Digital Video Essentials på USB sticka,Konsten att ställa in färger,svärtan
7 svar till detta ämne Ultra HD kalibrering med färg filter! Enkel grund kalibrering 2160p Färgrymd Colorimeter?
Postad 04 October 2015 - 11:14
Unregistered39429
  • Unregistered39429
  • 3116 inlägg
:) Tjena alla hemmabio diggare!
Nu har Mr. Video tec industri veteranen Joe Kane släppt en ny USB sticka med Ultra HD (Ultra High Definition) 2160p demo material & testmönster för att ställa in svärtan,alla färgerna & färgrymden,skärpan och gråskalan mm i bilden i alla dom nya Ultra HD tv's,blu-ray spelarna & projektorerna.Som alltså är den nyaste & allra senaste tekniken lagom tills det nu straxt efter julafton 2015 börjar dyka upp kompatibelt film och senare konsär material, inspelat i det nya formatet både på nedladdning,streaming och på blu-ray skivor i Ultra HD kvalite; http://www.videoesse...om/dve-uhd.html
dveuhd0_9_large.png?v=1414694584
DVE UHD v 0.9 - Digital Video Essentials UHD version 0.9
$150.00
Quantity: - +
This v 0.9 Digital Video Essentials UHD 4k release is aimed at content creators, software developers, hardware manufacturers, imaging professionals and reviewers in immediate need of UHD test materials.
As a v 0.9 release, there will be updates and additions so please be sure to purchase with a valid email address so that you receive the automatic emails.
For a limited time, all purchases of DVE UHD v 0.9 on the USB 3.0 thumb drive include a free copy of HD Basics on Blu-ray (normally $39.95).
DVE UHD V 0.9 is a joint production of Image Essence, LLC, Gary Demos, and JKP, Joe Kane. It marks JKP’s entry into the UHD domain with test and demonstration material in both 4096 by 2160 format, known as 4K in the program production world, and the 3840 by 2160 format, known as 2160p or UHD in the consumer world. The 2160p format is one of two pixel count arrays currently specified for UHD. We’ll eventually be addressing the other UHD format, 4320p, but not in this release of materials. The ITU and CEA initially called the consumer format UHD but we’ve since noticed the CEA has gone back to including 4K as part of the consumer name.
The real 4K format has been a part of the program production world for some 20 plus years. The idea of a higher resolution format for consumers started out as 4096, using one of the vertical resolutions options in the 4K professional formats, 2160. It has a 1.89:1 aspect ratio. The 2160 version of 4K is found in Digital Cinema projectors. When consumer connectivity of the 4096 by 2160 pixel count became an issue it was dropped back to a slightly lower number, 3840 by 2160, as set out in the ITU-R BT.1769 document in 2008. The 3840 by 2160p format also offers fairly easy up conversion from 1080p so it might be considered a better fit for existing HD content.
The materials on the USB stick are divided into two categories, test signals and still images. The images are there for test and demonstration purposes. There is a separate spreadsheet titled JKP-UHD Test Materials listing the contents and providing some additional details about each item. We’ll also be publishing .pdf documents with more detailed descriptions of the test patterns and images. These documents will be found on the http://www.videoessentials.com/ web site.
A number of the test images will have the initials EBD for Extended Bit Depth. Up to this point in the consumer world of distributing video the bit depth has been 8 bits. - We are including a number of test signals at that bit depth. While a larger bit depth is required for extended or high dynamic range (EDR or HDR), these images have not been set up for any specific approach to presenting EDR or HDR. They can be processed for either EDR or HDR. We are calling some of the test patterns high dynamic range, HDR, and they are named and described accordingly.
All of the materials presented are in the RGB domain. Most of the test patterns are not primary color dependent and should work in any color space, with possible exceptions of bit depth. The .tif and .dpx images have been color timed for ITU-R BT.709 color space and ITU-R BT.1886 gamma.
Så vad tror ni? denna usb sticka lär ju rocka apafett som efterträdare till "DVE HD Basics" för våra nya "4k" displayer eller?
Eller ska man satsa på en Colorimeter för att ställa in bilden istället? eller kanske både och?  :unsure:
Med vänlig hälsning/ jeppeman
Postad 04 October 2015 - 11:18
SKIBBE
  • SKIBBE
  • 5338 inlägg
Kostar endel, gratis motsvarigheten brukar vara minst lika bra. DVE kanske är mer användarvänligt dock?
Redigerat av SKIBBE, 04 October 2015 - 11:19.
Postad 05 October 2015 - 06:54
ekon
  • ekon
  • 5779 inlägg
Problemet blir att spela upp materialet rätt. Man kan inte stoppa den i USB porten på TVn och förvänta sig att TVn kommer hantera den på samma sätt som en HDMI ingång, eller ens på samma sätt som internt uppspelat material från tex Netflix UHD.
Att stoppa den i en dator med HDMI till displayen, ja det kan fungera. Så länge som man använder samma uppspelare för bilderna/mönstrena som man normalt gör när man kollar film genom datorn.
Postad 05 October 2015 - 07:31
Väntar på DVE Ultra HD Advanced Blu-rayen istället. :)
Såhär ser det, tydligen, förövrigt ut hemma Joe för tillfället.
Postad 05 October 2015 - 07:38
Du kan inte sätta dessa två i nått slags motsatsförhållande eftersom det är två helt olika saker.
DVE är testmönster/testmaterial. En colorimeter används för att mäta i testmönster.
Postad 05 October 2015 - 09:02
Erik_N
  • Erik_N
  • 1579 inlägg
Joe har bra smak för högtalare också! :)
Postad 05 October 2015 - 10:13
Skulle inte anlita honom som inredningsdesigner dock. :)
Postad 05 October 2015 - 18:10
Unregistered39429
  • Unregistered39429
  • 3116 inlägg
Ok jag ser,här hittade jag Prisjakts olika Colorimeters för att mäta om man har ställt in allting helt optimalt efter att man justerat in allting med Skivan DVE HD Basics eller denna nya USB Sticka "DVE v 0.9".Men är dom tillräckliga för det nya högkvalitativa formatet Ultra HD på Blu-ray med dess större färgrymd & gråskala och vitnivå, och inte att glömma HDR Spektrumet (High Dynamic Range) undrar jag?
https://www.prisjakt...ms=l=s239295995
Även taggad med Ultra HD, kalibrering med färg filter!, Enkel grund kalibrering, 2160p, Färgrymd, Colorimeter?
