* Officiell tråd - Arcam DV137 *
9 svar till detta ämne
Arcam DiVA DV137 (DVD-spelare) 1 8,4 (4) Inga priser
2 relaterade trådar
Postad 19 april 2006 - 16:37
Unregistereda0ef723f
  • Unregistereda0ef723f
  • 3 439 inlägg
Arcam kommer nu med en ny DVD-spelare i den prisvärda DIVA-serien. Stora nyheter denna gång är bl.a. SACD upp till 5.1 samt bildsignaler upp till 1080p.
Bifogad fil  Arcam_dv137.jpg   13,15K   0 Antal nerladdningar
Huvudspecifikationer, Arcam DV137
• true high performance universal player
• latest generation Zoran Vaddis 888s core processing engine
• DVD-Video, DVD-Audio, CD audio, SACD, DiVX playback
• motion adaptive progressive scan
• HDMI V1.1 digital video/audio output
• ABT1010 video scaler to 720p, 768p, 1080i, 1080p
• on-board video setup wizard for display calibration
• simultaneous analogue interlaced and digital progressive video outputs
• audiophile sound quality for movies and music
• Wolfson 8740 DAC´s (24-bit 192kHz) for all 6 audio channels
• Global audio delay manager, 0-150ms, for perfect lip sync with digital processors / displays
• Comprehensive bass management supported for all audio formats, including variable crossover frequencies from 50 - 150Hz in 10Hz steps, plus loudspeaker delay and level setting
• 10 bit video scaler
• No Chroma Upsampling Error (CUE)
• NTSC to PAL and PAL tp NTSC conversion
• High quality zoom function with 1.25 and 1.5 settings to fill "wrong aspect ratio" screens
• 10 x 11 bit 216 MHz Analog Devices video DACs - permitting simultaneous output of interlaced component (or RGB), S-video and composite video
• Supports DVD-Video, VCD, SVCD, DVD-R, DVD-RW, DVD+R, DVD+RW discs plus CD, HDCD, SACD, MP3, WMA, DiVX, Photo CD and JPEGs
• Universal Dolby Digital, DTS, CD-DA, plus stereo and multi-channel DVD-Audio and SACD playback
• Backlit remote (CR515)
• Mått: 430 x 340 x 85 (bredd, djup, höjd)
• Vikt: 8 kg
• Lansering: maj 2006
• Pris: Något svenskt pris har inte tillkännagivets än
Bifogad fil  Produktblad_Arcam_dv137.pdf   258,95K   121 Antal nerladdningar
Redigerat av Unregistereda0ef723f, 19 april 2006 - 18:10.
Postad 19 april 2006 - 17:22
skrotfot
  • skrotfot
  • 1 201 inlägg
Himla käckt med lipsync på en dvdspelare. Om man nu behöver sånt.
Postad 19 april 2006 - 17:28
  • 3 439 inlägg
Det som förvånade mig mest var 5.1 SACD och 1080p. 768p är ju inte helt fel för alla LCD-TV-köpare som sitter med en 1366x768-upplösning. :)
Denna DVD ser rätt fin ut tycker jag. Måtte den bara palla för trycket nu.
Postad 19 april 2006 - 18:27
Dego
  • Dego
  • 84 inlägg
En läckerbit om man kollar på spec. Vill ha! Perfekt för LCD!
Postad 20 april 2006 - 21:51
Forsyth
  • Forsyth
  • 1 649 inlägg
Jag tolkar det som att den bildvisare man tänkt använda måste stödja 1366*768 för att den upplösningen ska kunna sändas från spelaren. Det är ju tyvärr alldeles för få paneler som har det stödet inbyggt redan från fabrik :) . LG:s LCD:S ska iofs vara hyffsat enkla att modifiera....
/Micke
Postad 13 maj 2006 - 16:41
Mieron
  • Mieron
  • 918 inlägg
Den ser riktigt fin ut iaf!
Men den verkar inte bli nån billiga sak.
Denna sida nämner 1250£ vilket ger ett ca pris på 17000:-.
Blir nästan dyrare än bildvisaren så frågan är där hur många som satsar på en så pass dyr spelare när Blue-Rayspelare är på gång? Kanske går att programmera om den?
Postad 15 juni 2006 - 23:33
KenX
  • KenX
  • 39 inlägg
Runt 19000:- verkar den kosta nu. Är det någon som kommit åt att provspela den? Bild? Ljud?
Någon som sett en recension? Jag lutar nämligen åt en sån här, men osett/ohört blir det ju inget...
Postad 26 juli 2006 - 20:41
KenX
  • KenX
  • 39 inlägg
Tråden är inte kopplad till produkten/prisindexeringen verkar det som.
Fortfarande ingen som köpt denna och kan säga något om den?
Den verkar ha en hel del barnsjukdomar. Bl.a. har Arcam stängt av multi-channel SACD i senaste firmwaren (2.03) pga att den uppenbarligen låter väldigt illa. De "tror" att de kommer att fixa detta i en senare uppgradering, men lovar det inte. Antar att deras ingenjörer är förskräckligt bekymrade just nu...
Postad 16 april 2008 - 18:16
demi
  • demi
  • 176 inlägg
Jag ser att det var ett bra tag sedan denna tråden var på tapeten, men sen arcam fixat buggarna på denna spelare och priset blivit lite mer humanare så är jag inne på att handla denna spelare, det jag undrar över är
hur den hanterar brända skivor så som dvd-r och dvd-rw samt mp3 och cd-r? Bild och ljudmässigt vet jag att
den är oslagbar i prisklassen men ju dyrare och finare desto känsligare blir den, är den kräsen på vad man
matar den med?
Kom gärna med mer info som ni tycker är relevant, + eller -
Mvh demi
Postad 24 april 2008 - 08:36
Polyester
  • Polyester
Jag har aldrig haft någon skiva som krånglat med den spelaren.
Däremot så är nog inte DV137 bildmässigt "oslagbar i prisklassen", Denon 3930 har minst lika bra bild som DV137, men som CD-spelare låter Denonen som en toalettradio på steroider i jämförelse med bulkig och otäck bas.
