Placering av MAs RS fx
12 svar till detta ämne
Postad 30 June 2007 - 15:50
rayDreamer
  • rayDreamer
  • 58 inlägg
Where is the best place for my surround sound speakers?
- If possible, place surround speakers to either side of the listening area, not behind it. If that's not convenient, there are a few more options further on in this section. With regards to the Height and if space permits, install surrounds 2-3 feet above viewers. This helps to minimize localization effects. Aiming surrounds straight across the room, not down at viewers, helps create a more open, spacious surround sound field. However, some specially designed speakers (Silver Sfx & Gold GRfx) do require special positioning. Sidewall mounting, while preferred for direct radiating speakers (A), is usually required for surround speakers designed to radiate to both the front and rear (Silver Sfx & Gold GRfx) (B) If rear wall mounting is the only choice, aim the speakers at each other (A), towards the front (B) or even towards the sidewalls (C, D). Experiment with placement until surround sounds seem to envelop you, rather than coming from behind you. If there are no adjacent walls, or it is just not possible, surrounds can go on stands facing each other to approximate the preferred sidewall mounting (A), or to the sides or rear of the viewing area aimed upwards. In the latter case, they can go right on the floor, or preferably, a few feet off the floor such as on end tables (B).
Av nån anledning så förstår jag inte den där texten.
Sitter och funderar på hur jag ska placera min RS fx.
Det är väl smaksak som vanligt men av texten ovan. Ska man helst placera dom riktade mot lyssningspositionen eller bakom den. Skulle jag montera dom bakom underlättar det allt och har suttit och småtestat lite nu men kommer inte fram till nån bra slutsats. Vad tycker ni är bäst? På sidan riktad mot eller bakom riktade fram mot frontarna.
Redigerat av rayDreamer, 30 June 2007 - 15:51.
Postad 30 June 2007 - 16:19
TKvC-SainT
  • TKvC-SainT
  • 1011 inlägg
Vad jag får ut av texten så är det optimala att ha dom rakt till sidorna om lyssningspositionen och ca 66 - 99 cm över huvudet. Fast att det även funkar att ha de placerade på bakväggen, antingen riktade mot frontarna, eller ha de riktade mot varandra.
Redigerat av TKvC-SainT, 30 June 2007 - 16:31.
Postad 30 June 2007 - 16:42
rayDreamer
  • rayDreamer
  • 58 inlägg
det är väl så jag förstod det som oxå. Men hängde inte med när dom refererade till högtalare A,B,C och D.
Men dom får nog placeras på väggen bakom soffan iaf. Tegelvägg på ena sidan och ingen alls på den andra sidan om soffan. Går ju med en hylla men blir knepigt.
Så får nog bli baksidan...sålänge iaf.
Postad 04 August 2007 - 00:10
Unregistered71f94406
  • Unregistered71f94406
  • 74 inlägg
väcker liv i tråden igen. Ska förmodlingen införskaffa mig RSFX högtalarna också. Dock så har jag samma funderingar kring placeringen. Ni som har RSFSX/BRFX hur har ni satt dessa i förhållande till er lyssningsposition?
Själv så måste jag sätta mina på bakväggen, riktade framåt mot frontarna. I kloss mot samma bakvägg står min soffa, så jag underar över här hur spridningseffekten av surroundljudet blir när man placerar högtalarna så?
Kan det vara vettigare att satsa på RS1:orna som bakkanaler och då ha dessa riktade direkt mot min lyssningspostion, dvs ej mot frontarna? Bakkanalerna ska endast användas för film och ingen vanlig musik i 5.1.
//rowe
Postad 04 August 2007 - 14:00
Thomas S.
  • Thomas S.
  • 990 inlägg
//rowe
Jag har BFX (i princip samma som BRFX, men modellen tidigare - samma utseende och funktion), och har placerat dem på bakväggen, ca 50-60 cm ovanför lyssningsposition. Funkar utmärkt för mig. Jag har också soffan kloss mot bakväggen i ett inte speciellt stort rum.
Ska du dessutom bara ha dem till filmtittande, så kan du lätt välja BRFX. Halva priset och lika mycket glädje av dem. Ljudet funkar bra ihop med silverserien och utseendet är samma som RSFX.
Fördelen med BRFX/RSFX är ju att du kan växla mellan bipol & dipol för att lättare välja placering. Direktriktat ljud eller mer diffust om du tvingas ha dem nära dig.
Alltså ingen anledning att välja RS1:or som surrounder, om du inte ska ha dem till 5.1 musiklyssnande. Dessutom sparar du 3k på BRFX… ;)
Thomas
Postad 05 August 2007 - 22:10
  • 74 inlägg
Ok,
Tack för inputen Thomas.
Mitt rum är dock ganska stort ca 5x6 meter (~31m2). Tyvärr så kan jag inte möblera så att jag får surrounderna / frontarna efter kortsidorna utan får sätta dessa efter långsidan, dvs 6 metersväggen.
Vad tror ni, jag har tänkt införskaffa RS6 frontarna samt centern RSLCR. Eventuellt så kommer jag att komplettera med en sub senare. Dock så är jag lite orolig för att RS6:orna är för små för mitt rum, vad tror ni?
//rowe
Postad 05 August 2007 - 22:49
Thomas S.
  • Thomas S.
  • 990 inlägg
Ok,
Ok, ditt rum är ju nästan kvadratiskt, så det spelar nog ingen större roll på vilken sida du placerar dem på. Jag har själv tvingats göra på det viset i ett mindre rum. Se skissen…
Bifogad fil  Rumsskiss.png   17K   31 Antal nerladdningar
//rowe
Tror nog att det kommer att bli strålande så fort då får upp en sub. Har själv ingen, pga för liten lägenhet. (Blir kanske en så småningom när jag flyttar…) Valde därför RS8:orna för att ändå ha gott om bas. Det blir ordentligt tryck, även fysiskt, men aldrig någon "jordbävningseffekt" som man kan få med en sub. Det är klart att 8:orna hade fyllt upp ditt rum mera, men 6:orna räcker säkert till för musiken. Men du behöver förmodligen en sub för att känna riktigt med tryck/effekter i en actionfilm.
Men annars kan jag bara råda dig att skaffa 8:orna istället för 6:orna, de ger mer "fyllighet" än 6:orna. Åtminstånde innan du skaffar en bra sub…
Vad ska du driva högtalarna med?
Thomas
Redigerat av Thomas S., 05 August 2007 - 22:53.
Postad 06 August 2007 - 01:18
  • 74 inlägg
Hej igen,
se bifogad bild över mitt vardagsrum, skratta inte, den är gjort i paint :lol:
Bifogad fil  mitt_vardagsrum.PNG   16.43K   33 Antal nerladdningar
Dom röda boxarna är dagens placering på högtalarna (Wharfdale).
Frontarna är ett par "Modus One-Six"
Centern är också den från "Modus serien"
Bakkanalerna är "Modus One". Dessa är stativare.
Ovanstående driver jag med en gammal Onkyo TX-SR600E. Jag köpte systemet i slutet på 2002 (tror jag det var) och känner nu att det är dax att uppgradera, speciellt nu när man införskaffat ny platt-tv (Pioneer PDP-508XD).
Initialt tänkte jag mig att använda den gamla 600:an, men har nu fått upp ögonen på den nya 805:an som ser ut att ha allt det jag vill, dvs hdmi-växling/uppskalning, stöd för dom nya HD-formaten samt att den verkar ha tillräckligt med pulver :)
Dock så är jag lite oroad på hur pass bra onkyon matchar MAs högtalare, har inte lyckats hitta något riktigt svar på detta. Dom flesta verkar ju rekommendera Marantz eller Denon.
/rowe
Postad 06 August 2007 - 03:41
rayDreamer
  • rayDreamer
  • 58 inlägg
Skaffa dig RS8orna, jag va inne på RS6orna först men efter jag va och lyssnade på dom blev det storebror istället. Inget snack om saken. Mer drag i ljudet på dom. Du klarar dig utan sub som Thomas säger men du kommer sakna det riktigt låga mullret. Men jag är förvånad hur djupt dom spelar ändå. Kolla på scenen med det första skeppsslaget i Master and Commander. Underbar sekvens.
Jag driver mina med en NAD t753v2 och det ljuder på väldigt bra i mina öron. Var iväg med mina föräldrar till Reference Audio och lyssnade på RS8orna på en Rotel förstärkare på 2x75w. Det lät inte alls lika bra som hemma hos mig tyckte vi. Slutade med att dom köpte Dynaudio Audience 72 SE istället.
Postad 06 August 2007 - 08:17
Thomas S.
  • Thomas S.
  • 990 inlägg
Hej igen,
se bifogad bild över mitt vardagsrum, skratta inte, den är gjort i paint :D
Initialt tänkte jag mig att använda den gamla 600:an, men har nu fått upp ögonen på den nya 805:an som ser ut att ha allt det jag vill, dvs hdmi-växling/uppskalning, stöd för dom nya HD-formaten samt att den verkar ha tillräckligt med pulver  :lol:
/rowe
Haha, ett guldrum jämfört med mitt… :lol:
Vad gäller receivern, så kommer nog 600-modellen att vara i klenaste laget för att driva dom med rättvisa, men 805:an däremot kommer säkert att bli bra. Det är som med alla högtalare egentligen, ju mer kraft - desto bättre återgivning. Men jag drev mina i början med en gammal Kenwoood prologic-receiver och det lät bra än då. Nu däremot har jag en Pio VSX-AX4ASi (som jag dessutom har biampat nu), och varje ändring har varit en förbättring. Kanske en Marantz hade varit bättre för stereoljudet, men jag känner mig rätt nöjd ändå… :)
Thomas
Postad 06 August 2007 - 22:03
  • 74 inlägg
Återigen tack för inputen!
Blir nog RS6:orna och RSFX/BRFX. Tycker dessa spelar väldigt bra och är dessutom väldigt smäckra :)
Angående att RS6:orna är lite "basfattigare" så blir det nog att införskaffa en sub för att fylla upp det som eventuellt kommer att saknas. Tyvärr så bor man ju i lägenhet, så kommer man antagligen ändå inte att kunna spela ut dessa till sin fulla rätt!
/rowe
Postad 06 August 2007 - 23:35
Thomas S.
  • Thomas S.
  • 990 inlägg
/rowe
Själv valde jag bort subben just för att jag bor i lägenhet. Jag har fått intrycket av att subben låter mer in till gannarna än vad bara fronthögtalare gör, men jag har kanske fel? Jag tror att du kommer att bli nöjd oavsett…
Thomas
Postad 05 September 2007 - 17:47
olasahl
  • olasahl
  • 757 inlägg
NYTT LIV!
Någon som vet något bra sätt för att montera surrounder RSFX/BRFX i taket snett bakom lyssningspositionen? Tänkte mig få bort alla stativ eftersom de annars hamnar mitt mellan vardagsrum och kök i min nya lya... Fungerar det ljudmässigt bra om man riktar dem snett nedåt mot lyssnaren? Någon som kan ge ett bra förslag på upphängning av dessa så man kan rikta dem en aning nedåt (30-40 grader)?
Tackar för förslag.
/Ola
