newcs + sasc_ng = funkar ej...
7 svar till detta ämne
Postad 13 January 2011 - 21:48
lundbergfamily
  • lundbergfamily
  • 46 inlägg
Fick min kortläsare (en Smargo, USB-baserad) med posten idag så jag tänkte försöka mig på det här med newcs & sasc_ng, alltså med helt "eget" och legitimt kort.
Men det vill sig inte.
Kör jag med newcamd-protokollet så funkar det "bäst" tycker jag, då kommer jag hit (har klippt bort nycklarna, de ser OK ut här vad jag kan se):
[ 22:43:28 ] [ Box detect ] Box type 1 (General Boxtype - Generic)
&#91; 22&#58;43&#58;28 &#93; &#91; Config &#93; Option <blockc0> for device 0 &#40;Phoenix Interface&#41; not present, defaulting to NO
&#91; 22&#58;43&#58;28 &#93; &#91; Config &#93; Pincode for device 0 &#40;Phoenix Interface&#41;&#58; 0000
&#91; 22&#58;43&#58;28 &#93; &#91; Config &#93; /dev/ttyUSB0 ECM priority&#58; round
&#91; 22&#58;43&#58;28 &#93; &#91; Newcamd &#93; Server name &#58; cardserver
&#91; 22&#58;43&#58;28 &#93; &#91; Newcamd &#93; Des key	 &#58; 0102030405060708091011121314
&#91; 22&#58;43&#58;28 &#93; &#91; Newcamd &#93; User 2&#58; TestUser, Pass&#58; TestPassword, Host none, Port&#58; 0, Au&#58; On, Spider allowed&#58; No, Sidoverride&#58; No, level&#58; 0
&#91; 22&#58;43&#58;28 &#93; &#91; httpd &#93; httpd-user&#58; admin, password&#58; newcs, accesslevel&#58; admin
&#91; 22&#58;43&#58;28 &#93; &#91; EMM Cache &#93; Initialising dynamic Cache
&#91; 22&#58;43&#58;28 &#93; &#91; ECM Cache &#93; Initialising dynamic Cache
&#91; 22&#58;43&#58;28 &#93; &#91; Loader &#93; Starting Telnet on port 0
&#91; 22&#58;43&#58;28 &#93; &#91; Loader &#93; Started HTTP-server on port&#58; 8080
&#91; 22&#58;43&#58;28 &#93; &#91; Loader &#93; Reader type 2 on node /dev/ttyUSB0
&#91; 22&#58;43&#58;28 &#93; &#91; Phoenix &#93; Opening device /dev/ttyUSB0
&#91; 22&#58;43&#58;28 &#93; &#91; Phoenix &#93; Setting Parity to&#58; ODD
&#91; 22&#58;43&#58;28 &#93; &#91; Phoenix &#93; Setting 2 Stop bits on node /dev/ttyUSB0
&#91; 22&#58;43&#58;28 &#93; &#91; Phoenix &#93; Setting Baud to standard 9600
&#91; 22&#58;43&#58;29 &#93; &#91; Phoenix &#93; Normal RESET on node /dev/ttyUSB0
&#91; 22&#58;43&#58;31 &#93; &#91; ATR &#93; T=0  1etu=104.17us  Guardtime&#58;15etu  WWT&#58;9600etu
&#91; 22&#58;43&#58;31 &#93; &#91; ATR &#93; Historical bytes&#58; 3 &#91;B0&#93; &#91;09&#93; i &#91;FF&#93; J P p &#91;00&#93; &#91;00&#93; V T &#91;01&#93; &#91;00&#93; &#91;00&#93;
&#91; 22&#58;43&#58;31 &#93; &#91; Loader &#93; Init NDS card
&#91; 22&#58;43&#58;31 &#93; &#91; Phoenix &#93; Setting Parity to&#58; ODD
&#91; 22&#58;43&#58;31 &#93; &#91; Phoenix &#93; Setting 2 Stop bits on node /dev/ttyUSB0
&#91; 22&#58;43&#58;31 &#93; &#91; Phoenix &#93; Setting Baud to standard 9600
&#91; 22&#58;43&#58;32 &#93; &#91; KeymaN &#93; Adding key 000000xxxxxxxx type 0 on Provider 000000 for caid 090F ID=0
&#91; 22&#58;43&#58;32 &#93; &#91; KeymaN &#93; Adding key 000000xxxxxxxx type 1 on Provider 000000 for caid 090F ID=0
&#91; 22&#58;43&#58;34 &#93; &#91; Loader &#93; Card 090F on port /dev/ttyUSB0 ready
&#91; 22&#58;43&#58;34 &#93; &#91; Loader &#93; Starting Newcamd Server on port 10000
&#91; 22&#58;43&#58;34 &#93; &#91; NewCS &#93; Ready to GO! &#58;&#41;
&#91; 22&#58;43&#58;34 &#93; &#91; Newcamd &#93; Newcamd thread Server started on port 10000
&#91; 22&#58;43&#58;46 &#93; &#91; Newcamd&#58;10000 &#93; Connection from 127.0.0.1
&#91; 22&#58;43&#58;46 &#93; &#91; Newcamd&#58;10000 &#93; User TestUser logged in, client&#58; Generic
&#91; 22&#58;44&#58;20 &#93; &#91; Newcamd &#93; ECM -> TestUser &#40;NOT OK&#41; &#91;CAID 0000&#93; &#91;Prov 00000000&#93; &#91;SID 1388&#93;
&#91; 22&#58;44&#58;27 &#93; &#91; Newcamd &#93; ECM -> TestUser &#40;NOT OK&#41; &#91;CAID 0000&#93; &#91;Prov 00000000&#93; &#91;SID 1388&#93;
Problemet är just att jag bara får ECM "NOT OK"-svar på dessa... :( Tycker det ser ut som att sasc-ng frågar "på fel sätt" (dvs med CAID = 0000) av någon orsak. Kör jag med radegast istället för newcamd som protokoll/server så kommer det dock ännu mindre logginfo i newcs-loggen så jag tycker ändå detta är bäst hittils...
Min cardclient.conf ser ut så här:
newcamd&#58;localhost&#58;10000&#58;1/090F/ffff&#58;TestUser&#58;TestPassword&#58;0102030405060708091011121314
Tycker det ser rätt ut. 090F = Viasat antar jag, ser ut som att de strömmar som kommer in via sasc-ng är kodade med dels 090F och dels 093F (tror jag det var), så det borde ju liksom funka... :blink:
Hjälp!
Postad 13 January 2011 - 21:55
lundbergfamily
  • lundbergfamily
  • 46 inlägg
Testade med TV4 istället (i MythTV). Då kom den så pass långt att det blev ECM OK men trots det ingen bild... :blink: Suck! MythTV får lock på kanalen, men trots detta ingen bild och efter en stund ett felmeddelande. Verkar inte funka i Kaffeine eller VLC heller. ;)
Vad är det för versioner av newCS och open-sasc-ng som rekommenderas? Just nu kör jag bara med 1.66 och senaste open-sasc-ng från Mercurial (http://85.17.209.13:6100/sc). Tydligen är det inte ens open-sasc-ng längre utan, vdr-sasc-ng. Men det hjälper ju inte mycket, eftersom den inte funkar, åtminstone inte hos mig... :(
Redigerat av lundbergfamily, 13 January 2011 - 22:34.
Postad 14 January 2011 - 16:17
frust
  • frust
  • 122 inlägg
Byt till Oscam istället...Newcs fungerar dåligt med de nya korten från viasat...
Fast du verkar ju ha dem gamla kortet....
Du behöver kanske bara uppdatera kortet i originalboxen
Redigerat av frust, 14 January 2011 - 16:41.
Postad 14 January 2011 - 20:28
lundbergfamily
  • lundbergfamily
  • 46 inlägg
Är öppen för alla alternativ som gör att eländet funkar... :) Har du någon bra guide på lut för hur man konfar OScam till att köra mot en Phoenix-kompatibel kortläsare? Samt ett tips på protokoll jag kan använda från sasc-ng. Vilken version av sasc-ng kör du, funkar den bra?
Postad 20 January 2011 - 10:37
frust
  • frust
  • 122 inlägg
Oscamfiler för nya viasatkortet...
Du verkar ju ha det gamla så ändra bara caid så ska det fungera
oscam.conf
#oscam.config generated automatically
&#91;global&#93;
pidfile			 = /var/run/oscam/oscam.pid
usrfile			 = /var/log/oscam/oscamuser.log
logfile			 = /var/log/oscam/oscam.log
cwlogdir			= /var/log/oscam/cw
disablelog		  = 0
disableuserfile	 = 0
usrfileflag		 = 0
clienttimeout	   = 5000
fallbacktimeout	 = 2500
clientmaxidle	   = 120
cachedelay		  = 0
bindwait			= 120
netprio			 = 0
resolvedelay		= 30
unlockparental	  = 0
nice				= -1
serialreadertimeout = 1500
maxlogsize		  = 1024000
waitforcards		= 1
preferlocalcards	= 0
&#91;monitor&#93;
port				= 0
nocrypt			 =
aulow			   = 120
hideclient_to	   = 0
monlevel			= 2
appendchaninfo	  = 0
&#91;newcamd&#93;
port				= 12000@093E&#58;000000
key				 = 0102030405060708091011121314
allowed			 = 127.0.0.1
keepalive		   = 1
&#91;webif&#93;
httpport			= 8888
httpuser			= admin
httppwd			 = admin
httpcss			 =
httptpl			 =
httpscript		  =
httprefresh		 = 0
httpallowed		 = 127.0.0.1
httpdyndns		  =
httphideidleclients = 0
httpreadonly		= 0
&#91;anticasc&#93;
enabled			 = 0
numusers			= 0
sampletime		  = 2
samples			 = 10
penalty			 = 0
aclogfile		   = ./oscam_ac.log
denysamples		 = 8
fakedelay		   = 1000
oscam.server
# reader configuration
# USB serial reader
&#91;reader&#93;
label	= viasat
protocol = mouse
detect   = CD
device   = /dev/ttyUSB0
group	= 1
emmcache = 0,1,2
caid	 = 093e
#boxid	= XXXXXXX behövs bara till de nya viasatkorten
oscam.user
#oscam.user generated automatically
&#91;account&#93;
user				= user
pwd				 = pass
disabled			= 0
expdate			 =
group			   = 1
hostname			=
uniq				= 0
sleep			   = 0
monlevel			= 4
au				  = viasat
services			=
caid				= 093E&FFFF
betatunnel		  =
ident			   = 093E&#58;000000
keepalive		   = 1
numusers			= 0
penalty			 = 0
Jag har fungerande uppstättningar med open-sasc-ng r77 med complete-patchen och vdr-sasc med någon patch.
Din server verkar ju fungera. Får du verkligen bild med kortet i originalboxen ?
Postad 30 January 2011 - 22:33
lundbergfamily
  • lundbergfamily
  • 46 inlägg
Tack för dina filer, jättebussigt! Ska prova dem så snart jag hinner, lite fullt upp nu. Jo, kortet funkar helt perfekt i originalboxen, inga problem. Försökte mig på en newcs + hts-tvheadend-setup häromdagen också men det funkade inte heller (suck...), där fick jag inte ens FTA-kanaler att funka så där var det nog något mer fundamentalt som felade. Gick att scanna kanaler men inte sedan att tuna dem, vilket var sjukt skumt.
Men som sagt, ska testa din oscam-conf och den version av vdr-sasc du nämnde, så ska vi se om det inte blir lite roligare hela detta projekt snart... Än en gång, tack! :)
mvh,
Per
Postad 03 February 2011 - 21:48
lundbergfamily
  • lundbergfamily
  • 46 inlägg
Provade med dessa configar nu, i princip din config men modifierad eftersom mitt kort kör med CAID 090F. Nu funkar det! Om någon annan vill få det att funka och har "gamla" Viasatkortet: sök & ersätt 093e (och 093E) mot 090F i configfilerna enligt nedan. Då funkar det perfekt. Hockeykväll rullar i bakgrunden... :) :) :)
Postad 04 February 2011 - 08:40
frust
  • frust
  • 122 inlägg
Bra att det fungerade...
