Panasonic PT-AH1000E
9 svar till detta ämne
Panasonic PT-AH1000 (Projektorer) 1 (0) Inga priser
1 relaterade trådar
Postad 02 September 2011 - 12:45
Dr. Zaius
  • Dr. Zaius
  • 3612 inlägg
Bifogad fil  PT_AH1000E_1_jupiter_HiResA1001001A11H31B12651D75418.jpg   16.81K   5 Antal nerladdningar
Wiesbaden — Sep 2nd 2011
Panasonic Debuts a New Full-HD Home Cinema Projector with 2,800 Lumens of Brightness
The PT-AH1000E Delivers Full-HD Large Screen Entertainment with More Brightness and More Excitement for Movie, Sports and Game Enthusiasts
Panasonic has today announced the PT-AH1000E Full High-Definition LCD Home Cinema Projector with 1080p (1,920 x 1,080 pixel) resolution. Encompassing a high brightness of 2,800 lumens and a 50,000:1 contrast ratio, the PT-AH1000E lets friends and family enjoy Full-HD large screen entertainment from movies to sports and games in various lighting conditions. Whether for a house party, sports showing, or a regular movie night, the PT-AH1000E will keep viewers engaged in the story and action through the stunning image quality.
The PT-AH1000E projector produces bright, sharp images, by employing a new, high-power 280-watt Red-Rich lamp and optical unit that combine to generate 2,800 lumens of brightness for comfortable viewing in various lighting conditions. In addition, the advanced Light Harmonizer 3 assists the versatile use of the projector by automatically adjusting the picture quality of the image to match the living room or cinema room conditions. This is made possible by utilizing the built in ambient light and colour sensors that adjust the white balance, gamma curve, sharpness settings to maintain bright, crisp pictures to match the users’ viewing environment.
In a darker room, an even higher picture quality can be enjoyed with Panasonic’s Hollywood tuning imaging technology. The PT-AH1000E is equipped with many advanced optical components such as the Dynamic Iris Pro and Pure Colour Filter Pro that assists with reproducing a stunning 50,000:1 contrast ratio and exceptional colour accuracy. The intelligent Dynamic Iris Pro adjusts the unit’s optical iris, the Red-Rich Lamp and gamma curve 50 times per second to produce beautiful images with excellent black level and shadow detail. The PT-AH1000E’s Pure Colour Filter Pro achieves a high purity level of the three primary colours – red, green and blue – while displaying deeper, purer blacks, with extended colour gamut. In addition, the PT-AH1000E excels at showing fine detail thanks to the proprietary Detail Clarity Processor 3 engine.
With the powerful light output and the extended dynamic range, the PT-AH1000E encompasses a total of seven picture modes that provide optimal performance for different contents. Seven preset picture modes include, Sports, Game, Cinema1, Vivid Cinema, Normal, REC709, and Dynamic mode.
In Sports mode, users can enjoy the game with minimal frame delay and image tuning that lively brings out the players for an exciting match of football, baseball, soccer and many other sports enjoyed by a crowd. While in Game mode, picture quality characteristics have been specifically tuned to reveal more image details in the dark or over-saturated areas that are prevalent in many games. Together with the preset picture mode, the Motion Effect function makes sure that the fast-moving images are crisp and clear. This new technology detects and analyzes the brightness and frequency distribution data of the image. Based on this analysis, it optimizes the sharpness along a time axis to maintain naturally sharp images for optimal viewing.
Maximum picture quality can be assured on the PT-AH1000E by using the built in Waveform monitor as a guideline. Furthermore, the Split Adjust Mode provides an easy to navigate solution for those looking to adjust different picture settings on the projector.
Initial setup and installation are quick and easy, because the 2x zoom can cast a 120-inch diagonal image from as close as 3.5 meters (about 11.5 feet) to 7 meters (23 feet) from the screen. The projector’s lens shift capability enables 68 percent vertical adjustment and 26 percent horizontal adjustment, so the user can suspend the projector either close to the ceiling or mount it to a wall. The PT-AH1000E is also equipped with two HDMI™ inputs (supporting x.v.Colour™ and Deep Colour), so multiple HD sources can be connected without an HDMI switcher. More theatre automation, such as lighting and a motorized screen, is possible with the PT-AH1000E because it comes equipped with two programmable 12-volt trigger terminals and VIERA Link. VIERA Link provides seamless operation of multiple VIERA Link compatible Panasonic devices by using the PT-AH1000E remote control. All this and more give the PT-AH1000E the power that it needs to serve as the core of a dynamic AV home cinema or a casual entertainment centre right in your living room.
The PT-AH1000E also takes eco into consideration. The new Eco Management function reduces power consumption depending on different parameters, for example, ambient light conditions and situations when no signal is input to the projector. An off-timer can also be set to reduce wasteful power consumption when the projector is mistakenly left on unattended. Advanced Panasonic digital circuitry intelligently determines the necessary power output of the lamp depending on the content being displayed by analyzing more than 3 billion different image patterns. This advanced analysis process reduces the main power consumption by as much as 10 percent when the Dynamic Iris Pro function is operating, thus saving energy. The PT-AH1000E also prides an extremely low standby power consumption of 0.08 watt.
The Panasonic PT-AH1000E Full High-Definition home cinema projector is made in
Japan and will be available in October 2011, through authorized Panasonic resellers, at an MSRP of € 2,099.
To learn more about the new PT-AH1000E projector, please visit: http://panasonic.net/avc/projector or follow Panasonic Projectors on Facebook: www.facebook.com/panasonicprojector
http://www.panasonic...tail.php?news=9
Redigerat av Dr. Zaius, 02 September 2011 - 14:50.
Postad 02 September 2011 - 12:55
direktorn
  • direktorn
  • 198 inlägg
Trevligt med en lillebror :lol:
Postad 14 September 2011 - 10:52
masse70
  • masse70
  • 8528 inlägg
Äntligen en sann efterträdare till min gamla PT-AX200 och dessutom i vitt och rätt prisklass!
Postad 02 November 2011 - 07:35
  • 10392 inlägg
Den får bra betyg hos Projector Central (heter PT-AR100U där).
http://www.projector...ctor_review.htm
Redigerat av hassesolo, 02 November 2011 - 07:42.
Postad 02 November 2011 - 08:33
Unregistered7fb84d09
  • Unregistered7fb84d09
  • 1770 inlägg
Jag tror PC är kraftigt färgade i sina bedömningar när det gäller Panasonic så deras Panasonic-tester tar jag med en STOR nypa salt.
Postad 02 November 2011 - 09:46
Jokkmokksjocke
  • Jokkmokksjocke
  • 2384 inlägg
hehe..PC gillar alla projar..vad kommer denna att kosta i Sverige.
Postad 01 April 2012 - 09:51
Unregistered76636631
  • Unregistered76636631
  • 1029 inlägg
ehm...finns den att köpa i Sverige eller är den borttrollad ? FInns ju uppsatt på panasonics sajt.
http://www.panasonic...9310/index.html
Postad 01 April 2012 - 10:30
B8
  • B8
  • 4536 inlägg
Tja... en snabb sökning på tex prisjakt (;)) visar att den finns att köpa. https://www.prisjakt...t.php?p=1021716
Verkligen ingen som har den som kan ge ett litet utlåtande? Eller som åtminstone har sett den?
Postad 02 April 2012 - 14:11
  • 1029 inlägg
Tja... en snabb sökning på tex prisjakt ( ;)) visar att den finns att köpa. https://www.prisjakt...t.php?p=1021716
ha, undrar hur jag kunde missa den.
Synd att den inte prismässigt håller sig närmare w6000, är svärtan f.ö. i typ närheten av pt4000 eller är det bara att glömma?
Postad 15 April 2012 - 21:37
Unregistered4854993d
  • Unregistered4854993d
  • 31 inlägg
Är lite sugen på att köpa en PT-AR100U i USA som är samma modell som PT-AH1000E, enligt specen skall den ha ett nätagg som stödjer 100-240V så det borde inte vara några problem. Man kan köpa en USA modell för $1000-1100 och det är under halva priset med moms och tull mot svenska riktpriset på 20000 kr ink moms. Är det någon som vet om det finns några "dolda" skillnader som skull göra att det blev problem att använda den i Sverige bortsett från eventuella garantier?
/Jesper
  • More is Always Better
    2026-08-29 18:47:07
