Modeline för VGA till SCART
16 svar till detta ämne
Postad 18 November 2007 - 15:23
Unregistered977be0c4
  • Unregistered977be0c4
  • 84 inlägg
Har nu äntligen knåpat ihop en VGA->SCART sladd, och har nu stött på patrull när jag försöker få till en modeline. Jag vet helt enkelt inte var i xorg.conf den skall skrivas, och hur man får den att börja gälla. Jag gjorde ett försök, men fick parsningsfel i Xorg.0.log. Min ursprungliga xorg.conf ser ut såhär
[codebox]
Section "Files"
Fontpath "/usr/share/fonts/X11/misc"
Fontpath "/usr/share/fonts/X11/cyrillic"
Fontpath "/usr/share/fonts/X11/100dpi/:unscaled"
Fontpath "/usr/share/fonts/X11/75dpi/:unscaled"
Fontpath "/usr/share/fonts/X11/Type1"
Fontpath "/usr/share/fonts/X11/100dpi"
Fontpath "/usr/share/fonts/X11/75dpi"
# path to defoma fonts
Fontpath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "se"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Device" "/dev/input/mice"
Option "Protocol" "ImPS/2"
Option "ZAxisMapping" "4 5"
Option "Emulate3Buttons" "true"
EndSection
Driver "wacom"
Identifier "stylus"
Option "Device" "/dev/input/wacom"
Option "Type" "stylus"
Option "ForceDevice" "ISDV4"# Tablet PC ONLY
EndSection
Driver "wacom"
Identifier "eraser"
Option "Type" "eraser"
EndSection
Driver "wacom"
Identifier "cursor"
Option "Type" "cursor"
EndSection
Section "Device"
Identifier "ATI Technologies Inc ATI Default Card"
Driver "fglrx"
Busid "PCI:1:5:0"
EndSection
Section "Monitor"
Identifier "NEC FE791SB"
Option "DPMS"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "ATI Technologies Inc ATI Default Card"
Monitor "NEC FE791SB"
Defaultdepth 24
SubSection "Display"
Depth 1
Modes "1280x1024" "1280x960" "1152x864" "1024x768" "832x624" "800x600" "720x400" "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
screen "Default Screen"
Inputdevice "Generic Keyboard"
Inputdevice "Configured Mouse"
Inputdevice "stylus" "SendCoreEvents"
Inputdevice "cursor" "SendCoreEvents"
Inputdevice "eraser" "SendCoreEvents"
EndSection
Section "DRI"
Mode 0666
EndSection
Section "Extensions"
Option "Composite" "0"
EndSection
[/codebox]
Jag skulle bli väldigt tacksam om någon vänlig själ kan peta in de ändringar som behöver göras i koden ovan efterom jag inte tyckts ha fattat rätt. Den modeline jag testade är "720x576" 15,000 720 786 834 960 576 579 582 625 interlace +hsync +vsync.
Någon här kanske rentav har en fungerande modeline till en Philips 4:3 (25PT4455)?
För övrigt tror jag att sladden fungerar för jag får se Ubuntu's boot-bild, dock väldigt flimrig och rullande.
Tack så mycket på förhand!
Postad 18 November 2007 - 19:37
ille
  • ille
  • 99 inlägg
Lägg in den i Section "Monitor"
Modeline "720x576" 15,000 720 786 834 960 576 579 582 625 interlace +hsync +vsync
Sedan lägg till "720x576" i (eller ha en som enda val)
Depth 24
EndSubSection
Redigerat av ille, 18 November 2007 - 19:38.
Postad 19 November 2007 - 21:19
  • 84 inlägg
Depth 24
EndSubSection
Det var precis det jag gjorde vid mitt första försök, men jag upprepade försöket efter ditt svar och det blir grisnit igen. Här är min xorg.conf som jag försökt köra med.
Och här är Xorg.0.log som visar vad som ännu en gång gått snett.
X Window System Version 7.2.0Release Date: 22 January 2007X Protocol Version 11, Revision 0, Release 7.2Build Operating System: Linux UbuntuCurrent Operating System: Linux HTPC 2.6.20-16-generic #2 SMP Sun Sep 23 19:50:39 UTC 2007 i686Build Date: 04 April 2007	Before reporting problems, check [url="http://wiki.x.org"]http://wiki.x.org[/url]	to make sure that you have the latest version.Module Loader presentMarkers: (--) probed, (**) from config file, (==) default setting,	(++) from command line, (!!) notice, (II) informational,	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.(==) Log file: "/var/log/Xorg.0.log", Time: Mon Nov 19 20:50:58 2007(==) Using config file: "/etc/X11/xorg.conf"Parse error on line 93 of section Monitor in file /etc/X11/xorg.conf	ModeLine Hdisplay expected(EE) Problem parsing the config file(EE) Error parsing the config fileFatal server error:no screens found(WW) xf86CloseConsole: KDSETMODE failed: Bad file descriptor(WW) xf86CloseConsole: VT_GETMODE failed: Bad file descriptor(WW) xf86OpenConsole: VT_GETSTATE failed: Bad file descriptor
Rad 93 är alltså modeline-raden. Kan någon se vad som är fel??
Postad 20 November 2007 - 22:53
  • 84 inlägg
Okej, första problemet löst. Kommatecknet i 15,000 skulle vara en punkt, vilket resulterade i parsningsfelet.
Nu är problemet ett annat. Jag får ingen bild på TV'n och jag vet inte om det är sladden som jag inte lyckats löda rätt, eller om det är modeline'en som inte är korrekt.
Under bootning får jag ca 12 st Ubuntu splash screens som flimmrar och rullar uppåt. Detta verkar tyda på att något stämmer med sladden, eller?
När jag kommer till inloggningsläget blir bilden ihoptryckt, de översta 5-7 centimetrarna blir bäcksvarta. Därunder syns en röd, en grön och en blå horisontell linje (linjerna syns även under bootning). Därunder ser bilden gråaktig ut.
Någon som kan ha en kännsla för om detta bara beror på en skruvad modelie?
Postad 22 November 2007 - 15:30
Unregistered3ba57a84
  • Unregistered3ba57a84
  • 35 inlägg
Låter som att det är problem med synken. Hur har du satt ihop sladden, vilken ritning använde du? Jag får precis som du problem med fladdrande bild innan x servern startar men sen fungerar det bra.
OM jag inte kommer ihåg fel så har jag också en Philips 4:3 tv och följande modeline fungerar utmärkt för mig:
ModeLine "test3" 15.1 720 756 828 960 576 582 588 625 +hsync +vsync interlace
Vet inte om den fungerar med ATI kort eftersom jag kör nvidia på min burk
Postad 22 November 2007 - 23:20
  • 84 inlägg
Tack för ditt svar! Jag skall testa din modeline first thing efter jobbet i morrn. Hur fick du tag på din modeline? Har du fått tag på de tekniska data på din TV som behövs för att beräkna rätt modeline? I så fall, hur fasen gick det till? Jag har letat som en dåre efter specifikationer på min TV, dock utan att hitta ett skvatt....
Jag följde guiden för sladd utan ljud på http://www.nada.kth.se/~feldt/vgascart.
Postad 23 November 2007 - 14:24
  • 35 inlägg
Jag installerade först en windows xp som jag installerade powerstrip (trial) under. Där justerade jag bilder fram och tillbaka tills jag hittade en som verkade fungera bra. Man kan få ut färdiga modeline från powerstrip vilket jag använde.
Sedan justerade jag fram och tillbaka manuellet under linux tills jag fick bilden att bli bra, kommer dock inte exakt ihåg hur jag gjorde eftersom det över två år sedan jag gjorde det.
Har ingen spec på min tv men vad jag kommer ihåg så letade jag upp lite teori på nätet om hur modeline är uppbyggt så att jag slapp ändra helt och hållet i blindo. Tror inte att det skiljer så mycket mellan olika tv om man bara hittar ett bra snitt värde. Annars skulle ju inte någon extern enhet (DVD osv) som använder RGB fungera heller.
Postad 23 November 2007 - 16:10
  • 84 inlägg
Det har du så rätt i. Det måste ju finnas någon sorts standard som PAL-kompatibla enheter använder, men jag fattar inte hur det kan vara så jäkla knussligt med detta när man kan ansluta valfir DVD-spelare till vilken jädra TV som hellst (nästan). De måste väl köra med en universal fix upplösning (både synliga och osynliga rader) och fast frekvens som funkar på alla TV-apparater....hur kan de annars "veta" att det har blivit bild på TVn? Positiv eller negativ sync kan ju inte heller vara något problem.
Hur funkar det egentligen med uppdateringsfrekvensen för den modeline man använder? Till min monitor kan jag ju välja att köra en specifik upplösning med olika uppdateringsfrekvenser. Är det så att det finns en modeline för varje valbar frekvens för en given upplösning? I så fall, hur vet X vilken frekvens jag vill köra min modeline i?
Varför är det så jäkla knussligt?
Postad 23 November 2007 - 16:30
  • 35 inlägg
Hittade en länk med teori bakom modeline http://www.epanorama...gb/timings.html.
Finns även en del information på http://en.wikipedia.org/wiki/Modeline
Inte det lättaste att sätt sig in i men kort sammanfattat så har tv'n en väldigt specifik frekvens/upplösning faktor som måste uppfyllas till nära 100%. Sen verkar det skilja mellan olika tv apparater hur förlåtande de är när faktorn inte stämmer till 100%.
Själv är jag en glad amantör utan några vidare djupa kunskaper om modeline och kan till lika stor del tillskriva slumpen att jag lyckades hitta en som fungerade för mig :D
Postad 25 November 2007 - 22:46
  • 84 inlägg
Själv är jag en glad amantör utan några vidare djupa kunskaper om modeline och kan till lika stor del tillskriva slumpen att jag lyckades hitta en som fungerade för mig :)
Tack för länkarna och att du orkar bry dig! Det uppskattas oerhört.
Jag har gjort ett litet framsteg. Jag hittade en modeline-generator på lrmc.sourceforge.net som gav mig en modeline som faktiskt gav bild, dock väldigt flimmrig och rullande. Den modeline som jag fick fram därifrån är:
"720x576" 13.875 720 744 808 888 576 586 592 625 -hsync -vsync interlace
Om jag byter tecken på hsync och vsync från + till - på din modeline ovan så ger även den en flimmrande och rullande bild (med +hsync +vsync blir bilden bara mörkgrå). Det verkar dock som att din modeline inte är helt okej för min TV för bilden blir mer ihoptryckt, och när jag byter till någon annan kanal ställer TV om sig på något lustigt sätt.
Är jag på rätt väg? Jag har inte lyckats greppa vilka ändringar jag kan göra för att komma tillrätta med att bilden flimmrar och rullar. Någon som kan ge mig lite tips och råd så jag inte behöver famla i blindo.
Postad 26 November 2007 - 11:34
Unregistered1cc1b926
  • Unregistered1cc1b926
  • 201 inlägg
jag använder följande modeline på en jvc 28 tums 4:3 tv.
"768x576" 14.774 768 784 848 944 576 581 586 626 interlace +hsync +vsync
Fungerar bra för mig. Du behöver antagligen justera den efter din tv, då "overscanen" är grym på sådana här gamla tv:ar. ;-(
Viktigt: Kom ihåg att aktivera composite extension i xorg.conf eller lägg till option "composite" till din modeline (på samma sätt som interlace).
Sen är ju hela alltihopa "halvbra" att använda till myth. "flicker filtering" fungerar ju inte när man använder vga-scart kabeln. Det innebär att bilden blir väldigt "flimrig" på själva gränssnittet. Sägs bli bättre om man har en 100Hz tv, vilket jag inte har.
/Daniel
Postad 26 November 2007 - 15:34
  • 84 inlägg
Tack för tipset! Jag kan sätta min högra arm på att composite inte är påslaget. Hoppas bara att det gör någon skillnad.
Det där med flimmer låter ju liste trist eftersom jag inte har en 100Hz-are....ja ja, får väl se hur det blir om jag får ordning på det här någon gång. Det flimmrar väl ändå inte med s-video?
To be continued....
Postad 27 November 2007 - 12:56
  • 84 inlägg
Jahapp, ingen framgång än....Börjar bli drygt det här nu.
Det gjorde ingen som hellst skilnad när jag lade till "composite" i min modeline
"720x576" 13.875 720 744 808 888 576 586 592 625 -hsync -vsync interlace composite
När jag byter mellan olika modelines jag hittat här och där ser jag för det mesta ingen skilnad, vilket känns mysko.
Eftersom bilden rullar som fasen antar jag att det har med den vertikala syncen att göra. Kan den vara så galen att bilden börjar rulla över huvud taget? Kan någon hjälpa mig med lite tips på vad jag kan skruva på för att komma frammåt? Det skulle verkligen uppskattas! Börjar bli desperat....
Tack på förhand!
Postad 28 November 2007 - 22:47
  • 35 inlägg
Har du kontrollerat att kabeln är rätt och alla signaler går fram? Det låter mer och mer som att du har något problem med själva synksignalen och inte inställningarna för den eftersom du ännu inte lyckats får något som liknar en stabil bild.
Du har ingen möjlighet att installera windows och powerstrip? Det gör det hela mycket enklare och tar bort mycket av gissandet i arbetet.
Postad 29 November 2007 - 10:27
  • 84 inlägg
Jag skall kontrollera kabeln ordentligt i helgen, och förhoppningsvis är det väl en ledare som lossnat eller nått.
Att installera XP på min Ubuntu disk är jag inte så värst sugen på (har dock planer på att köra både Ubuntu och Vista i framtiden fast det är inte läge för det nu), men om jag lyckas hitta en gammal disk någon stans kan jag ju alltid köra in XP på den och prova med Power Strip. Hur går man till väga i så fall? Jag har ju bara en VGA-utgång. Funkar det med VNC eller någon annan remote desktop lösning?
Postad 29 November 2007 - 22:50
  • 35 inlägg
Gör som du själv föreslog, försök hitta någon gammal disk att installera på.
Föreslaget på endra forum är att du ansluter kabeln till TV och sedan ansluter till datorn via VNC från en annan dator (precis som du nämner). Då slipper du en helt oläslig skärm undertiden tv'n inte en ok synk.
Tänk bara på att ställa in så nära du kan först innan du startar tv'n (på den sida där du hittade sladden finn några tips). Teoretisk sett skulle du kunna förstöra din tv genom att skicka en helt galen signal.
Om du inte får det att fungera hur du än gör så såg jag idag en hårdvarulösning på misco.se (http://www.misco.se/?420136) som kostar ca 400 kronor som är en adapeter för VGA till S-VIDEO och även till en scart kontakt. Bara som en sista utväg menar jag :unsure:
Postad 29 January 2008 - 10:14
  • 84 inlägg
Tänkte väcka liv i den här sörjan igen efter några månaders missmod. Skam den som ger sig.... :(
Jag lyckades får tag på en disk som jag körde in XP på, installerade power strip, och voilá så fick jag bild! Alltså vet jag att kabeln är okej, och jag har en fungernade modeline. När jag sedan testade i Linux var TVn lika svart som vanligt. Det som återstår är väl att konfigurera X och drivrutinen för grafikkortet, men där famlar jag i mörker precis som förut :lol: . Jag kör med en gammal drivrutin från Ati (8.34.8) och xorg.conf ser ut som i mitt första inlägg i den här tråden (förutom modeline delen, samt att composite är aktiverat längst ner i filen).
Ni som fått detta att funka: vilka drivrutiner använder ni, hur är de konfigurerade, och hur ser xorg.conf ut?
Tack på förhand!
