Tips, trix och FAQ
16 svar till detta ämne
Postad 22 September 2007 - 11:57
Unregistered80d04991
  • Unregistered80d04991
  • 133 inlägg
Hittade denna på ett annat forum, fick jätte mycket bra tips här och svarade på en del frågor jag hade, har kopierat och pastat här under men orginal länken är här http://thegreenbutto...ead/175657.aspx.
obs, har ändrat lite rent utseendemessigt i den, rubriker osv, har också tagit väck något svärord. Annars är den i orginalutförande.
________________________________________________
-==Tips, Trix & FAQ========================-
Video, Decoding, audio, spdif:
Divx/Xvid (and about everything else) thumbnails and playing:
http://ffdshow-tryout.sourceforge.net/
This is the only codec you need for ALL media except h.264 and mpeg2 hardware.
During installation don't touch much. During setup it will ask you about mixer settings (speakers). Tell it to leave mixer off for SPDIF(toslink/coax) or select your speaker configuration from the list (do not select mixer if you use SPDIF passthru).
SP-DIF setup:
The final screen - tell it to open Audio configuration.
Select the [Codecs] (to the left - one of the first) - at the items AC3 and DTS - change it to SPDIF for both if you wish to have divx, xvid, mkv, mpg4 etc. to stream HD-Audio it to your receiver thru SPDIF. This is only possible if you have selected your SP-dif interface as your preferred in Vista (in some hardware configurations you need to disable Speakers!)
For HD/SD Digital Audio be sure to:
Start, Control Panel, Sound, Right Click SPIDIF Interface, Properties, Advanced(tab), and then.....
UNCHECK "Allow applications to take exclusive control of this device"
This will allow you to Record HD and Watch another channel without audio stuttering
OBS!
Don't install any codec packs, Gordian, kmedia, ultimate etc....Don't!
Don't install Nero Burning Rom - it's messes about everything up (march 2007) - including ordinary thumbnails etc.
MKV AND TS With matroska
h.264 codec incl. thumbnails in vista and integration with VMC:
Download Haali Media splitter : http://haali.cs.msu....skaSplitter.exe
Just leave the defaults on in the installation screen - make sure "explorer integration" is selected - this enables thumbnails.
For TS and PS MPEG files - add the selections in the install dialog
Enabling ts and mkv files in VMC and Mediaplayer do the following:
Open notepad and paste the following in:
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\.mkv]
@="MatroskaVideo"
"PerceivedType"="video"
"Content Type"="video/x-matroska"
[HKEY_CLASSES_ROOT\.ts]
@="MatroskaVideo"
Save the file as : matroska.reg to the desktop afterwards doubleclick it and say YES to add it to the registry.
You can now see and play TS and MKV files in VMC
MKV AND TS With Matroska and CoreAVC (the best!! but not free)
Use together with ffdshow (with h.264 disabled in Video configuration)
The same as above but add the following instead:
@="CoreMedia.MKV"
@="MatroskaVideo"
Save the file as : matroskaCore.reg to the desktop afterwards doubleclick it and say YES to add it to the registry.
MPEG2 codec:
Use PowerDVD 7.2 og 7.0 - this is the best.
Open PowerDVD and go in to setup/config (the tools button) - select hardware optimized. (it'll work for some and not for others)
Close powerdvd.
Setup MediaCenter with correct mpeg2 codecs with this tool:
http://www.whittakermoore.com/VMCD.exe
Select PowerDVD7 for Video and Microsoft DD for Audio.
If your MPEG2 playback begins to behave strange/stutter etc. It sometimes helps to:
Open VMCD.exe select MS MPEG video and Audio for MediaCenter - close the application.
Open MediaCenter - select LiveTV - Close MediaCenter again.
Open VMCD.exe and select PowerDVD7 as the Video decoder again and MS DD audio.
For ATI users with Catalyst Control Center - Make sure that AVIVO settings is set to BOB (not auto/Weave etc.)
MEDIA in VISTA:
1. Adding videos to VistaMC
Place shortcuts to your content folders (mkv, avi, divx, xvid) - the shortcuts should be placed in Shared Folders -> Videos. You can name the ShortCuts anything you want.
Divx files shouldn't be named MYMOVIE.DIVX - but MYMOVIE.AVI
2. If you have a lot of "Self created" folder.jpg's for you music - make sure they are marked as hidden before adding music/pictures to your WMP library.
3. Stuck with Folders that keep appearing:
Open your Media Player - navigate to Library - select Folders (little triangle pointing down) and remove those that annoy you.
Before deleting - make sure only to delete from library not from the filesystem (Functions -> Settings -> Library -> Do not delete from filesystem when deleting).
4. Adding DVD's
Enable DVD library with this key:
HKEY_Current_user->Software->Microsoft->Windows>CurrentVersion->MediaCenter->Settings->DVDSettings->ShowGallery
Set it to Gallery (with capital G) instead of Play
Remember - one folder with folders within for each movie. Within a movie folder the folders VIDEO_TS and AUDIO_TS is placed.
Or make a .reg file as mentioned above with this:
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Media Center\Settings\DvdSettings]
"ShowGallery"="Gallery"
Add DVD's like you add music - from within WMP.
Do not blindly add folders. Make a good hierarchy with a folder structure like:
d:\DVDs\Mymovie\Video_TS
d:\DVDs\MyMovie2\Video_ts
The DVD files within the Video_ts folder should match the content of the original DVD (video_ts.bup, video_ts.vob, video_ts.ifo etc.)
If you RIP and SHRINK DVDs then make sure to rip all files not just streams.
5.
Adding media to Media Center:
Don't just add everything, folders, music etc.
Use the correct tools.
Use Media Player's library function to tell where to look for music, pictures and DVD's
6.
DVD library "more info" function.
DVD's can be looked up in a central Database if the Correct ID is placed
For correct ID's - look them up on www.dvdxml.com and save the XML file like this:
the_faculty.dvdid.xml placed within the movie folder - not in the VIDEO_TS folder.
LIVE TV Quality Trouble:
1.
Change BitRate:
First of all check the key:
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Media Center\Service\Video\Tuners\DVR] and find the KEY DefAvgBitRate
Change it to somewhere between: 20000000 and 90000000
Select DECIMAL VALUE when changing.
REMOTE DESKTOP (multi users and blank password)
1.
(THANK YOU SCUFFS!!!!)
Download this: http://mjwii.com/prog/termsrv.zip
Unzip to c:\termserv go into this folder and make a shortcut to termhack.bat (right click drag to a place and select create shortcut here)
Right-click on the shortcut and select Properties - in the "Destination" add the following:
C:\termserv\termhack.bat MULTI BLANK
Only set BLANK if on a local-private network. BLANK enables passwordless connections.
If you use a non english version of Vista:
You need to know what the Administrators group is called in your language. Edit the termhack.bat file and go to the line that says:
icacls %SystemRoot%\System32\termsrv.dll /Grant Administrators:F
And change [Administrators] to your language.
NOW:
Right-click and select "run as administrator" on the shortcut
Now create users on your VMC and connect with these - Do not connect with the one you use as the default for TV/Video in your livingroom.
Various:
1.
For editing and backup of ones channels and order they come
The file:
C:\ProgramData\Microsoft\ehome\EPG\prefs\prefs.xml
Open it with notepad.
This file holds everything about your channel, frequency, name, Virtual name etc.
It's a good thing to back this up - if you ever reinstall Vista
2.
Recording configuration is stored here:
C:\ProgramData\MicroSoft\ehome\Recording\Recordings.xml
There is a backup there - but it's nice to copy it to another place :rolleyes:
3.
Some of the following items require you to enable visibility of hidden folders and OS folders
This is done thru Control Panel -> Folder settings
If any of the above things doesn't work for you - you probably misspelled something - or you went ahead and started installing things - without cleansing your Vista.
Vista x64 is unknown and explored - try some of the stuff.
Vista 32bit all of the above works.
Remove every program you have installed, that has to do with:
Codecpacks
Nero burning.
Several MPEG2 codecs you have tried.
Make sure your Media Center works before you start - i.e. Media Center, TV, tuning etc. must work with standard Vista Codecs before you start out.
Get ALL updates from Microsoft!
I hope it helps some of you guys/girls :blink:
Postad 14 November 2007 - 09:52
Gurgel
  • Gurgel
  • 16 inlägg
Många bra tips! :blink:
Postad 15 November 2007 - 10:29
Unregistered7fb84d09
  • Unregistered7fb84d09
  • 1770 inlägg
Rekomenderar denna tråden till att bli klistrad .
Postad 16 November 2007 - 10:27
denon1
  • denon1
  • 46 inlägg
Håller med! Klistra fast!
Postad 18 November 2007 - 11:08
Unregistered707aa2d4
  • Unregistered707aa2d4
  • 133 inlägg
Det här var riktigt bra, tackar :)
Postad 19 November 2007 - 21:49
Hence Esko
  • Hence Esko
  • 128 inlägg
Klistra!
Får inte till det med matroska dock! Det har funkat till för någpn dag sedan, nu vägrar den inse att det ligger mkv filer i mappen och visar den inte i video gallery nå mer, vad kan vara fel?
Den ligger kvar under mappar att övervaka så fattar verkligen inte vad som är fel.. =(
Postad 20 November 2007 - 05:52
Unregistered70c204f0
  • Unregistered70c204f0
  • 154 inlägg
Klistra!
exakt samma för mej, det funkar tills jag startar om datorn. Jag ska testa med Core AVC och se om jag kan få bort problemet där. Annars får man väl forsätta köra dubbla spelare
Postad 20 November 2007 - 18:59
Hence Esko
  • Hence Esko
  • 128 inlägg
Klistra!
Jag kör dock med CoreAVC, problemet för mig är inte att det försvinner när jag startar om datorn, utan att jag inte får fram det alls mer!
Postad 21 November 2007 - 09:32
  • 133 inlägg
Klistra!
Se till så att det verkligen är CoreAVC som används när du kör Matroska... Det finns verktyg för detta. Testa med gspot: http://www.headbands.com/gspot/
Postad 21 November 2007 - 12:47
Hence Esko
  • Hence Esko
  • 128 inlägg
Klistra!
Tack ska genast kolla upp detta! Återkommer
Postad 21 November 2007 - 13:12
Hence Esko
  • Hence Esko
  • 128 inlägg
Nu har jag kört G spot och mycket riktigt är det ffdshow som tar hand om uppspelningen av .mkv filer.
Vet inte om någon får ut något vettigt av detta så klistrar in det iallafall:
- - Type DSH
- - Function Decoder
DSH 4CC MPEG2_VIDEO
DSH Friendly Name ffdshow Video Decoder
DSH DirectShow CLSID {04FE9017-F873-410E-871E-AB91661A4EF7}
FIL File Description DirectShow and VFW video and audio decoding/encoding/processing filter
FIL File Version 1.0.3.1316
FIL Internal Name ffdshow
FIL Legal Copyright Copyright © 2002-2005 Milan Èutka
FIL Original Filename ffdshow.ax
FIL Product Name ffdshow
FIL Product Version 1.0.3.1316
FIL Legal Trademarks GNU GPL
REG Driver File C:\Program Files\ffdshow\ffdshow.ax
REG Merit 0xff800001
Hur ska jag nu göra för att få CoreAVC att spela upp .mkv? och behöver jag göra det? För om jag startar en .mkv film med media center (högerklick->öppna med...) så fungerar allt utan problem. Enda problemet är att filmerna inte visas i video library,
Tacksam för mer svar angående detta!
Postad 29 November 2007 - 17:23
GambitSWE
  • GambitSWE
  • 32 inlägg
brukar som de flesta använda mig av så få codecs som möjligt, och aldrig under några omständigheter installera codec packs, då dessa oftast suger...massor av småprogram/codecs till olika filtyper.
när jag köpte min laptop, så kom det med media center på vista installationen, och det jag blev lite förbryllad över, var att jag ej kunde se några hdmov/mkv/mp4 filer för högupplöst material. jag blev rekomenderad av en snubbe att testa Vista Codec Package. Den fixade allt utan några som helst problem, och nu kan jag se alla filer i media center, som jag innan endast kunde se "utanför" media center. lite tråkigt att ha några hddvd filmer, och inte kunna kolla på dem genom media center.
ok, använder visserligen inte media center alls, men fuktionen vill man iaf ha...
http://shark007.testbox.dk/ - Vista Codec Package
Redigerat av GambitSWE, 29 November 2007 - 17:25.
Postad 29 November 2007 - 18:54
Unregistered64f1b668
  • Unregistered64f1b668
  • 212 inlägg
Det viktigaste jag märkte när jag installerade codecs här om dagen var att det måste göras i rätt ordning för att det ska bli rätt...
ffdshow
haali media splitter
coreavc
ac3
vsfilter
funkar prima :) Undertexter till både divx och x264 genom vsfilter i WMC :)
Fast man måste slå på att vsfilter ska autoloadas under compatibility i haali media splitter för att det ska fungera...
Postad 30 November 2007 - 12:49
Unregistered44f7d5ec
  • Unregistered44f7d5ec
  • 347 inlägg
Är det något fel att köra Vista Codec Package 4.5.4 Beta 1 ? tycker det fungerar mycket bra.
Postad 25 December 2007 - 23:23
ruva
  • ruva
  • 2789 inlägg
Eller CCCP vilket gör att man kan köra mkv-filer i både MCE och Mediaportal utan problem.
Fråga om Nero
Jag köpte Nero och installerade det. Massa problem med sporadiska omstarter osv-
Avinstallerade Nero 7 och inga problem.
Har Nero blivit ett virusprogram efter version 5?
Postad 25 December 2007 - 23:50
  • 212 inlägg
Fråga om Nero
ta och sök efter nero lite på piratviken...
Nero har verkligen blivit som norton antivirus, skitkasst... Brännarprogrammet är ju bra, men vad ska resten vara bra för?
Postad 27 December 2007 - 07:52
ChrilleBerg
  • ChrilleBerg
  • 56 inlägg
Ett tips för er som fortfarande vill köra Nero men utan allt extra krafs så kan jag rekommendera Ligth eller Micro versionerna som finns här http://updatepack.nl/.
Dessa versioner fungerar kanon, dock krävs som vanligt en licens för programmet.
/Chrille
