Postad 29 September 2011 - 14:44
dhanjel
dhanjel
2495 inlägg
Känns som denna surf/läs-platta förtjänar en egen tråd!   Display 7" multi-touch display with IPS (in-plane switching) technology and anti-reflective treatment, 1024 x 600 pixel resolution at 169 ppi, 16 million colors. Size (in inches) 7.5" x 4.7" x 0.45" (190 mm x 120 mm x 11.4 mm). Weight 14.6 ounces (413 grams). System Requirements None, because it's wireless and doesn't require a computer. On-device Storage 8GB internal. That's enough for 80 apps, plus either 10 movies or 800 songs or 6,000 books. Cloud Storage Free cloud storage for all Amazon content Battery Life Up to 8 hours of continuous reading or 7.5 hours of video playback, with wireless off. Battery life will vary based on wireless usage, such as web browsing and downloading content. Charge Time Fully charges in approximately 4 hours via included U.S. power adapter. Also supports charging from your computer via USB. Wi-Fi Connectivity Supports public and private Wi-Fi networks or hotspots that use the 802.11b, 802.11g, 802.11n, or 802.1X standard with support for WEP, WPA and WPA2 security using password authentication; does not support connecting to ad-hoc (or peer-to-peer) Wi-Fi networks. USB Port USB 2.0 (micro-B connector) Audio 3.5 mm stereo audio jack, top-mounted stereo speakers. Content Formats Supported Kindle (AZW), TXT, PDF, unprotected MOBI, PRC natively, Audible (Audible Enhanced (AA, AAX)), DOC, DOCX, JPEG, GIF, PNG, BMP, non-DRM AAC, MP3, MIDI, OGG, WAV, MP4, VP8. Documentation Quick Start Guide(included in box); Kindle User's Guide (pre-installed on device) Warranty and Service 1-year limited warranty and service included. Optional 2-year Extended Warranty available for U.S. customers sold separately. Use of Kindle is subject to the terms found here. Included in the Box Kindle Fire device, U.S. power adapter (supports 100-240V), and Quick Start Guide.
Reklamfilm: Kindle Fire TV Commercial Hemsida: Kindle Fire - Full Color Kindle with 7" Multi-Touch Display, Wi-Fi Går inte beställa/köpa internationellt än, men går säkert med tex BorderLinx. Någon som tänkt beställa / förboka? Släpps den 15:e november.
Redigerat av dhanjel, 29 September 2011 - 14:43.
Postad 29 September 2011 - 14:48
jaQoB
jaQoB
1691 inlägg
Helt klart intressant, om man på ett vettigt (och billigt) sätt kan köpa böcker och framförallt tidningar från t.ex. Amazon. Nej, har ingen lust att betala 4 gånger så mycket för tidningarna bara för att jag bor utanför USA
Postad 29 September 2011 - 15:41
dhanjel
dhanjel
2495 inlägg
Zinio ger ju iof redan billiga tidningar.
Men ca 2000kr för en fire med frakt och tull känns ju rätt ok.
Postad 30 September 2011 - 09:28
jaQoB
jaQoB
1691 inlägg
Zinio ger ju iof redan billiga tidningar. Men ca 2000kr för en fire med frakt och tull känns ju rätt ok.
Har inte GQ, inte Wired och inte sådär jättebilligt... Prenumeration på pappersversionen av Wired i USA. 29.99$ / 24 nummer ~ 1.25$ GQ 15$ / 12 nummer = ~ 1.25$ Det är vad jag kallar billigt. Evinnerligt trött på de svenska priserna på tidningar... Trodde det skulle lösa sig med läsplattorna, men icke.
Postad 02 December 2011 - 12:56
Ireniak
Ireniak
1 inlägg
Jag har spanat lite på den här men är osäker. Jag är ute efter en läsplatta, men Fire har ju inte e-ink, hur pass stor skillnad blir det från att läsa på skärmen till laptopen till Fire'n? En "vanlig" kindle har ju e-ink, men inte speciellt många andra funktioner vad jag förstår. Om jag ändå ska köpa en så känns det ju värt med en Fire.
Hur funkar det med att ha den i Sverige och kan man ens köpa den hit än? Tänker dels på wifin, men även på utbudet, låna eller köpa? Är den låst till Amazon? Format?
Hur pass med är Sverige när det kommer till e-böcker, inte bara på svenska utan även på engelska?
Många frågor, hoppas någon kan svara.
Postad 07 December 2011 - 11:39
hensod
hensod
26 inlägg
Jag har spanat lite på den här men är osäker. Jag är ute efter en läsplatta, men Fire har ju inte e-ink, hur pass stor skillnad blir det från att läsa på skärmen till laptopen till Fire'n? En "vanlig" kindle har ju e-ink, men inte speciellt många andra funktioner vad jag förstår. Om jag ändå ska köpa en så känns det ju värt med en Fire. Hur funkar det med att ha den i Sverige och kan man ens köpa den hit än? Tänker dels på wifin, men även på utbudet, låna eller köpa? Är den låst till Amazon? Format? Hur pass med är Sverige när det kommer till e-böcker, inte bara på svenska utan även på engelska? Många frågor, hoppas någon kan svara.
På www.elib.se så kan du se utbudet på böcker som kan läsa via läsplatta.
Postad 07 December 2011 - 15:46
dhanjel
dhanjel
2495 inlägg
Ska du bara läsa är en riktig läsplatta ovärderlig, jag har själv en Kindle (3rd gen). Vill du göra andra saker så fungerar en surfplatta som mellanting, men det är långt ifrån optimalt.
Postad 18 May 2012 - 09:47
Skrewie
Skrewie
69 inlägg
Nu när IC9 med HWacc så är detta en full odlad Android platta ! (Allt funkar klockrent) >> http://forum.xda-dev...play.php?f=1309Benchmarks Antutu : 5750 Quadrant: 2800 (Fick bättre med IC7 nästan 4k) Vet ej varför ??!?! Linpack : 42 mflops / duel 72 mflops Rätt bra för en platta för 1400:-
Redigerat av Skrewie, 18 May 2012 - 12:05.
Även taggad med Amazon, Kindle, Fire, KindleFire
Hemma →
Mobiltelefoni & GPS →
Tablets →
Startad av
Alban
, 18 Oct 2018
kindle, letto, e-bok
Media & Mediauppspelning →
Bild/Ljuduppspelning (Övriga format & Vintage) →
Startad av
Unregistered03303df7
, 07 Jan 2018
Amazon, Alexa, Siri, Apple och 4 fler...
Hemma →
Tablets →
Startad av
eLGee
, 19 May 2016
kindle, amazon, oasis
Hemma
Mobiltelefoni & GPS
Tablets
Ny projektor!
