4 the record 1.6.0.0 release den 25:e Maj
6 svar till detta ämne
Postad 19 May 2011 - 14:47
Unregistered16b96569
  • Unregistered16b96569
  • 280 inlägg
Kommer en riktigt intressant release den 25:e av For The Record :) Hoppas på att den blir riktigt bra.
ForTheRecord 1.6.0.0 announcement !
Hi everyone,
Mark in your agenda's :
May 25th 2011 :
- Towel Day
- ForTheRecord 1.6.0.0 release !
This is a "short", filtered list of most important changes since 1.5.0.3 :
•Added support for RTSP streaming.
•Optimized RTSP zapping in MediaPortal client.
•Set default RTSP port to 8554.
•Added new setting to MediaPortal 1.1 plugin to optionally play recordings over RTSP instead of UNC.
•Major internal change -- totally new data layer: replaced Gentle.NET with NHibernate.
•Updated SQL CE to 4.0.
•Schedules with 'Contains' rules should be faster, especially on MySQL.
•Now works with Linux MySQL servers.
•Improved search guide -> no longer searches channels that are not visible.
•Core: Marked VideoAspect as obsolete and replaced the property with GuideProgramFlags, which also contains a flag for HDTV.
•Core: Implemented '<video>/<quality>' importing in XMLTV (for HDTV).
•Core: Improved around-time rule in combination with week-day(s) or on-day for programs around midnight.
•Core: Added EPISODENUMBERDISPLAY formatting code.
•Core: Added LiveStreamTuned event, sent when an active live stream is tuned to a different channel.
•Core: XMLTV importing should be faster.
•Core: when building a recording's path, title, episode title, schedule name and full-title are all limited to 80 characters now.
•MMC: EPG will now show programs from 3AM in the morning until 3AM the next day to make it easier to deal with programs around or after midnight.
•MMC: Will now show [HD] on HDTV programs.
•MMC: Channels not broadcasting are shown with grey background in the EPG grid.
•MMC: Live TV panel in MMC: double-click on a row now starts Live TV.
•Argus: Added quality/strength bars to the Scan panel in the Argus MMC.
•Argus: Implemented support for Digital Devices cards (DiSEqC and CAM support).
•Argus: It's now possible to delete services by holding down the Shift key when clicking Hide in the Argus MMC Services panel.
•Argus: Made advanced settings for the core services hidden(automatic) by default during setup.
•Argus: Implemented CAM-limit check in Argus and TV Server recorder/tuners for live TV.
•Argus: CAM limit of 0 now means unlimited (except for MDAPI, when it's required to be set).
•Argus: Added TBS vendor-specific code (but doesn't seem to work yet).
•Argus: Most card-host settings are now available through the Argus MMC (and have been removed from the CardHost.exe.config).
•Argus: when a live stream is started, any left-over timeshift files from that card are now deleted automatically.
•Argus: added card settings section to the Cards panel.
•Argus: added preliminary support for Genpix DVB-S cards.
•Argus: small PCR fix in TS demuxer.
•Argus: returns better error codes when re-tuning an existing live stream fails.
•Argus: tweaked GrabEpgOnLiveTvAndRecordings setting. If false, EPG grabbing will now also not be allowed when another card is busy with a recording or live TV.
•Argus: added ForTheRecord.RecorderTuner.Interop.dll to make C++ interop possible (for MDAPI_Plus).
•Argus: fixed the way Argus creates its tuning spaces... changes to the LNB frequencies will now properly take effect.
•Argus: fixed Genpix code.
•Argus: fixed transport stream scanner to handle the case where multiple services are using the same pid for their PMT.
•Argus: fixed IsScrambled flag when tuning a service.
•Argus: changed "Scan frequency" to "Scan frequency for" in the Argus Cards panel, advanced settings.
•Argus: modified Hauppage code to support their newer KSPROPSETID_BdaTunerExtensionProperties2 as well as KSPROPSETID_BdaTunerExtensionProperties.
•Argus: when scanning, check provider and name limits. Similar fix to mdapi code.
•Argus: Digital devices: send DisEq command before tuning.
•Argus: fixed offset bug when parsing SDT entries (caused scanning issues).
•Argus: Fixed manual recordings with really long names to no longer cause problems with the recording's title length.
•Argus: Fixed remaining disk size calculation to only look at recording shares (and not timeshift shares).
•Argus: Fixed EPG grabbing time check (for idle grabbing).
•MediaPortal: TV client plugin now allows TV guides with more than 10 lines.
•MediaPortal 1.x client will now read the size of its logo icons from the skin't 4TR_Home.xml file.
•Tweaked audio language selection in MediaPortal client.
•Tweaked display format of groups in MediaPortal's recorded TV and radio screens (more consistent with the programs).
•MediaPortal: fixed MP1.2 guide screen for large guides (> 10 channels).
•MediaPortal: client will no longer filter out non-existing recordings -- speeds up the call.
•Removed support in MediaPortal client for old Aeon Wide, Indigo and Monochrome skins.
•MP client always shows the current TV program info even if TV is off (as long as a previous channel is known).
•MP: miscellaneous improvements to the client.
•MP 1.2: added chapters, subtitling and post-processing menu to full-screen TV popup menu.
•MP 1.2: improved EPG, based on latest SVN code.
•MP 1.2: tweaked the behavior of the EPG, clicking an active program will start live TV now, and all other functionality is now part of the context menu.
•MediaPortal client will now show a message box instead of an empty screen if there are no active recordings and you use the "Active Recordings" button.
•Remove support for MediaPortal 1.0.x.
•Added default setting for KeepUntilMode and Value for schedules.
•Added norwegian webclient translation files.
•Added MP client norwegian translations.
•Tweaked Twinhan code (didn't work with USB2 devices).
•Tweaked search to include a single quote or dash as start of a word (like in french: l'année).
•MediaPortal: Alot of MediaPortal client tweaks.
•Tweaked calculation of the split point when recordings are combined (the ratio of the pre/post-record will now be respected instead of simply picking the halfway point).
•When a GuideProgram is imported, the 'source' is now kept in the database. Overwrites have been made smarter, so they automatically occur if the source is the same (or 'other').
•XMLTV importing will now first move the files being processed to a Processing directory now.
•Implemented support for the "Accept-Encoding: gzip" header for REST calls: if set, the response of most calls will be compressed with gzip.
•Revised REST api to send more arguments over POST to avoid issues with special characters.
•Added "Open Local Logs" button to the MMC's Log panel to open the local "ForThe Record/Logs" folder.
•Added new "Core/Version" REST method to return the server's version number.
•Added Guide/FullPrograms call to REST api.
•Added "Wake Up Server" option to the tray notifier.
•Visual C++ runtimes are now installed during setup (if needed).
•Improved SQL dependency check during installation.
•Fixed web access setup in IIS7.
•Tweaked firewall setup code to put the two windows services back to public/private/domain.
•Reworked firewall code in custom installer (and added rule for HTTP for private/domain -- for REST).
•Added option to the installer to only install the Web Access files, and not configure a web server (e.g. for use with Apache).
•Updated Satellites.xml
•Updated cables.xml
Postad 08 June 2011 - 20:28
  • 280 inlägg
Har nu uppgraderat ill FTR 1.6.0.0 på servern och MP 1.2 Beta på klienterna och det funkar perfekt än så länge. Har kört sen i lördags och inte en enda omstart av varken server eller tjänster har behövts :)
Supernöjd!
P
Postad 09 June 2011 - 18:24
freddehboy
  • freddehboy
  • 304 inlägg
Trevligt om det skulle gå för dig nu när du haft sådana problem, bra för mig om det går för dig!
Mitt problem är just att servern är pålitlig i 3-4 dagar och sedan behöver man starta om för att det ska gå igen. Fel som ingen signal eller ljud hittas till fel som hackig bild m.m. Efter en omstar går det som inget har hänt men varför kan den inte hålla stabiliteten under längre tid?
3 punkter som jag vill ha ordning på:
Bättre EPG hantering!
Möjlighet att uppdatera kanallistor automatiskt!
Kunna återställa MP servern var 3 dag utan att behöva starta om datorn!
Får jag detta med den nya Argus så är det super! Har du NewCS och ACamnd till Argus och fungerar det bra? Fick det aldrig att fungera så det är ett krav att jag får det att fungerar om jag ska gå över till Argus!?
Förutom dessa problem är servern stabil men vissa codec problem, vad har du för Codec?
Tillägg: Vi hade schemalagt för inspelningar idag men när vi sedan skulle gå in och titta hade tjänsten stängt av sig! Varför beter den sig så här?
Mvh Fredik
Redigerat av freddehboy, 09 June 2011 - 19:39.
Postad 15 June 2011 - 21:22
  • 280 inlägg
Jag hade satt upp min Argus med 1.5.0.3 som jag uppade till 1.6.0 och det gick utan problem. Hade redan kortdelningen på plats så det åkte med i uppen. Servern har nu funkat felfritt sen den 4:e med bara en omstart och det berodde på en annan grej. Min NewCS server som körs på en liten EEEPC 900 startas istortsätt aldrig om.
Har tänkt riva kanallistan och göra en nysökning, men jag väntar med det till semestern när det finns mer tid.
P
Postad 15 June 2011 - 22:25
freddehboy
  • freddehboy
  • 304 inlägg
Låter ju väldigt bra!
Du kör bara Argus TV server mot MP klienten?!
Förut fick du starta om nästan var 3-4 dag?
Det ända är att det fungerar rätt bra nu men om man får bort även de små felen så är det nog värt att gå över, man kan ju ha kvar mp tv server men stänga av tjänsten när man testar!
Det ända är att jag aldrig fick newcs att prata med Argus men om jag gör som din setup så kan jag försöka!
Är den stabilare generellt än mp tv server?
Mvh Fredrik
Postad 27 June 2011 - 11:05
freddehboy
  • freddehboy
  • 304 inlägg
Hej Petta
Hur går det?
Mvh Fredrik
Postad 06 July 2011 - 09:44
  • 280 inlägg
Allt går bra förutom att båda mina Terratec kort och mitt skystar kort har dött. Misstänker att värmen på vinden har gett sin bidragande faktor. Korten hittas men det går inte få signal på något av korten varken i Argus eller i MPs tv server. Mitt TeVii kort funkar kalas, så jag har beställt två till TeVii kort istället från DVBSHOP.
Argusen funkar hur bra som helst, om MPs stabilitet är 10% är Argus 90%. Har inte rört servern på veckor, jämfört med MP som måste startas om flera ggr om dagen i värsta fall.
Jag tror att Argus är lättare att få till om du redan har MPs TV server instalerad och fungerande med NewCS och MDPlugins. Inaktivera tvserver servicen och installera sedan Argus i MySql eller SQLExpress, jag har gjort så att MP kör i MySQL och Argus kör i SQLExpress, tror det kan vara bra att skilja även där.
Sedan har jag kopierat in hela katalogstrukturen från MPs MDPlugins till rätt ställe under fortherecord så då funkar allt perfa för mig iallafall.
Peter
