MP version 1.0.1 finns nu ute
20 svar till detta ämne
Postad 12 April 2009 - 21:07
Nybbe67
  • Nybbe67
  • 266 inlägg
Med många nya gosaker och fixar:
TV guide:
•Improvements concerning the speed of the TV guide
•New group button which allows switching between TV channel groups more easily
TV-Server:
•Support for analog TV cards has been improved a lot, TV experience should be much smoother now
Performance:
•Animations of default skin feel a lot snappier
•Scrolling text is displayed smoother
•Subfolder navigation is much faster in certain circumstances
•Pictures plugin is more responsive during DB additions
•Better handling of network shares
•Faster channel zapping
Better error handling:
•Users will receive an error message when video files don't play due to missing codecs
•GPU recovery in Windows Vista will no longer hang the system
•Better handling of system wake-ups from standby
Configuration:
•Configuration now remembers the removal of optical drives
•Support for the DVD Navigator of PowerDVD 8
•The previous limit of 20 shares was increased to 128
Various others:
•The Refreshrate Changer is now integrated into MP
•Recordings can now be imported even if the channel does no longer exist
•Better handling of skin changes from within the MP GUI
•Subtitles can now be enabled / disabled from the GUI
•Integrate non-linear (smart) stretching of 4:3->16:9
•Automatic start of the TVService if necessary
Postad 13 April 2009 - 11:27
JohanOscarPersson
  • JohanOscarPersson
  • 201 inlägg
Härligt att den nya versionen är ute!
Dessutom är det bara att uppdatera, alltså slippa avinstallation sen installation:
One big useability improvement is the introduction of an update feature. For the first time you will be able to update an existing MediaPortal 1.0 installation to 1.0.1 without losing any user settings.
All you have to do is to run the MediaPortal 1.0.1 installer and select "update".
Redigerat av JohanOscarPersson, 13 April 2009 - 11:29.
Postad 13 April 2009 - 11:48
Unregistered35020
  • Unregistered35020
  • 635 inlägg
Absolut! Den åkte på direkt....nåja, inte helt strulfritt, kör man med SVN-builds så åker man på en hel nyinstallation.
Ap-MF-svindrygt, man lär ju undra om gänget bakom MP gör sådana saker med flit och sitter på kammaren och garvar sig harmynta.
...bara att ge fasen i SVN hädanefter, nu har man lärt sig det.
/J
Postad 13 April 2009 - 12:47
dhanjel
  • dhanjel
  • 2495 inlägg
Ja man måste lägga teknik-nörderiet lite åt sidan och undvika svn-byggena, både för sin egen skull och för WAF ;)
Postad 14 April 2009 - 10:35
Unregistered65a0fb25
  • Unregistered65a0fb25
  • 319 inlägg
Visst, men efter realese 1.0.0 var man ju så illa tvungen att lägga på SVN efterosm den faktiskt hade en hel del allbvarliga buggar kvar. Jag tycker verkligen att teamet bakom MP saknar en hel del i sitt release-tänk jämfört med konkurrerande alternativ. jobbar som bäst med att omvandla min windowsbaserade Mediaportal till Ubuntubaserad XBMC. Stabiliteten är en helt annan...
Postad 14 April 2009 - 12:15
Unregisteredc6f44378
  • Unregisteredc6f44378
  • 1229 inlägg
Vore grymt om det fanns en ForTheRecord-klient till XBMC. Då skulle nog jag byta med. Men inte dessförrinnan ;)
Postad 14 April 2009 - 16:03
Unregistered35020
  • Unregistered35020
  • 635 inlägg
...exakt...
Men för varje förbättring de gör, så nog f*n lyckas de smyga in ett par nya "features" - nu går gränssnittet betydligt raskare (det gjorde det redan i senaste SVN-builden), men nu kan man inte scrolla runt i epg:n, den stannar vid sista kanalen...GAAAAAAAAAAAAAAAAAAAH, i nyss nämnda SVN-build så hamnade man på kanalikonen på 1:an när man snurrat ett varv - sådana detaljer driver ned WAF i botten kan jag lova.
Sjukt bra grejer är det - men hur svårt kan det vara?
Jag har klurat på linux mer än en gång, och sparkat fart på ett par kubuntuvarianter på diverse bärbara, men inte kommit längre än så, det fungerar för bra hemma för att man skall orka ta tag i't.
/J
Postad 14 April 2009 - 21:01
RedEnzo
  • RedEnzo
  • 218 inlägg
Har en fråga, är en ganska flitig texttv användare och tidigare så har ju inte texttv fungerat jätte bra i MP men jag läste att den skulle bli bättre i denna version. Installerade denna precis och till min förvåning har de ju blivit katastrof, allt man får nu är en liten plutt ruta i mitten av bilden. Är de fler än jag som har detta problem?
Postad 14 April 2009 - 21:25
tyve
  • tyve
  • 1618 inlägg
Det var konstigt. Den ser bra ut för mig. Vad kör du med för skin? Om du inte använder original Blue så prova det.
Postad 15 April 2009 - 17:33
RedEnzo
  • RedEnzo
  • 218 inlägg
Du hade rätt, var skinet som spökade. Använde Xface men när jag bytte till blue fungerade den son vanligt. Undrar bara om dom kan fixa så texttv fyller hela bilde dvs 16:9?
Postad 15 April 2009 - 19:03
tyve
  • tyve
  • 1618 inlägg
Fast det finns det väl ingen poäng med? Det blir bara längre rader som blir svårare att läsa. Bättre de fixar split screen så man kan kolla på text-tv på ena halvan och TV på andra.
Postad 16 April 2009 - 15:07
Unregisteredc96d6be8
  • Unregisteredc96d6be8
  • 7392 inlägg
Finns det något snabbt ställe att ladda mediaportal från, laddar via länken på deras hemsida och ligger på 4-6kb/s tar ju en evighet då :D
Postad 16 April 2009 - 15:56
Unregistered35020
  • Unregistered35020
  • 635 inlägg
Eh...för mig går det raskt som fasen?
/J
Postad 16 April 2009 - 17:34
  • 7392 inlägg
/J
Fick ner hela, men det tog nästan 2h :) och det lär inte vara anslutningen, för jag ladda hem en nästan identisk fil innan från ett annat ställ och det tog ca 3min :D
Postad 16 April 2009 - 20:31
Unregistered735fb370
  • Unregistered735fb370
  • 380 inlägg
Skumt, jag svarade på den här tråden innan, men nu är mitt inlägg borta?
I alla fall, jag installerade MP 1.01 tidigare ikväll. Wow, vilket lyft! GIU:t flyter 100 gånger bättre, och kanalväxlingen är rejält uppsnabbad. Skönt också att refresh rate changer har blivit integrerad, det var guld värt!
MP är riktigt fint nu!
Postad 16 April 2009 - 21:22
JohanOscarPersson
  • JohanOscarPersson
  • 201 inlägg
Riktigt gott att höra, jag måste helt enkelt testa det imorgon eller möjligtvis ikväll :D
Postad 18 April 2009 - 18:49
Unregistered998cf521
  • Unregistered998cf521
  • 178 inlägg
Är det någon som har fått smart stretch att funka?
Postad 18 April 2009 - 19:30
  • 380 inlägg
Vad innebär det?
Postad 19 April 2009 - 21:00
  • 178 inlägg
Vad innebär det?
4/3 --> 16/9 utan att alla är breda som elefanter. Jag tror jag problemet är löst. I osd:n visas pan and scan, då smart stretch är valt i inställningarna
Postad 19 April 2009 - 21:03
  • 380 inlägg
Men det måste ändå innebära att en del av bildytan skärs bort eller? I över- och underkant? För funktionen är väl inte så smart att den interpolerar fram all information i sidofälten? :)
Postad 20 April 2009 - 09:31
  • 1229 inlägg
Nej. Det är bara en "breddning" av en 4:3-bild, inget behöver beskäras. Skillnaden mot en vanlig breddning är att på mitten av bilden sker ingen omskalning och desto mer omskalning sker vid kanterna, detta för att det som är i fokus på bilden ska se normalt ut men den ändå ska täcka hela bildytan.
Jag tycker personligen att både den och linjär stretch är skitfult ;)
För övrigt, installerade om HTPCn från scratch och uppdaterade till MP 1.01. Fan vad snappy allt är nu, och än så länge inga stabilitetsproblem öht. ForTheRecord 1.3.3 sköter sig jättebra med, och kunde importera mina gamla inspelningar rakt av.
Tog aslång tid att göra allt, men nu verkar det fungera bättre än någonsin (tog även bort en hårddisk ur HTPCn, en sunkig 250-giggare, någon som vill köpa? Det är alltså inget fel på den, men jag ville banta datorn :))
