Pentax K-1
3 svar till detta ämne
Postad 18 February 2016 - 06:03
Pentax K
  • Pentax K
  • 284 inlägg
Pentax K-1
SENSOR
Primary color filter, CMOS, Size: 35.9 x 24.0mm, Effective pixels: 36.40 MP, Total pixels: 36.77 MP
Recorded resolution photo: [35mm Full Frame]
JPG: L (36M): 7360x4912, M (22M): 5760x3840, S (12M): 4224x2816, XS (2M): 1920x1280
RAW: (36M): 7360x4912
Recorded resolution photo: [APS-C size]
JPG: L (15M): 4800x3200, M (12M): 4224x2816), S (8M): 3456x2304, XS (2M): 1920x1280
RAW: (15M): 4800x3200
Movie (resolution/FPS):
Full HD (1920x1080) @ 60i/50i/30p/25p/24p, HD (1280x720) @ 60p/50p
Quality levels: Best, Better, Good, RAW (14-bit) PEF, DNG, RAW + JPEG
LENS MOUNT
Type/construction: PENTAX KAF2 bayonet mount (AF coupler, lens info contacts, K-mount w/ power contacts). Usable lens series: KAF3, KAF2 (power zoom compatible), KAF, KA mount lens
FOCUS SYSTEM
Type: TTL: Phase-matching autofocus
Focus Sensor: SAFOX 12, 33 point (25 cross type focus points in the center)
Brightness Range: EV -3 to 18 (ISO100 @ normal temperature)
AF mode: Single AF (AF.S), Continuous (AF, C)
AF point selection: Spot, Select, Expanded Area (S, M, L), Zone select, Auto (33AF Points)
AF assist light: dedicated LED AF assist light
VIEWFINDER
Type: Pentaprism finder
Coverage (field of view): 100%
Magnification: approx. 0.70X (50mm F1.4 at infinity)
Eye relief length: approx. 20.6mm (from the view window), Approx 21.7 mm (from the center of lens)
Focusing screen: Natural-Bright-Matte III focusing screen
Diopter adjustment: approx. -3.5m to +1.2m-1
Viewfinder overlay: AF Points, Grid Display, Electronic Level, AF Frame, Spot Metering
Frame, Crop
LCD MONITOR
Type: wide viewing angle TFT color LCD, Air-gapless glass, Flexible tilt
Size: 3.2 inch (3:2 Aspect)
Resolution: 1037K dots
Adjustment: brightness, saturation and colors adjustable
Outdoor View Setting: adjustable ±2 step
LIVE VIEW
Type: TTL method using image sensor
Focusing mechanism: Contrast detection (Face Detection, Tracking, Multiple AF points, Select,
Spot), Focus peaking : On/Off
Display: field of view approx 100%, magnified view (up to 16x), grid display (4x4 grid, golden
section, scale display, square 1, square 2, grid color: black/white), histogram, bright area
warning, composition adjustment
BUILT-IN GPS
Satellites: GPS, QZSS, SBAS (WAAS/EGNOS/GAGAN/MSAS)
Reception frequency: L1 1575.42MHz
Recorded information: latitude, longitude, altitude, time (UTC), direction
Geodesics: World Geodetic System (WGS84)
GPS logging: KML format, logging interval 5/10/15/30 sec./1min., logging duration: 1
24hr (Up to 9 hrs at logging Interval 5 sec, up to 18 hrs. at logging interval 10 sec.)
EXTERNAL FLASH
Flash modes: auto flash discharge, auto flash + red-eye reduction, flash on, flash on
+ red-eye reduction, slow speed sync, slow-speed sync + red-eye, P-TTL, trailing
curtain sync, contrast-control sync*, high-speed sync*, wireless sync
*Contrast-control-sync and high-speed sync requires 2 or more dedicated external flashes
Sync speed: 1/200 sec., flash exposure compensation: -2.0~+1.0 EV
STORAGE MEDIA
Internal memory: n/a
Dual card slot: sequential use, save to both, separate RAW/JPG, image copy between
slots possible
Removable memory: SD, SDHC and SDXC memory card (conforms to USH-I standards)
INTERFACES
Connection port: USB 2.0 (Micro B ), external power supply terminal, external cable switch
terminal, X-sync socket, HDMI output terminal (Type D), stereo microphone input terminal,
headphone terminal
USB Connection: MSC/PTP
WIRELESS LAN
Standard: IEEE 802.11 b/g/n
Security: authentication, WPA2, Encryption: AES
POWER SUPPLY
Battery type: rechargeable lithium-ion battery D-LI90
AC Adapter: AC adapter kit K-AC132 (optional)
Battery life: number of recordable images: approx 760, playback time approx 390 min.
* With a fully-recharged rechargeable lithium-ion battery, tested in compliance with CIPA standard.
Actual results may vary depending on the shooting condition.
PHYSICAL SPECIFICATIONS
Body dimensions approx. 5.37” (W) x 4.33”(H) x 3.37”(D) (excluding protrusions)
Body Weight: 32.6oz (body only), 35.6oz (with battery and 1x SD card)
Construction material(s): magnesium alloy shell over metal chassis
Weather resistant: yes (87 special sealing parts)
Operating temperature: 14-104°F (-10 to 40°C)
LANGUAGE SUPPORT
English, French, German, Spanish, Portuguese, Italian, Dutch, Danish, Swedish,
Finnish, Polish, Czech, Hungarian, Turkish, Greek, Russian
IMAGE STABILIZATION
Type: sensor-shift shake reduction (SRII), 5-axis electronic level function: displayed in VF/LCD (Horizontal and vertical)
Horizon correction: SR on: correction up to 1˚, SR off: correction up to 2˚
METERING SYSTEM
Type: TTL open aperture metering using 86K pixel RGB sensor, multi-segment, center weighted and spot metering
Range: EV-3 to 20 (ISO100 at 50mm F1.4)
Exposure Mode: Scene Analyze Auto, Program, Sensitivity Priority, Shutter Priority,
Aperture Priority, Shutter & Aperture Priority, Manual, Bulb, Flash X-sync Speed,
USER1, USER2, USER3, USER4, USER5
EV compensation: ±5EV (1/2EV steps or 1/3EV steps can be selected)
AE lock: button type (timer type: two times the meter operating time set in custom
setting); continuous as long as the shutter button is halfway pressed
ISO SENSITIVITY
ISO AUTO/100 to 204800 (EV steps can be set to 1EV, 1/2EV or 1/3EV)
WHITE BALANCE
AUTO WB, Multi Auto WB, Daylight, Shade, Cloudy, Fluorescent Light (D: Daylight Color, N: Daylight White, W: Cool White, L: Warm White), Tungsten Light, CTE, Manual WB (up to 3 settings), Color Temperature Configuration (up to 3 settings), copying the white balance setting of a captured image
Fine Adjustment: Adjustable ±7 steps on A-B axis or G-M axis
SHUTTER
Electronically controlled vertical-run focal plane shutter (electronic w/ Pixel Shift Resolution)
Shutter speed: auto: 1/8000 to 30 sec., manual: 1/8000 to 30 sec. (1/3 or 1/2EV steps), Bulb
CAPTURE MODES
Custom image: Auto Select, Bright, Natural, Portrait, Landscape, Vibrant, Radiant,
Muted, Flat, Bleach Bypass, Reversal Film, Monochrome, Cross Processing
Cross Process: Random, Preset 1-3, Favorite 1-3
Digital filter: Extract Color, Replace Color, Toy Camera, Retro, High Contrast, Shading,
Invert Color, Unicolor Bold, Bold Monochrome
Clarity: adjustable ±4 steps
Skin tone: Type 1/Type 2
HDR: Auto, HDR1, HDR2, HDR3, Advanced HDR, Exposure bracket value adjustable,
Automatic composition correction function
Lens Correction: distortion correction, peripheral illumin. correction, lateral correction,
aberration correction, diffraction correction
D-RANGE compensation: highlight correction, shadow correction
Composition adjust: ±1.5mm up, down, left or right (1mm when rotated); 1 degree of range
DRIVE MODES
Mode selection
Still image: single frame, continuous (H, M, L), self-timer (12s, 2s, continuous), remote control (0s., 3s., continuous), bracketing (2, 3 or 5 frames), mirror-up (possible to use with remote ctrl), multi-exposure (possible to use with continuous, self-timer or remote ctrl), interval shooting, interval composite, interval movie record, star stream
Movie: remote control *bracketing, interval shooting, interval composite, interval movie record and star stream are possible to use with self-timer/remote control.
Continuous shooting (approximates)
[35mmFull Frame]
Max. 4.4 fps, JPEG ( L: ★★★ at Continuous H): up to 70 fr., RAW: up to. 17 fr.
Max. 3.0 fps, JPEG L: ★★★ at Continuous M): up to 100 fr., RAW: up to 20 fr.
Max. 0.7 fps, JPEG ( L: ★★★ at Continuous L): up to 100 fr., RAW: up to 100 fr.
[APS-C size]
Max. 6.5 fps, JPEG ( L: ★★★ at Continuous H): up to 100 fr., RAW: up to approx. 50 fr.
Max. 3.0 fps, JPEG L: ★★★ at Continuous M): up to 100 fr., RAW: up to 70 fr.
Max. 1.0 fps, JPEG ( L: ★★★ at Continuous L): up to 100 fr., RAW: up to 100 fr.
*ISO100
Multi-exposure: composite mode (additive/average/bright) # of shots(2 to 2000 images)
Interval shooting:
[Interval shooting] interval: 2s. to 24h./ standby interval: 1sec. to 24hrs., number of images: 2 to 2000, start interval: now/self-timer/remote control/set time
[Interval composite] interval: 2sec. to 24hrs./ standby interval: 1sec. to 24hrs., number of images: 2 to 2000, start interval: now/self-timer/remote control/set time, composite mode: additive/average/bright, save process: on/off
[Interval movie] recorded pixels: 4K/FullHD/HD, file format: motion JPEG (AVI), interval:2sec. to 24hrs./standby interval: 1sec. to 24hrs., number of shots: 8 to 2000 images (8 to 500 images at 4K), start interval: now/self-timer/remote control/set time
[Star stream] recorded pixels: 4K/FullHD/HD, file format: motion JPEG (AVI), interval:2sec. to 24hrs./ standby interval: 1sec. to 24hrs., number of shots: 8 to 2000 images (8 to 500 images at 4K), start interval: now/self-timer/remote control/set time, fade-out: off/low/medium/high
PLAYBACK MODES
Single frame, multi-image display (6,12, 20, 35, 80 segmentation), display magnification (up to 16, 100% display and quick magnification available), grid display (4x4 grid, golden section, scale display, square 1, square 2, grid color: black/white ), rotating, histogram (Y histogram, RGB histogram), bright area warning, auto image rotation, detailed information, copyright information (photographer, copyright holder), GPS information (latitude, longitude, altitude, coordinated universal time) , orientation, folder display, calendar filmstrip display, slide show
FILE FORMATS
Still: RAW (PEF, DNG), JPG (EXIF 2.30), DCF 2.0 compliant
Movie: MPEG-4 AVC/H.264 (MOV) - JPEG(AVI) for internal movie record
CUSTOM FUNCTIONS
Functions available: 26
COMPUTER SYSTEM REQUIREMENTS
For device connectivity. Bundled software requirements may vary.
Windows: Windows 10/Windows 8.1 (32 bit/64 bit) / Windows 8 (32 bit/64 bit) / Windows 7 (32 bit/64 bit) / Windows Vista (32 bit/64bit). Mac: Mac OS X 10.10 / 10.9 / 10.8 / 10.7
Redigerat av Pentax K, 18 February 2016 - 06:22.
Postad 18 February 2016 - 11:53
Pentax K
  • Pentax K
  • 284 inlägg
19690 kr på Cyberphoto.
Redigerat av Pentax K, 18 February 2016 - 11:56.
Postad 18 February 2016 - 12:33
Mikael_R
  • Mikael_R
  • 15622 inlägg
Fortfarande bara Pentax som kan det där med knapp layout.... Fast nikon har blivit bättre, men Pentax ser fortfarande ut att tänka två steg längre än alla andra. Kul med FF för Pentax folket!!!
Ser ut att vara en gigantisk sökare på den där.
Redigerat av Mikael_R, 18 February 2016 - 12:34.
Postad 18 February 2016 - 13:07
frollic
  • frollic
  • 14167 inlägg
https://www.minhembi...howtopic=327829
