Onkyo 2013: TX-NR525 , TX-NR626, TX-NR727
276 svar till detta ämne
Postad 29 March 2013 - 22:00
vilhelm65
  • vilhelm65
  • 26 inlägg
Har inte sett nån tråd för Onkyos modeller för 2013, så jag startar en! :)
TX-NR525 :
  • 4K Passthrough Function from Compatible Source Devices via HDMI®
  • Internet Radio and Music Streaming Service Connectivity (TuneIn Radio, Last.fm, Spotify, AUPEO!, and Simfy)*1
  • Playback of Audio Files Through Local Network (MP3, WMA, WMA Lossless, FLAC, WAV, Ogg Vorbis, AAC, Apple Lossless, DSD, LPCM*2, and Dolby® TrueHD)
  • Supports Onkyo Remote Apps for iPod touch/iPhone*3 and Android Devices*4
  • Picture-in-Picture Input Source Preview with InstaPrevue™ Technology
  • Direct Digital Connection of iPod/iPhone via Front-Panel USB Port
  • Phase-Matching Bass Boost
  • Audyssey MultEQ® for Room Acoustic Correction
  • Audyssey Dynamic EQ® for Loudness Correction
  • Audyssey Dynamic Volume® Automatic Listening-Level Adjustment
  • Overlaid On-Screen Display (OSD) via HDMI with Quick Set-Up and Home Menu
  • Zone 2 Line-Out for Distributed Audio Playback in Another Room
  • Hybrid Standby Function to Reduce Power Consumption
  • Smart Grid-Ready
*1 Availability of services depends on region. Some services may require a firmware update. Availability of third-party services advertised here is accurate at the time of publication, but may be subject to change without notice. *2 LPCM is available via DLNA only.*3 Compatible with iPod touch (3rd generation or later) and iPhone 3GS or later. All models require iOS 4.2 or later. *4 Requires Android OS 2.1 or later.
AMPLIFIER FEATURES
  • 130 W/Ch (6 Ω, 1 kHz, 1% THD, 1 Channel Driven, IEC)
  • WRAT (Wide Range Amplifier Technology)
  • H.C.P.S. (High Current Power Supply) Massive High Power Transformer
  • Discrete Output Stage Circuitry
  • Optimum Gain Volume Circuitry
  • PLL (Phase Locked Loop) Jitter-Cleaning Circuit Technology for S/PDIF Audio
PROCESSING FEATURES
  • HDMI Support for 3D, Audio Return Channel, DeepColor™, x.v.Color™, LipSync, Dolby TrueHD, DTS-HD Master Audio™, DVD-Audio, Super Audio CD, Multichannel PCM, and CEC
  • TI Burr-Brown 192 kHz/24-Bit DAC for All Channels
  • Advanced 32-Bit Processing DSP Chip
  • 4 DSP Modes for Gaming: Rock, Sports, Action, and RPG
  • Advanced Music Optimizer for Compressed Digital Music Files
  • Theater-Dimensional Virtual Surround Function
  • CinemaFILTER™
  • Direct Mode
  • Pure Audio Mode
  • Double Bass Function
  • Non-Scaling Configuration
  • A-Form Listening Mode Memory
CONNECTION FEATURES
  • 6 HDMI Inputs and 1 Output
  • 2 USB Ports (1 Front/1 Rear)
  • Mass Storage Class USB Memory Playback Capability (Wide Selection of File Formats Supported)
  • Compatible with UWF-1 Wireless LAN Adapter and UBT-1 Bluetooth USB Adapter (Sold Separately)*5
  • HDTV-Capable (720p/1080i) Component Video Switching (2 Inputs and 1 Output)
  • 5 Composite Video Inputs (1 Front/4 Rear) and 1 Output
  • 3 Digital Audio Inputs (1 Optical and 2 Coaxial)
  • 6 Analog Audio Inputs (1 Front/5 Rear)
  • 2 Parallel Subwoofer Pre-Outs
  • Color-Coded, Banana Plug-Compatible Speaker Posts
  • Headphone Jack
OTHER FEATURES
  • Crossover Adjustment for Each Channel (40/50/60/70/80/90/100/120/150/200 Hz)
  • A/V Sync Control (Up to 800 ms in 10 ms Steps at 48 kHz)
  • Tone Control (Bass/Treble) for Front L/R Channels
  • 3-Mode Display Dimmer (Normal/Dim/Dimmer)
  • RDS (PS/RT/PTY/TP) (European Model Only)
  • 40 FM/AM Random Presets
  • Certified with DLNA Version 1.5
  • Firmware Updates via Ethernet and USB
  • RIHD (Remote Interactive over HDMI) for System Control
  • Preprogrammed RI (Remote Interactive) Remote Control
*5 UWF-1 is compatible with front-panel USB port only.
TX-NR626:
  • HDMI® Video Upscaling to 4K with Qdeo™ Technology by Marvell
  • 4K Passthrough from Compatible Source Devices via HDMI
  • Built-in Wi-Fi-Certified Wireless LAN Capability
  • Onboard Bluetooth Audio Streaming Technology
  • Three-Stage Inverted Darlington Circuitry for Front and Center Channels
  • Rearside MHL™ for 1080p Video and Stills from Smartphone and Tablet
  • Playback of Audio Files Over Wireless Home Network (MP3, WMA, WMA Lossless, FLAC, WAV, Ogg Vorbis, AAC, Apple Lossless, DSD, LPCM*2, Dolby TrueHD)
  • Supports Onkyo Remote Apps for iPod touch/iPhone*3 and Android-Powered Devices*4
  • Picture-in-Picture Input Video Preview with InstaPrevue™ Technology
  • Dolby® Pro Logic® IIz Upmixing for Seven-Channel Surround Sound
  • Powered Zone 2 and Zone 2 Line-Out for Distributed Audio Playback in Another Room
  • Hybrid Standby Power-Saving for Video and Network Connectivity in Standby
  • Smart Grid-Ready
  • Bi-Amping Capability for Front Channels
*1 Availability of services depends on region. Some services may require a firmware update. Availability of third-party services advertised here is accurate at the time of publication, but may be subject to change without notice. *2 LPCM is available via DLNA only. *3 Compatible with iPod touch (3rd generation or later) and iPhone 3GS or later. All models require iOS 4.2 or later. *4 Requires Android OS 2.1 or later.
AMPLIFIER FEATURES
  • 160 W/Ch (6 Ω, 1 kHz, 1% THD, 1 Channel Driven, IEC)
  • H.C.P.S. (High Current Power Supply) Massive High-Power Transformer
  • PROCESSING FEATURES
  • HDMI Support for 3D, Audio Return Channel, DeepColor™, x.v.Color™, LipSync, Dolby® TrueHD, DTS-HD Master Audio™, DVD-Audio, Super Audio CD, Multichannel PCM, and CEC
  • CinemaFILTER™
  • Direct Mode
  • Pure Audio Mode
CONNECTION FEATURES
  • 6 HDMI Inputs and 2 Outputs with Audio Return Channel
  • Front-Panel USB Port for Mass Storage Class Devices (Wide Selection of File Formats Supported)
  • HDTV-Capable (720p/1080i) Component Video Switching (1 Input and 1 Output)
  • Phono Input for Turntable Connection
  • Headphone Jack
OTHER FEATURES
  • Independent Crossover Adjustment for Each Channel (40/50/60/70/80/90/100/120/150/200 Hz)
  • Firmware Updates via Network and USB
  • Compatible with RI Dock for iPod/iPhone and AirPlay (DS-A5)
TX-NR727 :
  • THX® Select2 Plus™-Certified for Studio Reference Playback
  • HDMI® Video Upscaling to 4K with Qdeo™ Processing Technology by Marvell
  • Three-Stage Inverted Darlington Circuitry with Discrete Output Stage for All Channels
  • Frontside MHL™ for 1080p Video and Stills from Smartphone and Tablet
  • Playback of Audio Files Over Wireless Home Network (MP3, WMA, WMA Lossless, FLAC, WAV, Ogg Vorbis, AAC, Apple Lossless, DSD, LPCM*2, and Dolby® TrueHD)
  • Audyssey DSX® and Dolby® Pro Logic® IIz Upmixing for Seven-Channel Surround Sound
  • Powered Zone 2 and Zone 2/3 Line-Out for Distributed Audio Playback in Multiple Rooms
  • Smart Grid-Ready
AMPLIFIER FEATURES
  • 170 W/Ch (6 Ω, 1 kHz, 1% THD, 1 Channel Driven, IEC); 185 W/Ch (6 Ω, 1 kHz, 1 Channel Driven, JEITA)
PROCESSING FEATURES
  • Direct Mode
  • Pure Audio Mode
CONNECTION FEATURES
  • 8 HDMI Inputs (1 Front/7 Rear) and 2 Outputs
  • 4 Composite Video Inputs and 1 Output
  • Headphone Jack
OTHER FEATURES
  • Audyssey Dynamic Volume® Listening-Level Adjustment
  • 3-Mode Display Dimmer (Normal/Dim/Dimmer, Volume Knob LED: On/Off)*
  • Aluminum Volume Control Knob
*Note: Volume knob LED is always off when display is dimmed
Redigerat av vilhelm65, 29 March 2013 - 22:01.
Postad 30 March 2013 - 09:45
Unregisteredbf364490
  • Unregisteredbf364490
  • 1887 inlägg
Vad är nytt egentligen? Jag kan inte se nåt...
Postad 30 March 2013 - 09:51
sturebyking
  • sturebyking
  • 124 inlägg
926 och 727 verkar ha inbyggd wifi och bluetooth
Postad 30 March 2013 - 13:17
  • 1887 inlägg
Just det ser det nu. Tyvärr fortfarande bara uppskalning till 4K och ingen 4K pass-through. :-(
Undrar när 828an kommer. 818 kom ju på vårkanten förra året.
Postad 30 March 2013 - 13:55
vilhelm65
  • vilhelm65
  • 26 inlägg
Nima01, det står så¨här: "4K Passthrough from Compatible Source Devices via HDMI", är det det du menar?
Postad 30 March 2013 - 22:02
  • 1887 inlägg
Jisses vad blind jag är...suck! Just det menade jag ja. Det är riktigt bra!
Postad 04 April 2013 - 20:49
Unregistered6fefcfad
  • Unregistered6fefcfad
  • 89 inlägg
Nu har även 929 och 828 börjat dyka upp hos Tyska återförsäljare med pris, dock utan information vad som finns i tyvärr (högst intresserad av om dom behåller audyssey XT32 i 828).
929 ligger just nu på 1599 EUR (~13500kr) och 828 ligger på 1199 EUR (~10000kr), dock så kommer dessa priser med all sannolikhet att ändras i samband med att försäljning börjar men det är ändå en fingervisning av hur priset kan komma att se ut.
Postad 04 April 2013 - 22:51
  • 1887 inlägg
Bara de kan komma ut med vad dessa två burkar innehåller! Kan köpa en 818 för 699 euro (5871 kr) men vill inte köpa en och veckan efter se dessa två. På nåt engelskt forum sa de sept/okt. Samtidigt som tyska siter sätter ut dem redan nu.
Tror inte heller 828an kommer ligga på 1199 euro men kanske på 1000 euro. Det är ändå 300 euro upp från 818.
Postad 05 April 2013 - 08:29
  • 89 inlägg
http://www.schlauershoppen.de skriver 2-3 veckor på 727 och 4-6 veckor på 828, men svårt att veta trovärdigheten i denna information.
Egentligen så skulle jag kunna vänta med inköp till nästa vinter, men jag är lite orolig för att dom väljer att plocka bort xt32 från 828 och gör detta till säljargument för 929 vilken troligen kommer vara ett par tusenlappar dyrare nästa vinter gentemot hur 818 är prissatt just nu i Tyskland.
Dock så brukar elektronik alltid bli bättre med tiden, så kanske är onödigt att stressa med ett köp just nu, men samtidigt lockar det alltid att uppgradera (sitter på en onkyo 674 som börjar bli lite gammal men som egentligen fyller mina behov).
Postad 06 April 2013 - 13:03
vilhelm65
  • vilhelm65
  • 26 inlägg
Lutar åt en 626:a, men vill avvakta lite pga av problemen med 616, o se hur det avlöper med FW etc. 616 går bort, då den inte har phonoingång vad jag kan se, o det vill jag gärna ha.
Postad 08 April 2013 - 15:24
vilhelm65
  • vilhelm65
  • 26 inlägg
Ser än så länge bara en svensk webbutik (www.hembiobutiken.se) som har de senaste modellerna listade, o här är deras priser
(OBS! Rätt pris på 626:an visas inte förrän man lagt den i kundvagnen):
525: 3990:-
626: 5990:- (5190:- i kundvagnen)
727: 9990:-
Redigerat av vilhelm65, 08 April 2013 - 15:25.
Postad 12 April 2013 - 11:58
PalmiNio
  • PalmiNio
  • 8074 inlägg
Känns inte som där är mycket att jubla för i detta årets line-up.
I och med 4k stödet redan kom förra året och 6 HDMI eller fler redan kom i billiga modeller så är det svårt för dem att få en att länga till en uppgradering.
De har liksom inte mer i värde att stoppa in.
Postad 12 April 2013 - 16:33
iqbefriad
  • iqbefriad
  • 241 inlägg
Vad menas egentligen med "4K Passthrough Function from Compatible Source Devices"?
Är det att man kan spela upp 4K på t.ex en dator eller extern spelare och om man har den kopplad genom HDMI så kommer det upp i 4K på TVn?
Postad 12 April 2013 - 17:11
Unregistered1605
  • Unregistered1605
  • 1863 inlägg
Om inkälla kör 4k och TV kan se 4k så kan du se det via receivern.
Postad 24 April 2013 - 15:41
Wingman31
  • Wingman31
Goddag ,,, är det nån som har köpt nån av de 3 än?
Postad 30 April 2013 - 11:06
vilhelm65
  • vilhelm65
  • 26 inlägg
Nä, väntar tills priset sjunkt lite, men sen blir det en 626:a.
Postad 30 April 2013 - 16:41
Wingman31
  • Wingman31
Jag orkade inte vänta , så jag slog te på en 626 :) . Fick ett kanon pris på fyndbörsen 4990 :)
Redigerat av Wingman31, 30 April 2013 - 16:41.
Postad 01 May 2013 - 16:10
Unregistered529cdb41
  • Unregistered529cdb41
  • 46 inlägg
Vad bli skillnaded från förra årets 616? bättre att köpa gamla 717 eller nya 626?
Postad 01 May 2013 - 16:49
wesslan
  • wesslan
  • 1438 inlägg
Dessa nya har: Audyssey MultEQ® for Room Acoustic Correction och på officiella sidan står bara "upgraded" audyssey. Varför vågar de inte skriva ut exakt vilken multiEQ version varje modell har?
Körde på ett säkert kort och köpte en 818 på rea för 7300 kr från komplett så jag får XT32 :)
Postad 02 May 2013 - 09:20
vilhelm65
  • vilhelm65
  • 26 inlägg
Begärde du offert, eftersom priset blev mindre?
Postad 02 May 2013 - 12:04
Wingman31
  • Wingman31
Japp det gjorde ja.
Postad 03 May 2013 - 12:47
vilhelm65
  • vilhelm65
  • 26 inlägg
Slog oxå till på en 626:a nu, fick den oxå för 4990:-, fraktfritt. Nu börjar väntans tider :)
Postad 06 May 2013 - 07:37
vilhelm65
  • vilhelm65
  • 26 inlägg
Wingman, har du fått din ännu? Om så, var det lätt o installera? Några FW-uppdateringar?
Postad 06 May 2013 - 18:35
Wingman31
  • Wingman31
Japp jag har fått min. Nä det tycker jag inte ,gick rätt smärtfritt faktiskt. Tror inte det har kommit några FW-uppdateringar än . Det jag saknar är manuell inställning av ljudet.
Postad 07 May 2013 - 07:49
vilhelm65
  • vilhelm65
  • 26 inlägg
Hämtade ut min igår, o rev runt i mediabänken för o plocka bort den gamla o installera den nya :) Men sen funkade allt kanon! Fick sätta tv:n till passtrough tror jag det hette, så jag har ljud i den när inte stärkaren är på. Lite meck med Spotify tills jag googlade att man inte kunde använda facebookinloggningen utan måste göra det med originalkontot, men sen rullade det på fint. Testade oxå ljudet med blurayutgåvan av Rambo, körde stridsscenerna i slutet av filmen, imponerande ljud, återstår nu bara o lära sig vilken knapp som gör vad på fjärren :)
Postad 07 May 2013 - 19:23
Wingman31
  • Wingman31
Jag hade en 609 innan och det blev lite bättre om en säger så :) . Blev en helt annan klang i mina
XTZ 95.44:or :) . Saknar eq som va i 609:an bara.
Annars ä ja nöjd :)
Postad 09 May 2013 - 20:44
Unregisteredd7a46a96
  • Unregisteredd7a46a96
  • 1612 inlägg
Ni som fått era hur funkar spotify i dessa??
Går de att sortera efter artist/låt/album och finns shuffle??
Har idag en 818 och för mig är spotify i recivern helt oanvändbart då dessa funktioner saknas.
Postad 13 May 2013 - 14:28
vilhelm65
  • vilhelm65
  • 26 inlägg
Nej, jag har inte hittat nån shufflefunktion eller sorteringsfunktion..
Postad 24 May 2013 - 15:59
http://www.webhallen..._tx-nr626-svart
Postad 25 May 2013 - 11:58
KimKom
  • KimKom
  • 77 inlägg
Jag ser på en del film och TV på min iPad och har funderat på att skaffa ATV, för att kunna ha möjlighet att se det på vanlig TV också.
Om jag istället skaffar mig 626an med inbyggd Bluetooth, så borde det väl gå lika bra att streama allt från paddan till TVn, utan ATV.
Eller tänker jag fel?
Redigerat av KimKom, 25 May 2013 - 12:03.
Postad 25 May 2013 - 15:05
Unregistered46f62999
  • Unregistered46f62999
  • 1007 inlägg
jag tror du tänker fel.
ipad har ju inte blåtand. i ditt ändamåt tror jag att atv blir bäst tror jag?!
vet inte om jag uppfattade din fråga/påstående rätt men svarar som jag tror du undrar över.
Postad 25 May 2013 - 15:37
KimKom
  • KimKom
  • 77 inlägg
Tack smörgås, du uppfattade min fråga rätt. Paddan har Bluetooth, så det går utmärkt att streama ex musik. Men jag har inte haft möjlighet att testa bildöverföring, om det nu är möjligt? För isf känns ju 626an klockren för ändamålet ��
Postad 26 May 2013 - 01:36
  • 1007 inlägg
Ingen video kan streamas genom 626 på det viset. Bara ljud å om den hanterar bilder tror jag inte.
Blåtand : enbart ljud ingen video
Postad 04 June 2013 - 17:57
vilhelm65
  • vilhelm65
  • 26 inlägg
Nu har det hänt nåt märkligt..helt plötsligt har jag inget ljud från subben. Det är en aktiv Jamo, o kopplar jag loss kabeln från stärkaren o knackar lätt på kontakten så låter det ur subben och lampan lyser på subben. Det har funkat fram tills nu. Systemet hittar inte subben när jag försöker kalibrera med mikrofonen heller. Jag är noob, o vill bara att saker o ting ska funka...vad kan vara fel??
Edit: Kabelfanskapet var det glapp i....tog loss den o nu åker den i bingen, köper en ny..
Redigerat av vilhelm65, 04 June 2013 - 18:12.
Postad 14 June 2013 - 08:39
markusvinsa
  • markusvinsa
Vad är största skillnaden mellan NR626 och NR717? De är ju ungefär lika kostsamma...
NR626
+Bättre video (Ultra HD, är detta nödvändigt?)
+WiFi
-Lägre effekt
-Färre utgångar än NR717
NR717
+ Spotify (om man nu behöver det i burken...)
+Något högre effekt än NR626
+THX???
Något mer? Någon som kan rekommendera någon?
Postad 14 June 2013 - 09:38
vilhelm65
  • vilhelm65
  • 26 inlägg
NR626 har oxå Spotify och Tunein radio etc. Jag är väldigt nöjd med min, men det kanske inte säger något, då jag haft min förra stärkare i närmare 10 år. Så allt kanske låter bra i jämförelse :)
Postad 14 June 2013 - 10:32
  • 1007 inlägg
NR626
+WiFi
-Lägre effekt
NR717
+THX???
Jag skall sälja min 717(titta min annons) men den har snyggare display än 626 och 626 volym nob lyser nog ej inte medans 717 gör det och det finns pre-out till utbyggnad och förstärkning.
Jag hade valt 717...
Postad 18 June 2013 - 09:08
Unregistered57f393f8
  • Unregistered57f393f8
Är i tagen att köpa 616 eller 626. tveksam till 616 då folk tydligen haft problem med den men tycker 626 verkar vara lite nedgraderad fast till ett högre pris(?!)
Dels verkar det inte vara THX i 626, rätta mig om jag har fel. Sedan förstår jag inte varför de tagit bort hdmi-porten framtill och ersatt med en rca-ingång? Sjukt smidig om man snabbt vill koppla in någon laptop. Visst är det en fördel med inbyggt wifi i 626, men en adapter stör inte mig. Sedan plus till Phono på 626. Hur skulle det fungera att koppla den på en annan rca-ingång? Phono-ingången är väl frekvensjusterad på något sätt, finns det alternativ lösning? (Lite ot men tacksam för svar:))
Tack
Postad 28 June 2013 - 18:51
  • 46 inlägg
Så köper man en wifi dongel och valfri bluetooth adapter till 717 så är den att föredra framför 626?
Eller är det fortfarande en massa buggar o krångel med 717?
Postad 28 June 2013 - 19:07
MikeVKR
  • MikeVKR
  • 4029 inlägg
Tack
jag har onkyo 616 och jag är jättenöjd med min,har aldrig haft problem med den..tyvärr verkar det som att på forum är det oftast dom som har fått problem som skriver och klagar och vi andra sitter tysta och är nöjda.om det är många som klagar så kan det ju bero på att den är populär och fler som köper just den förstärkaren och då är där ju fler måndags ex..bara en känsla jag fått. Tycker inte du ska vara orolig,det är en väldigt prisvärd förstärkare...sen får du själv avgöra om du kommer behöva rca-ingången eller phono ingången :ph34r:
Postad 29 June 2013 - 11:14
  • 46 inlägg
Använder inte hörlurar så phono är inte något jag saknar däremot pre out fullregister som 717 har hade varit trevilgt :)
Postad 29 June 2013 - 11:51
MikeVKR
  • MikeVKR
  • 4029 inlägg
ja vill man ha pre-out så e 717 väldigt prisvärd då den endast kostar 4000kr nu och 626:an som nästan är identisk med 717 kostar 5000kr
Postad 29 June 2013 - 12:05
  • 46 inlägg
Så vad är dock anledningen att köpa en 626? Är det något nytt gränssnitt i menyerna? För med en wifi o bt dongel har du samna funktioner?
Postad 29 June 2013 - 12:16
pickepock
  • pickepock
  • 158 inlägg
Min åsikt också. Tror det är svårt att komma med nya saker varje år. Känns som man slagit i taket just nu och försöker trycka in det sista i funktionalitet. En sak som jag tycker dom kan jobba vidare med är att förbättra ljudet i 2 ch. Med förbättra menar jag kanske bättre komponenter så att just en receiver alltid blir ett lika bra alternativ som en vanlig 2 ch förstärkare. Här skulle man kanske kunna utveckla att man alltid har separata steg för stereo-lyssning.
Postad 29 June 2013 - 12:20
MikeVKR
  • MikeVKR
  • 4029 inlägg
ja jag kan inte heller se varför man hellre ska köpa 626:an än 717
Postad 29 June 2013 - 14:38
tack för svaret! Det blev en 616 till slut och är kalasnöjd! Inget att klaga på än så länge och den spelar skönt med mina chrono 509or:)
Postad 29 June 2013 - 22:54
MikeVKR
  • MikeVKR
  • 4029 inlägg
Grattis till köpet :)
Postad 23 August 2013 - 14:28
Weekend Rush 626 för 3490kr på..
http://www.dustinhom...10749981_130823
Postad 23 August 2013 - 18:16
MikeVKR
  • MikeVKR
  • 4029 inlägg
Det va ett väldigt bra pris :)
Postad 26 August 2013 - 18:02
626 på komplett 3495kr..
http://www.komplett....aspx?sku=781705
  • More is Always Better
    2026-08-29 18:47:07
