Dreambox DM500HD
156 svar till detta ämne
Postad 19 February 2010 - 20:43
Unregistered1669805e
  • Unregistered1669805e
  • 37 inlägg
Startar en ny tråd för den nya dreamboxmottagaren DM500HD.
Vet ej när den lanseras i sverige.
Bifogad fil  dreamboxdm500hd.jpg   138.03K   34 Antal nerladdningar
Bifogad fil  dreamboxenuebersichtOE23G.jpg   143.26K   41 Antal nerladdningar
Powerful receiver for digital TV and Radio programs.
Main features are a 400 MHz processor, the Dreambox DM 500 HD supports the Linux TV API
Have a look to HighDefinition TV on your Dreambox
•10/100MBit compatible Ethernet Interface
•HDMI connector
•eSATA
Technical Features
• 400 MHz MIPS Processor
• Linux Operating System
• 2 LED status
• MPEG-2 / H.264 Hardware decoding
• Tuner: DVB-S2
• 1 x Smartcard-Reader (Dreamcrypt CA)
• eSATA connector
• Mini USB for Service and software update
• 10/100Mbit Ethernet Interface
• 1 x Scart (RGB, FBAS, YUV or S-Video)
• HDMI
• analog modem
• S/PDIF Interface for digital bit stream out (AC-3)
• 64 MByte Flash, 256 MByte RAM
• unlimited channel lists for TV/Radio
• channel-change time < 1 second
• automatic service scan
• directly bouquet-lists
• EPG (electronic program guide)
• multiple LNB-Switching control (supports DiSEqC)
• OSD in many languages and skin-support
• Videotext Decoder
• external 12V power supply
DreamBox DM 500 HD technical data
DBS-Tuner, DVB-S2:
Frequency Range 950 .... 2150 MHz
Demodulation DVB-S (QPSK); DVB-S2 (8PSK,QPSK)
Symbol rate DVB-S: 2 ... 45 Mbaud/s, SCPC/ MCPC
DVB-S2: 10 – 31 Mbaud/s (8PSK) , 10 –30 Mbaud/s (QPSK)
Video decoder:
Video Compression MPEG-2 and MPEG-1 compatible, H.246
Video Formats 4:3 / 16:9
Letterbox for 4:3 TV-Device
Audio decoder:
Audiokompression MPEG-1 & MPEG-2 Layer I and II, MP3
Audio Mode Dual (main/sub), Stereo
Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz
Output analog:
Output Level L/R 0,5 Vss on 600 Ohm
THD > 60 dB (1 kHz)
Crosstalk < -65 dB
Output digital:
Output Level 0,5 Vss on 75 Ohm
Sampled Data Filtering 32 kHz, 44.1 kHz, 48 kHz
S/PDIF-Output optical, Toslink
Ausgang Video:
Ausgangspegel FBAS 1 Vss +/- 0.3 dB an 75 Ohm
Video parameter:
Input Level FBAS 1 Vss +/- 0.3 dB on 75 Ohm
Teletext filter in conformity with ETS 300 472 Standard
TV-Scart:
Output: FBAS, YUV, RGB, S-Video
MiniUSB service connector
Function: Firmware update
Ethernet:
10/100 MBit compatible interface
Analoge modem:
analoge modem for Internet connection
LNB power and polarisation per tuner:
LNB Current 500mA max.; short-circuit-protected
LNB Voltage vertical < 14V no load, > 11,5V at 400mA
LNB Voltage horizontal < 20V no load, > 17,3V at 400mA
Count of active satellite position:
DiSEqC 1.0/1.1/1.2 and USALS - Rotor Control
Power consumption:
< 12W at 12V in operation
< 1W in standby
External PSU
Input:
110-240V AC / 50-60Hz / 0,6A
Output:
12V = / 3,0A
Physical specification:
Ambient Temperature +15°C...+35°C
Humidity < 80%
Size (W x D x H): 195 mm x 130 mm x 40 mm
Weight: 0,7 kg
Redigerat av Unregistered1669805e, 19 February 2010 - 21:07.
Postad 20 February 2010 - 00:54
citronjuicez
  • citronjuicez
  • 12 inlägg
Man bör avvakta ett par månader innan man köper den, med tanke på alla buggar DM 800 hade när den kom ut.
Man bör avvakta minst ett par månader innan köp med tanke på alla buggar Dm 800 hade när den kom ut.
Postad 20 February 2010 - 00:58
Leatherface
  • Leatherface
  • 7299 inlägg
Alla produkter kan ha barnsjukdomar i början men det har varit mjukvaran till stor del som varit problemet och mjukvaran är samma som den i DM800.
Redigerat av Leatherface, 20 February 2010 - 00:59.
Postad 20 February 2010 - 09:27
somoene2
  • somoene2
  • 1991 inlägg
köpte mig en DM800 bland dom första som kom till sverige. Bild/ljud funkade utan problem.
jag hade ljusblå text i ett par veckor innan det var fixat och boxen funkade bättre en vilken annan HD mottagare som helst. Tror inte denna kommer vara sämre!
ser helt klart intressant ut :(
Postad 20 February 2010 - 09:37
MartinG
  • MartinG
  • 177 inlägg
Fick en liten flashback här och sökte lite. Detta sade du om DM800 när den var på G :(
eftersom det är samma mjukvara i dm800/dm8000 som i dm7025 så kommer den ha fullt fungerande mjukvara med allt man behöver från start...
Nog är det så att vill man vara säker på en fullt fungerande och stabil Dreambox från den dag man köper den gör man bäst i att invänta andras rapporter och första bugfixarna, men jag tror också den blir stabil snabbt.
Ska bli intressant om det verkligen är så att det bara är USB->Serieport och om DM sabbat så inte processorns kapacitet kan utnyttjas för divx etc (ryktas lite om det).
Attans synd inte den har plats för minneskort, usb-sticka bara.
Priset verkar också bli högre än de 299 euro som DM tidigare sagt.
/Martin
Redigerat av MartinG, 20 February 2010 - 09:38.
Postad 20 February 2010 - 20:09
bpl
  • bpl
  • 858 inlägg
Mums filibabba...
Inte en chans att det finns större buggar i denna mottagare då mjukjaran har funnits i nästan 2 år i DM800 och DM8000...
Postad 20 February 2010 - 21:17
Leatherface
  • Leatherface
  • 7299 inlägg
Själva gränsnittet (enigma2) har ju varit fungerande länge även om vissa saker kan förbättras.
Problemen med dm800 i början var väl till stor del att tuners blev för varm och det löstes i senare secondstage loaders.
Rekomenderade priset är satt till 339€ men euron har sjunkit en hel del på sistone och tror den kan ta sig nereåt 9:- igen snart och då kostar boxen under 3000:- om man beställer från Tyskland åtminstone.
I Sverige får man nog räkna med ett påslag på runt 500:- som vanligt.
BCM7405 chipet som sitter i DM500HD klarar divx/xvid precis som BCM7400 chipet i DM8000.
Redigerat av Leatherface, 20 February 2010 - 21:25.
Postad 21 February 2010 - 13:30
MartinG
  • MartinG
  • 177 inlägg
Japp, men på tyska (vanligtvis initierade) forum har det spekulerats i att inte divx etc skulle funka då 500hd i så fall slår undan benen för 800hd. Kör du extern hd/nas är ju 500hd ett bättre och billigare alternativ. Fördelarna jämfört med 800 (snabbare och bättre CPU) borde överväga nackdelarna (ingen USB eller möjlighet till inbyggd disk). Eller är det så att swapfil är ett krav på en 800 körandes Enigma2 med lite plugins?
Lite fult att höja priset vid release, de har tidigare sagt (inte på hemsidan men väl i mail) att riktpriset blir 299 euro.
Sitter fortfarande med min gamla 7020S så 500HD är ett alternativ. Har ingen plattTV/HD-tv ännu så jag sitter inte i sjön (kollar HD på datorn via DVB-S2). Priserna för 800-kloner är nu nere på 2000 i Sverige, ska bli intressant vad 500HD-klonen hamnar på :/
/Martin
Postad 21 February 2010 - 18:30
Leatherface
  • Leatherface
  • 7299 inlägg
swapfil är inget krav på dm800 utan det gäller bara dm7025 med mycke saker installerad och exprimentella enigma2 images för enigma1 boxar.
Men det går ha swapfil över nätverk också men är väl kanske inte det mest stabila.
Funkar inte divx/xvid så är det isf driver problem som säkert fixas till så småningom.
Redigerat av Leatherface, 21 February 2010 - 18:34.
Postad 22 February 2010 - 16:59
badpojken
  • badpojken
  • 108 inlägg
Låter som en intressant box. Har testat AB-Com IPBOX 900HD en del, och de har väl inte direkt den mest stabila mjukvaran. Man kanske ska införskaffa sig en DM500 HD helt enkelt, DM 500S har ju varit riktigt stabil.
Postad 22 February 2010 - 20:17
Leatherface
  • Leatherface
  • 7299 inlägg
DM500 är stabil med rätt mjukvara i boxen (orginal åtminstone).
Har man köpt en dom senaste åren så har man mest troligt en klon då orginalen slutade tillverkas för flera år sen.
Men DM500 HD är en helt annan box och mycket bättre.
Redigerat av Leatherface, 22 February 2010 - 20:18.
Postad 22 February 2010 - 22:00
Unregisteredcab460d8
  • Unregisteredcab460d8
  • 701 inlägg
Kommer det funka att köra Viasat på denna box, inklusive HD kanalerna?
Postad 22 February 2010 - 22:19
MartinG
  • MartinG
  • 177 inlägg
Inte HD, iaf inte i nuläget. Och hur det blir med SD i framtiden vet ingen.
Postad 25 February 2010 - 19:29
Brando70
  • Brando70
  • 651 inlägg
Dreambox DM-500HD är utan tvekan BÄTTRE än Dreambox 800HD!
Dreambox DM-500HD har snabbare processor som ligger på 400 MHz och denna processor gör Dreambox DM-500HD till en STABIL HD-box som har god framtid och stöd. Själv kommer jag inte att vänta flera månader utan beställer den via nätet från Tyskland så fort det går. Och jag ser fram emot att få titta en hel del nya Europeiska HD-kanaler via min parabollantenn. Hoppas bara att det blir original modell. Jag vill inte ha nån kopia Dreambox från Kina!
Postad 01 March 2010 - 23:38
Unregistered84e84fab
  • Unregistered84e84fab
Någon som har tips på var i tyskland man ska köpa 500 hd så man inte blir blåst på en kina kopia ?
och till rätt pris :)
Postad 02 March 2010 - 00:31
ImpreZa
  • ImpreZa
  • 167 inlägg
Såg att vissa svenska sidor har den till förhandsbokning. 3995:- ligger de runt. Inte riktigt det priset man hade väntat sig, lite för dyrt.
Postad 02 March 2010 - 00:38
Unregistered1103
  • Unregistered1103
  • 5967 inlägg
Det är 1000 spänn förmycket
Med tanke på att man kan ha HDD i HD800 och det enda som skiljer
är några komponenter som man till största sannolikhet inte kommer
att märka av skillnaden på mellan 500 och 800 vid normalt användande
Maveric
Postad 02 March 2010 - 00:44
Unregistered1103
  • Unregistered1103
  • 5967 inlägg
https://www.dream-mu...i...lue=&title=
Postad 02 March 2010 - 01:01
Leatherface
  • Leatherface
  • 7299 inlägg
DM500 HD har snabbare processor och klarar divx/xvid bla.
Men ni får den nästan en tusenlapp billigare från visssa ställen i Europa.
Postad 22 March 2010 - 15:05
Unregistered7beef5b5
  • Unregistered7beef5b5
  • 135 inlägg
hej
Nån som köpt den och kan ge ett utlåtande?
Vilken image kör ni?... finns kanske bara Pli
Har Lt image nån på gång till 500HD
Var i tyskland kan ni rekomendar att att handla ifrån.
Postad 18 April 2010 - 18:20
kalle23456
  • kalle23456
  • 315 inlägg
Har en vanlig 500s box, tror det är en klon.
Börjat tröttna på den usla bilden alla omstarter och den
värdelösa fjärren som kräver att man trycker stenhårt
för att få den att reagera.
Har funderat på en 800HD box men ser nu att det kommit en ny 500HD box som är billigare.
500HD har ju snabbare CPU och är 2 år nyare så det borde väl vara ett bättre val
om den nu inte håller samma låga kvalitet som min nuvarande 500s box.
Jag tror iallafall att jag får bättre bild både vad gäller HD och vanlig upplösning med nya 500HD boxen.
Eller skall man ändå satsa på en 800HD box?
Redigerat av kalle23456, 18 April 2010 - 18:20.
Postad 18 April 2010 - 18:58
Leatherface
  • Leatherface
  • 7299 inlägg
Om du ska ha DM800HD så vänta på den nya versionen isf
http://www.dream-mul...-new-hdtv-boxes
Postad 30 April 2010 - 12:11
fashion85
  • fashion85
  • 26 inlägg
Någon som köpt denna och kan ge ett utlåtande?
Postad 30 April 2010 - 12:26
Leatherface
  • Leatherface
  • 7299 inlägg
Finns inte att köpa än.
Postad 30 April 2010 - 15:10
bpl
  • bpl
  • 858 inlägg
Vad svamlar du om lädret?
Är du full innan brasan tänts B) :P
Redigerat av bpl, 30 April 2010 - 15:11.
Postad 30 April 2010 - 15:53
Leatherface
  • Leatherface
  • 7299 inlägg
Ok kanske missförstod han tänkte om han menade nya DM800HD modellen som ska släppas.
DM500HD och gamla DM800HD finns självklart.
Postad 30 April 2010 - 18:16
fashion85
  • fashion85
  • 26 inlägg
hmmmm jag tror du har fel.
https://www.prisjakt...kt.php?p=567642
Tråden är ju till för DM 500 HD
Postad 13 May 2010 - 05:02
fashion85
  • fashion85
  • 26 inlägg
Beställde en dm 500 HD i förrgår =)!
Skall återkomma när jag provkört den!
Postad 13 May 2010 - 09:32
BioBerra
  • BioBerra
  • 5776 inlägg
Jag är ganska ny på det här med Sattelit TV, jag undrar om det finns någon Dreambox som klarar både HDTV samt både Canal Digital och Viasat samtidigt ?
Enligt killen på Viasat så behövde man inte ha 2 paraboler, det skulle gå att köra båda på samma. Men jag skulle ju helst vilja ha en gemsam box för detta också, gärna med inspelningsmöjligheter.
Är det bara DM8000 HD som gäller för min del ?
Postad 18 May 2010 - 19:06
Unregisteredf915588c
  • Unregisteredf915588c
  • 35 inlägg
bumpar denna lite..
Vad säger ni om boxen, ni som äger denna? Är intresserad av att kunna spela in, och förstår att det fungerar med en extern hårddisk till denna?! Är det vanlig usb man kör då eller? Innebär det också att man kan pausa live-tv?
Tacksam om någon ville hjälpa mig då jag är i valet och kvalet om vilken box jag ska köpa.. 600s, 800s, 7020, 7025 eller 500 hd. Hjälp!!!!
Postad 18 May 2010 - 19:45
BGPv4
  • BGPv4
  • 923 inlägg
Det klarar ju alla Linux boxar idag, inget speciellt med den setupen, dock får du ju aldrig HD från Viasat att fungera på annan box än Viasats egna.
Postad 25 May 2010 - 19:42
fashion85
  • fashion85
  • 26 inlägg
Du klarar dig med en parabol (tallrik) Men du måste ha två st LnB:er samt en switch.
Boxen klarar av Viasat och canal digital och canal digitals HD kanaler. Viasatś HD kanaler vet jag inte. men dom funkar inte för mig!
DM500HD fungerar lika bra till detta som Dm800HD
Postad 28 June 2010 - 18:22
fashion85
  • fashion85
  • 26 inlägg
Nu har jag fått tillbax min 500HD efter den första krashade!
nu har jag haft den i ettt dygn och har redan proble IGEN!
men nu kommer jag åt den via nätverket och kan förmodligen flasha om den så
funkar det igen! men tycker detta är förjävligt att en box för 3500:- inte funerar bättre.
Enda som händer nu är att start bilden kommer upp på TV:n och sedan hänger den sig och blinkar rött!
DENNA BOX REKOMMENDERAS INTE! kör en 800HD istället!
Postad 28 June 2010 - 18:33
Leatherface
  • Leatherface
  • 7299 inlägg
Det är ett mjukvaru problem som jag förstått det som är fixat i nyare mjukvara som gjorde att boxarna slutade boota.
http://git.opendream...513a145e8f7745c
Du borde alltså flasha in secondstage loader 79 eller en image som redan kommer med den.
Redigerat av Leatherface, 28 June 2010 - 18:37.
Postad 01 July 2010 - 11:58
fashion85
  • fashion85
  • 26 inlägg
Jaha! där ser man!
Hur gör jag detta? eller vet du någon image som redan kommer med den!?
Jag kör i dagsläget Gemini V.5 och det finns ingen nyare till denna box så vitt jag vet!
Har provat andra images men i dom flesta andra går inte mgcamd att installera via menyn så därför har det få
blivit Gemini!
Postad 01 July 2010 - 16:10
Leatherface
  • Leatherface
  • 7299 inlägg
LT6 SP3 har den och släpptes för några dagar sen.
Men andra images komemr ha det också som är släppt efter det datumet.
Redigerat av Leatherface, 01 July 2010 - 16:11.
Postad 04 July 2010 - 09:52
fashion85
  • fashion85
  • 26 inlägg
Jaha ok! Har för mig att jag testade LT6 med SP3 men jag tror inte jag hittade MgCamd då.
men jag kan ju avvakta och se vad som kommer. Gäller bara att inte starta om boxen! =)
Postad 04 July 2010 - 10:39
BGPv4
  • BGPv4
  • 923 inlägg
Det är egentligen en 500:- box, det är bara att DMM tar hurlösa priser för bara att vissa personer vill ha namnet Dreambox på framsidan.
Postad 04 July 2010 - 10:45
Leatherface
  • Leatherface
  • 7299 inlägg
Nog finns den och många andra cams där.
Postad 04 July 2010 - 21:07
fashion85
  • fashion85
  • 26 inlägg
Men så vitt jag vet så finns det ingen annan klon som har HD.
Har du provat själv med LT6 och kan svara på om den blir stabilare
i omstarterna med denna image!?
Postad 04 July 2010 - 22:04
Leatherface
  • Leatherface
  • 7299 inlägg
Inte just på DM500HD modellen men inga problem alls på DM7025 och DM8000.
Postad 11 July 2010 - 17:01
fashion85
  • fashion85
  • 26 inlägg
Nu kommer jag ihåg vad problemet med LT6 var!
Provade att installera den igen men boxen kommer bara till välkomstskärmen där det står LTVI sedan
händer ingenting! Inte heller när jag trycker på fjärren!
så denna image verkar inte fungera!
Postad 11 July 2010 - 21:57
Unregistered2530e964
  • Unregistered2530e964
  • 167 inlägg
Någon som vet om det kommer en DVB-T2 version av denna?
Redigerat av Unregistered2530e964, 11 July 2010 - 22:04.
Postad 12 July 2010 - 00:10
Leatherface
  • Leatherface
  • 7299 inlägg
Lär inte komma men det lär komma DVB-T2 tuners till modeller som är Plug N Play.
Men osäkert om de kommer gå se annat än SVT's HD kanaler iaf med tanke på att dom lär kräva CI+ och godkänd CA modul med stör för MPEG4 kanaler.
För att få HD box med CI platser överhuvudtaget så finns det bara ett alternativ och det är DM8000.
Redigerat av Leatherface, 12 July 2010 - 00:12.
Postad 12 July 2010 - 08:49
hannhimhe
  • hannhimhe
  • 93 inlägg
Glöm inte DM7020HD som kommer...ja, det återstår naturligtvis att se vilket år den blir tillgänglig.
Postad 12 July 2010 - 11:04
Leatherface
  • Leatherface
  • 7299 inlägg
Ja den är ett alternativ också.
DM800SE är ju sagt bli tillgängligt i höst nån gång och skulle tro att DM7020HD blir det ett tag efter det.
Redigerat av Leatherface, 12 July 2010 - 11:06.
Postad 30 July 2010 - 20:05
whome
  • whome
  • 949 inlägg
Kan man ta emot Canal Digital och dess HD-kanaler med DM 500 HD?
Postad 30 July 2010 - 20:08
Leatherface
  • Leatherface
  • 7299 inlägg
I dagsläget funkar det iaf.
Men slår dom på pairing så är det ajöss med dom.
Om dom skippar kravet på CI+ så kommer dom funka i DM7020HD och DM8000 med CD's pairing cam.
Redigerat av Leatherface, 30 July 2010 - 20:10.
Postad 30 July 2010 - 20:24
whome
  • whome
  • 949 inlägg
Nu fattar jag inte riktigt. Först säger du att det funkar men sen ska de skippa kravet på CI+...?
Om dom (Canal Digital) har krav på CI+ så fungerar det väl inte, eller?
Postad 30 July 2010 - 20:30
Leatherface
  • Leatherface
  • 7299 inlägg
I dagsläget har dom ingen pairing på HD kanalerna.
Det jag nämnde gäller bra ifall dom inför pairing.
Redigerat av Leatherface, 30 July 2010 - 20:30.
  • More is Always Better
    2026-08-29 18:47:07
