Panasonic TH-50PZ600 1920*1080P plasma
48 svar till detta ämne
Postad 26 August 2006 - 22:45
junkan
  • junkan
  • 5321 inlägg
Denna intressanta pjäs verkar hamna på ca 35000:- vilket är mycket intressant.
Äntligen en plasma man kanske har råd med, ingen nackdel att det är Panasonic heller ju...
Pressmeddelande
Edit:
Japanskt pris ligger just nu på 31000:-
Spec översatt till "engelska":
<< Kousei detail reproducing image! Full hi-vision panel & full hi-vision PEAKS >>
- Full hi-vision plasma panel: Total approximately 207 ten thousand pixels of approximately 2 times that of hi-vision panel (1920・1080 pixel)
- Kousei detail of hi-vision broadcast image frank reappearance
- < The visual resolution which is superior >
- It maintains high resolution even with fast animated picture the liquid crystal television (until recently LX30) with in comparison, Kousei detail it is possible to enjoy image,
- < The color reappearance which conforms to broadcast standard >
- Hi-vision broadcast standard (HDTV standard) it conforms, reproduces beautiful color faithfully
- Color is clean < considered as tilt >
- The liquid crystal television (until recently LX30) with in comparison, considered as tilt beautiful color reappearance is possible
- "High picture quality the full hi-vision PEAKS which produces image"
- Hi-vision image is reproduced to high picture quality without deteriorating with the digital processing which is consistent
- < Digital signal processing of maximum of 16 bits >
- Actualizing the gradation expression of former ratio 2 time. It can enjoy with the beautiful image where (65PX500 ratio) also delicate image overflows with rich gradation, material feeling
- < Digital color reality >
- The image data of color and brightness until recently (65PX500 ratio) at precision of 4 times digital control
- It approaches to the studio monitor, it expresses even to "texture small-scale color tone" and "the warmth of light"
- < HD ・・・・・"c・・ゃk痺・>
- MPEG noise of the digital hi-vision broadcast reception time effective in the high-level noise detection which is adapted to the scene decrease
- Being clearer, clearing it can enjoy hi-vision broadcast image
- Furthermore, loading the noise reduction circuit of the new development which decreases noise even in external input system. Clearing image was actualized with all input and the various scenes
- < Contrast management >
- While assuring the adjustment of image front and back, it controls every design, by the fact that contrast is adjusted, it improves the depth expression impression of hi-vision image more
- << Viyella link >>
- < At remote control one comfortable operation Viyella link >
- If it connects with the HDMI cable, high picture quality treble quality. Furthermore the D moth and sound set can be operated comfortably at remote control one, (only the Viyella link corresponding type)
- < The photograph of the digital camera it is large to the television indication >
- It can start projecting the photographing picture of the digital camera which is retained in the SD memory card, to the picture of television largely
- < The animated picture which was videotaped in the SD memory card (MPEG2) simplicity playback >
- The image which photographed with the SD card movie, using the Viyella SD card slot, it can play back in the large picture
- << It is easy to use simplicity convenient function >>
- Wide intelligent television program guide
- Internet "T Nabi" of television
- The Viyella operation guide (the audio guide it is attached)
- SDHC of bulk (4GB) it corresponds to the memory card
- New very easily remote control
- HDMI terminal 3 systematic equipment (as for 1080p input correspondence and 1 system the front)
- << Product specification >>
- < Image >
- Panel: Full hi-vision PEAKS panel
- Panel size: 50V type
- The number of pixels (horizontal ・ verticality): 1920・1080
- High picture quality circuit: Full hi-vision PEAKS
- 3 dimensional Y/C separated circuit
- Wide clearing vision identification
- Digital ghost reduction
- < Sound >
- Speaker system: Smart sound speaker system
- ・≪ラ・絶#潟mャ俄"泣ュモ・リャ・
- ・・b痺俄"泣ュモ・リャ・circuit
- Audio multiple (stereo)
- Speaker size: 2.3・10.0cm・2 ・・ヮ痺鞘#・ ・ 8cm・2
- Utility installed capacity (JEITA): 31W
- < Broadcast media >
- Terrestrial digital broadcast: 2 tuners
- BS digital broadcast: 2 tuners
- 110 degree CS digital broadcast left and right: 2 tuners
- Terrestrial analog broadcast: 2 tuners
- CATV pass through correspondence
- CATV reception
- < Function >
- Television program guide: Wide intelligent television program guide (terrestrial digital /BS digital /110 degree CS digital/terrestrial analog broadcast correspondence)
- VIERALink correspondence
- 2 picture functions
- SD still picture playback
- SD animated picture playback: MPEG2 playback
- T Nabi
- < Terminal group >
- HDMI terminal: 1/2 (the front/rear) (1080p input correspondence)
- I.LINK terminal: 2
- D terminal: D4・2
- Video input (the front/rear): 1/3 (the front/rear)
- S2 video input (the front/rear): 1/1 (the front/rear)
- Monitor output: 1
- S image monitor output: S2
- Optical digital voice response: 1
- Modem terminal: 1
- LAN terminal
- SD card slot
- Ir system terminal
- Family earphone
- Earphone terminal
- < Picture size >
- Breadth: 1106mm
- Height: 622mm
- Opposite angle: 1269mm
- < External size >
- Width: 1266mm
- Height: 802mm
- Depth: 95mm (largest depth 138mm)
- Mass: Approximately 48kg
- Use power source: AC100V 50/60Hz
- Electric power consumption: 598W (when waiting electric power consumption: Approximately 0.1W)
- Annual electric power consumption quantity: 509kWh/ year
- < Accessory >
- Remote control electric battery single type 3 ・2 B-CAS card antenna plug F type junction 2 dividing filter modular cable modular distributor IR cable power source cord/code AC conversion connector guarantee instruction manual operation guide B-CAS pamphlets
Redigerat av junkan, 26 August 2006 - 23:10.
Postad 26 August 2006 - 23:09
DanielP
  • DanielP
  • 222 inlägg
Pris i SWE lär hamna på 40tkr, 35 är nog en ren önskedröm när den kostar 31 i Japan.
Postad 26 August 2006 - 23:11
junkan
  • junkan
  • 5321 inlägg
Vem har sagt att man skall handla i sverige...
Jag kommer att handla i tyskland och där kommer det säkert att hamna på runt 35000:-
(pris utan skatt i Japan är 27700:-)
Officiell specifikation:
Panasonic
Redigerat av junkan, 26 August 2006 - 23:16.
Postad 26 August 2006 - 23:48
DanielP
  • DanielP
  • 222 inlägg
Det kan nog vara smart, ja :rolleyes:
Postad 27 August 2006 - 08:18
kalvbräss
  • kalvbräss
  • 454 inlägg
Kommer den i närheten av Pioneers prestanda på 5000-modellen så finns det nog stora chanser för den att bli en "marknadsvinnare" ,om prislappen hamnar på bra nivå :rolleyes:
Postad 27 August 2006 - 10:42
Prism
  • Prism
  • 856 inlägg
Grymt intressant, speciellt om den kommer att säljas till priserna som nämnts. Då åker nog mina JVC plasma ut..
Postad 27 August 2006 - 14:01
wesslan
  • wesslan
  • 1438 inlägg
3 1080p hdmi med hdcp är ju bara för mums men tror prislappen här hemma kommer hamna runt pioneers monster. Vi bor ju ändå i svindyra moms o skatt sverige.
Postad 27 August 2006 - 21:27
junkan
  • junkan
  • 5321 inlägg
Pioneer har alltid varit dyra så Panasonic ´kommer garanterat vare betydligt billigare.
Postad 27 August 2006 - 21:47
Unregistereda8f82565
  • Unregistereda8f82565
  • 660 inlägg
Hmmm... verkar dra 600W.
HS
Postad 27 August 2006 - 23:18
bigbadboogie
  • bigbadboogie
  • 819 inlägg
Lite mer info
Info, babelfisha japansk sida (förutom bildtexter)
Babelfishad japansk sida
Specifikationer från ovan länk
Mer info
Lite prel jp priser
50" för ca 43 000 i Japan låter lovande
Liten video - visst ser 50" fjuttig ut bredvid 100# aren :P
Boogieman
Redigerat av bigbadboogie, 27 August 2006 - 23:41.
Postad 28 August 2006 - 10:54
bigbadboogie
  • bigbadboogie
  • 819 inlägg
Även om plasman inte finns i Sverige ännu kanske man kan göra denna tråden officiell?
Utan tvekan en av de apparater som ser intressantast ut inför hösten/vintern.
Boogie
Postad 28 August 2006 - 16:22
junkan
  • junkan
  • 5321 inlägg
HS
Jag kan upplysa om att 600W är en toppeffekt som redovisas på alla plasma och det tar apparaten endast med en helt vit bild.
I själva verket är det faktiskt så att en plasma drar MINDRE än en LCD i samma storlek eftersom LCD:n tar samma effekt hela tiden (i stort sett), min 42" plasma varierar någonstans mellan 100W - 300W beroende på bildinnehållet.
I senaste numret av tyska Video har de testat att köra två filmer på en CRT, LCD respektive plasma och mätt energiförbrukningen:
Sin city (ganska mörk film):
CRT 32" Samsung WS-32 Z 409 T: Genomsnittlig förbrukning 114W min 74W max 250W
LCD 37" Thomson 37 LB 330 B5 : Genomsnittlig förbrukning 164W min 161W max 167W
Plasma 37" Panasoniv TH-37PV60: Genomsnittlig förbrukning 125W min 66W max 284W
Ice age (ganska ljus film):
CRT 32" Samsung WS-32 Z 409 T: Genomsnittlig förbrukning 124W min 87W max 232W
LCD 37" Thomson 37 LB 330 B5 : Genomsnittlig förbrukning 166W min 164W max 170W
Plasma 37" Panasoniv TH-37PV60: Genomsnittlig förbrukning 165W min 73W max 285W
Sä är det med den saken!
Redigerat av junkan, 28 August 2006 - 16:23.
Postad 28 August 2006 - 16:49
  • 660 inlägg
Jo, jag känner till resonemanget om förbrukning hos Plasma kontra LCD
I posten en bit upp framgick 598W som "Power Consumption" men inget om vad man menar.
Det finns också en uppgift om årlig förbrukning som väl ändå måste vara en uppskattning grundat på plasmans medelförbrukning per timme och antal timmar per dag man har den påslagen.
509 kWh ger vad jag förstår ca 2,5h per dygn om förbrukningen är de angivna 598W
...och förstås mer om förbrukningen i snitt är lägre.
PV60 har jag för mig brukar anges till 265W - och det kanske är ett snittvärde då.
Man borde enas om en enhetlig deklaration kan man ju tycka.
Ungefär som på tvättmaskiner/diskmaskiner kyl/frys.
HS
Postad 28 August 2006 - 17:12
junkan
  • junkan
  • 5321 inlägg
I mitt svar är det inget resonemang utan uppmätta VERKLIGA värden.
265W lär inte vara ett snittvärde utan det hamnar snarare på 165W.
Edit:
De hade testat att köra ett antal apparater med samma tv-kanal i 72h också och där var Panasonic TH-42PV60 med, medelförbrukningen stannade på 176W så min gissning låg ganska nära verkligheten.
Redigerat av junkan, 28 August 2006 - 17:42.
Postad 28 August 2006 - 17:15
junkan
  • junkan
  • 5321 inlägg
Boogieman
Jag körde en slags prisjakt i Japan och den säljs alltså redan för 31000:- i 50" (27700:- exkl skatter)
Postad 28 August 2006 - 17:37
norwayhustler
  • norwayhustler
  • 122 inlägg
Verkar intressant. Men med tanke på att en TH-50PV600 kostar 40 000kr i Sverige så kan man ju undra vad denna kommer kosta. Jag tippar på i alla fall 60 000kr. Blir väl att handla från tyskland om man kan få bra pris från pålitlig butik......
Postad 28 August 2006 - 17:41
Unregistered52a88696
  • Unregistered52a88696
  • 2049 inlägg
Ser helt klart MYCKET intressant ut! Tack junkan för den goda infon! Mycket uppskattat :)
Blir till att följa denna tråd med stort intresse framöver.
Postad 28 August 2006 - 21:40
andersos
  • andersos
  • 3199 inlägg
Verkligen intressant. Ser ut att bli till å välja mellan nya Sharp 1080p lcd och denna Panasonic 50". Blir alltså att väga lcd fördelar mot plasma :)
Postad 29 August 2006 - 00:35
bigbadboogie
  • bigbadboogie
  • 819 inlägg
Boogieman
Ok, jag utgick bara från de prel priser jag hittade på de siterna jag länkade till.
Det är väl gissningsvis motsvarande våra "rek priser" så att det är billigare på "japansk prisjakt" låter ju troligt.
Men det borde ju innebära att 50"aren har börjat säljas i Japan.
Jag hittade inte någon info om det och då googlade jag nog igenom ett par hundra länkar.
Tell me - jag e nyfiken...
Du tror inte du skulle kunna posta en länk till "Japanska prisjakt".
Hade varit väldigt nyttigt och intressant att ha bland bokmärkena. :)
Boogie
Redigerat av bigbadboogie, 29 August 2006 - 00:36.
Postad 29 August 2006 - 06:07
KenX
  • KenX
  • 39 inlägg
Finns det några 1080p displayer som denna som är strippade på TV-mottagare och audio?
Jag skulle väldigt gärna ha en ren display, och dessutom lite billigare då, än en fullspecad TV.
Postad 29 August 2006 - 07:39
andersos
  • andersos
  • 3199 inlägg
kakaku är lägsta priset ca. 29259kr. Vet inte om det är exkl. moms. Men lågt är det ju :)
Postad 29 August 2006 - 10:47
bigbadboogie
  • bigbadboogie
  • 819 inlägg
Ink japansk moms, men svensk tillkommer klart vid import.
BABELFISHAD LÄNK
Låter fntastiskt.
Synd att de har 110V i Japan men borde inte dessa appparater vara multinorm?
Ujuj, frakt + moms + tull till Sverige = (gissar frakt) 6000 + (moms 25%) 9000 + (tull) 1000.
Totalt ca 46 000.
Pioneer / 2 :-)
Boogieman
Redigerat av bigbadboogie, 29 August 2006 - 10:48.
Postad 29 August 2006 - 12:25
Unregistered49258b8a
  • Unregistered49258b8a
  • 94 inlägg
Jo det finns...50tummaren heter TH-50PF9. Släpps i början av oktober
Länk
Redigerat av Unregistered49258b8a, 29 August 2006 - 12:25.
Postad 30 August 2006 - 10:58
bigbadboogie
  • bigbadboogie
  • 819 inlägg
Länk
Oj, den var riktigt sexig :)
Ingen silvrig kant, bara en ren och fins svart kant.
Måste börja kika på vad den går på i JP :-)
EDIT: Hitta inga priser bara en länk till som finns här
Boogie
Redigerat av bigbadboogie, 30 August 2006 - 11:07.
Postad 30 August 2006 - 11:18
t93pan
  • t93pan
  • 1117 inlägg
[Oj, den var riktigt sexig  :)
Boogie
Enligt den länken ska det även komma nya 42-tummare i september, ngn som vet ngt om dessa?
Postad 30 August 2006 - 14:01
SonySamppa79
  • SonySamppa79
  • 1832 inlägg
Kommer den i närheten av Pioneers prestanda på 5000-modellen så finns det nog stora chanser för den att bli en "marknadsvinnare" ,om prislappen hamnar på bra nivå :)
Blir inte alla panasonic plasmor marknadsvinnare!? :)
(har pv60)
Postad 01 September 2006 - 15:53
KenX
  • KenX
  • 39 inlägg
Precis den tänker jag köpa. Fast billigt lär det ju inte bli. Urk och ve. 50tkr?
Jag skulle tro att 1080p displayerna tokrasar i slutet av året och att just den modellen ramlar ner under 30tkr. Klipp gärna in info när det finns priser på dessa i Sverige! Tack.
Länk
Oj, den var riktigt sexig :blink:
Boogie
Postad 03 September 2006 - 20:21
bigbadboogie
  • bigbadboogie
  • 819 inlägg
OFFTOPIC
Hitta ingen prodspec på 50"aren men en kort en på 103"aren så det säger väl inte så mkt men kan ge en liten hint om vad som komma skall kanske.
Helt klart är att man skall ha en 103"are på väggen får man allt ha ett rejält montage då denna best väger 215 Kg
Länk finns här
Det som är intressant är ju att den verkligen verkar klara allt när det gäller 1080 och enligt (vad jag gissar, paccis e.d. får konfirmera) gällande SMTP norm för full HDTV
1250(1080)/50i
1125(1080)/60i・50i・24p・24sF・25p・30p・60p・50p…SMTPE274M
Får hoppas detta även kommer gälla för 50-tummaren och Z600 serien som detta inläg ej handlade om.
Back on topic - jag lovar
Boogieman
Redigerat av bigbadboogie, 03 September 2006 - 20:32.
Postad 03 September 2006 - 20:29
bigbadboogie
  • bigbadboogie
  • 819 inlägg
Lite mer info Z600 serien
Boogieman
Nu verkar det komma lite estimatpriser på Z600 (som denna tråd startade och bör fortsätta med) för US marknaden i alla fall
AV Watch estimat
Estimated prices courtesy of AV Watch:
50-inch TH-50PZ600 - $5,138.30US
58-inch TH-58PZ600 - $7,279.26US
65-inch TH-65PZ600 - $8,478.20US
103-inch TH-103PZ600: $51,383.04US
Boogieman
Redigerat av bigbadboogie, 03 September 2006 - 20:33.
Postad 13 September 2006 - 19:49
junkan
  • junkan
  • 5321 inlägg
27200:- i Japan nu inklusive japansk moms.
Undrar när de börjar skeppa...
Några få japs har betygsatt delar av den nu också:
bablad sida
Postad 20 September 2006 - 18:04
Tomgot
  • Tomgot
  • 463 inlägg
Nån som vet när denna kan tänkas komma till Sverige?
Postad 27 September 2006 - 23:05
bigbadboogie
  • bigbadboogie
  • 819 inlägg
Nä nu har det varit alldeles för lite fart i denna tråden.
Är i stort sett två apparater som kommer bli intressanta närmaste månaden.
Denna är den ena och Sharps Aquos LCD 46 eller 50" som verkar har riktigt bra deinterlacer.
Dock har ju plasman ett försprång så om inte priset sticker allt för mkt mot japanska priset så kommer denna pjäs sparka rumpa när den kommer till sverige :)
Regards
Boogieman
Postad 28 September 2006 - 19:35
junkan
  • junkan
  • 5321 inlägg
Tyvärr verkar de sälja för bra i Japan... så det tar en stund innan den kommer hit.
Postad 28 September 2006 - 19:42
bigbadboogie
  • bigbadboogie
  • 819 inlägg
Jaså :)
Var har du läst det?
Kan vara bra och veta så man inte går och väntar.
Vad jag läst på amerikanska forum så har 65"aren redan kommit dit (US) men 50"aren dröjer än.
Tydligen så var det dock lite skillnader och modellbeteckningen var något ändrad.
Bla fick de ju byta powersupply från japansk till am spänning.
Attans att de inte har en switchbar supply annars hade det nästan varit lönt att ta en resa til JP, köpa en plasma o ta den under armen på planet (om den nu inte överskridit maxmåtten :()
Regards
Boogieman
Postad 30 September 2006 - 18:30
Unregisteredbaa1ce65
  • Unregisteredbaa1ce65
  • 63 inlägg
Nu har Panasonic Tyskland lagt upp TH-50PF9 på deras sida. Länk hittar ni här
Priset ska tydligen hamna på ca 4200$ utan moms.
Hoppas nu på att få se denna skönhet i Sverige före årsskiftet bara ;)
Postad 05 October 2006 - 11:37
bigbadboogie
  • bigbadboogie
  • 819 inlägg
Hoppas nu på att få se denna skönhet i Sverige före årsskiftet bara :ph34r:
Panasonic TH-50PF9
Det var $ nu så det inte var Euro?
Blir i så fall ca 31 000 ex moms
Skulle bli 39 000 ca om man räknar på 25% moms
Om detta kommer att stämma kommer Sharp få det svårt med sina nya LCD skärmare om de inte presterar OTROLIGT bra.
5000:1 i kontrast - är det statisk kontrast så kommer detta vara något i hästväg ;)
Men denna var jäkligt stilren, en ren o fin monitor precis som jag vill ha det. Ser dessutom ut att vara matt svart vilket är kalas ur reflektionssynpunkt.
6/11 skulle den börja säljas i Tyskland såg jag.
Undrar om PZ600 serien kommer till Sverige över huvud taget eller om det endast blir PF9an ovan?
Mums fillibabba
Boogieman
Redigerat av bigbadboogie, 05 October 2006 - 11:40.
Postad 05 October 2006 - 11:45
Unregisteredf64a5233
  • Unregisteredf64a5233
  • 14825 inlägg
Man kan inte räkna med att priset blir dollarpriset direkt översatt till SEK plus moms.
Priset blir i bästa fall 42.000:- + 25% moms, 52.500:-.
Förmodligen landar priset på runt 60.000:-...
Postad 05 October 2006 - 19:11
junkan
  • junkan
  • 5321 inlägg
Finns inte en chans att priset hamnar där eftersom de i så fall inte kommer att sälja ngt.
LCD i 52" med full hd kommer inom kort i stora skaror till priser runt 40000:-
Postad 05 October 2006 - 21:02
  • 14825 inlägg
Det är så vitt jag vet enbart sharp som ligger så lågt med sin 52a. Pioneeer har sin 50-tums plasma, om man ska jämföra äpplen med äpplen, runt 90.000:-. Sony kommer med sin 52X LCD runt 60.000:-. Så jag finner det inte osannlikt att Panasonic skulle lägga sig i den prisklassen.
Jag har dock ännu inte sett någon 50:ish LCD från Samsung, LG eller Philips på G inom kort...
Återstår att se om Pioneer justerar priset på sin.
Redigerat av Unregisteredf64a5233, 05 October 2006 - 21:02.
Postad 05 October 2006 - 21:29
junkan
  • junkan
  • 5321 inlägg
Sharp LC-52XD1E kostar 37000:- i Tyskland just nu
Sony KDL-52X2000 kostar 49000:- i Tyskland just men Sony ligger ju ca 20% över de andra...
Toshiba 47WLG66P kostar 24000:- !! i Tyskland just nu
Alla är FULL-HD LCD och fler är på gång, tidigare har ju plasma legat lägre i pris men nu kanske vi får se en vändning där LCD kommer att vara billigast.
Att tro att Panasonic och Pioneer då skall kunna ta 60000:- är utopi, de skulle knappt sälja en apparat, dessutom så kostar de redan nedåt 27000:- med Japansk moms i Japan...
Postad 05 October 2006 - 21:37
  • 14825 inlägg
Sharp LC-52XD1E kostar 43.000:- i Sverige just nu
Sony KDL-52X2000 kostar 55.000:- i Sverige just nu
Toshiba 47WLG66P kostar 45.000:- i Sverige just nu
60.000:- inkl moms som ett riktpris i sverige finner jag högst sannolikt för Panasonics 1080p-plasma.
Återstår att se vart den hamnar.
Självklart kan de sälja maskiner med ett pris som ligger högre än konkurrenterns diton. Dels för att det är en annan teknik, men framförallt om den uppvisar ett bättre resultat än de övriga. Sen måste de ta ut de pengarna förmodligen också, det är billigare att tillverka en 1080p LCD jämte en 1080p plasma idag.
Med din logik annars så skulle sony inte kunna sälja en enda 40-tummare i X-serien eller W-serien eftersom de är minst 10.000:- dyrare än Amoi... trots 1080p på alla... :ph34r:
Sen måste du jämföra på lika villkor, inte plocka hejvilt priser från olika länder, eller världsdelar. Vad det kostar i Japan är helt ointressant.
Redigerat av Unregisteredf64a5233, 05 October 2006 - 21:44.
Postad 05 October 2006 - 21:49
junkan
  • junkan
  • 5321 inlägg
Det är inte ointressant vad de kostar i japan för tar man det japanska priset och lägger på ca 30% hamnar man på de priserna som existerande modeller ligger på i Tyskland idag.
27000:- * 1.3 skulle alltså hamna på runt 35000:- (kolla mitt första inlägg i tråden).
För övrigt är det ju upp till var och en att betala 45000:- för en Toshiba i Sverige när man kan få en i Tyskland för 24000:-, det finns mycket kul man kan lägga 21000:- på.
(not, pioneer ligger ca 40% över Panasonics priser i Japan)
Redigerat av junkan, 05 October 2006 - 21:50.
Postad 05 October 2006 - 21:56
  • 14825 inlägg
För att återgå till kärnfrågan så handlade det om vad den landar på i sverige, inte vad man kan få den för i andra länder. :(
Not: Om Pioneer ligger 40% högre i japan så kanske detsamma gäller i sverige. 90.000:- för pion är i runda slängar 40% mer än 60.000:- för en panna...
Redigerat av Unregisteredf64a5233, 05 October 2006 - 21:57.
Postad 05 October 2006 - 22:20
junkan
  • junkan
  • 5321 inlägg
Kärnfrågan ? :( Det var väl jag som startade tråden med just prisuppgiften i Tyskland med 35000:- ? :wub:
Not Pioneer ligger på 65000:- i Tyskland
Redigerat av junkan, 05 October 2006 - 22:22.
Postad 05 October 2006 - 22:35
  • 14825 inlägg
Kärnfrågan ?    :wub:
...som jag blandade mig i på. :(
Postad 10 October 2006 - 11:44
bigbadboogie
  • bigbadboogie
  • 819 inlägg
Pion har (kan ni tänka er) droppat lite grand i pris - från 90 till 75. Undrar vad det kan bero på B)
Så om den har ett 40% premium mot panna så borde pannan hamna runt 53 (75 / 1,4).
Vi får se vad som händer helt enkelt - oavsett så kommer priserna garanterat fortsätta droppa närmaste tiden när det kommer fler och fler konkurerande produkter. Pion har haft sina sötebrödsdagar som första bra 1080p plasma men nu har konkurenterna vaknat och det vet vi vart det brukar leda :rolleyes:
Regards
Boogieman
Redigerat av bigbadboogie, 10 October 2006 - 11:54.
Postad 11 October 2006 - 23:06
  • 14825 inlägg
Redigerat av Unregisteredf64a5233, 27 October 2006 - 00:56.
Postad 27 October 2006 - 08:03
NisseT1
  • NisseT1
  • 209 inlägg
Vi kan hoppas att de hamnar i samma prisklass som 1366x768, 50" plasmorna har idag, om ett år.
Då skulle jag vara riktigt glad men det är väl bara en dröm.
Postad 01 November 2006 - 12:42
bigbadboogie
  • bigbadboogie
  • 819 inlägg
TH-65PV600 med 1920*1080 är på G nu i alla fall. Prisindikation ca 125 KKr ink moms.
Info klicka här
Eller läs lite om px-600 och pv-600 här
Om jag får tid skall jag iväg o kika på den om 1,5 vecka.
Klarar tydligen ej 1080 24p (vikken miss) men däremot 1080 50/60i samt 50/60p.
Har ej läst något om 48/72p men gissnigsvis inte det heller då.
Endast analog mottagare på PV600 medans PX600 har digital. Också lite skumt att de inte kör dubbelt upp som t.ex. LCD tillverkarna gör?
Tyvärr så är ju 50" PV600 bara 1366*768 så det ser inte ljust ut med att få en 1080p 50" Pana ifrån Sverige i år i alla fall om de inte släpper en PV700 serie innan jul kanske så folk kan få sin 50" 1080p plasma för under 50 spottstyvrar ink moms (ren gissnisg om man kikar på ovan pris och tar med 50" PV600 i jmf och kikar på LCD priser i olika storlekar).
Verkar som man får vänta till nästa år (om de inte släpper nya precis innan jul då) om man skall ha en 50" 1080p plasma i lilla Sverige (42" lär nog dröja ett tag till - 1080p på 50" är bra jobbat bara det). Får hoppas de lagt till 24/48p kompabilitet då också då många BlueRay filmer är inspelade i detta format (vill ju inte ha problem med cadence flaggor).
Japan, Usa (t.o.m. Tyskland) har ju haft de nya 1080p skärmarna ett tag nu men lilla tekniksverige verkar ligga långt ner på Pannas priolista :huh:
Boogieman
Redigerat av bigbadboogie, 01 November 2006 - 12:47.
