Sherwood Newcastle R-872
18 svar till detta ämne
Sherwood R-872 (Förstärkare) 1 8.333332 (2) Inga priser
2 relaterade trådar
Postad 14 September 2008 - 23:38
Gargantua
  • Gargantua
  • 237 inlägg
Nu har den alltså kommit sent omsider. Hoppas att den var värd att vänta på....
Sherwood R-872
Färger:
Postad bild Black
Key Features
- HD Audio Decoding for Blu-Ray & HD-DVD
DTS-HD (Master Audio / High Resolution Audio)
Dolby TrueHD
Dolby Digital Plus
- Legacy Audio Decoding
DTS-ES (Discrete /Matrix)
DTS 96 / 2 4
DTS Neo : 6 (Cinema / Music)
Dolby Digital EX
Dolby Headphone ver.2
Dolby Pro Logic IIx (Movie, Music)
Dolby Virtual Speaker ver.2 (2/3/4/5 Speaker Layout)
- Multi Channel PCM Decoding
- 10 DSP Modes (Theater, Movie, Hall1, 2 /Stadium/Church/Club 1, 2 /Game/Matrix/ 4 Stereo)
- Digital Audio Remastering for Greater Detail & Clarity
- Pure Audio (Source Direct) for the Purest Stereo Reproduction
- Digital Video Upscaling (1080p Full HD) A/V Sync
- One touch Automatic Speaker Setup Automatic Room EQ
- 192kHz/24bit D/A Converter (All Channels)
- 7.1 Channel Analog Input 7.1 Channel Preamp Output
- 4 HDMI Inputs & 1 Output (ver. 1.3)
- Video Upconversion (HDMI Analog & Composite S-Video Component)
- Advanced Multi Room Function-Dedicated Remote Controller
- OSD (On-Screen Display) from All Video Output
- Learning Remote Control with LCD
- Programmable Input Labeling for Front Panel Display and OSD
Amplifier Features
- 100Watts x 2@8?, 20Hz~20kHz, 0.08% THD in Stereo Mode
- 120W x 7 (1kHz, THD 0.7%)@8? / Only Channel
- Wide Range Amplifier Stage (10Hz~100kHz)
- Heavy-Duty Speaker Binding Post
- Assignable 2 Channel Power Amp(Surround Back L /R, Room2 or Bi-AMP)
Tuner Features
- Quartz Synthesized Digital Tuning
- 30-Station Presets (Random)
- RDS Function : PS, TA, RT, CT, etc (Europe Version)
General Features
- 4 A / V & 3 Audio Inputs
- Front Panel A / V Input (Including S-Video and Optical In)
- 3 Component Video Inputs & 1 Output (HDTV Compatible)
- Assignable 6 Digital Inputs(4 Optical & 2 Coaxial) & Digital Output (Optical)
- Color-coded Terminals Headphone Output Jack
- 12V DC Trigger Output
- IR Input and Output Jack on the Rear Panel
- Dimensions (W x H x D) : 440 x 169 x 380 mm
- Weight (Net) : 16.0 kg
Postad 15 September 2008 - 14:03
Murre R
  • Murre R
  • 115 inlägg
Vad menas med "- 120W x 7 (1kHz, THD 0.7%)@8? / Only Channel" ?
Postad 15 September 2008 - 20:06
Unregistered5b876f4b
  • Unregistered5b876f4b
  • 175 inlägg
Det undrar jag också
hoppas inte de menar att det är en kanal i drift de har mätit upp dessa värden
Har för mig att Sherwood stärkarna är strömstarka
Postad 15 September 2008 - 21:23
Gargantua
  • Gargantua
  • 237 inlägg
Ja, det var skumt. Vi får väl avvakta och se om de justerar specen framöver.
Redigerat av Gargantua, 15 September 2008 - 21:23.
Postad 19 October 2008 - 11:37
tomasgbg
  • tomasgbg
  • 1310 inlägg
Någon som köpt och kan dela med sig av lite lysnings intryck?
Verkar vara dåligt med inputs av denna maskin, inte hittat en enda recension eller test.
Redigerat av tomasgbg, 19 October 2008 - 11:41.
Postad 19 October 2008 - 16:13
Unregistered1254
  • Unregistered1254
  • 5090 inlägg
Jo, de är strömstarka. Men deras specifikationer anges alltid på ett konstigt sätt av någon anledning.
Postad 19 October 2008 - 17:13
Unregistered6c9bcd9b
  • Unregistered6c9bcd9b
  • 101 inlägg
Se min tråd angående denna pjäs! -> https://www.minhembi...s...211503&st=0
780W strömförbrukning max, relativt stöddig :)
  • Bifogad fil  R_872.JPG   102.82K   1 Antal nerladdningar
Postad 19 October 2008 - 17:53
AlexanderE
  • AlexanderE
  • 4905 inlägg
Den ser väldigt spännande ut! Det börjar ju snart bli dags att gradera upp sig till en som klarar HDMI och allt. :)
Postad 20 October 2008 - 19:50
Unregistered1254
  • Unregistered1254
  • 5090 inlägg
Mm, om det blir inköp av hembio i framtiden blir det väl troligtvis något från Sherwood-skogen. :)
Grymma grejer. Grymma grejer.
Postad 20 October 2008 - 20:01
Unregistered9d8a0d93
  • Unregistered9d8a0d93
  • 2585 inlägg
Bra är dom men syd på att dom är så ###### fula *L*
Postad 26 October 2008 - 21:05
  • 101 inlägg
Smaken = Baken :)
Själv HATAR jag h/k´s design, medan andra älskar den... :unsure:
Postad 27 October 2008 - 07:57
Turtle
  • Turtle
  • 1399 inlägg
Våga vägra H/K säger jag!
Det var det enda märket jag inte ville ha.
Postad 27 October 2008 - 13:40
Unregistered1254
  • Unregistered1254
  • 5090 inlägg
Känner faktiskt också lite så. Har dock H/K i bilen, men det får räcka så.
Har inget bra svar på varför. Magkänsla.
Postad 27 October 2008 - 20:06
Turtle
  • Turtle
  • 1399 inlägg
Jag har hatat H/K för folk som jag känner har köpt det ihop med ett par Infinity högtalare som en viss POSITIV ÅF sålde som smör i solsken.
Och det är en av dom sämsta komb jag lyssnat på.
Postad 27 October 2008 - 20:48
  • 2585 inlägg
Smaken = Baken ;)
Själv HATAR jag h/k´s design, medan andra älskar den... :)
H/K lika med plast nä inget för mig heller ..
Postad 28 October 2008 - 07:29
Turtle
  • Turtle
  • 1399 inlägg
Vad ligger den på för pris? Edit: jag hittade priset själv 8995:- Vilket pucko jag var i morse! :)
Riktigt sugen på att byta upp mig.
Edit2:Jag såg även att det är en 972 på väg också! ;)
Redigerat av Turtle, 28 October 2008 - 18:07.
Postad 28 October 2008 - 21:42
  • 101 inlägg
Vad ligger den på för pris? Edit: jag hittade priset själv 8995:- Vilket pucko jag var i morse! :(
Edit2:Jag såg även att det är en 972 på väg också! :lol:
Turtle! Var hitta du infon om R-972? :D
Postad 29 October 2008 - 08:03
Turtle
  • Turtle
  • 1399 inlägg
https://www.minhembi...s...145060&st=0
http://www.audioholi...mi-1-3-receiver
Postad 29 October 2008 - 10:29
  • 101 inlägg
Såg dem, men var står det datum? :) :(
