Onkyo 3008/5008
24 svar till detta ämne
Postad 30 June 2010 - 18:50
jonasprivate
  • jonasprivate
  • 11286 inlägg
Snart kommer Onkyos största maskiner.
Main features for both models include:
* Eight HDMI® 1.4a inputs, with compatibility specified for an Audio Return Channel and 3D video, and support for both mandatory video formats for 3D broadcasting ("Side-By-Side (Half)" and "Top-and-Bottom")
* Dual HDMI outputs, allowing users to connect two high-definition displays simultaneously.
* HQV-Reon VX video processor
* 1080p upscaling of all video inputs, regardless of source resolution
* Advanced ISF video calibration, which allows users to make fine-grained, independent adjustments for each video source.
* Audio networking
* Internet radio
* Rear-side Ethernet port for firmware upgrades and direct connection to the internet or to a home PC. Users can access streaming internet radio through Pandora, Rhapsody, Napster, Slacker, Sirius Internet Radio, and vTuner, or play back a wide variety of PC-based audio files, including FLAC, MP3, WAV, Ogg Vorbis, WMA, WMA Lossless, AAC, and LPCM.
* Windows 7 compatible
* DLNA 1.5 certified
* 9.2 audio channels
* Audyssey DSX (adds extra height or width channels for greater spatial ambience) and Dolby Pro Logic (provides the option of extra height channels)
* Dolby TrueHD and DTS-HD Master Audio
* Compatibility with DSD Direct
* Burr-Brown DACs
* Audyssey room-correction and equalization
* Flexibility in multi-room set-ups: the TX-NR5008 and TX-NR3008 let users play a 5.1-channel source in the main room, along with fully powered stereo audio of two different sources in Zone 2 and Zone 3. On top of that, users also have the option of Zone 2/3 pre outs and Zone 2 video output.
* Music playback and album art display from USB port
* Gold-plated audio inputs
* PLL jitter-cleaning circuit technology on all models
* Separate transformers for audio and video processing
* Analog RGB input for video content from a connected PC
* Backlit and customizable remote controller
* HDMI Thru: allows children to still watch programs when the receiver is not turned on
* Onkyo's new overlaid graphical OSD for seamless adjustment of settings during a viewing session
The TX-NR5008 adds a second USB port at the rear, and a "massive" toroidal transformer and 22,000 ìF capacitors.
Postad 14 April 2011 - 19:25
dallan1981
  • dallan1981
  • 2249 inlägg
Och nu har 3008:an gått ner till 12995kr! man undrar varför inte 5008:an har gått ner...än!?
När kommer 3009 och 5009? Ngn som vet...
Micke
Postad 14 April 2011 - 21:32
Audio One
  • Audio One
  • 832 inlägg
Synd att de inte ändrat utseendet ser lika tråkiga ut som innan. 609 har ju fått ett ansiktslyft.
Postad 15 April 2011 - 10:21
Triggerhappy
  • Triggerhappy
  • 853 inlägg
Utseendet ändras säkert till 3009/5009 kommer....
Postad 15 April 2011 - 12:32
PeterK71
  • PeterK71
  • 47 inlägg
12995! Och jag som beställt en för 15000 på Media Markt för några dagar sen. Undrar om de matchar priset eller om man kan lämna tillbaka den på öppet köp?
Postad 15 April 2011 - 20:17
ekon
  • ekon
  • 5779 inlägg
Beställningsvaror brukar det inte vara öppet köp på, men det skadar aldrig att fråga!
Postad 16 April 2011 - 12:51
dallan1981
  • dallan1981
  • 2249 inlägg
Jag väntar bara på att 5008:an ska sänkas oxå, och lägg till Tysklands köp på det... så har du en sjukt bra Reciver till ett sjukt bra pris!
Postad 20 June 2011 - 15:07
dallan1981
  • dallan1981
  • 2249 inlägg
Nu smäller dom ut 5008:an för 15000 blankt till trogna kunder.. bara så ni vet.
Bästa Recivern på marknaden just nu, och även Integras motsvarighet 80.2.
Redigerat av dallan1981, 20 June 2011 - 15:14.
Postad 20 June 2011 - 15:12
Nattlorden
  • Nattlorden
  • 553 inlägg
Synd att man avpolleterat den som alternativ då, det är ju samma maskin som Integra 80.2 (minus ett par utgångar).
Postad 20 June 2011 - 16:14
dallan1981
  • dallan1981
  • 2249 inlägg
Japp, men för 15000kr! inte 28-29000kr.
Postad 20 June 2011 - 16:20
Nattlorden
  • Nattlorden
  • 553 inlägg
Jo, det är väldigt mycket bättre pris. För min del så tycker jag bättre om Pioneer LX-73 och den kostar något lite mindre till. :)
Unregistered2000
  • Unregistered2000
  • 328 inlägg
Där talar du i nattmössan min Lord :)
Det är inte bara ett par ut/ingångar som skiljer mellan Onkyo och Integra
Om så hade varit fallet, hade inte Integra tagit plats på tronen över många andra märken och då talar vi inte bara att de är i världsklass vad gäller installation.
Postad 20 June 2011 - 16:23
Nattlorden
  • Nattlorden
  • 553 inlägg
Det enda övriga som kan skilja är firmware, då alla komponenter för övrigt är de samma förutom fronten. Det står båda modellbeteckningarna på ritningarna i båda manualerna t.o.m. 3008/5008/70.2/80.2 samt 5508 samt processor 80.2. Tror du mig inte så gör som jag - köp servicemanualerna till båda två och jämför. Och jag har hört det där med "tightare matchning" på komponenter, men då kan man ju fråga sig varför det är oväsentligt att informera den som skall byta ut en komponent att den skall hålla en tightare spec. :ph34r: 272 sidor var det att läsa igenom vill jag minnas...
Redigerat av Nattlorden, 20 June 2011 - 16:25.
Postad 20 June 2011 - 16:28
Unregistered2000
  • Unregistered2000
  • 328 inlägg
Vad kallar du då detta för :)
http://www.eu.onkyo....1009-43224.html
Bifogad fil  TX_NR1009__S__Front_N3894x1928.jpg   1.26MB   0 Antal nerladdningar
Eftersom att du har läst dig till detta, så rekommendar jag dig att läsa dig till vad jag precis berättade för dig och vill du ha det muntligen berättat för dig så rekommendrar jag dig att ringa Integra och fråga.
Manualen berättar bara om funktioner och de är desamma. Men komponenterna skiljer sig avsevärt.
Postad 20 June 2011 - 16:33
Nattlorden
  • Nattlorden
  • 553 inlägg
Jag pratar om reparationsmanualerna. Ritningarna på alla kretskorten samt listor över exakt vilka komponenter som sitter på dem. Det är exakt samma komponenter, det är typ 100 A4-sidor med komponentlista och de är EXAKT samma för 5008 och 80.2. Det är inget som "skiljer avsevärt", tror du det har någon lurat dig.
Om en resistor skulle vara +-10% på en Onkyo och +-1% på en Integra, så utelämnar man inte den detaljen för serviceteknikern som skall byta komponenten.
Redigerat av Nattlorden, 20 June 2011 - 16:34.
Postad 20 June 2011 - 16:40
Nattlorden
  • Nattlorden
  • 553 inlägg
Kostade mig ett antal hundralappar att köpa manualerna... så du kan inte klaga på hur noga jag undersökt saken... :)
Postad 20 June 2011 - 16:41
dallan1981
  • dallan1981
  • 2249 inlägg
Ja Pioneers maskiner är oxå väldigt bra, det handlar mer om att matcha ihop högtalarna och sin Reciver enligt mig, och i vissa fall är ju då Pioneer mer lämplig än en Onkyo och vice versa..
Postad 20 June 2011 - 16:43
Nattlorden
  • Nattlorden
  • 553 inlägg
Hade jag fått välja fritt, så hade jag velat ha Marantz klang och upplösning, Integrans jäklar-anamma, Pioneers rumsmätning, interface & strömförbrukning. Vet inte vem som säljer en sådan...
Redigerat av Nattlorden, 20 June 2011 - 16:44.
Postad 20 June 2011 - 16:47
dallan1981
  • dallan1981
  • 2249 inlägg
Sen angående Integra Vs Onkyo snacket....
Köpte och ägde själv en 70.2 för ett tag sedan och var helt klart mkt nöjd med vad den presterade, MEN! det går inte undkomma att Onkyos motsvarigheter är så fruktansvärt mer prisvärda, och man får istortsett samma maskiner, en Integra har dock ett lite mer stramt ljud (ngt mer korrekt?) och det är lite mer "status" med en Integra i racket...
Men en Onkyo 5008 för 15tkr som jag betalar i dagsläget är grymt prisvärt, även om mina komponenter inte är lika hårt kontrollerade, sen har jag hört att Integra kanske har en mer påkostad strömförsörjning..?
+1
Postad 20 June 2011 - 16:51
  • Audio Code 3
  • 12561 inlägg
Onkyo rockar bra, de levererar kvalitet och pålitlighet, de är dessutom snygga :)
Postad 20 June 2011 - 16:55
Unregistered2000
  • Unregistered2000
  • 328 inlägg
Kostade mig ett antal hundralappar att köpa manualerna... så du kan inte klaga på hur noga jag undersökt saken... :ph34r:
Om det gör att du kan känna dig tillfreds med att köpa en Onkyo istället för en Integra
så var det väl investerade pengar. Dock så kan du fortfarande inte läsa dig till skillnaderna
mellan de komponenter som man stoppar i Onkyo respektive Integra
Det är skillnad, tro mig jag vet :)
Postad 20 June 2011 - 17:01
Nattlorden
  • Nattlorden
  • 553 inlägg
Exakt samma ritning och komponenter i servicemanualen. Däremot är det en större i 5008/80.2. 3008 resp 70.2 har olika däremot - där verkar 70.2 ta allt från en nätdel, medan 3008 har tre som 5008/80.2. Vilket jag skulle kunna tänka mig är till fördel för 3008. Kom 70.2 innan 3008 måntro?
Jag skall inte köpa någon Onkyo - ingen av dem är bra nog åt mig.
Klart jag kan - jag sitter på reparationsmanualen som berättar precis vilka komponenter som sitter i.
Menar du att om jag lämnar en Integra på service, så kommer den att försämras eftersom serviceteknikern inte
får reda på hur noga han måste leta upp komponenter? Tror inte det.... :ph34r:
Att de kan låta olika om du A/B-testar dem tänker jag inte ha någon invändning emot - för det har jag inte gjort. Men den skillnaden sitter i så fall i mjukvaran och ingen annanstans. Och det är jag helt ok med.
Dessutom om jag skulle ha gillat Integrans ljud fullt ut, så hade det blivit Integra - eftersom man i den i mjukvaran gjort det möjligt att använda två slutsteg för att driva passiva subwoofers - det har man inte öppnat upp i Onkyon.
Redigerat av Nattlorden, 20 June 2011 - 17:04.
Postad 20 June 2011 - 22:01
jonas_79
  • jonas_79
  • 1085 inlägg
+1
Var hittar man Onkyo 5008 för 15 000 kr då ??
Postad 20 June 2011 - 22:44
Unregistered9d8a0d93
  • Unregistered9d8a0d93
  • 2585 inlägg
Det är skillnad, tro mig jag vet :huh:
Detta med finare och dyrare apparater har man ju sett hur det är med sen tidigare Denons finare skulle ju vara testad och ha bättre komponenter än den vanliga varianten. Och den skulle vara utan buggar med mera när den lämna fabriken. Och inget av det verkade stämma ialla fall. Företagen gör allt för att tjäna så mycket som möjligt.
Postad 20 June 2011 - 23:15
dallan1981
  • dallan1981
  • 2249 inlägg
Du har PM.
