TOSHIBA HD-EP10, Tredje HD DVD Spelare För Europa
36 svar till detta ämne
Postad 16 March 2007 - 11:28
Über-Guru
12561 inlägg
HD-EP10 kommer under maj månad tror jag och 1080p är vad den klarar av och ligger mellan HD-E1 och HD-XE1. Lite oklarheter vad spelaren egentligen heter, men tror att det ska vara EP10. Kanske Martin skulle kunna lägga un den här i HD-E1 och HD-XE1 tråden så småningom KEY FEATURES 1080p video output Supports the playback of HD DVD, DVD, DVD-R, DVD-ROM, DVD-RW and CD formats Ethernet port supports internet connectivity for access to additional HD DVD feature content¹ Audio support for Dolby Digital™, Dolby Digital Plus™, Dolby True HD™, DTS™, DTS-HD™ and Linear PCM™ ¹ HDMI, composite, S-video and component video outputs; digital optical and 2ch analogue outputs Sleek, slim line design Notes: 1. HD DVD with high-definition content required for HD output. Viewing high-definition content and up-converting DVD content may require an HDCP capable DVI or HDMI input on your display device. Firmware update may be required for some interactive features depending on content, which may also require an always-on broadband internet connection. Some features may require additional bandwidth. Some recordable media may not be supported. Dolby Digital Plus™, Dolby TrueHD™ and DTS™ support for up to 5.1 channels (DTS HD™ support for DTS™ core only). MP3/WMA audio files not supported. Some DVDs, CDs, Combo Discs and Twin Format Discs may not be compatible. HDMI audio support for PCM only. Because HD DVD is a new format that makes use of new technologies, certain disc, digital connection and other compatibility and/or performance issues are possible. This may, in rare cases, include disc freezing while accessing certain disc features or functions, or certain parts of the disc not playing back or operating as fully intended. If you experience such issues, please contact Toshiba Customer Solutions. Some features subject to delayed availability. 1080p capable display required for 1080p output resolution. Some devices may not be compatible. HD DVD discs containing high definition content at a field rate of 50Hz or a frame rate of 25Hz cannot be played on HD-EP10 without a firmware update. Firmware update is expected in the future. Should you have any questions about the frame rate of your disc, please contact the disc vendor. While Toshiba has made every effort at the time of publication to ensure the accuracy of the information provided herein, product specifications, configurations, prices, system/component/options availability are all subject to change without notice. COMPATIBLE FORMATS HD DVD Video DVD Video DVD VR CD (CD-DA) COMPATIBLE DISCS HD DVD Video Twin format Disc (HD DVD & DVD Video) DVD-ROM (Video) DVD-R (Video) DVD-R DL (Video) DVD-RW (Video/VR) CD (CD-DA) CD-R (CD-DA) CD-RW (CD-DA) VIDEO SPECIFICATIONS Codecs: - MPEG2 - MPEG4 AVC (H.264) - VC1 HD output resolutions: - 1080p - 720p - 1080i DVD: - PAL - NTSC SD upscale to HD resolution (via HDMI): - Up to 1080p AUDIO SPECIFICATIONS Codecs: - Dolby Digital (up to 5.1ch) - Dolby Digital Plus (up to 5.1ch) - Dolby True HD (5.1ch: 48kHz&96kHz / 2ch: 192kHz) - dts (up to 5.1ch) - dts-HD (core only, up to 5.1ch) - PCM (up to 5.1ch) TERMINALS Video outputs: - Composite - S-Video - Component Audio outputs: - Analogue 2ch - Digital optical HDMI output Ethernet (10/100BASE) Extension Terminal DIMENSIONS Size (WxDxH mm) 430x345x65.5 Weight 4.1kg Manual PDFhttp://www.toshibahd...cts/hd-ep10.cfmhttp://www.areadvd.d...1P_Detail.shtml
Redigerat av Audio Code 3, 06 May 2007 - 19:16.
Postad 16 March 2007 - 16:20
Unregistered5a1b49f6
120 inlägg
Edit: verkar som det finns en tidsbegränsning på länkade översättningar genom google. Nedan är länk till översättningssidan. http://www.google.co...age_tools?hl=en
Redigerat av Unregistered5a1b49f6, 16 March 2007 - 16:59.
Postad 26 April 2007 - 09:43
Über-Guru
12561 inlägg
Pünktlich zur CeBIT präsentiert Toshiba mit dem HD-EP10 seinen dritten HD DVD-Player. Nachdem mit den Modellen HD-E1 und HD-XE1 die ersten kommerziellen Player für das hoch auflösende Bild im Markt eingeführt wurden, folgt jetzt der HD-EP10 mit einem überragenden Preis-Leistungsverhältnis. Er unterstützt die Wiedergabe von HD DVDs und bietet eine faszinierende Bildqualität. DVD-Inhalte werden zudem auf das High Definition-Format hochgerechnet. Gegenüber dem ansonsten baugleichen HD-E1 beherrscht der neue Toshiba-Spieler die Bildausgabe mit einer Auflösung von 1080p. Mit dem HD-E1 startete Toshiba Ende 2006 in ein neues DVD-Zeitalter, das Videobegeisterten die hoch auflösende HD DVD-Qualität bietet. Mit dem HD-XE1, der dank aufwändiger Video- und Audioverarbeitung mit noch besserer Bild- und Tonqualität punktet, folgte im Februar das zweite Gerät. Zur CeBIT stellt Toshiba nun einen weiteren Player vor, der erstmals in der günstigen Preisklasse die Ausgabe mit 1080p beherrscht. Durch die 1080p-Ausgabe ist der HD-EP10 auch perfekt als Zuspieler für die neuen Toshiba Full-HD LCD-TV der Serie X3030D geeignet, die diese hohe Auflösung direkt verarbeiten können. Durch Scaling oder De-Interlacing hervorgerufene Bildfehler sind damit ausgeschlossen. HD-ready-Geräte mit 720 beziehungsweise 768 Bildzeilen und 1080p-Kompatibilität können das Signal von der HD DVD direkt als Vollbild weiter verarbeiten. Der HD-EP10 unterstützt wie die bereits im Markt eingeführten Modelle die Wiedergabe von HD DVDs, DVDs und Audio CDs und beeindruckt mit einer umwerfenden Bildqualität in High Definition – die Möglichkeiten herkömmlicher DVDs werden bei weitem übertroffen. HD DVDs bieten zudem eine Vielzahl neuer und interaktiver Funktionen, die mit den herkömmlichen verfügbaren DVD-Formaten nicht vergleichbar sind. Der Toshiba HD-EP10 ist mit bestehenden DVD- und CD-Formaten abwärtskompatibel. Durch seine Upscaling-Funktion kann er sogar DVD-Inhalte zu einer Auflösung von 720p oder 1080p hochrechnen und auf HD-ready-Geräte wie LCD-TVs oder Projektoren ausgeben. Da das HD DVD-Format mit einer weit höheren Bildauflösung als die Standard-DVD arbeitet, ist die Bildqualität beispiellos – Bilddetails und –schärfe werden mit bisher unerreichter Qualität dargestellt. Der HD-EP10 gibt die Inhalte von HD DVDs sowie DVDs über seine HDMI-Schnittstelle mit Auflösungen von 720p oder 1080p aus. Alternativ bietet er einen analogen Komponentenausgang. Die Standardauflösung von 576i stellt er am S-Video- und Videoausgang bereit. Neben der verbesserten Bildqualität liegt der Fokus des neuen Toshiba-Players auf der Klangperformance. Umwerfende Ergebnisse werden durch die neuen digitalen Tonformate Dolby Digital Plus, Dolby True HD und DTS-HD gewährleistet. Diese arbeiten mit wesentlich höheren Bitund Samplingraten und bieten Surround-Sound in Studioqualität. Die neuen HD DVDs ermöglichen zudem interaktive Inhalte in einer neuen Dimension. So lassen sich beispielsweise die Kapitel eines Films oder das HD DVD-Menü aufrufen, ohne dass die Wiedergabe gestoppt wird. Je nach Film können über eine Bild-im-Bild-Option Zusatzinformationen in einem zweiten Bild eingeblendet werden. Dies sind beispielsweise Specials zum Film oder Kommentare des Regisseurs. Ein Ethernet-Anschluss ermöglicht ein Software-Update, denkbar ist aber auch ein Download von Bonusmaterial zum Film über eine DSL/Netzwerk-Verbindung. http://www.toshiba.d...ets/hd-ep10.pdf Och nu kan man åka till Tyskland och finna denna pjäs från 545 till 758 Euro.
Redigerat av Audio Code 3, 06 May 2007 - 19:17.
Postad 26 April 2007 - 10:14
Über-Guru
12561 inlägg
Några högupplösta bilder finns i länken. http://www.toshiba.d..._189_id4_2.aspx
Redigerat av Audio Code 3, 26 April 2007 - 10:15.
Postad 26 April 2007 - 10:38
mr.keyser
mr.keyser
1266 inlägg
Den där stod i en liten glaskupa på cebit.
Blev lite förvirrad av att den såg ut precis som E1:an men hette något helt annat
Får se vad den kan tänkas kosta när den dyker upp på lite bredare front. Kanske skulle uppgradera från E1:an.
Postad 26 April 2007 - 12:22
Über-Guru
22892 inlägg
Undra vad det sitter för deinterlacer i den. Och är den bra? Dels när det gäller deinterlace till 1080p men även 576i. Har A20 landat i USA? Vad säger de om den?
edit: Enl "jason_m" på Avs är sköter ABT1018 skalningen...imponerande om det stämmer (tror det är det som sitter iScan VP30 och bättre skalning än så tror jag inte man kan önska sig - förutsatt att implementationen är bra). Lite värt dock om deinterlaceingen skulle suga.
Redigerat av pacman, 26 April 2007 - 12:55.
Postad 26 April 2007 - 16:28
5366 inlägg
nackdelen är ju analog 2.0 endast om man jämför med EX-1 känner inte för att köpa ny stärkare just nu men klart fin asåå..
Postad 26 April 2007 - 18:37
Über-Guru
12561 inlägg
Optisk koppling låter inte så dumt ändå, bara man har en kompatibel förstärkare så att säga
Postad 26 April 2007 - 20:30
khalnur
khalnur
1668 inlägg
Hur står sig detta chip jämfört med det som sitter i HD-XE1?
Redigerat av khalnur, 26 April 2007 - 20:31.
Postad 27 April 2007 - 07:11
Über-Guru
22892 inlägg
<{POST_SNAPBACK}> Hur står sig detta chip jämfört med det som sitter i HD-XE1?
Jag egentligen ingen aning, men vad man "hört" (och som sagt, förutsatt att det är vettigt implementerat) så är det minst lika bra på skalning som HQV iaf. Vem/vad som sköter A20:ans deinterlace vet i fasen dock. ABT kan väl ses som en av de 3 stora high-end chip-tillverkarna tillsammans med Silicon Image (HQV) och Gennum (VXP). Arcam kör endel med ABT tex och deras DVD-spelare är ju inte kattskit. Vad jag vill se i en HDDVD (eller ännu hellre, i min display  ) är ABT2010 (sitter i VP50) som verkar ha helt sjukt bra deinterlace plus att den kirrar att omvandla 1080i60 till 1080p24... Jajja..OT.
Postad 27 April 2007 - 22:04
khalnur
khalnur
1668 inlägg
Tack för ditt svar Pacman!
Postad 29 April 2007 - 01:47
shuriken
shuriken
851 inlägg
Denna har alltså inte stöd för 5.1?
Postad 29 April 2007 - 08:34
5366 inlägg
Nopee, inte analogt iaf 2.0 endast
Redigerat av henke007, 29 April 2007 - 08:35.
Postad 29 April 2007 - 09:09
Über-Guru
12561 inlägg
Den är så mycket hi-tech att man behöver en receiver med hdmi eller optisk ingång, mao framtids anpassad kan man nog säga, men lite synd om den analoga biten, frågan återstår vad blir det svenska priset när den släpps även här?
Postad 29 April 2007 - 09:47
Max_Power
Max_Power
433 inlägg
Med optisk ingång får man inget DD+. Optisk klarar väl bara starax under 700 kbit? De flesta DD+-ljudspår ligger på 1,5 mbit.
Postad 29 April 2007 - 09:56
Rätt väg är väl att ta de nya hd-ljudformaten via hdmi v1.3 in i en receiver som klarar hdmi v1.3... analogt ? nej tack, nevvah!
Postad 29 April 2007 - 10:04
Unregistered41070
Unregistered41070
783 inlägg
<{POST_SNAPBACK}> Jag egentligen ingen aning, men vad man "hört" (och som sagt, förutsatt att det är vettigt implementerat) så är det minst lika bra på skalning som HQV iaf. Vem/vad som sköter A20:ans deinterlace vet i fasen dock.
Jajja..OT.
Går det att få ut signalen INNAN skalningen sker? Typ SDI mod eller liknande?
Postad 29 April 2007 - 10:10
Max_Power
Max_Power
433 inlägg
Man kan få de ny hd-ljudformaten som PCM-signal genom en "vanlig" hdmi-ingång på receivern.
Postad 29 April 2007 - 10:18
joakim99
joakim99
3433 inlägg
Det är inga problem att skicka 1.5 mbit till en optisk ingång. Ett vanligt DTS-spår (fullrate) är 1536 kbit och det går bra. Som jämförelse är bitströmmen från en cd-spelare på 1411 kbit och inte heller detta är ju några problem att skicka över en toslink-kabel.
Postad 29 April 2007 - 10:54
Max_Power
Max_Power
433 inlägg
Med optisk ingång får man inget DD+. Optisk klarar väl bara starax under 700 kbit? De flesta DD+-ljudspår ligger på 1,5 mbit. Det är inga problem att skicka 1.5 mbit till en optisk ingång. Ett vanligt DTS-spår (fullrate) är 1536 kbit och det går bra. Som jämförelse är bitströmmen från en cd-spelare på 1411 kbit och inte heller detta är ju några problem att skicka över en toslink-kabel.
Okej. Då är jag med.
Postad 29 April 2007 - 13:26
Über-Guru
22892 inlägg
Jajja..OT.
Innan skalning är ju inga problem, 1080 eller 576 ut beroende på om vi snackar HDDVD eller DVD. Inte innan deinterlace när det gäller HDDVD heller (skicka det som 1080i bara) men tyvärr lär väl den här spelaren, precis som så många andra, inte klara av att, via HDMI, skicka ut DVD utan deinterlace (dvs den kirrar inte 576i ut, bara 576p).
Postad 29 April 2007 - 18:45
Unregistered41070
Unregistered41070
783 inlägg
Jajja..OT.
Då borde det ju funka att skicka 576p till VP50 som får fixa resten?
Postad 30 April 2007 - 07:22
Über-Guru
22892 inlägg
Ja absolut men då använder du ju HDDVDs deinterlace, gissar att din VP50 (respekt!) är bättre, i vissa scener. Iofs så har du inget val, om det nu inte kommer en SDI-mod. Och så har ju VP50 iofs Progressive Re-Processing (dvs den tar en taskigt deinterlacead 576p signal, interlacear den till 576i och deinterlacear den sen rätt till 576p igen) men det är ju inte optimalt det heller. Men det kan ju vara värt att prova för de filmer där spelaren uppenbart inte hänger med.
Postad 30 April 2007 - 10:35
Unregistered41070
Unregistered41070
783 inlägg
<{POST_SNAPBACK}> Ja absolut men då använder du ju HDDVDs deinterlace, gissar att din VP50 (respekt!) är bättre, i vissa scener. Iofs så har du inget val, om det nu inte kommer en SDI-mod.
Ja SDI hoppas man på! Man får väll testa 1080i oxå? Fast det klart, man kanske ska vänta ett tag till innan man bestämmer sig för vilken spelare man ska välja?
Postad 06 May 2007 - 19:06
Über-Guru
12561 inlägg
Nu finns det en manual ute också: HD-EP10 manual
Redigerat av Audio Code 3, 06 May 2007 - 19:13.
Postad 06 May 2007 - 19:29
Någon som vet när den börjar säljas här ?
Postad 06 May 2007 - 19:43
Über-Guru
12561 inlägg
Om ett par veckor till ett ca pris på 7500kr  men den blir väl billigare allt eftersom hoppas man
Postad 06 May 2007 - 19:46
Über-Guru
12561 inlägg
Den har fallit ned i pris i tyskland -numera kostar den som lägst 538.50 Euro.
Postad 07 May 2007 - 22:05
Über-Guru
12561 inlägg
Ytterligare pris sänkning i tyskland till 507.42 Euro
Postad 14 May 2007 - 09:49
Postad 14 May 2007 - 16:38
"The A20 fits nicely in the Toshiba HD DVD player lineup, offering 1080p60 output, the Silicon Optix Reon chip and HDMI 1.3 without the price of the HD-XA2"
Postad 14 May 2007 - 22:37
khalnur
khalnur
1668 inlägg
<{POST_SNAPBACK}> "The A20 fits nicely in the Toshiba HD DVD player lineup, offering 1080p60 output, the Silicon Optix Reon chip and HDMI 1.3 without the price of the HD-XA2"
Tack för ditt svar! Då finns alla förutsättningar att den är lika bra som storebror på vanliga dvd.  Har du möjligen en länk till informationen?
Postad 14 May 2007 - 22:39
Info från review från engadgethd: http://www.engadgeth...-hd-a20-review/Fast nu är orden "the Silicon Optix Reon chip" överstrukna av en linje ?!?! Enligt inlägg så verkar den ej ha detta chipet...  EDIT: från avsforum: "So does the A20 have the Reon chip or not? This Engadget article states it does: No, it doesn't. It uses an ABT chip for scaling/deinterlacing. However, from all initial reports and past tests, the difference between the ABT and the SO Reon is minimal, if any. " Verkar vara ABT chip som nämnts tidigare!
Redigerat av Viggen, 14 May 2007 - 22:46.
Postad 31 May 2007 - 09:40
Über-Guru
22892 inlägg
Enl UltimateAV verkar 1080p-outputen rätt crappy. Som väntat tar spelaren 1080p-materialet på skivan och gör om det till 1080i60 (som E1). Det hade väl varit ok om deinterlaceingen till 1080p va bra, vilket den inte verkar vara. ABT finns uppenbarligen i olika smaker... Looking at the battery of test patterns I have at my disposal, I immediately saw some alarming signs. Fine horizontal 1080p luma and chroma bursts from the Spears and Munsil test disc and sections of Video and Film Resolution Loss tests on the Silicon Optix HD Benchmark on HD DVD showed artifacts. In particular, the areas with the finest horizontal luma lines were strobing, or blinking. With a video processor, this would suggest that its deinterlacing of 1080i material to 1080p is suspect. But why would this be the case with a player with a 1080p output? Simple, it clearly suggests that the HD-A20 converts the 1080p signal from the disc to 1080i, and then deinterlaces it back to 1080p incorrectly.
Going further to check this with program material, I looked at the Vatican scenes from Mission: Impossible 3, which are loaded with torturous brickwork and other fine details. Sure enough, this scene threw the A20 into veritable fits at 1080p. Obvious moiré, line twitter and other artifacts were plentiful, and some of the images were noticeably softened in detail as a result of the motion artifacts
Positivt att den lämna interlace vid DVD-playback. Bra om man har en display med bättre deinterlace än spelaren (vilken verkar vara "ok" men inte mer..knappast XA2/XE1-klass). http://www.ultimatea...ers/507tosha20/
Postad 28 October 2007 - 10:32
Unregistered1320
Unregistered1320
404 inlägg
Hur går det för denna spelare?
Har den HDMI version 1.3?
Såg att den var riktigt billig nu... ÄR den bra ? BÄttre än XE1?
Redigerat av Unregistered1320, 28 October 2007 - 10:48.
Postad 29 October 2007 - 13:53
Über-Guru
22892 inlägg
BÄttre än XE1?
Det är en lillebror till XE1 så givetvis är den inte bättre än den. Den hade tidigare crappy 1080p output (iaf enl ovan) men man undrar om inte nya 1080p24-updaten (för den gällde även E1P va?) har fixat detta - i så fall är den ju nog XE1-klass på HDDDVD sidan (minus lite HQV-filter i XE1 - om man vill använda dem). XE1 har "the edge" när det gäller DVD-playback dock.
Postad 29 October 2007 - 17:47
Unregistered1320
Unregistered1320
404 inlägg
BÄttre än XE1? Det är en lillebror till XE1 så givetvis är den inte bättre än den.
fast jag har en bra dvd spelare.(3930) Letrar en HD som har bra filmljud och 1080/24. rekomenderar ni XE iaf?
Media & Mediauppspelning
High Definition
HD DVD
XBox Halo Edition
2026-07-29 08:14:23
VM på nya AppleTV
