Kommentarer till Gamla lägenheten av linusgrip
15 svar till detta ämne
Postad 30 October 2012 - 12:12
linusgrip
  • linusgrip
Kommentarer till mina leksaker av linusgrip
bulmash
  • bulmash
  • 20 inlägg
Vad betalade du för divorna och var? Vad har du haft som du jämfört dom mot? Har själv nämligen kollat på just dessa.
Postad 30 October 2012 - 12:18
linusgrip
  • linusgrip
MYChifi i borlänge köpte jag dem, betalade 26k då dem har rea november ut på hela sitt sortiment. Jämförde dem med Mentor 8 men dessa föll mig bäst i smaken =)
Postad 17 November 2012 - 01:10
Unregistered411ed869
  • Unregistered411ed869
  • 0 inlägg
Vackert! Riktigt fina dessa divor!
Grattis.
Postad 20 November 2012 - 16:18
MrLelle
  • MrLelle
  • 288 inlägg
Grattis till en bra projje för priset! Rekommenderar testa dessa inställninga som jag hittade en gång (blev klart bättre!:
TW3200/TW3600 settings for optimum colour and black level with movies:
-In the Signal menu choose Advanced and then HDMI Range. It can be set to either Expanded or normal. Choose HDMI Range Normal.
-In the Image menu set Brightness control to Eco mode. Brightness is thereby lowered a tiny bit and this increases life time of the bulp. Also black level is increased slightly and the fan is less noisy.
-In the Image menu set Auto iris to High Speed: Will unquestionably increase black level slightly in very dark scenes with it's lowering of the light coming through the iris on a scene by scene basis. The downside is a slight noise from the iris when it opens/closes. There are two settings - Normal and High Speed mode. Normal is not recommended as it can't really keep up with very fast cuts between bright and dark scenes. High Speed is almost perfect visually but does make more noise. Like the noise from the projector's fan it is inaudible except during silent scenes in movies. Some don't mind, others do - so you will have to try for yourself to see if you prefer it off or on.
-In the image menu set Colour temperature to 7000k: The default is 6500k and for most projectors this is the best setting. The colour temperature is a bit warmer on the TW3200 than the norm though so several prefer to counter this with either the 7000k or 7500k setting. Black level also benefits slightly from 7000k/7500k.
-In the Gamma menu (pres "Gamma" on the remote) several people have experienced better black level when running with the Gamma 2.3 setting in stead of the default 2.2 setting.
Postad 20 November 2012 - 17:31
balagarba
  • balagarba
  • 157 inlägg
Grattis till nya projjen! fina högtalare också.Ang att du inte är riktigt nöjd med svärtan på projjen så tror jag största problemet är att rummet är helvitt,Allt ljus reflekteras tillbaka på duken och blaskar ur bilden.
Postad 20 November 2012 - 19:10
Unregistered95265801
  • Unregistered95265801
  • 930 inlägg
Tack! Du har sjukt fina prylar du med, härligt!
Postad 21 November 2012 - 01:06
linusgrip
  • linusgrip
Tack för tipsen MrLelle, det skall testas!
balagarba: det är så sant som det är sagt, funderar på om jag ska byta till någon mörkare färg/tapet framöver.
Postad 25 November 2012 - 10:33
Ahla77
  • Ahla77
Fin fint! Tunga högtalare! Snyggt!!
Postad 30 November 2012 - 16:14
Unregistered91fc4080
  • Unregistered91fc4080
Det tackar man för! ;) Grymt nyfiken på hur Swans spelar, riktigt snygga ialla fall !
Postad 10 January 2013 - 11:28
Unregisteredb27a28b7
  • Unregisteredb27a28b7
  • 2307 inlägg
Härlig stereo!
Har tyvärr aldrig haft äran att lyssna på ett par Swans. Men spelar de i närheten av hur de ser ut verkar de lovande!
10p inskickat.
Postad 10 January 2013 - 11:40
Unregistered1573
  • Unregistered1573
  • 900 inlägg
Snyggt! Riktigt fina absorbenter.
Postad 17 January 2013 - 09:18
Unregistered2bf97601
  • Unregistered2bf97601
  • 45 inlägg
Vad kostade det att skriva ut på tyget? :)
är sugen på att göra mig några tavlor, dock är jag inte sugen att betala ~2000kr som canvas tavlor kostar :(
Postad 01 February 2013 - 08:21
kongo_fw
  • kongo_fw
  • 92 inlägg
Grymt snygga högtalare! Hoppas dom låter lika bra som dom ser ut.
Tavlorna var oxå jätte fina. 10p
Postad 15 February 2013 - 19:55
DigetZ
  • DigetZ
  • 82 inlägg
Älskar dina Swanar! Kompakta men kraftiga!
Postad 03 November 2014 - 21:39
Jag såg dessa Svanar live, snygga absolut:) Är du nöjd med projektorn?
