LG OLED 55EC930V
476 svar till detta ämne
Postad 14 September 2014 - 16:20
Tänkte vi som är intresserad eller redan köpt denna grymma tv kunde diskutera och hjälpa varandra vid ev frågor. Finns en tråd rubrik och böjningen diskuteras i redan befintlig tråd som finns i forumet tack :)
Postad 14 September 2014 - 18:55
Enator
  • Enator
  • 4026 inlägg
Och här kommer en review av tv:n:
We’re in a pickle here. On one hand, the 55EC9300 delivers the promise of near-perfect blacks, excellent contrast, and rich color that OLED is revered for. Pair that with an excellent smart TV interface and wrap it up in a sexy package, and you’ve got a winning TV.
But the judder issue is not one that we’re able to overlook, and that’s not just because we stare at TVs day in and day out, either. More casual viewers struggled with the judder issue as well, so we can’t help but worry that you might, too.
Unfortunately, it appears LG had to cut some corners in order to bring the 55EC9300 to market at an unprecedentedly low price. And frankly, we probably should have seen it coming. This TV could easily have scored a 9, but considering its premium price and the judder issue, we just have to knock it down a couple points. It’s hard to throw our recommendation behind something that may disappoint the sort of buyer who would consider this TV in the first place.
With all of that in mind, we’ll say this: If you’re so hungry for OLED that you’re willing to overlook some image judder, or if you’re not one easily bothered by such things, then the EC9300 is an otherwise excellent television. However, if you’re sensitive to motion issues and prone to buyer’s remorse, you might want to wait until next year. Or, alternatively, you can go for broke and drop $8,000 on the excellent 65-inch 4K OLED LG will be unleashing next month. Either way, you should head down to your local electronics store and have a look at this television. This is what TVs will look like in the future … without the judder, we hope.
http://www.digitaltr...5ec9300-review/
Postad 14 September 2014 - 19:48
Har hittills inte märk några problem med material i 24fps med senaste FW med Trumotion (dejudder + blur) satt till 0. Inga problem med fotboll heller (1080i 50hz), bollen rör sig som den ska.
Lite dåligt att ingen av recensenterna nämner om de uppdaterat TV'n eller inte innan recensionen.
Postad 14 September 2014 - 19:59
Jag valde att låta denna tv rulla hela helgen (mycket fotboll) och kunde inte heller se något problem med judder. Var i menyn går man in för att se vilken fw man har? :)
Redigerat av mcmike, 14 September 2014 - 19:59.
Postad 14 September 2014 - 20:37
Legion
  • Legion
  • 1029 inlägg
Blir det skillnad på trumotion satt till noll jämfört mad att ha det avstängt?
Den danska recensionen anger att de hade en tidig fw och att tvn ej heller gick att uppdatera vid testtillfället. Som jag förstår testet hade de också problem med menyer och liknande som inte finns idag.
http://www.lydogbild...5ec930v-oled-tv
Jag tyckte annars att det testet ganska väl överenstämde med hur jag upplever tvn, bla. ett tydligt drag åt grönt, jag har ingen kalibreringsskiva för tillfället så jag har bara på måfå ändrat nyansen lite åt det röda hållet.
De upplevde också hack i bilden vid tv-sändningar, speciellt vid panoreringar och det gör jag också, inte vid 24p eller HD-sändningar i hög bitrate, där är bilden och rörelser mycket bra.
Men tvn verkar inte klara att hantera en dålig signal speciellt bra, fenomenet med hackande bild försämras av trumotion vilket känns bakvänt då funktionen är tänkt att ge mjukare rörelser :rolleyes:
Nåt är galet och frågan är ställd till LG.
Postad 14 September 2014 - 20:38
General -> About this TV
Min är 04.30.09
webOS versionen är 1.2.0-3209(afro-arches)
Redigerat av Tomanista, 14 September 2014 - 20:45.
Postad 14 September 2014 - 20:42
Går inte att stänga av Trumotion, 0 är det närmsta man kommer och får väl räkna som "av". Sedan beror det på om man matar 1080i eller om man skalar upp TV-signalen till 1080p. 720p eller 576i har jag inte provat än men om TV'n klaraa av att visa fotboll utan att det hackar så är det iaf tillräckligt för mig för att säga att det inte är några problem med att det skulle hacka i vanliga TV-sändningar.
Postad 14 September 2014 - 20:48
Min är 04.30.09
Tack hade samma som dig.
Postad 14 September 2014 - 20:54
Någon mer som laddat ner LG's webOS app? Lite smidigare än fjärren (magic remoten har jag bojkottat hittills) enligt mig, speciellt med pekplattefunktionen då inmatning av text blir mycket smidigare, speciellt då man loggas ut från Viaplay-appen varje gång man stängt av TV'n.
WebOS är tyvärr rätt segt även om menyerna på min LX5090H inte var de rappaste man upplevt heller...
Postad 14 September 2014 - 21:05
Legion
  • Legion
  • 1029 inlägg
Nja, Trumotion går ju att ställa på av. Frågan var ju om det är samma sak som att i användarläget sätta det på 0?
Postad 14 September 2014 - 21:19
Vart då? Eller menar du att byta till PC på en HDMI-ingång?
Postad 14 September 2014 - 21:28
Legion
  • Legion
  • 1029 inlägg
Bild-bildjusteringar-bildalternativ-trumotion. Där finns valen: av, mjuk, rensa och användare.
Kul översättning förresten på clear= rensa :blink:
Postad 14 September 2014 - 21:32
Se där, jag hade Trumotion off på TV-ingången. Vart fan fick jag för mig att det inte gick att stänga av?
Postad 14 September 2014 - 21:36
Legion
  • Legion
  • 1029 inlägg
Angående ryckande bild och uppskalning av tv-sändningar, min humax BXR HD är inställd på 720p, jag har även testat 1080i. Kan det vara en fördel att ställa boxen på "orginal" och låta tvn sköta uppskalningen?
Postad 14 September 2014 - 21:55
Tror 1080i är bättre om man ser på HD-kanaler. Brukar vara det som rekommenderas.
Postad 15 September 2014 - 08:44
Unregisteredc58591b9
  • Unregisteredc58591b9
  • 157 inlägg
Jag satte min på original. Och det funkar på 720p och 1080i HD sändningar.
Men på SD(576) så blir det 1080i av någon anledning. Så original är inte helt original om man säger så :D
Detta konstaterar jag genom att trycka på info knappen på LG fjärren. (Finns ej på magicfjärren)
Postad 15 September 2014 - 17:46
Legion
  • Legion
  • 1029 inlägg
Min gör likadant, ställer jag boxen på orginal visas 1080i på tvn.
Med magic-fjärren trycker man i ett av de övre hörnen så kommer info-skylten fram ;)
Postad 15 September 2014 - 19:13
Jag använder Ci+ (comhem) fungerar som det ska. Vill personligen inte ha en separat box :)
Postad 16 September 2014 - 05:47
Unregistereddfe6e5ac
  • Unregistereddfe6e5ac
  • 13 inlägg
Man kan även trycka på "pilen upp" på styrkorset runt scrollhjulet.
Postad 16 September 2014 - 06:44
Fråga: Ser ni verkligen inte gröntinten i vinkel (ses enklast med en helt grå bild)?
Trodde dessa bilder ljög men det jag så på ElG var minst lika tydligt:
https://www.minhembi...dpost&p=4097758
Postad 16 September 2014 - 11:22
  • 157 inlägg
Jag tyckte jag fick avsevärt bättre bild via min Humax box för Boxer än med den inbyggda DTV mottagaren.
Och dessutom kan den hanteras med magic remoten så det är inga problem för mig iaf.
Nej det kan jag inte påstå men har heller inte kikat med testbilder på det viset.
Det enda jag stör mig på med denna TV är buzzing ljud.
Redigerat av Unregisteredc58591b9, 16 September 2014 - 11:22.
Postad 16 September 2014 - 12:32
Min är knäpptyst..
Postad 16 September 2014 - 12:47
Np10
  • Np10
  • 10 inlägg
Behöver man kalibrera denna tv:n när man köpt en helt ny o aldrig varit använd förut? Får hem min om ca 3-4v.
Postad 16 September 2014 - 14:06
Unregistered769bb3eb
  • Unregistered769bb3eb
  • 13 inlägg
Min är knäpptyst..
Min hade ett buzzljud när jag körde HTPCn till den med input satt som HDMI , ändrade jag till PC istället försvann det helt. Är mycket nöjd med den, kommer ju från en Samsung 46M86 så skillnaden är enorm. Nu kan man njuta av att se mörka filmer också ;-)
Postad 16 September 2014 - 15:06
Legion
  • Legion
  • 1029 inlägg
Ändra till bio eller isf så blir tvn knäpptyst. På eco och standard går nån energibesparing på vilket orsakar buzzing från strömdelen.
Jo, skrev om det i ett tidigare inlägg. Även danska bild och ljud såg detta i sitt test men fick bort det efter kalibrering. Jag ska köra DVE så fort jag orkar köpa det.
Postad 16 September 2014 - 17:12
I vinkel, inte i sweet-spot mao. Inget man kan kalibrera bort.
Såg det tydligt med LGs demomaterial (inget man behöver testbilder för att se mao).
Mkt märkligt, nått som spunkar med kontrastfiltret i visst ljus (ElGs butiksljus) tro? I vilket fall som helst en ev skillnad mot förra generationen.
Redigerat av pacman, 16 September 2014 - 17:14.
Postad 16 September 2014 - 19:17
Provade med min box kan inte påstå att det blev någon drastisk skillnad..
Nej, kan du göra senare efter ett tag..
Kör bio läget själv, men kan inte påstå att jag hör någon buzz i de andra lägena. Men det är klart, kommer man från plasma (jag) så tycker man väl det oavsett :D Får min utbytt på torsdag pga av pixel felen..
Redigerat av mcmike, 16 September 2014 - 19:23.
Postad 16 September 2014 - 23:26
logh
  • logh
  • 186 inlägg
I väntan på FlatplanelsHDs recension:
http://www.ljudochbi...-tv-lg-55ec930v
Postad 17 September 2014 - 05:38
EVOVII
  • EVOVII
  • 1892 inlägg
Att kompromissa med kvaliteten för att få ner priset på en highend-teknik som OLED tycker vi är lite som att kasta ut barnet med badvattnet.
Är det nått norskt talesätt? :D
Postad 17 September 2014 - 09:22
Jodå, jag ser den och är oroad. Tog de inte upp gröntinten på testet? Jag har inte sett shootouten själv tyvärr. Är det bara den Oled:en som har det?
Postad 17 September 2014 - 16:38
Cnet review:
http://www.cnet.com/...ts/lg-55ec9300/
Trebb>> nej såg inget om gröntint i vinkel i testet. Edit: eller menar du om de tog upp det i shootouten? Ja det vill jag minnas, lustigt nog enda gången jag hört om det
Redigerat av pacman, 18 September 2014 - 06:30.
Postad 17 September 2014 - 22:22
Np10
  • Np10
  • 10 inlägg
MCMIKE >>> Pga pixel felen? Var det länge sen du inhandlade den? Hur märkte du av de? Oerfaren inom denna branschen :blush:
Redigerat av Np10, 17 September 2014 - 22:24.
Postad 18 September 2014 - 06:28
Du ser om det finns någon avvikande prick (pixel) som man ser lättast lysa vid svart eller ljus bild, som inte ska vara där. I mitt fall lyser det blåa vid svart bakgrund (nolltolerans gäller), de är väldigt små. Haft min 2 veckor!
Redigerat av mcmike, 18 September 2014 - 06:29.
Postad 18 September 2014 - 07:21
Och HDGuru:
http://hdguru.com/lg...ed-hdtv-review/
Postad 18 September 2014 - 07:27
Prova gärna detta klipp och återkom med åsikter. :)
http://privat.bahnho...92876/test2.mp4
Postad 18 September 2014 - 10:10
Charl3s
  • Charl3s
  • 117 inlägg
Har precis packat ihop min tv igen. Har en död och en defekt pixel men det stör inte så mycket.
Det jag stör mig på är ett buzzande ljud som blir högre vid ljusare bilder samt att varken jag eller min
fru upplever att bilden är mycket bättre än vår 4år gamla 47LE850.
Kanske fick ett måndagsex ? Borde jag pröva ett annat ex ?
Postad 18 September 2014 - 10:26
Ja om du inte tycker att bilden är bättre än en 4 år gammal LCD så känns ju pengarna defenitivt bortkastade, att varken du eller frugan ens reflekterat över svärtan är ju konstigt.
Jag gissar på att ni aldrig hade båda skärmarna inkopplade samtidigt så att ni kunde jämföra dom bredvid varandra? Vilket material har ni tittat på, analog kabel-tv, Blu-ray?
Postad 18 September 2014 - 11:12
Charl3s
  • Charl3s
  • 117 inlägg
Svärtan är fantastisk. Men 47tummaren är bakrundsbelyst med local dimming och smiskar dom flesta TV på fingrarna
när det gäller svärta än idag.
Har kopplat in samma källor med samma kablar till bägge TV apparaterna.
*Canal Digital HD box
*XBOX ONE
*HTPC
Tror jag hade för höga förväntningar, men största felet är ju det störande ljudet.
Tror jag ska byta ut den mot ett annat ex och ge den en ny chans
Redigerat av Charl3s, 18 September 2014 - 11:14.
Postad 18 September 2014 - 11:27
Och du gick ifrån standardläget och stängde av eco enl tips ovan?
Redigerat av pacman, 18 September 2014 - 11:28.
Postad 18 September 2014 - 13:57
Charl3s
  • Charl3s
  • 117 inlägg
eco var det första jag stängde av, testat olika lägen samma ljud även om det inte var lika påträngande i isf lägena
Postad 18 September 2014 - 18:37
Np10
  • Np10
  • 10 inlägg
Alla verkar ha något prob.!!! Är det någon som är nöjd med sin apparat???
Postad 18 September 2014 - 19:27
Så är det på forum. Få inte den nojjan bara, man letar då bara fel ;) Jag är nöjd annars skulle jag inte ta emot en ny, bästa bilden jag sett och det är några topp of line skärmar/projektorer :)
Redigerat av mcmike, 18 September 2014 - 19:27.
Postad 18 September 2014 - 19:55
Ecis
  • Ecis
  • 453 inlägg
Jag har en LG930 och kan bara säga den har den bästa bilden jag någonsin sett på en TV.
Fantastisk svärta och kontrast. Inga reflexer, inte ens i dagsljus.
På forum skriver många om problem (och så skall det kanske vara) men sitter man med specialbilder och letar fel som aldrig kommer synas i verkligheten kanske tekniken blir viktigare än resultatet.
Postad 18 September 2014 - 20:32
Ehh...Det är väl ingen som klagat i tråden som suttit med "specialbilder"?
Men iövrigt håller jag med, EC930 är asgrym.
Redigerat av pacman, 18 September 2014 - 20:47.
Postad 18 September 2014 - 20:44
+1
EC930 är asgrym.
Du glömde gubben ;)
Postad 18 September 2014 - 20:46
Nä där ska vi inte ha nån gubbe. :)
Postad 18 September 2014 - 21:09
Jasså inte! Kan förstå det, tyckte också bilden var skit i ladan för det var väl där du såg den ;)
Postad 18 September 2014 - 21:38
Har du fått för dig att jag tyckte den va skit eller vad försöker du säga?
Postad 19 September 2014 - 04:56
ztrafe
  • ztrafe
  • 13 inlägg
Lämnar tillbaka mitt ex och köper en 4k tv istället för lite dyrare pris. Finns ju UDTV NetFlix nu :)
Redigerat av ztrafe, 19 September 2014 - 06:20.
Postad 19 September 2014 - 08:13
  • 157 inlägg
Jag har också lämnat tillbaka min.
Buzzingen gick inte att vänja sig vid och nej den var där även i bio och isf lägen.
  • More is Always Better
    2026-08-29 18:47:07
