hdtv-kort TechnoTrend Connect S2-3600
11 svar till detta ämne
Postad 27 March 2007 - 03:25
Unregistered4085fea2
  • Unregistered4085fea2
  • 645 inlägg
En intresant manick från TechnoTrend.
HDTV receiver the size of
a cigarette pack
USB box for reception of DVB
and DVB-S2 in SDTV/HDTV
dvbshop
dvbshop Technotrend S2-USB-CI
SENASTE UPPDATERAT
Drivisar mm
Några citat ur texten från tele-satellite.com/
Even HDTV channels
in DVB-S2 can be displayed using ProgDVB, even though the software itself does not originally support DVB-S2. The TechnoTrend data application running in the background as a tuning aid makes it possible.
SDTV side by side to appreciate the enormous improvement that HDTV brings via-à-vis standard television. While SDTV reception did not bother the CPU of our P4 3.7 GHz much, situation changed for HDTV reception and the processor
rattled away in full speed. So long as no additional software was running during HDTV reception
there was an absolutely synchronous
presentation of audio and video, but as soon as the CPU had to provide some power for additional applications or for data transfer via the USB port, HDTV video got out of sync.
Redigerat av Unregistered4085fea2, 06 May 2007 - 13:10.
Postad 03 April 2007 - 10:27
Dr Cain
  • Dr Cain
  • 492 inlägg
Ingen möjlighet till CI dock, men det skall komma nån USB-modell senare från TT som har det.
Postad 06 May 2007 - 02:46
  • 645 inlägg
Ser idag att CI länken har funnits där hela tiden från Apr 3 2007 i mitt första inlägg.
Redigerat av Unregistered4085fea2, 06 May 2007 - 02:49.
Postad 06 May 2007 - 03:21
  • 645 inlägg
Technotrend USB-IR Receiver unit en programerbar fjärrkontroll
CI-Interface-PCI-and-3-5--for-Satelco-DVB-cards.
SCM-Starkey-DVB-S-USB-1-1-incl--ProgDVB-CD
:) Denna grejen (sladden med bläcket)verkar mycket intresangt och har nog många användningsområden
The Technotrend cards don't offer RGB/S-Video basically. DVBSHOP.NET made their own professional extensions now: a separate slotbracket, connected to the J2 pinout of the DVB-card, now offeres RGB-signal and/or S-Video quality.
Technotrend PCI cards and USB-Boxes
Technotrend download/download
Redigerat av Unregistered4085fea2, 14 June 2007 - 16:03.
Postad 14 June 2007 - 16:06
Magnus Thome
  • Magnus Thome
  • 1064 inlägg
Vad hamnar hela paketet på med S2-tuner ihop med CI-delen?
Postad 15 June 2007 - 21:18
PCB Support
  • PCB Support
  • Jobbar hos PCB Distribution AB
  • 34 inlägg
Enligt dvbshops sida 179 Euro plus ev frakt något under 2000SEK kanske
Den modell som nog skulle länkats är väl Technotrend S2-3650 HDTV-S2 USB+CI
Finns dock inget levdatum
Det verkar som om Floppydtv S2 hinner först.
Om det nu är nån tävling :)
Edit:
Glömde !!
Jag såg faktiskt 3650 på Cebitmässan i mars
Redigerat av PCB Support, 15 June 2007 - 21:20.
Postad 16 June 2007 - 20:05
  • 645 inlägg
Om det nu är nån tävling  :wub:
Edit:
Glömde !!
Länken finns i mitt andra inlägg nämligen detta:
BlueeAYess Postat May 6 2007, 03:46
QUOTE(Dr Cain @ Apr 3 2007, 11:27 )
Redigerat av Unregistered4085fea2, 16 June 2007 - 20:06.
Postad 16 June 2007 - 20:11
Dr Cain
  • Dr Cain
  • 492 inlägg
Om det nu är nån tävling  ;)
Edit:
Glömde !!
Jag måste varit blind... :wub:
Postad 17 June 2007 - 00:50
  • 645 inlägg
Test från tele-satellite.com/
Redigerat av Unregistered4085fea2, 17 June 2007 - 00:55.
Postad 10 August 2007 - 14:51
bbjs
  • bbjs
  • 123 inlägg
Verkar som TT-3650 S2 CI USB 2.0 nu skeppas i Tyskland, pris mellan 139-179 Euro.
Rapporterat fungerande med kodat innehåll och Sceneo frontend, dock ingen synlig CA meny.
Någon som beställt/fått/testat detta kort ?
/b
Postad 18 March 2008 - 11:14
Unregistereda33d64e8
  • Unregistereda33d64e8
  • 275 inlägg
Funderar på en sådan här till min shuttle som skall bli mediadator i sovrummet. Blir 2 st Interna S2-3200 kort till huvudburken i vardagsrummet.
Kan denna köras med newcamd för att ta emot share från mina parabolkort som sitter i usb phoenix läsare i vardagsrums HTPC'n??
Postad 19 March 2008 - 02:54
  • 645 inlägg
Hej Mascot
En mycket intressant fråga ,som jag oxå vill ha svar på.
MEN, som Tony.E säger i Lets dans.
Frågan kan vara lite no no på grund av att en del av typen Mr Rickard Rättrådig härjar här.
Kanske en lite väl svår fråga i detta forum.
MEN man vet aldrig!!!
En intresant variant på frågan
Du skulle nog ställa dina frågor på http://www.dvbnetwork.de i deras forum
Dom fixar både engelska och tyska.
S2 korten och Drembox är,som du vet Tyska grejer.
