dvd3930.jpg 12,97K 3 Antal nerladdningar
DVD3930CI_fram.jpg 20,81K 0 Antal nerladdningar
DVD3930CI_bak.jpg 32,4K 1 Antal nerladdningar
Huvudspecifikationer, Denon DVD-3930CI
• Powered by Teranex Realta HQV processing
• 10bit operation scaling processing
• Keystone function (grymt bra för alla med projektorer som måste använda sig av keystone!)
• Adjustable Chroma Delay and Level, White/Black Levels, CCS On/Off controls
• Exclusive Denon Picture Image Correction - provides for Vertical and Horizontal pixel enhancement
• New ESS Vibrato "Chroma Bug Free" MPEG/DVD-Audio Decoder
• Sony CXD-2753 Second Generation DSD Decoder
• 1080p upscaling
• New GUI on screen graphics
• MDDF(Multi-Direction Diagonal Filter)
• DivX Playback (3.11 / 4.x / 5.x/6.0)
• DVD Video/DVD Audio/SACD Player with Dolby Digital and DTS decoder
• HDMI (High-Definition Multimedia Interface)
• Component video Out
• 'CI' for Custom Integration - for use with premium control systems
• Denon Link 3rd Edition & i.link for audio, both carry SACD and DVD-Audio
• Finest available processing for film, video, graphics or mixed-mode content
• 216 MHz, 4:4:4, 14 bit Video D/A Conversion
• 8x Oversampling Progressive and 16x Interlace output
• Wideband relay switched component video outputs
• Variable Black Level (Setup): 0 and 7.5 IRE
• Passes below-black (PLUGE) on progressive and interlace outputs
• HDMI Multi-Channel Audio Compatible, outputs with selectable 480p/720p/1080i /1080p output
• Burr-Brown 24-bit, 192-kHz DSD-1796 Audio DACs that decode PCM and DSD signals separately with no DSD to PCM conversion
• 40/60/80/100/120Hz crossover points with 12dB high and 24dB low pass slopes
• Adjustable delay time and Channel Levels
• Source Direct Mode for PCM or SACD, bypasses Bass Management Speaker Configuration, but permits Channel Level and Delay Time adjustments (No conversion of DSD signals to PCM)
• JPEG photo file viewer, Kodak Picture and Fujicolor CD compatible
• HDCD decoding
• AL24 Processing Plus for all 6 Channels
• PCM and DSD Compatible IEEE-1394 Outputs, featuring exclusive DENON Clock Synchronized System (DCSS), a proprietary and defeatable system
• Anamorphic Scaling for 4:3/16:9 Sets
• 4:3 Squeeze and Zoom Controls
• Pure Direct Modes to defeat unneeded portions of player for the ultimate in audio performance
• SRS TruSurround
• RS-232C and Remote in/out ports
• 8MB Buffer to aide better layer change
• PAL & NTSC Progressive Scan Output
• RGB SCART Socket
• Separated block construction of 3 boxes
• Electric power consumption: 60W (waiting electric power approximately 1W)
• Mått (WxHxD): 434×139×407mm
• Vikt: 11.5 kg
• Pris: ca 13998:-
Denon Japan (översatt till engelska)
Distributör i Sverige är HiFi-Klubben.
Några av nyheterna är rödmarkerade i specen. Mer info läggs till längre fram.
Edit 060805: La till CI i slutet på modellnamnet samt cirkapris
Edit 060806: Förklaring av CI samt två bilder
Redigerat av Unregistereda0ef723f, 06 augusti 2006 - 16:12.
