Key features DV-393-S
Play back MP3 / WMA / JPEG files
Virtual Surround Sound
Playback DV-393-S
Playback Discs DVD Video/DVD-R/DVD-R DL/DVD-RW/DVD-RW DL
DVD+R/DVD+RW
SVCD/VCD
CD/CD-R/CD-RW
DVD-RW recorded in Video Recording Mode Yes
DVD-R/DVD-RW recorded in Video Mode Yes
DivX Video Playback Yes
DivX Profile Type Home Theater
JPEG Play back Yes
JPEG + MP3/WMA simultaneous Play Yes
MP3 Yes
WMA Yes
Audio Features DV-393-S
96 kHz/24-bit D/A Converter Yes
DSP Modes Rock, Pop, Live, Dance, Techno, Classic, Soft
Dynamic Range Control Yes
Virtual Surround Yes
Dialog Yes
Video Features DV-393-S
PureCinema Progressive Scan: PAL/NTSC Yes
Zoom Function Yes
Video Adjust Yes
Video Signal D/A Converter 108MHz/12-bit
Dual System (PAL/NTSC) (Video output) Yes
Conveniences DV-393-S
Advanced GUI (Graphical User Interface) Yes
Advanced Disc Navigator with moving thumbnails Yes
Resume Function (Stop Key) Yes
Continue Play Memory (Last Memory) Yes
Repeat Mode (All, Title/Chapter, A-
Programme Play Yes
Still/Step Play (Forward/Reverse, DVD Video only Yes
Slow Play (Forward/Reverse, DVD Video only Yes
Random Play Yes
10-Key Direct Search and Play (Chapter/Track) Yes
Title Search Yes
Track/Time search Yes
Remote Control Unit Yes
Auto Power-Off Yes
Terminals DV-393-S
Euro-SCART 1
RGB Video Output (on Euro-Scart) Yes
Component (Y'Pb'Pr') Yes
Video Output 1
Audio Output 1
Coaxial Digital Output 1
Digital Audio Characteristics DV-393-S
Total Harmonic Distortion 0,0023 %
Frequency Response 4 – 44.000 Hz
Signal-to-Noise Ratio 115 dB
Dynamic Range 101 dB
Miscellaneous DV-393-S
Power Requirements 220 – 240 V/ 50/60 Hz
Power Consumption 7 Watt / Standby Mode: 0.7 W
Dimensions (W x H x D) 420 x 49.5 x 214 mm
Weight 1.8 kg
Bruksanvisning 393 <-- Höger klicka och väljs "Spara mål som...."
Pioneer DV-490
Key features DV-490V-S
Plays: CD, CD-RW, DVD, DVD-RW, DivX, MP3, SVCD, WMA, VCD, JPEG
Terminals: HDMI, component, Euro-SCART, S-Video, Audio
Power consumption (in use/standby): 7W / 0.7W
Vikt: 1.7 kg
Playback DV-490V-S
DVD+R/DVD+RW
SVCD/VCD
CD/CD-R/CD-RW
JPEG Play back Yes
MP3 Yes
WMA Yes
Audio Features DV-490V-S
Dialog Yes
Video Features DV-490V-S
Zoom Function Yes
Video Adjust Yes
Conveniences DV-490V-S
Programme Play Yes
Random Play Yes
Title Search Yes
Auto Power-Off Yes
Terminals DV-490V-S
Euro-SCART 1
HDMI Video Output Yes
Video Output 1
Audio Output 1
Digital Audio Characteristics DV-490V-S
Miscellaneous DV-490V-S
Weight 1.7 kg
Bruksanvisning 490 <-- Höger klicka och väljs "Spara mål som...."
Pioneer DV-696AV
HDMI (High-Definition Multimedia Interface)
HDMI Video Upscaling (720p/1080i)
DivX Playback (3.11 / 4.x / 5.x)
Will output Dolby Digital from DivX titles
Compatible with SACD, DVD-A, DVD-Video, MP3, CD-R, CD-RW, DVD-R and DVD-RW
Built-in Dolby Digital & DTS Decoders & Virtual Dolby Surround
Burr-Brown 192kHz/24-bit DACs
x2 and x4 picture zoom (still image and full-motion)
Full DVD-RW compatibility, incl. 'VR' format
Will playback JPEG/WMA/MP3all on the same DVD-R or CD-R (can display a JPEG while playing WMA/MP3 )
NTSC 2-3 pull down I/P processing (for film contents)
Motion Adaptive I/P processing (for video contents)
I/P Simultaneous Interlaced and Progressive video output
True NTSC to PAL conversion
Video Adjustment
Sharpness / Brightness / Contrast / Gamma / Hue / Chroma Level
BNR (Block Noise Reduction / effective for MPEG1/2 and DivX bad quality sources)
108MHz / 12-bit Video DAC
Picture parameter adjustments
Includes MP3 and WMA playback for CD-R/DVD-R with on-screen navigator
JPEG Photo Viewer for DVD-R/CD-R
On screen MP3 Bit-rate Meter
1 SCART socket with RGB output
PAL & NTSC Dual PureCinema Progressive Scan Output
Virtual Surround
Dialogue Enhancer
New Disc Navigator with moving pictures
http://www.avland.co...dv696/dv696.htm £160
Redigerat av HkanW, 13 december 2006 - 10:15.
