Officiell Tråd - HTC Desire Z
28 svar till detta ämne
HTC Desire Z 512MB RAM (Mobiltelefoner) 2 9.229166 (47) Inga priser
1 relaterade trådar
Postad 28 December 2010 - 16:11
Lias08
  • Lias08
  • 2705 inlägg
Desire Z specifikationer:
* 800 MHz Processor Qualcomm MSM7230
*Android 2.2 (Froyo) with HTC Sense
*Internal phone storage: 1.5 GB
*RAM: 512 MB
*119 x 60.4 x 14.16 mm (4.69 x 2.38 x 0.56 inches)
*180 grams (6.35 ounces) with battery
*3.7-inch SLCD touch screen with 480 x 800 resolution
*HSPA/WCDMA: • Europe/Asia: 900/2100 MHz • Upload speed of up to 5.76 Mbps and download speed of up to 14.4 Mbps
*Quad-band GSM/GPRS/EDGE: 850/900/1800/1900 MHz
*Optical Trackpad
*Z-slider QWERTY keyboard
*Internal GPS antenna
*G-Sensor
*Digital compass
*Proximity sensor
*Bluetooth® 2.1 with FTP/OPP for file transfer, A2DP for wireless stereo headsets, and PBAP for phonebook access from the car kit
*3.5 mm stereo audio jack Standard micro-USB (5-pin micro-USB 2.0)
*5.0 megapixel color camera with auto focus and flashlight
*720p HD video recording
*Audio supported formats – Playback: .aac, .amr, .ogg, .m4a, .mid, .mp3, .wav, .wma (Windows Media Audio 9) • Recording: .amr
*Video supported formats – Playback: .3gp, .3g2, .mp4, .wmv (Windows Media Video 9) • Recording: .3gp
*1300 mAh Battery
*Talk time: • Up to 400 minutes for WCDMA • Up to 590 minutes for GSM
*Standby time: • Up to 430 hours for WCDMA • Up to 430 hours for GSM
*microSD expansion (SD 2.0 compatible)
*100 ~ 240 V AC, 50/60 Hz DC output: 5 V and 1 A AC adaptor
*Share pictures, video or music to your big screen TV or PC display via DLNA® (Digital Living Network Alliance).
HTC Desire Z 720p HD video
Redigerat av Lias08, 29 December 2010 - 11:21.
Postad 28 December 2010 - 21:02
junkan
  • junkan
  • 5324 inlägg
He he har du också förstått att Samsung Galaxy S inte är så bra?
Sa ju det!
Postad 28 December 2010 - 21:47
Lias08
  • Lias08
  • 2705 inlägg
Sa ju det!
SGS:n ligger i lådan hemma :)
Är riktigt nöjd med DZ hittills, har haft den i några veckor nu.
Postad 29 December 2010 - 08:03
Unregisterededb978dd
  • Unregisterededb978dd
  • 3073 inlägg
Hur får jag in en mp3-låt som ringsignal ?
har ett klipp av en låt på ca 24s. och har lagt det på minneskortet nu..
- dels testat att lägga det i en mapp kallad "ringtones", en kallad "Ringsignaler"
men också testa att lägga det i /media/mp3 etc.. (eller vad mappen kallades)
men sedan när jag går in bland de "medföljande" ringsignalerna så finns inte den inlagda med där
vad gör jag för fel?
testade också att maila den till mig, och öppna mailen via telefonen..
sparar ner den, men vet inte vars i telefonen den sparas.. suck.. ska det vara såhär krångligt?
Postad 29 December 2010 - 11:17
Lias08
  • Lias08
  • 2705 inlägg
Börja med att skapa en mapp på ditt minneskort med namnet media i den mappen skapar du en som heter audio. Lägg till dessa mappar i audio.
alarms
notifications
ringtones
ui
sedan fyller du dessa med vad du vill, så poppar de upp när du ska byta ringsignal...
Postad 29 December 2010 - 11:32
  • 3073 inlägg
alarms
notifications
ringtones
ui
är "htc desire z" samma som htc desire ? har nämligen den vanliga modellen
nåja, mappen media fanns redan på minneskortet (/sdcard)
skapade alla de där mapparna i media-mappen, och la till mp3n i "ringtones"
kan fortfarande inte se den om jag går in och ska ändra ringsignal....
Postad 29 December 2010 - 11:39
Lias08
  • Lias08
  • 2705 inlägg
Läs mitt inlägg en gång till :)
I mappen Media ska du skapa en ny mapp som heter Audio och där lägger du till:
alarms
notifications
ringtones
ui
Postad 29 December 2010 - 12:56
  • 3073 inlägg
alarms
notifications
ringtones
ui
Media fanns redan
har där skapat "audio" och sedan följande i audio-mappen:
alarms
notifications
ringtones
ui
sedan la jag en mp3-fil i "ringtones" men det gör ingen skillnad, kan inte välja den!
Postad 29 December 2010 - 16:20
Unregistered6b8ff32e
  • Unregistered6b8ff32e
  • 321 inlägg
Media fanns redan
alarms
notifications
ringtones
ui
Starta om telefonen eller tanka ner "scan media" från market
Postad 31 December 2010 - 21:55
amanito
  • amanito
  • 50 inlägg
tjabba..skaffade oxå mig en sådan skön lur i mellandagarna för 3990:- älskar den:) är ute efter skydd till den, någon som har lagt invisible shield? är det bra/dåligt?
Postad 02 January 2011 - 02:02
Lias08
  • Lias08
  • 2705 inlägg
Själv betalade jag 5100kr för luren hos MM början på december ^_^
Det finns snygga väskor på ebay uk, jag kör med en vanlig displayskydd och en väska.
eBay UK
Postad 12 January 2011 - 14:04
Unregisteredbf364490
  • Unregisteredbf364490
  • 1887 inlägg
Jag har nu kört med min DesireZ nu i tre veckor och än så länge är jag väldigt nöjd!
Jag köpte ett nytt batteri från Mugen på 1800 mAh och är klart nöjd med batteritiden jämfört med telefonens orginalbatteri på 1300 mAh. Jag märker en förbättring på 20-30% på hur länge batteriet räcker.
En fråga dock som inte har med batteriet att göra. Jag är ny i Android-världen så ni får ha överseende....
På första skärmen har jag nere till höger kört en 2x2 Widget utan problem. Sen plötslig en dag när jag skulle uppgradera programmet som jag hade på framsidan stod det bara en grå ruta nere till höger "Gadget kan inte laddas" står det. Hur blir jag av med den?
Postad 12 January 2011 - 14:20
Unregisteredc96d6be8
  • Unregisteredc96d6be8
  • 7392 inlägg
Håll fingret på den tills den blir röd och dra den ner till soptunnan sen lägger du till widgeten på nytt
Postad 12 January 2011 - 14:33
  • 1887 inlägg
Men allvarligt vad lätt det var! Suck
Tack för hjälpen!
Postad 12 January 2011 - 15:04
  • 7392 inlägg
Tack för hjälpen!
Dock kan det vara en varning om det händer igen, en del widgets funkar dåligt tex med sense och kan inte laddas när man startar om telefonen, jäkligt irriterande, kan också ibland bero på slött minneskort om appen ligger på sd-kortet
Postad 16 January 2011 - 10:02
Pulver
  • Pulver
  • 2387 inlägg
Bifogad fil  1.JPG   59.2K   0 Antal nerladdningar
Bifogad fil  2.JPG   52.13K   0 Antal nerladdningar
Edit: (fick inte med texten)
Finns det något sätt att "mixtra" med tangentbordslayouten utan att först "roota" telefonen ?
Exempelvis skulle jag gärna ha några slags piltangenter så man kan scrolla via tangentbordet exempelvis när man surfar.
Dessutom använder jag SSH en del (en orsak till att jag köpte en telefon med tangentbord) och av någon anledningen fungerar inte TAB - man måste köra homeknapp+i för att få TAB
Redigerat av Pulver, 16 January 2011 - 10:10.
Postad 16 January 2011 - 14:15
Pulver
  • Pulver
  • 2387 inlägg
Kan svara mig själv på en fråga :(
Kör man SSH använder man troligtvis programmet Connectbot, men vill man att det ska fungera bättre med tangentbordet på Desire Z så ska man istället använda varianten irssi-connectbot
Där finns bla fixar för Desire Z:s tangentbord att aktivera i inställningarna för programmet - även för oss med skandinavisk layout, och då fungerar bla TAB.
Jag har dock fortfarande problem med att få "Esc" att fungera - men det är antagligen endast en inställningsgrej eller en fix som dyker upp snart.
Piltangenter är dock någonting som jag fortfarande saknar på tangentbordet.
I USA har modellen HTC EVO Shift 4G nyligen lanserats - på den modellen har HTC ändrat mekaniken för tangentbordet samt lagt till en styrplatta.
Bifogad fil  evoshift_open_top_1.jpg   57.23K   0 Antal nerladdningar
Postad 22 January 2011 - 21:42
MrYamakasi
  • MrYamakasi
  • 117 inlägg
Tangentbordet på desire z med engelsk layout har två knappar nere till höger som man kan programmera shortcuts till.
Finns inte de på svenska layouten??
Postad 01 February 2011 - 18:01
Lias08
  • Lias08
  • 2705 inlägg
Jag är 24/7 online på facebook fast jag loggar in 1-2 ggr via mobilen per dag!!
Varför visar mobilen att jag är online fast jag är inte det? Går det att ändra på nåt sätt?
När jag kollar på Inställningar/Konto och synkronisering där ser jag att jag har två facebook app, en vanlig Android app och en Facebook for HTC Sense! Måste man ha båda?
Postad 07 February 2011 - 19:47
hansemannen
  • hansemannen
  • 36 inlägg
Skulle oxå vilja ha nån sån funktion. Det vore ju guld om det fanns nån app/inställning så att dom danska ae (ä) o oe (ö) kunde bli pil vänster höger isället eller nån valfri shortcut. Går det utan att roota?
Så till min egentliga fråga. Igår började min HTC DZ börja starta om sig (!) Hänt fyra gånger inom ett dygn, två gånger utan att jag gjort nåt med den och två gånger då jag spelat mp3/flac i PowerAMP via bluetooth. Någon annan som haft detta problem?? Blir ju lagom orolig nu när jag googlade lite och upptäckte att mängder av Desire (inte Z då) haft omstartsproblem och behövt få moderkortet utbytt...Hoppas hoppas att det inte behövs reparation så man slipper lämna iväg telefonen till mupparna på Anovo.
Postad 13 April 2011 - 08:19
Snurrbo
  • Snurrbo
  • 542 inlägg
Är alla fortfarande nöjda med telefonen? Är tangentbordet BRA eller bara ok?
Postad 17 April 2011 - 12:31
Lias08
  • Lias08
  • 2705 inlägg
Jag gick tillbaka till iPhone 4, min DZ ligger hemma i en låda.
Postad 25 April 2011 - 19:07
CyberVillain
  • CyberVillain
  • 1789 inlägg
Grymt nöjd med min Z. Grym för business, MusHunter kan ju leka i sandlådan med sin ifåne så kan vi som använder telefonen seriöst i jobbet köra med vår :)
Nån som lyckas roota sin Desire Z efter senaste upgrade? Jag har testat både med Visionary R14 och manuellt med Rage metoden, ingen av dem lyckas gå in i temproot mode
edit: Android version 2.2.1, Kernel 2.6.32.21
Redigerat av CyberVillain, 25 April 2011 - 19:11.
Postad 30 May 2011 - 20:13
Unregistered98d503b8
  • Unregistered98d503b8
  • 326 inlägg
Lyckades klicka på Dustin Homes reklam längst upp på sidan där de erbjuder en Desire Z för 2990 kr:
http://www.dustinhom...e_Prisjakt_6298
Grejen är den att jag har en gammal X10 mini (som jag köpte samma dag den släpptes). Börjar bli lagom less på det mindre formatet, och vill dessutom ha en telefon med tangentbord men inte lägga för mycket pengar :)
Hur ser ni på ett köp av Desire Z?
Kommer telefonen kännas gammal redan nu?
Hur fungerar tangentbordet för en som skriver mycket mail t.ex?
// Mattias
Postad 01 June 2011 - 07:28
  • 326 inlägg
Tack för alla svar! :D
Köpte en Desire Z igårkväll. Hittills riktigt nöjd :D
Postad 01 June 2011 - 13:07
  • 7392 inlägg
Grejen är den att jag har en gammal X10 mini (som jag köpte samma dag den släpptes). Börjar bli lagom less på det mindre formatet, och vill dessutom ha en telefon med tangentbord men inte lägga för mycket pengar :D
// Mattias
Även om det är lite sent iom att du redan köpt :D
Men iom att du mest ogillade det mindre formatet och lägre upplösningen så borde inte desire z kännas gammal, om den inte redan har fått så kommer den att få android 2.3 och kommer säkert att kännas fräsch ett bra tag till.
Testade en Z ett par veckor men kom på att jag minst lika ofta skrev på skärmen som på tangentbordet så det blev aldrig nått köp :rolleyes: Trevlig telefon i övrigt och skönt tangentbord.
Postad 15 July 2011 - 13:37
emilager97
  • emilager97
Hej jag har tänkt att köpa Htc Desire Z men den avgörande frågan är kan man uppgradera den till android 2.3 (gingerbread) och isånnafall hur?
Redigerat av emilager97, 15 July 2011 - 13:39.
Postad 20 July 2011 - 09:33
CyberVillain
  • CyberVillain
  • 1789 inlägg
Jag fick precis 2.3 till min, du får en update notification helt automatiskt
Postad 28 February 2012 - 15:43
CyberVillain
  • CyberVillain
  • 1789 inlägg
Det finns ju rätt många olika 4.0 roms nu för Desire Z, nån som orkat testa nån?
