om det på LG's hemsida.
Postad 05 January 2006 - 10:50
AndyB
  • AndyB
  • 25 inlägg
Enligt LG pdf på hemsidan är det samma upplösning. Men 3MVA har SD flatron display och 1M XGA display. Vad är skillnaden?
Postad 05 January 2006 - 11:08
kevinergo
  • kevinergo
  • 185 inlägg
SD står antagligen för Standard Definition (852x480) så min gissning är att det helt enkelt är ett skrivfel i PDF'en när det gäller upplösningen på skärmen.
Postad 05 January 2006 - 13:04
erik h
  • erik h
  • 366 inlägg
LG 42PM3MVA från LG:s hemsida
Nån som har hört nåt om pris på den?
Redigerat av erik h, 05 January 2006 - 13:06.
Postad 05 January 2006 - 13:15
Kurben
  • Kurben
  • 348 inlägg
LG 42PM3MVA är lågupplöst... Står klart och tydligt på LG hemsida på specarna.
Verkar som den inte tas in av någon svensk importör.
Postad 09 January 2006 - 09:19
Kurben
  • Kurben
  • 348 inlägg
Nu har vi väntat tillräckligt länge :) När får vi se lite bilder Maind? :P
Postad 09 January 2006 - 10:45
Rosetwig
  • Rosetwig
  • 45 inlägg
hmm...har verkligen Maind fått plasman eller har han bara beställt en ? Jag har letat som en galning och inte sett att någon buitk har/haft den i lager.
Skynda dig nu Maind :)
Kan inte bärga mig längre... :P
//Jonas
Postad 09 January 2006 - 11:14
kevinergo
  • kevinergo
  • 185 inlägg
Det enda Maind har sagt är att han har beställt den så vi får hoppas att han återkommer när han fått den levererad. Jag skulle fortfarande vilja få bekräftat att den är HD-ready.
Postad 10 January 2006 - 23:56
Kent74
  • Kent74
  • 9 inlägg
Kamrater!
Förbaskat snyggt och prisvärt alternativ till övriga HD-ready plasmaskärmar jag har sett hittills. Nu behöver vi bara lite feedback från er som redan slagit till på denna skönhet.
Kraven för min del är enkla:
Vill ha en snygg 42" plasma med dubbla tuners och gärna HD ready. Behöver ej högtalare eftersom ljudet låter vackrare från hemmabion.
Alternativen för mig är f.n.
LG 42PM1M
Samsung PPM42M5HSX
LG RZ-42PX4RV m Väggstativ
Samsung PPM42M5S + Stand
LG RZ-42PX5R + Väggstativ
Andra alternativ någon?
//Kent
Postad 11 January 2006 - 07:17
Kurben
  • Kurben
  • 348 inlägg
Ja om du ska ha dubbla tuners så är den här 42PM1M inte alls för dig för den har inga tuners alls! Det borde ha framgått med största tydlighet.. ;-)
