Officiell tråd - Dune HD Base 3D
810 svar till detta ämne
Postad 18 January 2013 - 16:41
PalmiNio
  • PalmiNio
  • 8074 inlägg
Nämen den finns i verkligheten!
Har inte hittat någon annan med hands-on själv. Kan jag säga world-exclusive?
Posta vad ni tycker jag ska testa. Har 3D TV hemma nu!
Bifogad fil  bild3.JPG   87.8K   26 Antal nerladdningar
Bifogad fil  bild.JPG   138.14K   25 Antal nerladdningar
Bifogad fil  bild2.JPG   89.18K   21 Antal nerladdningar
Utdrag från PDF:
 Processor: Sigma Designs 8672/8673
 RAM: 512 MB
 Flash memory: 256 MB + 4 GB
 Connectors: HDMI 1.4, 3x USB 2.0 (2x rear, 1x front), composite, component, analog stereo outputs, optical S/PDIF, coaxial SPDIF, Ethernet 10/100/1000 Mb/s, SD card slot (front), power input, power switch (back), LED indicator (front)
 Internal storage: Internal HDD rack with hot swap function for SATA HDD 3.5".
 Media sources: external HDD (USB), external optical drive (USB), USB devices (USB flash drive, USB card reader, etc), built-in SD card reader (SD/SDHC), PC and NAS in local network (SMB, NFS, UPnP, HTTP), other Internet and local network media sources (HTTP, multicast UDP RTP)
 Web Browser: Opera, WebKit
 DLNA: DLNA (1.5 or 2.0) client support
 Adobe Flash: 3.1 (Lite, standalone) supported
 DRM options: PlayReady, Verimatrix, Secure Media. Other DRM can be added by request
 Video codecs: MPEG2, MPEG4, XVID, WMV9, VC1, H.264; support for very high bitrate video (up to 50 MBit/s and higher)
 Video file formats: MKV, MPEG-TS, MPEG-PS, M2TS, VOB, AVI, MOV, MP4, QT, ASF, WMV, BDMV, DVD-ISO, VIDEO_TS
 3D Video Support: MVC, Side-by-side, Top/Bottom
 Video output modes: wide range of supported output resolutions (up to 1080p) and framerates (including 23.976p, 24p, PAL, NTSC)
 Video output framerate: automatic (according to the played content) and manual
 Audio codecs: AC3 (Dolby Digital), DTS, MPEG, AAC, LPCM, WMA, WMAPro, EAC3 (Dolby Digital Plus), Dolby True HD, DTS HD High Resolution Audio, DTS HD Master Audio, FLAC, multichannel FLAC, Ogg/Vorbis; support for very high quality audio (up to 192 kHz / 24-bit)
 Audio file formats: MP3, MPA, M4A, WMA, FLAC, APE (Monkey’s Audio), WV Pack, Ogg/Vorbis, WAV, AC3, AAC
 HD audio support: pass-through (up to 7.1 channels) and decoding (up to 7.1 channels) of Dolby TrueHD and DTS HD MA audio tracks (Blu-ray, TS, MKV), pass-through (up to 7.1 channels) of multichannel LPCM audio tracks (Blu-ray, TS, MKV), decoding (up to 7.1 channels) of FLAC audio tracks (MKV, external)
 Subtitle formats: SRT (external), SUB (Micro DVD) (external), text (MKV), SSA/ASS (MKV, external), VobSub (MP4, MKV, external SUB/IDX), PGS (Blu-ray, TS, MKV)
 Hardware 3D Graphics Acceleration: OpenGL support
 Picture file formats: JPEG, PNG, BMP, GIF
 Playlist file formats: M3U, PLS
 Photo viewer functions: slideshow, transition effects, picture rotation, zoom, browse playlist, repeat, shuffle
 Audio playback functions: browse playlist, repeat, shuffle, ID3 tags, plasma TV burn-in prevention
 File systems: FAT16/FAT32 (read-write), EXT2/EXT3/EXT4 (read-write), NTFS (read-write)
 Ethernet: 10/100/1000 Mb/s
 Wi-Fi: Internal Wi-Fi (b/g/n) module
 Dune Network Playback Accelerator: special optimizations ensuring best-in-class network playback performance for the Sigma Designs 864x-865x-867x platform and enabling smooth playback of any supported kind of media content via any network protocol (including NFS and SMB) even in 100 Mbit/s Ethernet networks.
Redigerat av PalmiNio, 18 January 2013 - 16:42.
Postad 18 January 2013 - 20:56
Unregistereda7fc6b80
  • Unregistereda7fc6b80
  • 555 inlägg
Grattis väntar själv spänt på få min vart köpte du din ?
Testa gärna streama BD.iso över nfs och samba samt 3D streaming, har A400 hemma och testar denna och kan ju direkt säga att den inte lever upp till sina spec
Postad 19 January 2013 - 08:58
Unregistereddc471864
  • Unregistereddc471864
  • 24891 inlägg
Håller med. Testa streaming av 3D bluray isos
Postad 19 January 2013 - 09:11
  • 555 inlägg
Dem ville på AV forum att jag skulle testa om A-400 med smb istället och det har jag nu gjort med damma resultat, buffrar efter 10 sek ich tappar sync ljud försvinner, knappt dvd iso filer fungerar.
Rent hopplöst! Hoppas verkligen Dune tagit vara på en senare release och släpper den med lika stabil och fungerande som Max varit med allt man streamat!
Körde samma filer till Mede8er och den tiggar 3D felfritt, har Qnap 669 Pro så mitt nätverk är knappast hindret! A-400 kan säkerligen bli riktigt grym men inget jag tänker sitta och vänta på!
Dune Base 3D är mitt enda hopp nu :) Mede8er skall ut då den inte passar in här :)
Postad 19 January 2013 - 10:09
PalmiNio
  • PalmiNio
  • 8074 inlägg
I am on it:)
Postad 19 January 2013 - 10:14
  • 24891 inlägg
min xtreamer 3 har inga sånna problem. Funkar fint med streaming av BD isos i 3D.
Postad 19 January 2013 - 10:44
  • 555 inlägg
Xtreamer är ju en leksak :) Jag hade själv en Prodigy eller rättare sagt både den svart Black och vanliga.
Visst fungerar det strama men så fort du skall göra ngt, försök Zooma så hänger sig hela skiten. Sedan hatar jag allt vad Xtreamer heter de utlovar massa saker men skösätter aldrig det. Gillar inte Hemorojd i mina mediaspelare och dessutom inte gränssnittet heller. Den gör sitt jobb men då är Mede8er betydligt bättre och stabilare som även klarar zooma och ändra subs utan den freakar ut.
Postad 19 January 2013 - 11:01
PalmiNio
  • PalmiNio
  • 8074 inlägg
Suck. Dagens första problem.
Spelaren hittar min dator över SMB men inget innehåll.
Den hittar men HTPC i samma workgroup men där hittar den också innehållet.
Jobbigt.
Postad 19 January 2013 - 11:06
  • 555 inlägg
De problemet hade jag också du måste väl lägga till inloggning för smb.
NFS fungerar bättre om du har möjlighet
Postad 19 January 2013 - 11:53
PalmiNio
  • PalmiNio
  • 8074 inlägg
Fixat.
Har testat vanlig BluRay över SMB. Inga problem med Bitstream DTS-MA so far.
Postad 19 January 2013 - 12:36
Unregistered7c5139ba
  • Unregistered7c5139ba
  • 1310 inlägg
Fixat.
Låter strålande! Om du har möjlighet så testa gärna någon "branched" BD-ISO. Disney använder dessa mycket. (Menar alltså filmer uppstyckade i många små m2ts). De flesta andra spelare har problem med detta.
Avengers 3D vore spännande om du kunde testa, eller annan titel med väldigt hög bittrare.
Vad tycker du om snabbhet i menyer och så?
Postad 19 January 2013 - 12:40
PalmiNio
  • PalmiNio
  • 8074 inlägg
Efter strul med kabel som gjorde att jag aldrig fick 3D så har jag nu fattat att jag var tvungen att ha en HDMI 1.4 kabel.
Den som ingick var såklart det och drog den rakt in i TVn.
Har nu Testat följande 2 filmer i 3D.iso:
- Avatar
- Brave
Direkt när jag drog igång kände TVn av 3D och glasögonen gick igång. Prima bild! Detta då över Samba.
Postad 19 January 2013 - 13:20
  • 1310 inlägg
- Avatar
- Brave
Inga problem med buffer underrun eller drop-out med HD-ljud? När du körde direkt mot TVn kunde du kanske inte testa 3D med HD-ljud?
Om du har någon MKV 1080p med DTS-HD MA så vore det också spännande att höra hur det går.
Låter i vilket fall väldigt lovande hittills... :)
Postad 19 January 2013 - 13:37
PalmiNio
  • PalmiNio
  • 8074 inlägg
Körde 2D varianten av TinTin med DTS-MA bitstream. Inga problem under den tiden jag kollade.
Finns inställning för buffring.
Postad 19 January 2013 - 17:28
PalmiNio
  • PalmiNio
  • 8074 inlägg
Så. Efter lite inställningar på min Onkyo so fick jag 3D att funka med receivern som mellansteg.
Min setup:
Onkyo TX-NR515
LG 60OM970T
Körde Brave och Avatar. Dune HD Base 3D drar igång filmerna på ca 2-3s. Kör över Samba. Kommer upp hela chapterlistan med huvudspåret som 3D markerad. När jag trycker play startar 3D på TV automatiskt.
DTS-MA körs igång på Onkyon. Efter ca 1h tittande - Inga problem! Inga bufferingsproblem - nothing!
Kör trådat. Avatar peakade runt 85+ i bitrate.
Postad 19 January 2013 - 18:06
  • 24891 inlägg
Nog prodigy som är buggig då. Går utmärkt att zooma på min xtreamer sidewinder 3. Min hänger aldrig sig.
Min setup:
Onkyo TX-NR515
LG 60OM970T
Trevligt. Kan du prova en BD ISO som har extramaterial. Går det att se det då? Det saknar jag på min xtreamer. Den spelar bara default spellistan.
  • 1310 inlägg
Tack för test och övrig info! :)
Är det något du har att anmärka på annars?
För det verkar ju som den går som en klocka?
Postad 19 January 2013 - 18:08
PalmiNio
  • PalmiNio
  • 8074 inlägg
Hela content listan kommer upp så ja det kan man.
2-3s lagg när jag körde på subs i 3D.iso. Annars inget.
Postad 19 January 2013 - 18:12
  • 24891 inlägg
Låter lovande. Vad kostade den?
Postad 19 January 2013 - 18:18
PalmiNio
  • PalmiNio
  • 8074 inlägg
0kr. Är på lån för test :)
Körde precis Jelly Sample med bitrate över 110Mbps - [email protected]
Körde även 120Mbps klippet utan problem
Redigerat av PalmiNio, 19 January 2013 - 18:27.
Postad 19 January 2013 - 18:28
PalmiNio
  • PalmiNio
  • 8074 inlägg
Readtest som ger över 27MB/s!
nova85
  • nova85
  • 256 inlägg
Finns det möjlighet att justera texten i höjdled på Dune HD Base 3D? Sitter med en 2.35:1 duk och behöver byta ut min tvix n1 som har just denna funktion.
Postad 19 January 2013 - 18:41
PalmiNio
  • PalmiNio
  • 8074 inlägg
Tyvärr inte vad jag kan se i de vanliga menyerna utanför filmen.
Postad 19 January 2013 - 18:44
nova85
  • nova85
  • 256 inlägg
Aha ok synd, tack för att du tog dig tid att kolla.
Postad 19 January 2013 - 18:57
  • 555 inlägg
Är det nytt gränsnitt mot Dune Max?
Postad 19 January 2013 - 19:19
Rilly89
  • Rilly89
  • 785 inlägg
I HD Max vill jag minnas att man flyttar texten när filmen är igång. Det borde nog vara likadant på den här.
Postad 19 January 2013 - 20:36
PalmiNio
  • PalmiNio
  • 8074 inlägg
Yes. Dock lika enkelt.
Kommer kolla senare.
Måste säga att den känns jävligt stabil. Osexiga menyer och inget extra extra - men jävligt stabil!
Postad 19 January 2013 - 21:26
  • 24891 inlägg
Jag gillar osexigt och enkelt. Massa covers å skit kan man vara utan :)
Postad 19 January 2013 - 23:53
Unregistered577c6879
  • Unregistered577c6879
  • 2986 inlägg
Har du testat om den flaggar Cinavia?
Är det gamla Dynamics på datorn? =)
Postad 20 January 2013 - 00:24
PalmiNio
  • PalmiNio
  • 8074 inlägg
Ingen BluRay = ingen cinavia
Postad 20 January 2013 - 00:40
Unregistered03b1c43b
  • Unregistered03b1c43b
frågan är ju när dom släpper Dune HD Max 3d.....skulle ju vara klart intressant med en spelare i den också
blir nog en uppdatering mot min gamla Prime 3.0....
Postad 20 January 2013 - 00:53
  • 2986 inlägg
Ja det är vad AACS säger, men Sigma inkluderar Cinavia i alla sina SDK numera.
Postad 20 January 2013 - 01:59
PalmiNio
  • PalmiNio
  • 8074 inlägg
Har kört några "olagliga" filmer så borde ha flaggats. No issues
Postad 20 January 2013 - 08:16
  • 24891 inlägg
Nja det är väl bara om man använder bluray licensen man måste ha cinavia. Dvs om man ska ha full stöd för bluray med menyer och allt så måste man också inkludera cinavia. SÅ har jag fattat det iaf.
  • 1310 inlägg
Njaa, i denna Dune sitter ett förhållandevis gammalt chip. Jämfört med PCH A-400 som har det nya 8911. 8910 var det chip som var på tapeten länge (även för Dune). 8911 är ett 8910 fast utan Cinavia...
Och om Cinavia är inkluderat i ett SDK är det endast bundlat med full BD-licens (menyer)
Aktiveras inte full BD-licens så aktiveras inte heller Cinavia.
Det kommer aldrig komma en (BD-spelarlös) mediaspelare som inkluderar Cinavia. Varför? Det vore som att sälja en bil utan motor och där det inte finns någon passande motor i världen att köpa och montera in heller.
Går inte att använda = går inte att sälja...
Postad 20 January 2013 - 08:17
  • 24891 inlägg
Isf måste de implementera cinavia också så det lär inte hända.
Postad 20 January 2013 - 10:05
PalmiNio
  • PalmiNio
  • 8074 inlägg
Kan bekräfta att man kan shifta Subs när man är inne i filmen.
Bifogad fil  Subs. Shift.JPG   343.42K   23 Antal nerladdningar
Bifogad fil  subs.JPG   334.66K   16 Antal nerladdningar
Postad 20 January 2013 - 12:50
innebär det att det inte finns någon media spelare som klarar 3d (både över skiva och nätverk och även andra filer ex. mkv) finns?
var lite inställd på att det skulle komma en sådan?
Redigerat av Unregistered03b1c43b, 20 January 2013 - 12:51.
Postad 20 January 2013 - 13:06
cave
  • cave
  • 160 inlägg
PalmiNio, en eloge för dina tester, väldigt metodiskt genomfört! Jag har dock ändå några utestående frågor:
Blir nyfiken på vad du behövde ändra i receivern.
Så en fråga från mig som inte haft Dune-produkter innan:
Finns det en funktion för att skippa X antal sekunder i en filmfil? Ofta vill jag skippa i intervaller om 15 eller 30 sekunder i början av TV-serier. Har haft den funktionen på xbmc och TViX men inte på WDTV och saknar den enormt mycket. För att vara användbar ska det gå riktigt snabbt att skippa eftersom man oftast behöver skippa mer än en gång, dvs max 1s och gärna 1/10 s.
Hur är det med switching av framerate? Specifikt 24 hz. Har förstått på specarna att den switchar, men gör den rätt™?
Har du testat DLNA-stödet?
Finns det chans att Airplay-stöd kommer?
Du skrev också
Förutsätter att enklare filmfiler drar igång snabbare än så?
Du har kollat av ganska många filmer på ganska kort tid, så jag antar att du inte kollat mer än några minuter på respektive film? EDIT: Såg nu att du kollat 1h på Avatar, 1h borde räcka, tack!
Redigerat av cave, 20 January 2013 - 13:07.
Postad 20 January 2013 - 13:13
  • 24891 inlägg
Alla blurayspelare måste ha cinavia numera.
Postad 20 January 2013 - 14:26
PalmiNio
  • PalmiNio
  • 8074 inlägg
Fick sätta att den skulle skicka endast via utgång 1 och inte mixtra med bilden. Då gick signalen klockrent.
Ej testat DLNA. AirPlay är möjligt men vet ej :)
Hade den på Auto och den switchade bra. Upplevde inga 24hz problem men det brukar inte Sigma ha.
Postad 20 January 2013 - 16:53
  • 555 inlägg
Dock klarar ju inte A-400 ens att streama filmerna så dem får ha hur bra chip som helst så länge skiten inte fingerar så är set helt ointressant. Orka vänta ett halvår innan man ens kan använda den.
Då har ju Dune Max förhoppningsvis släppts och tills dess Dune Base som tydligen verkar fungera i alla fall :)
Postad 20 January 2013 - 20:13
  • 1310 inlägg
Jo, Dune HD Max är undantaget. De visade upp en fungerande spelare på CES nyligen. Planeras att lanseras till sommaren.
Grejen med den är att det inte sitter Sigma chip i utan Intel. Dune säger själva att Cinavia är inkluderat för att kunna spela skivor (och med menyer). De säger också att Cinavia INTE blir aktiverat då man spelar filer, men att en BD rip ändå kan spelas med fulla menyer...
Får väl se om det blir så.
@eureka: jag håller med dig. Nämnde bara chipet i samband med att det talades om att Cinavia är inkluderat i alla nya SDK! :)
Dock verkar de ju fått ordning på en del grejer i A-400, men inte allt. Kommer heller inte köpa den. Inte förrän alldagligt användande fungerar som det skall.
Postad 21 January 2013 - 14:24
PalmiNio
  • PalmiNio
  • 8074 inlägg
Den spelaren tror jag på när ser den på en lista som går att lägga order mot :)
Ne men Dune HD gör uppenbarligen bra spelare men samtidigt visar de upp rätt många som man undrar när de kommer.
Postad 21 January 2013 - 17:23
  • 555 inlägg
Jag kände samma sak över Dune Base 3D den dagen den verkligen finns tror jag att den finns, men nu finns den ju uppenbarligen :) får min på Onsdag så nästa steg blir att vänta på Dune Max 2 får hoppas den kommer till sommaren.
Frågan är om man klarar sig utan menyer så kan man ju faktiskt sälja sin Dune Max nu som för övrigt är super bra, dock onödigt med 2 st och det är ju rätt många som inte ens är intresserade eller har användning av 3D och då är ju Max Nr.1
Postad 21 January 2013 - 18:07
ktd
  • ktd
  • 1662 inlägg
Oh, såg att Base 3D finns på Webhallen. Ska slänga mig i bilen och införskaffa en idag. :)
Xtreamer SideWinder 3D får åka in i sovrummet om jag skulle få för mig att titta på br iso där. Om jag inte försöker få NetOnNet att ta tillbaka den.
Borde gå iom att den är full av brister som Xtreamer verkar skita i.
Postad 21 January 2013 - 18:36
  • 555 inlägg
Dem har väl bara på postorder ?!
Postad 21 January 2013 - 18:37
ktd
  • ktd
  • 1662 inlägg
Dom har butik i Fruängen också.
Postad 21 January 2013 - 19:28
ktd
  • ktd
  • 1662 inlägg
Så där ja. Då har man nått att göra ikväll också. :)
Bifogad fil  Dune HD Base 3D.jpg   1.79MB   22 Antal nerladdningar
Det jobbigaste med att byta prylar är att programmera om Harmonyn. Gjorde en stor ändring innan jul precis när jag bytte Tv, AVR & mediaspelare i ett svep.
Men men... Nån måste ju göra dom smutsiga jobben också.
Postad 21 January 2013 - 23:25
  • 2986 inlägg
1. Du behöver inte BDA-licens för att använda menyer.
2. Du behöver BDA-licens för att använda optisk läsare.
3, AACS är relevant för Cinavia.
4. AACS skiljer på licensed drive och licensed product. Några av Dunes äldre produkter faller in under de kategorierna, men denna i dagsläget faller in under licensed player. Varken du eller jag vet dock vilka licenser de ansökt om eller hurvida licensen gäller för utökande till optisk läsare.
5. Aldrig hört talas om dessa Sigma-bundles, existerar de ens?
