Ken Kreisel Quattro Series
96 svar till detta ämne
Ken Kreisel DXD-808 (Subwoofers) 1 8.333332 (2) Inga priser
Ken Kreisel DXD-12012 (Subwoofers) 1 9 (4) Inga priser
Ken Kreisel Q125 Centre (Centerhögtalare) 1 (0) Inga priser
Ken Kreisel Q125 (Surroundhögtalare) 1 7.5 (1) Inga priser
Ken Kreisel Q85 (Surroundhögtalare) 1 (0) Inga priser
Ken Kreisel QFH (Surroundhögtalare) 1 7.5 (1) Inga priser
2 relaterade trådar
Postad 24 March 2014 - 09:31
MikeVKR
  • MikeVKR
  • 4029 inlägg
Ken Kreisel Q125 L/C/R
Net weight (kg) 7,6
Net height (cm) 42,3
Net width (cm) Front: 16, Rear: 14,5
Net depth (cm) Right: 17, Left: 19
Design type Sealed enclosure
Tweeter 4 x 1"
Midrange N/A
Bass 2 x 5,25"
Sensitivity N/A
Crossover 1250 Hz
Terminal N/A
Power handling N/A
Frequency response 100Hz-25kHz (anechoic), 80Hz-25kHz (in-room response near a wall or on a stand)
Impedance 4
Speaker type Bookshelf
Ken Kreisel Q125 Center
Net weight (kg) 7,6
Net height (cm) Front: 16, Rear: 14,5
Net width (cm) 42,3
Net depth (cm) Bottom: 17, Top: 19
Tweeter 4 x 1"
Midrange N/A
Bass 2 x 5,25"
Sensitivity N/A
Crossover 1250 Hz
Terminal N/A
Power handling N/A
Impedance 4
Speaker type Center
Ken Kreisel TRIFX
Net weight (kg) 6,5
Net height (cm) 29
Net width (cm) Bottom front: 17, Top front: 16,5, Rear: 21,5
Net depth (cm) Bottom: 15, Top: 19
Tweeter 4 x 1"
Midrange 2 x 3"
Bass 5,25"
Sensitivity N/A
Crossover 1250 Hz
Terminal N/A
Power handling N/A
Impedance 4
Speaker type Surround
Ken Kreisel Q85
Net weight (kg) 6,5
Net height (cm) 29
Tweeter 4 x 1"
Midrange N/A
Bass 5,25"
Sensitivity N/A
Crossover 1250 Hz
Terminal N/A
Power handling N/A
Impedance 4
Net weight (kg) 35
Net height (cm) 60
Net width (cm) 39
Net depth (cm) 49
Design type Push-Pull
Woofer size 2x12"
Amplifier power 750+ W RMS
Ken Kreisel DXD-808
Net weight (kg) 21.3
Net height (cm) 45.5
Net width (cm) 27
Net depth (cm) 33
Woofer size 2x8"
  • Bifogad fil  image.jpg   60.89K   7 Antal nerladdningar
  • Bifogad fil  image.jpg   54.29K   7 Antal nerladdningar
  • Bifogad fil  image.jpg   57.16K   3 Antal nerladdningar
  • Bifogad fil  KK Q85.jpg   37.37K   1 Antal nerladdningar
  • Bifogad fil  image.jpg   19.72K   1 Antal nerladdningar
  • Bifogad fil  image.jpg   19.1K   1 Antal nerladdningar
Redigerat av MikeVKR, 17 December 2014 - 11:53.
Postad 24 March 2014 - 09:35
MikeVKR
  • MikeVKR
  • 4029 inlägg
Test: http://www.ljudochbi...-q125-dxd-12012
Postad 24 March 2014 - 09:39
MikeVKR
  • MikeVKR
  • 4029 inlägg
Vad jag vet finns ingen svensk distrubitör ännu utan går endast att köpas via Lsound:
http://www.lsound.eu...manufacturer=18
Redigerat av MikeVKR, 24 March 2014 - 09:40.
Postad 01 April 2014 - 19:33
Plingen
  • Plingen
  • 485 inlägg
Blir spännande att se huruvida dom står sig mot XTZ's Cinema...subbarna är ju helt annorlunda så där måste det ju vara skillnad.
Postad 01 April 2014 - 20:26
fristil
  • fristil
  • 3279 inlägg
verkar vara lite bråk och gräm på AVFORUMS :-) där Ken här mailat XTZ ang. hur de löst delningen med diskanten, eller nått, kommer inte ihåg, men inte fått svar, kan vara patent fråga.
Postad 02 April 2014 - 10:44
MikeVKR
  • MikeVKR
  • 4029 inlägg
Tycker oxå det ska bli väldigt intressant att se hur Xtz står sig mot dessa skapelser. Ett test med just renodlade biohögtalare hade varit kul.
Postad 23 April 2014 - 21:05
Plingen
  • Plingen
  • 485 inlägg
Iom att Ken Kreisel inte äger patentet, så lär det nog inte vara någon fara för XTZ. Ska kolla in och se om jag hittar det, har du någon länk?
Postad 24 April 2014 - 07:05
MikeVKR
  • MikeVKR
  • 4029 inlägg
Om jag inte minns fel så skrev Joel i xtz cinema tråden att det hade skett en förändring ang delningen av diskanterna på M6, så om det var något problem mellan xtz och ken kreisel så är det kanske åtgärdat.
Redigerat av MikeVKR, 24 April 2014 - 07:24.
Postad 24 April 2014 - 07:29
MikeVKR
  • MikeVKR
  • 4029 inlägg
Någon som vet varför det inte finns någon svensk återförsäljare av denna serien än.?
Postad 24 April 2014 - 20:39
lukashund
  • lukashund
  • 47 inlägg
Jag tror att Lsound.eu är återförsäljare för hela Eu.
Postad 25 April 2014 - 06:39
MikeVKR
  • MikeVKR
  • 4029 inlägg
Ja det stämmer, vad jag läst från andra så verkar L-sound väldigt bra o ha att göra med, tex erbjuder dom kundsupport 7dagar i veckan, fri frakt, upp till 7års garanti och 45dagars Buy and Try. :)
Postad 25 April 2014 - 17:10
willswing
  • willswing
  • 267 inlägg
LSound är bra att ha och göra med. Köpt två subbar vid två olika tillfällen från dom, utan problem.
Postad 29 April 2014 - 11:54
Unregistered49e83b02
  • Unregistered49e83b02
  • 544 inlägg
Köpte en ken kreisel sub från L sound. Mycket service inriktade människor:)
Läst en del tester om dessa biohögtalare och de ska tydligen ha sjuk dynamik
Redigerat av Unregistered49e83b02, 29 April 2014 - 11:55.
Postad 09 June 2014 - 13:30
RickyDeg
  • RickyDeg
  • 1169 inlägg
Alldeles för lite aktivitet i denna tråd!
Nyligen köpt mitt 5.1 KK Q125 system med DXD-12012 från Lsound, som för övrigt är mycket bra att ha o göra med!
Driver just nu med NuForce försteg och slutsteg men ska testa med integrerade Primare SPA23 i dagarna, bara för att Primär är så sjukt bra på musik. Högtalarsystemet har ett härligt driv som är galet dynamiskt och detaljerat på alla nivåer. Basen integrerar mycket väl i rummet, en av de bästa subwoofers jag ägt. Har dock svårt att bestämma mig för om jag ska använda TriFX eller Q125 som surround. TriFX är gjorda för ändamålet men Q125 på sina dedikerade golvstativ ser snyggare ut och lättare att integrera då jag inte har möjlighet till väggmontering. Bytte från Monitor Audio Apex, och dessförinnan Kef KHT, och utan att överdriva är detta helt klart det mest engagerande högtalarsystem för film jag ägt!
Redigerat av RickyDeg, 09 June 2014 - 13:30.
Postad 09 June 2014 - 14:34
Degpojken
  • Degpojken
  • 572 inlägg
Rycker rejält i baguetten här! en får gratulera
Postad 09 June 2014 - 20:45
MikeVKR
  • MikeVKR
  • 4029 inlägg
Gratulerar till köpet :) Väldigt intressanta högtalare!
Postad 09 June 2014 - 21:27
Plingen
  • Plingen
  • 485 inlägg
Får man fråga hur mycket det gick på...?
Postad 21 July 2014 - 12:41
RickyDeg
  • RickyDeg
  • 1169 inlägg
TACK! :) Sorry för det sena svaret!
Det rycker i min egen varje gång jag lyssnar på dessa! ;)
Hela systemet med golvstativ och den större subwoofern DXD-12012 gick på ca 62.000:- :ph34r:
Håller med! De är intressanta! Och spelar som bara den!
Redigerat av RickyDeg, 21 July 2014 - 12:39.
Postad 21 July 2014 - 12:44
RickyDeg
  • RickyDeg
  • 1169 inlägg
Här har ni en bild till på Quattro-systemet! Ny mediamöbel (Spectral CL1580) och förstärkare (Primare SPA23).
Postad 28 July 2014 - 12:14
MikeVKR
  • MikeVKR
  • 4029 inlägg
Snyggt! Hur upplever du diskanterna.?
Postad 28 July 2014 - 12:32
RickyDeg
  • RickyDeg
  • 1169 inlägg
^ Utseendemässigt trodde jag först de skulle vara distraherande, men de fyra diskanterna (även om de påminner om spindelögon) gör att högtalaren ser väldigt cool ut. De är överlag ändå ganska diskreta tycker jag.
Ljudmässigt är det enormt mycket information i toppen, utan att de på något sätt låter påstridiga eller "ljusa". Jag hade Monitor Audio Apex tidigare och älskade dem! Men här hör man utan tvekan "längre in" i ljudspåren, så att säga, plus att det är ett mycket ärligt och transparent ljud. Transientsvar och dynamik är hissnande på dessa högtalare (spela "Pacific Rim" så förstår du direkt) och mycket av detta tack vare diskanterna som är delade i olika frekvens. Alla frekvenser behöver således inte pumpas ut genom en och samma diskant. Det låter oansträngt med massor av närvaro. De hjälper också till att sprida ljudet från högtalaren bra - det hänger liksom i luften kring högtalaren och ger fin bredd och djup. Det låter inte diffusa utan bara generöst stort med bibehållen fokus. Det är skarpskuret så det förslår, men slår aldrig över till det hårda eller spretiga. Välbalanserade skulle man kunna säga. Mest imponerad är jag nog ändå på återgivningen av röster som (med bra soundtrack) kan låta väldigt realistiskt.
Postad 28 July 2014 - 12:57
MikeVKR
  • MikeVKR
  • 4029 inlägg
Tack för ett välformulerat svar :) Man blir inte mindre sugen på quattro serien om man säger så ;)
Postad 28 July 2014 - 13:15
RickyDeg
  • RickyDeg
  • 1169 inlägg
^ Varsågod! :)
Med tanke på att du har projektorduk och ett rum där jag tror det kan bli enkelt att integrera Quattro skulle du säkerligen uppnå imponerande resultat. Kanske med surround modellerna TriFX monterade direkt på bakväggen? Och eventuellt 2 st DXD-808 eller den större DXD-12012 subwoofern? Du skulle få ett väldigt stort ljud tillsammans med din stora bild, det kan jag garantera! Jag har tyvärr ett litet rum (ca 4x4 kvm) men det låter som att rummet och högtalarsystemet är större än vad det faktiskt är. Bästa högtalarsystemet jag hört för pengarna! Även för live-konserter och musik i övrigt!
En liten bild på center högtalaren där du ser diskanterna bättre. Jag gillade inte utseendet på den dedikerade centern med sitt bordstativ så jag bytte till en separat Q125 (front - höger) och vände den så jag fick vinkeln uppåt mot mig istället. Fungerade bättre i mitt rum och ser finare ut.
En bild på subwoofern DXD-12012 utan sidoskydd. Ska med fördel stå direkt i något av rummets hörn med bas elementet mot väggen. En regäl best som inger respekt men ändå förvånansvärt enkelt att hantera. Lite synd bara att den inte har 12V trigger ingång, men man kan inte få allt.
Redigerat av RickyDeg, 28 July 2014 - 13:17.
Postad 31 July 2014 - 12:08
MikeVKR
  • MikeVKR
  • 4029 inlägg
Q125 är en vacker högtalare, Jäkligt trevlig bild på centern du lade upp :) Skulle jag bytat högtalare så är det tänkt att dom främst ska användas i en framtida dedikerad bio. Kommer börja leta hus nästa år..Subbarna jag har nu är jag väldigt nöjd med så dom kommer få hänga med även till framtida projekt :)
Postad 31 July 2014 - 14:02
RickyDeg
  • RickyDeg
  • 1169 inlägg
Jag håller med - de är vackra! :)
Quattro gör sig säkert ännu mer hemma i ett dedikerat rum än i ett vardagsrum, som i mitt fall, så där gör du nog ett smart val i sådana fall. De förtjänar riktigt kapabla subwoofers som verkligen kan hänga med i svängarna. Har inte testat dina men rekommenderar ändå att de paras ihop med DXD. Det finns ju många bra subwoofers på marknaden men kan för egen del bara säga att DXD kopplar enormt bra med mitt rum, utan någon EQ. Bästa subwoofern jag testat hittils. Har haft problem med Sunfire, Velodyne och Monitor Audio subwoofers när det gäller detta att försvinna ur ljudbilden och fylla rummet med välkontrollerad bas. Väldigt lite distortion också, iallafall som jag uppfattat. Med DXD-12012 är det faktiskt första gången jag lyckats skapa illusionen av att satellit högtalarna låter som full-frekvens! Blev lite överraskad av detta själv.
Postad 31 July 2014 - 17:36
MikeVKR
  • MikeVKR
  • 4029 inlägg
Jag tvivlar inte på att DXD 12012 gör ett bra jobb men jag tror faktiskt mina 15" DIY subbar hänger på ganska bra, iaf tillräckligt för mig,fast för en betydligt billigare peng ;) Du har helt rätt i att det hade varit trevligare med subbar ifrån samma serie men har man en begränsad budget som jag så tycker jag alternativet att skaffa diy subbar är rätt väg att gå. Huvudsaken är att man är nöjd och det verkar vi vara båda två :)
Postad 31 July 2014 - 18:05
mikee
  • mikee
  • 1638 inlägg
Dina !5" Ultimax byggen kommer käka vilken Kreisel Sub som helst till frukost!!
Postad 01 August 2014 - 00:08
MikeVKR
  • MikeVKR
  • 4029 inlägg
Postad 01 August 2014 - 07:48
RickyDeg
  • RickyDeg
  • 1169 inlägg
Helt korrekt!!! :)
Postad 01 August 2014 - 10:23
MikeVKR
  • MikeVKR
  • 4029 inlägg
Den dedikerade centern är den vinklad.? Vad är skillnaden annars mot q125 front.? Förutom stativet som inte jag heller tyckte var speciellt snyggt. Blev det någon prisskillnad när du bytte?
Postad 01 August 2014 - 11:35
RickyDeg
  • RickyDeg
  • 1169 inlägg
^ De tre fronthögtalarna L/C/R är helt identiska ljudmässigt, vilket självklart bådar gott i sig. Alla Quattro är vinklade. Den dedikerade centern med det fula bordsstativet är därför också vinklad - tyvärr åt fel håll i mitt tycke! Ken Kreisel skulle ha flippat över den åt andra hållet så den vinkel som finns på högtalaren pekar uppåt, så att säga. Så här ser den ut ursprungligen:
Om man måste placera högtalaren under tv/projektorduk på t ex en mediamöbel i normalhöjd (säg ca 50 cm) gör det att högtalaren pekar rakt fram istället för lite uppåt. Så när jag testade denna pekade högtalarelementen mycket riktigt mot mina knän istället för uppåt mot mig vid lyssningsplatsen trots att jag hade vinklat den till max på bordsstativet. Du kan skippa bordsstativet och skruva loss underredet och vända på högtalaren för att få "rätt" vinkel uppåt men då syns skruvhålen. Inte speciellt bra.
Tyvärr säljer inte LSound Q125 L/R front separat! :angry: Men jag hade redan köpt ett extra par av dessa så jag returnerade bara den dedikerade centern och använde en separat Q125 R som jag vände horisontalt med vinkeln uppåt. Funkade mycket bättre! Nu har jag en Q125 L över som jag ska sälja till en kompis som tänkt göra på samma sätt. På detta vis kan man också använda spikes eller dylikt som ger bättre avkoppling från underlaget.
Postad 01 August 2014 - 11:43
RickyDeg
  • RickyDeg
  • 1169 inlägg
Här ser du lite bättre min Q125 med sin vinkel uppåt. Den är placerad direkt ovanpå 3 st Soundcare SuperSpikes Standard (platt spike).
Postad 11 August 2014 - 11:35
MikeVKR
  • MikeVKR
  • 4029 inlägg
Tack för infon :) Ska försöka få en L/R front istället för centern då när/om det blir dax för köp.
Redigerat av MikeVKR, 11 August 2014 - 11:36.
Postad 02 September 2014 - 08:30
MikeVKR
  • MikeVKR
  • 4029 inlägg
Funderat lite på q85 som L/C/R. Har du provat dina trifx i fronten.?
Postad 02 September 2014 - 09:15
MikeVKR
  • MikeVKR
  • 4029 inlägg
Lite konstigt varför dom inte skriver ut känslighet på dessa talare. Hittar inte det någonstans..
Postad 02 September 2014 - 10:07
RickyDeg
  • RickyDeg
  • 1169 inlägg
Det är många som har Q85 i fronten så det bör funka utmärkt! Den borde helt enkelt ger lite 'mindre' än vad Q125 gör. Den är ju dess littlebror, så att säga. Dock inte rekommenderat att använda TriFX i fronten (L/C/R) eftersom det är en tripol-högtalare så jag har inte testat det. Den nedåtriktade vinkeln på TriFX design gör front-placering svår dessutom. Nej, den ska helt klart användas till surround och inget annat (eller möjligtvis front höjd).
Tekniska detaljer är väldigt sparsamma för Quattro, av någon konstig anledning. Det är lite dumt! Jag mailade Ken Kreisel om detta och han sa att de har en känslighet på "mellan 89-91db". Lite luddigt svar. Upplever inte att de är trögdrivna alls, däremot behöver de kvalitéts-elektronik av hög klass för att komma till sin rätt och blomma ut. De kommer inte låta lika dynamiska, detaljerade eller kraftfulla med en enklare integrerad receiver. Det funkar, men du kommer uppleva stor skillnad med ex.vis ett potent slutsteg, utan tvekan.
Postad 02 September 2014 - 10:10
RickyDeg
  • RickyDeg
  • 1169 inlägg
OBSERVERA att bilderna på Q85 på LSounds hemsida är helt fel! De visar bild på TriFX eller QFH. Q85 har inte några sido-element!
Postad 02 September 2014 - 10:18
RickyDeg
  • RickyDeg
  • 1169 inlägg
Nedan ser du lite tydligare skilladerna på TriFX och Q85. Som synes har Q85 inte några sido-element och ska inte ha det heller.
Observera att du kan få problem med den nedåtriktade vinkeln på Q85 om du använder den som front (L/C/R). Beror på hur högt du placerar dem. Du bör INTE vända på den upp-och-ner! Då blir ljudet konstigt. Jag tror Q85 främst är tänkt som ett direkt-strålande alternativ till TriFX som surround högtalare. Men som sagt jag har hört fler som använder den i fronten så det bör inte vara några problem.
Postad 02 September 2014 - 19:53
MikeVKR
  • MikeVKR
  • 4029 inlägg
Aha.Jag fick för mig att det gick att skifta om till direktstrålande på trifx:arna. Har funderingar på att använda antingen q125 eller q85 bakom en AT duk men vet inte hur bra det kan bli när man antagligen får ha dom ganska högt upp med tanke på vinklingen..
Postad 03 September 2014 - 07:05
RickyDeg
  • RickyDeg
  • 1169 inlägg
Det har du ju faktiskt rätt i - det går att göra det med TriFX. Då blir sido-elementen oanvända.
Sorry. Har inte brytt mig om det då det inte intresserade mig i min installation.
Q125 lär iallafall inte bli några problem pga vinklingen. Finns flera ägare som har den bakom projektorduk vet jag.
Den är ju inte vinklad neråt som TriFX och Q85 utan innåt mot lyssnaren.
Postad 03 September 2014 - 07:16
MikeVKR
  • MikeVKR
  • 4029 inlägg
Det jag tänker på är att ska man ha q125 stående så blir centern vinklad antingen åt vänster ilr höger och har man högtalarna liggande så blir dom vinklade antingen uppåt ilr neråt..Du känner inte till någon bild som exempel på en q125/q85 installation bakom en AT duk?
Redigerat av MikeVKR, 03 September 2014 - 07:23.
Postad 03 September 2014 - 08:08
RickyDeg
  • RickyDeg
  • 1169 inlägg
Om du vill ställa centern vertikalt bakom duken så kanske du bara kan vrida på den lite så vinkeln hamnar som du vill ha den? Eller fäster du dem direkt på väggen? Välj vinklingsbart väggfäste? Om du vill placera alla 3 fronter horisontalt så kan vinkeln bli en utmaning. Beror på hur högt/lågt du placerar dem helt enkelt. Återigen, om du fäster dem horisontalt på väggen bakom duken välj ett vinklingsbart väggfäste så är problemet ur värden (?).
Dessa högtalare har speciella utmaningar i vissa lägen pga sin vinklade design, helt klart.
Jag minns att jag har sett flera bilder på Quattro bakom projektordukar i forumet på http://speakershack.co.uk men kan inte länka dig direkt till någon tyvärr. Det finns många KK ägare och kunniga som är med där så det forumet är ett hett tips! Jag har varit aktiv lite grann också men det var ett tag sen nu.
Redigerat av RickyDeg, 03 September 2014 - 08:09.
Postad 03 September 2014 - 08:25
MikeVKR
  • MikeVKR
  • 4029 inlägg
Bra tips med fästet,ja lite mer utmaning blir det med vinklade lådor :) Har kollat runt lite på vad man även skulle kunna använda om man nu vill ha högtalarna horisontiellt. Sådana här borde funka: http://www.thomann.d...stik_isopad.htm
Tack för länken, ska kolla runt lite där med..
Postad 03 September 2014 - 10:20
RickyDeg
  • RickyDeg
  • 1169 inlägg
Dom där har jag aldrig sett! Verkar väldigt smarta lösningar! :)
Postad 05 September 2014 - 13:25
RickyDeg
  • RickyDeg
  • 1169 inlägg
Här kommer en låååång personlig recension på Quattro systemet på AVSForum:
http://www.avsforum....nal-review.html
Postad 05 September 2014 - 17:39
lukashund
  • lukashund
  • 47 inlägg
Snygg bild! Tror nog att det blir bättre bas om du bytar plats på högtalare o sub.
Postad 05 September 2014 - 18:08
RickyDeg
  • RickyDeg
  • 1169 inlägg
^ Tack!
Bättre bas om jag byter plats på högtalare och sub??? DXD är ämnade att stå i hörn och presterar klart bäst där så om du menar att jag ska skifta plats med Front Höger och subwoofern så.... no no no! ;) hehe
Postad 07 September 2014 - 21:16
MikeVKR
  • MikeVKR
  • 4029 inlägg
Väldigt välskriven recsension, Tack för det :)
Postad 09 September 2014 - 09:30
RickyDeg
  • RickyDeg
  • 1169 inlägg
^ Tack! :) Kanon att du läste! Lite lång är den, men hade mycket att täcka!
(och jag tror ändå inte jag fick med precis allt hehe)
Postad 14 December 2014 - 20:54
MikeVKR
  • MikeVKR
  • 4029 inlägg
Jag gillar att läsa långa rescensioner så för mig var det ett nöje :) Hur upplevde du skillnaden när du körde Nuforce för och slutsteg mot din Primare.?
