Hej! Backkamera via A/V-in port. Hjälp!!
1 svar till detta ämne
Postad 10 August 2020 - 09:36
Colton11
  • Colton11
I am doing a "home construction" where I try to play a reversing camera in the car's original screen via the A / V-in port.
The only problem is that it does not work with a standard A / V cable.
The picture becomes very flickering and all you see are waves.
For some strange reason, however, it works to get a color image with the red cord on an RGB cable via a DVD player. It also works via the rear view camera, but in black / white.
What do you think I'm doing wrong?
How can an RGB cable work when it should be the A / V cable that should work?
Thanks so much for the help / suggestions !!
https://9apps.ooo/
Redigerat av Colton11, 11 August 2020 - 04:06.
Postad 10 August 2020 - 14:55
Unregistered9a1f280a
  • Unregistered9a1f280a
  • 1715 inlägg
Finns det någon inställning där du kan välja inmatning?
Låter som det är ett PAL-NTSC problem
https://sv.wikipedia...lternating_Line
oftast måste man göra ett aktivt val. Speciellt om det rör sig om Kinaprylar....
alternativt att jordningen till kameran är dålig.
https://camera-sourc...ats-not-working
Redigerat av Unregistered9a1f280a, 10 August 2020 - 14:58.
