* Officiell tråd - Epson TW-200 *
115 svar till detta ämne
Postad 15 September 2003 - 11:59
EmuMannen
EmuMannen
2096 inlägg
För att göra det lättare för våra medlemmar att hitta i djungeln av inlägg så inför vi officiella topicar på våra mest populära trådar. I denna tråd skriver du om allt som rör Epson TW-200.
//HenrikMed tanke på hur fantastiska dess föregångare TW100 och TW100H varit så tänkte jag att det kunde vara av intresse att starta en egen tråd för information om deras efterföljare TW200. Continuing on from the highly rated TW100 Epson’s new TW200 brings W-XGA resolution within reach of films enthusiasts.
Epson's TW200 home cinema projector has 1300 lumens, 1280x 720 (720p) native resolution and a contrast ratio of 800:1. It’ has six colour modes, such as, Dynamic and Living room mode for a higher brightness for gaming applications, with Theatre and S-RGB mode to provide increased contrast for more subdued lighting conditions to give a more cinematic performance.
For maximum installation flexibility the TW 200 is fitted with powered focus and zoom, manual horizontal and vertical lens shift adjustment as well as electronic keystone correction. Not only does it have component video, s-video and composite video connectors the TW200 is also fitted with SCART connection for quality, hassle free connectivity. Epson TW200 Technical Specifications Projection system 0.7" D4 RGB Liquid Crystal Shutter Projection System Brightness 1300 ANSI lumens (Colour Mode: Living Room/Dynamic) Resolution 1280 x 720 Native video resolution 720p Aspect ratio 16:9 Contrast ratio 800:1 Focal length 21.4 – 31.7mm Zoom ratio Optical Zoom [1.0-1.5] Lamp Type 200W UHE Inputs Composite Video S-Video Component Video SCART Analog VGA Dimensions 440mm(W) x 320mm(D) x 114mm(H) Weight Approx. 5.3kg Projection method Front/Rear/Ceiling Mount Fan noise Silent mode 28dB (Theatre/Natural/s-RGB) Standard Accessories Power cord 3m SCART Adaptor Remote Control USB Cable User Manual Quick Reference Card Safety Instructions Warranty 3 year next day on site repair or replace (UK & Ireland)
Redigerat av Martin.M, 04 August 2004 - 06:08.
Postad 15 September 2003 - 12:01
EmuMannen
EmuMannen
2096 inlägg
Idolbilder:
Redigerat av EmuMannen, 08 October 2003 - 14:30.
Postad 15 September 2003 - 12:10
millstream
millstream
196 inlägg
Nice ... synd bara att DVI-anslutning saknas. Vet du när den släpps och vad priset hamnar på?
/Anders
Postad 15 September 2003 - 12:20
EmuMannen
EmuMannen
2096 inlägg
Jag vet inte var Aero hittade den här informationen: Dreamio EMP-TW200 D4 panel Resolution: 1280 x 720 Brightness: 1300 Ansi Lumens Contrast: 800:1 Lens: 1,5x zoom, short throw Image processor: Pixelworks 8bit DNX Inputs: Composite, S-video, Component (3X rca), VGA (Dsub15), HDMI Control inputs: USB, RS232C Horizontal and vertical lens shift Price: 3000 euros (not sure if it's MSRP and for which country. If it is for Greece then expect it around 2500 euros for countries like Germany and France).Sug på den... HDMI i stället för DVI + SCART och ett pris på mellan 20-30 000 kr. Det ser ut som den perfekta julklappen åt sig själv tycker jag! Referens: https://www.minhembi...ndpost&p=278073
Redigerat av EmuMannen, 15 September 2003 - 12:22.
Postad 15 September 2003 - 12:42
Unregistered34520
Unregistered34520
300 inlägg
Då har man bara att vänta på att någon som är beredd att dela med sig av sin erfarenhet faktiskt får se den live!
Postad 15 September 2003 - 13:41
Über-Guru
22892 inlägg
"scart": Digital-tv och tv-spel via rgb-scart kombinerat med DCDi? Jatack!
Hmm...HDMI vore ju riktigt trevligt ja...
Ärligt talat, de kan väl inte vara så puckade att de släpper en toppproj idag som inte har nån form av digitalingång? Isf är denna proj i mina ögon DOA .
Finns det nån officiell data från Epson? Vad är det som gäller? Scart eller HDMI eller kanske både och?
"manual horizontal and vertical lens shift": Mkt najs! Stort plus i mina ögon!
800:1 i kontrast. Oavsett om det är ovanligt ärliga siffror eller inte så känns det lite för lite i dessa DLP-tider. Detta tillsammans med hög ljusstyrka (i "Living Room/Dynamic"-mode iofs) låter lite klassisk platt LCD-bild tyvärr... Men om den kan köpas för cirka 25, max 30, papp så har ju LCD inte så mkt konkurrens. Och Epson, om någon, kan ju det här med LCD-teknik. Vi får hoppas att TW200 hamnar däromkring, då kan det nog vara ett riktigt najs köp!
Lite lätt småful var den oxå men jaja, det är ju bara en parantes.
Väntar (trots allt) med spänning på erfarenheter och demo utav denna!
Postad 15 September 2003 - 13:47
Unregistered34520
Unregistered34520
300 inlägg
"Lite lätt småful var den oxå men jaja, det är ju bara en parantes. "
... själv har jag funderat på Optoma H76, den projektor som förmodligen kan kräva titeln "Fulaste projektorn 2003", så i mina ögon var denna projektor väldigt stilig
Postad 15 September 2003 - 14:03
EmuMannen
EmuMannen
2096 inlägg
Jag tyckte också att den var lite ful först men om den är någelunda rektangulär så tror att den är snyggare i verkligheten än vad den ser ut på bilderna...
Intressant att de flyttat utblåset från fronten. Jag har aldrig haft problem med det på min TW100 med de finns de riktigt känsliga på AVS som klagar på ljusspill mot duken...
Verkar faktiskt som om Epson lyssnat på den feedback användarna gett dem angående TW100 och verkligen åtgärdat det i TW200. Bäst att hålla sig ifrån en demo om man inte är beredd att uppgradera...
Bra att de behåller den vita färgen på ytterhöljet. Jag älskar färgen på min TW100 eftersom man knappt lägger märket till den då den monterats mot ett vitt tak. Annat hade det varit om den varit i silver eller någon annan färg...
Postad 15 September 2003 - 14:08
Über-Guru
22892 inlägg
Nidhugg>> Hehe, sant...  Och som sagt, det är ju verkligen bara en parantes.
Postad 15 September 2003 - 15:09
soren
soren
646 inlägg
Inget som är värt att uppgradera för dock?
Nån som sett vad det sitter för deinterlacer i den?
/Sören
Postad 15 September 2003 - 19:48
Unregistered89018446
291 inlägg
Om man skall lita på den posten jag postade här (skall man aldrig  )
Så kommer den info från en Grekisk tidning(bara det) som kört ett 'live and kicking" ex.
Då är det Pixelworks med 8 bits historia. Det går som sagt fint att göra motion adatpive i 8 bit, speciellt i förhållande till våra sunkiga DVD och andra källor idag, men 10 bits intern behandling innebär högre korrigerar för ett perfekt gamma output värde. Dessutom är det svårare att urskilja hårda kanter i genomsökningen av MXM block..bah....det här blir nog bra. De flesta har ju bra DVD spelare. Epson är (umm...som om du som ägare till TW100 inte visste  ) ärliga i sina Spec.
f.ö är det nog ingen som kan skilja längre på företagen Genesis-pixelworks, måste vara svårt för de anställda....
Postad 16 September 2003 - 12:18
EmuMannen
EmuMannen
2096 inlägg
Mer information om TW200, Babelfiskad från tyska:Epson: HDTV LCD projector Emp-tw200 for 2990 EUR 15.09.2003 (ks) Epson announces a new HDTV LCD projector for 2990 EUR, which should be available starting from at the end of Octobers 2003 in the trade with the Emp-tw200. The successor of the Epson Emp-tw100 has an engine zoom shot and a manual Lens SHIFT, with which the picture is movable both horizontal and vertically. In the case of a dissolution of 1280 x 720 the projector is to supply a light achievement of 1.300 ANSI lumens and a contrast relationship of 800:1. The 1.5fach-Zoom-Objektiv is to make picture diagonals possible up to maximally 7.63 m, in addition, to project with small distances from 2-3 m already large pictures. A selection of 5 color modes adapts each application to the respective space brightness. All the same whether the projector is located in the bright dwelling or in the dark bedroom, the preset color modes are to provide on the different projection conditions for a simple, suitable image replication. Thus e.g. with the choice "theatre" is activated automatically, "natural" and "sRGB" the Cinema filter for the increase of the contrast and for better black value representation. For the ambitionierten user on CD Rome a "Cinema Color Editor" software is provided, with which it should be possible ambitionierten users to adjust further farbeinstellungen according to individual desires at the Hometheatre PC. The micro-adjustments of the colours and the brightness are storable and can completely as required again be called up. These attitudes can be protected against inadvertent changes with the again integrated key lock. Additionally the Hometheatre PC, e.g. with rueckprojektionen, can be used, in order to take over all of the comprehensive remote maintenance functions. Also the operating noise was reduced: In " the theatre " mode should be loud the projector straight still 28 railways. As De-Interlacer chip of Pixelworks is used " " in the Emp-tw200 of the DNX, which is to guarantee gentle and natural outlines particularly with the projection of fast movements. During the connections the Epson Emp-tw200 up to an DVI interface of everything has on board, which one needs nowadays. Beside a VGA socket, a Composite, s-video and a YUV connection via Cinch also still another second source of component can be attached to the projector over the D4-Schnittstelle common in Japan with the help of an adapter. EPSON grants a Carry in warranty of two years, which can be extended optionally on three years suburb service. The Hotline is under Tel. 01805/235470 (12 cent/minute) attainable. Technical data: D4 LCD with 10bit drive Color management technology "ColorReality II" for improved color representation Dissolution 1,280 x of 720 pixels (aspect ratio 16:9) Brightness 1,300 ANSI lumens Contrast 800:1 Color reproduction 16.77 million colors Trapezoid correction (key clay/tone) -15 - 15 degrees vertically Cinema filter activates automatically with the color mode choice (ON: Theatre/Natural/sRGB) Objectively zoom with motorized zoom shot and focus Objective shift vertical & horizontal, manually Zoom shot relationship 1,5: 1 F 2.1 - 2,8 Focal length 21.4 - 31.7 mm Lamp 200W UHE, lamp life span: up to 3.000 hours (in the Low lamp mode) Dimension of picture area 0.76 - 7.62 m diagonally Projection distance 0.87 - 13.65 m Horizontal/field frequency 15 - 92 kHz/50 - 85 cycles per second Video standard NTSC/NTSC4.43/PAL/M-PAL/N-PAL/PAL60/SECAM/52ï/525p/62ï/625p/750P/112ï Entrance/exit 1x YCbCr/YpbPr (D4) 1x s-video (4pin mini DIN) 1x component video (3x Cinch) 1x similar to RGB (D-sub 15pin) 1x USB 1x Rs-232c (D-sub 9pin) 1x trigger (3.5 mm of mini socket) Extra: EPSON Cinema Color editor, key lock, child barrier, focus barrier, zoom shot barrier Operating noise 28 railways (theatre/Natural/sRGB mode) Voltage supply AC 100-240 V, 50/60 cycles per second Dimensions 44.0 cm x 32.0 cm x 11.4 cm (B x T x H) Accessories: Remote maintenance, mains cable, USB cable, Scart adaptor cable, Instruction manual, kurzanleitung Warranty 3 years bring in Referens: http://www.areadvd.d...920030001.shtml
Postad 16 September 2003 - 12:20
EmuMannen
EmuMannen
2096 inlägg
2990 € ~ 27 000 Kr
Lägre pris, mer funktion, sämre kvalitet? Vad tror ni till exempel om bytet från DCDi till Pixelworks chip? Personligen hade jag hoppats på en uppgradering från FLI2200 till FLI2300 i stället...
Det jag verkligen uppskattat med min TW100 har just varit den inbyggda bildbehandlingen och det faktum att den känns solid. Hoppas de inte sänkt ambitionsnivån till förmån för ett lågt pris.
Redigerat av EmuMannen, 16 September 2003 - 12:43.
Postad 16 September 2003 - 13:25
Über-Guru
22892 inlägg
Hmm...fattade jag rätt nu men säger de alltså att det INTE finns nån DVI-ingång?
Ingen DCDi...  Iofs så vet vi inget om DNX-chippet. Kanske är ok det med.
Att de har snålat in på chassikvalité, komponenter (och optik??) och sånt är nog inte helt omöjligt. Eftersom LCD inte längre kan konkurrera med DLP i ~50000 klassen där TW100 en gång i tiden låg så antar jag att man får se till att bygga billigare projjar helt enkelt.
Ska iaf bli kul att se denna i jämnförelse med den billigare Z2:an, HS20 och såsmåningom mot AE500.
edit: ändrade från TW1000 till TW100...verkade vettigare så...
Redigerat av pacman, 16 September 2003 - 14:33.
Postad 16 September 2003 - 14:05
EmuMannen
EmuMannen
2096 inlägg
pacman, jag önskar verkligen att vi kunde få se en bild på baksidan (eller var nu kontakterna kan tänkas sitta). Den information vi har såhär långt är: 1x YCbCr/YpbPr (D4) 1x s-video (4pin mini DIN) 1x component video (3x Cinch) 1x similar to RGB (D-sub 15pin) 1x USB 1x Rs-232c (D-sub 9pin) 1x trigger (3.5 mm of mini socket) Observera följande citat "During the connections the Epson Emp-tw200 up to an DVI interface of everything has on board, which one needs nowadays. Beside a VGA socket, a Composite, s-video and a YUV connection via Cinch also still another second source of component can be attached to the projector over the D4-Schnittstelle common in Japan with the help of an adapter." Det talas om dels en DVI-kontakt (frågan är om det är HDMI som indikerats tidigare) och dels ett D4-interface (vanligt i Japan). Vi saknar även en Cinch för komposit-video i ovanstående lista och man kan fråga sig vart SCART-kontakten tog vägen? En mening som "similar to RGB (D-sub 15pin)" lämnar också en del öppna frågor. Är det ett vanligt VGA-interface eller är det ett multi-interface för andra typer av signaler som RGBS etc. Behövs i så fall en specialkabel eller går det bra med en normala VGA-kablar, "breakout cables" etc. En möjlighet är att det kan komma flera modeller där D4-kontakten bara sitter på den Japanska, SCART på den Europeiska osv. I annat fall kanske man tvingas använda adapters för att exempelvis köra komponent genom D4-kontakten osv. Bara spekulationer än så länge med andra ord...  För er som inte sett eller hört något om D-Terminal tidigare så finns det en Q&A här: http://www.nhk.or.jp...n/qa-9910e.html
Redigerat av EmuMannen, 16 September 2003 - 14:24.
Postad 17 September 2003 - 18:28
videopac
videopac
125 inlägg
Men, den verkar högljudd...
"Operating noise 28 railways (theatre/Natural/sRGB mode) "
dB = DB = Die Bahn = Tyska järnvägen!
MVH,
Rikard
Postad 17 September 2003 - 19:30
EmuMannen
EmuMannen
2096 inlägg
Jag noterade också Babelfiskens sinne för humor...
Postad 18 September 2003 - 06:00
Unregistered8fda5b62
1120 inlägg
Tja jag ser ingen anledning att uppgradera till denna ..
Samma kontrast och högre ljusstyrka e inget jag behöver eller vill ha.
Säker en bra proj men ser inget i specen som gör mig sugen på att byta..
Mina önskemål hade varit högre kontrast och evt högre upplösning..
Kanske lite lägre ljudnivå från den oxå...
Men klart för 27000kr e det säkert ett klipp.... känns lite surt att man betalade över 40000kr för sin TW100H nu.. men men det visste man nästa att det skulle bli så här..
Postad 18 September 2003 - 09:11
EmuMannen
EmuMannen
2096 inlägg
Tja jag ser ingen anledning att uppgradera till denna .. känns lite surt att man betalade över 40000kr för sin TW100H nu..
Sluta sura Demon , du har fel attityd.  Jag har sett över 100 filmer på min TW100 för en kostnad av cirka 40 kr per rulle. Alternativkostnaden hade varit att ta med sig familjen på bio (och då blir det att åka bil, parkera i parkeringsgarage, äta ute, köpa biljetter, godis etc.). Det brukar gå på i snitt 300 kr per film. Jag har med andra ord "tjänat" 26.000 kr så min projektor betalar sig själv! Det är så du skall se det.
Postad 18 September 2003 - 10:23
1120 inlägg
Emumannen... Du har då svar på allt!!!
Postad 19 September 2003 - 07:59
Unregisteredf998178d
173 inlägg
Nu börjar det bli lite off-topic men hur har du räknat fram 40Kr/film? Demon nämde summan 40.000:- vilket blir 400Kr/film.
The Reaper
Postad 19 September 2003 - 11:42
EmuMannen
EmuMannen
2096 inlägg
Nu börjar det bli lite off-topic men hur har du räknat fram 40Kr/film? Demon nämde summan 40.000:- vilket blir 400Kr/film. Demon nämnde 40kkr men från det skall dras kostnaden för en TW200 om alternativet var att köpa en sådan. Dessutom så har han ju faktiskt redan haft sin TW100 i nästan ett år. Egentligen borde kostnaden per film räknas ut över hela projektorns livstid. Personligen räknade jag med 40 kr efterom jag brukar hyra en DVD för i snitt 30 kr och sedan lade jag på kostnaden för lamptid etc. Med den kalkylen så har projektorn tjänat in sig själv på mindre än två år!
Redigerat av EmuMannen, 19 September 2003 - 11:44.
Postad 07 October 2003 - 14:49
Unregisterede74c2883
88 inlägg
Pris ca: 30000:- Epson tw-200
Postad 08 October 2003 - 14:30
EmuMannen
EmuMannen
2096 inlägg
Länk till information om TW200 från Epson (reklam, specification mm.): http://www.epson.co....ector/emptw200/Här finns minst sagt en del intressant information (det verkar som om Epson tagit mig bokstavligen när jag klagat på TW100s dåliga stöd för RGBS, kontakter, aspect control och bildbehandling): Refresh Rate:50Hz or 60Hz (based on input signal) SCART Input:Input Signal Video Standard: 625i/525i Video Signal: RGB Video (0.7Vp-p 75ohm), Sync: CVBS (1.0Vpp/Sync.negative, 75ohm) Input Terminal:RCA x 4 (Red/Green/Blue/Yellow) (in common with Component Video and Composite Video terminal) ANALOG RGB:Native: 750P, Resize: 1024 x 768/800 x 600/640 x 480 /525i/625i/525P/625P/1125i Men var tog kontakten för digital videosignal vägen? Det saknas DVI eller HDMI!
Redigerat av EmuMannen, 08 October 2003 - 14:48.
Postad 08 October 2003 - 15:29
291 inlägg
Arghaha... Jag säger som mitt kära (ehh..nåja  Flygbasjägar befäl skulle sagt "Finns absolut inget värre än dissinformation" Sorry..gubbar, men det var info som postades i början av Tw200 ryktet..fel av mig =) Verkar vara nya trenden att lämna ut DVI, sjukt. Även nya Domino kör utan DVI/HDMI ingång. En annan bra länk om D4 panelen, jag nyligen hittade och postade på AVS. Epson D4EDIT-tog bort en länk som inte alls var TW200 utan TW10..inte många rätt idag!!
Redigerat av Unregistered89018446, 08 October 2003 - 15:31.
Postad 09 October 2003 - 14:55
soren
soren
646 inlägg
Vem sjutton vill köpa denna utan digitalingång???
Jag skulle rekommendera alla att kolla vad som händer med Panasonic AE500 istället, hoppas den har digitalingång.
/Sören
Postad 09 October 2003 - 15:40
Unregisteredc9c5a2e4
29 inlägg
Nu blir jag lite förvirrad.
Jag har läst om TW100 att den skall vara en superproj och har blivit heltänd på TW200. Och den verkar ju hamna strax under 30k vilket känns ganska rimligt.
Såg att projectorcentral.com listar TW100 som Highly Recommended!
Men i alla fall, jag läste lite i slutet av TW100 tråden och det verkar mest vara gnäll och problem med TW100, konvergensproblem och döda pixlar?
Och nu i TW200 tråden så skriver ni att den inte har DVI ingång och att den är kass pga detta. För mig som kört Philips Fellini, helt utan dataingång i tre år så har jag ingen data erfarenhet alls, blir dt verkligen bättre med DVI? Och det är väl bara signal från er dator som ni skickar via DVI, eller har nyare DVD-spelare DVI utgång?
Emumannen: Jag har helt förkastat Nec 240K och alla billiga DLPer :-)
Postad 09 October 2003 - 16:24
29 inlägg
Även på användarrecensionerna på Projector Central så verkar det vara en hel del som haft kvalitetsproblem med TW100? http://www.projector...fm?part_id=1731TW100 Recensioner
Postad 09 October 2003 - 16:59
Über-Guru
22892 inlägg
Undra om det finns nån anledning att köpa denna istället för Sanyo Z2...
Inte på pappret iaf, men man vet ju aldrig, vi får se hur det blir IRL.
Postad 09 October 2003 - 19:10
EmuMannen
EmuMannen
2096 inlägg
TW100 var revolutionerande när den kom och den är i mitt tycke (något jävig men endå) fortfarande en mycket bra projektor. Döda pixlar och konvergensfel dras de flesta LCD med och inte tror jag att problemet är större för TW100. Däremot tror jag att deras ägare kanske är mer krävande än de flesta (inte så konstigt kanske om man lagt ut runt 50 000 kr för en projektor). TW100 var tidigt ute med DVI och fick därför inte stöd för HDMI. Nyare projektorer kommer att ha mer, bättre och billigare teknik. Jag tycker dock att TW100 har åldrats med värdighet. Frågan är om TW200 kommer att konkurrera ut TW100 rent kvalitetsmässigt? Den kommer i alla fall att vara rejält mycket billigare.
Postad 09 October 2003 - 19:32
29 inlägg
Hmm... där dök han upp som en hök. Tack för svaret Emumannen.
Imorgon skall det shoppas en TW200 eller en Panasonic AE300 som väljer jag mellan just nu. 30000:- vs 17000:- Jag har insett att AE300 är en jäkligt bra proj för pengarna, men det är trots allt en budgetproj och steget upp till TW200 verkar ge mig en instegsmodell till Hi-End, vilket vore roligt då jag har en hyfsad ljudanläggning (Dali Grand front+center samt Denon 3803).
Någon som sett både TW100 och AE300 som har nån kommentar.
Läste i tidningen hemmabio att AE300 hade "många småskavanker i bilden"
Är det vanskligt att gissa på att TW200 kommer att bli bättre än TW100?
Postad 09 October 2003 - 22:07
EmuMannen
EmuMannen
2096 inlägg
Jag tycker Panasonic bygger otroligt "prisvärda" och innovativa projektorer. Ingen skugga över deras produkter (utom möjligen vissa kvalitetsproblem, men de är de ju inte direkt ensamma om)... När det gäller TW100 vs TW200 så har jag ingen aning ärligt talat. Det skulle dock inte förvåna mig om TW200 är lika bra eller "bättre" (någonting bör de väl ha lärt sig från första generationen)... Om jag vore som du så skulle jag försöka få båda demonstrerade och sedan välja den du tyckte såg bäst ut... Lycka till med köpet.
Postad 09 October 2003 - 22:58
mattiask
mattiask
1837 inlägg
lofvet: Har du missat nya Sanyo PLV-Z2 som kommer kunnas köpas när som helst. Den tycker jag är helt klart mest intressant på papperet med ett pris även i sverige under 25000:-. Mattias.
Postad 10 October 2003 - 16:42
29 inlägg
Tja... nu är den beställd i alla fall. Det blev en TW200 på personal-hempc-köp. Fick passa på nu innan det blir nya regler :-) Att få en sådan schysst proj för 13000:- netto är ju inte fy skam!
En stor anledning till att det blev just denna är att firman som levererar våra hempc hade fina avtal med just Epson, Nec och Sony. (För en AE-300 ville de ha 23000:- eftersom de inte hade några avtal. Och Sanyo ville de inte ha att göra med!) Och HT1000 blev lite väl dyr samt att jag verkar vara riktigt DLP-känslig efter att ha sett X1 och Nec-LT240 live.
Så fort jag får den skall jag posta en recension här!
Postad 10 October 2003 - 17:00
Über-Guru
22892 inlägg
Grattis! Låter som en jäkligt bra deal! Vad det gäller regnbågar o DLP så är det iofs inte säkert att du är känslig för dem bara för att du sett X1 och LT240. HT1000 har ju ett helt annat färghjul än dessa två. Men det spelar ju ingen roll nu iofs...
Postad 10 October 2003 - 18:09
EmuMannen
EmuMannen
2096 inlägg
lofvet GRATTIS! Du kommer säkert att bli hur nöjd som helst! Åtminstone i ett par månader innan du läst alla andra recensioner, upptäckt brister och glömt bort alla fördelar. Att köpa projektor börjar bli en lika dålig investering som att köpa en dator. Men å andra sidan så är det en så skön känsla att slå på projektorn och att slippa en vanlig tv att det är värt varenda krona! Räkna dock med att det inte finns någon väg tillbaka. Mycket vill ha mer och aldrig kommer du att nöja dig med 32" igen! Välkommen till dårarnas paradis! Den snabbt växande skaran projektorägare som har förmånen att få uppleva "hemmabio" på riktigt!  Eller som jag brukar säga -"Endast stort ljud gör ingen hemmabio!"  Ps. Jag ser verkligen fram emot en recension av TW200!  Ds.
Redigerat av EmuMannen, 10 October 2003 - 18:11.
Postad 11 October 2003 - 07:23
88 inlägg
lofvet: personal-hempc-köp!!!! vilka regler gäller igentligen? komplett datorutrustning vet jag men gäller det även för projektorer? eller har du möjlighet till en liten "luring"?
Postad 11 October 2003 - 20:01
29 inlägg
Projektorer som hem-pc skärm är en gråzon. (Man får ju bara köpa en "skärm" i sitt paket.) Det är bara att blunda och hoppas på att det inte skiter sig. Det var dock en artikel i Computer Sweden i veckan där det stod att det finns ett förslag på att ändra hem-pc reglerna. Detta för att stoppa oss extremköpare :-( Det stod tydligen nåt om att man inte skulle få ha en fräckare dator hemma än man har på jobbet!?! Hur kollar dom det måntro? Förslaget skulle i alla fall gå igenom ganska snart, så det är nog slut på extremköpen inom ett par månader. Jag är så himla glad att jag hann beställa min Epson TW-200 :-)
Jag är faktist projägare sedan tidigare. Köpte en begagnad Philips Fellini 100 redan år 2000 när min TV gick sönder. Sedan dess har jag kört proj-only, sett både nyheter, väder och filmer på projjen och är svin-nöjd.... kan fortfarande sätta mig ned framför en film och känna mig så jäkla nöjd över att ha en proj. Finns dock några grejer som stör mig med den: 1) Den låter ju ganska mycket, 2) Kan inte se på tv/film när det är för ljust ute 3) Kommer in damm på lcd:erna alldeles för lätt.
Min nästa quest blir att försöka köpa en Stewart Firehawk till bästa möjliga pris! Skall söka lite här i forumet och kolla med lite kontaker.... (Har en EuroScreen Diplomat som jag kört med min Fellini och den har fått ett såndärt fint häng-"V" som stör mig som faan)
Redigerat av Unregisteredc9c5a2e4, 29 October 2003 - 16:29.
Postad 27 October 2003 - 01:48
29 inlägg
Jag antar att alla sett artiklarna i dagtidningar osv det senaste. Reglerna för hem-pc kommer att ändra 1 januari 2004. Troligtvis kommer det att bli ett maxbelopp på 30000:-
Just nu kör jag DVD från min xbox och även divx och sån från min xbox. Men när jag får min TW200 så känns det lite b-aktigt. Hur fräck spelare behöver man ha för att mata en TW200 med tillräckligt bra signal? Ni som kört TW100 ett tag vad kör ni för spelare? Räcker det med billigaste möjliga spelare som kan leverera progressiv scan via komponent?
PS: Fick sålt min Philips Fellini 100 för 4500:-, måste säga att jag är hyfsat nöjd iaf.
Postad 27 October 2003 - 08:57
Über-Guru
22892 inlägg
Offtopic: Hehe, ja det där med personal-pc-köp är rätt skadat egentligen. Men bra för oss givetvis  Min polare har köpt en "Broadbandbox" på detta sätt. Broadbandboxen är iofs i grunden en pc men den är ju inte i första hand så man tänker sig en pc. Dessutom ska det ju följa med en "skärm" till "pc:n" så han valde en 42 tums plasma från NEC. Så ja, gränserna är nog rätt luddiga i dagens läge.... Mer offtopic: lofvet, hehe, har du levt med enbart en Fellini och ingen tv i 3 år alltså? Starkt måste jag säga. Den fläkten är ju inte att leka med direkt.  Tror du kommer bli helnöjd med TW200:an nu iaf.
Postad 27 October 2003 - 09:56
soren
soren
646 inlägg
Men är det inte förtaget som får ligga ute med pengarna till de kan skriva av det?
/Sören
Postad 27 October 2003 - 11:04
Unregisteredc6213648
51 inlägg
OT: Företaget ligger väl ute med pengarna tills de kan skriva av prylarna. Men om jag förstått rätt så dras pengar från lönen innan skatt för den som handlat "Hem-PC" från jobbet. Det betyder ju att staten inte får in lika mycket skatt. Och staten vill gärna kontrollera allt och alla och få in så mkt pengar som möjligt, skatt på skatt osv..
Postad 27 October 2003 - 11:51
Unregistered3e8a25cd
1114 inlägg
Nu har jag testat TW200 och jag kan bara säga WOW! Om ni vill veta vilken utrustning jag använde så kolla min minitest av Sanyo Z2. Vad jag har hört, och jag hoppas att det stämmer, är att Sanyo Z2 och Panasonic PT-AE500E kommer att ha samma 1280 x 720 paneler som sitter i TW200, dvs gjorda av Epson. En anledning till att jag hoppas det är att det sample jag testade av Z2 inte var lika bra när det gäller pixligheten som TW200. I mitt sample satt "fel" paneler så produktionsexen borde ha de nya. Tiden för testen var extremt kort men det lilla jag han testa var mycket imponerande. För det första håller jag med om att TW200 ser lite skum ut på bild men i verkligheten är den faktiskt riktigt snygg. Har lagt upp bilder på fram- och baksida samt fjärr här: http://www.hembiobut...p?pgrpnr=107800Linsen justeras inte vid linsen utan ovanpå projektorn vilket enligt mig är en klart bättre lösning än på tex Z2. Det finns ingen DVI eller HDMI-ingång vilket är synd men bara att konstatera. Det finns en D4-ingång som liknar en VGA-ingång och som tydligen är en japansk standard för digital komponentsignal. Han inte testa linjedubbleringen ingående så jag kan inte svara på om bytet från DCDi vart till det bättre eller sämre. Epson har satt brightness till +5 på fabriken och då väsnas den rejält. Sänker man istället till 0 så innfinner sig en behaglig tystnad. Ljudet kändes som att det var i nivå med Z2 eller något lägre. Svärtan med min Greyline duk var mycket bra! Att man kan kalibrera TW200 med sin PC och sedan dela med sig till andra via en fil över nätet är också en cool finess! Det som talar för TW200 är en otroligt bra bild, att den är tyst och att den har en hög ljusstyrka. Det som talar emot TW200 är avsaknaden av DVI- eller HDMI-ingång och det något höga priset i jämförselse med Z2. Om jag fick välja en av dem skulle det bli en TW200!
Redigerat av Unregistered3e8a25cd, 27 October 2003 - 11:55.
Postad 27 October 2003 - 15:41
soren
soren
646 inlägg
Trevligt!
Jag tror dock att Epson gjorde en stor tabbe som inte satte DVI/HDMI på TW200. Då detta kommer bli enormt stort inom det närmaste året...
Deras dyrare modell kommer inte ha en chans mot de billigare projektorerna som är i stort sett lika bra.
/Sören
Postad 27 October 2003 - 16:18
EmuMannen
EmuMannen
2096 inlägg
Jag tror dock att Epson gjorde en stor tabbe som inte satte DVI/HDMI på TW200. Då detta kommer bli enormt stort inom det närmaste året... Deras dyrare modell kommer inte ha en chans mot de billigare projektorerna som är i stort sett lika bra.
Jag håller med men å andra sidan så har ju de dyrare DVI!
Postad 28 October 2003 - 10:49
Unregisteredb48adf6d
21 inlägg
Kul att läsa en possitiv recension.
Har själv stora funderingar på denna TW-200.
Har dock två frågor:
1: Hur stor skillnad är det på bilden om man ej har en DVD spelare med PS PAL ?? (jag har en Marantz DV-8300 som är kanon via komponent till TV).
2: Vart köper man den till lägsta pris??
/Bob
Postad 28 October 2003 - 11:18
improwise
improwise
3696 inlägg
Sandstream:
Var skillnaden mot Z2 så pass liten att det, efter de första 2 veckorna, inte spelade så stor roll eg vilken man väljer? Har du någon åsikt om hur dessa båda står sig mot Sonys HS20?
/pJ
Postad 28 October 2003 - 13:19
EmuMannen
EmuMannen
2096 inlägg
Min erfarenhet är att det är just skillnader, hur små de än må vara som man retar sig på eller uppskattar med tiden. De är definitivt ingenting man "glömmer bort" i alla fall!
Postad 29 October 2003 - 14:28
1114 inlägg
Sandstream: Var skillnaden mot Z2 så pass liten att det, efter de första 2 veckorna, inte spelade så stor roll eg vilken man väljer? Har du någon åsikt om hur dessa båda står sig mot Sonys HS20?
/pJ
Iom att Z2:an som jag testade hade fel paneler är det orättvist att jämföra den med TW200 som har rätt paneler. Jag tror att skillnaden som jag såg i pixlighet, till TW200s fördel, kommer att vara borta när produktionsexemplaren av Z2 kommer. Personligen uppskattar jag den högre ljusstyrkan i TW200 men saknar DVI/HDMI-ingång. Sen ska ju priset vägas in också och det skiljer hos oss 7000:- i pris mellan modellerna. HS20 har jag inte sett ännu men vi har beställt hem ett par stycken så jag hoppas få tillfälle testa en. Har precis lagt upp min HS10 till försäljning så det kanske blir en HS20 som julklapp
Postad 29 October 2003 - 21:55
mattiask
mattiask
1837 inlägg
sandstream71: I vilket lamp läge var projektorerna när du jämförde ljudnivån ? ( Z2 vs TW200 ) I sina lägre lamp lägen borde väl bägge vara mycket tystare Sony HS10 i sitt "Cinema" läge va ? Hur är det med Lens Shift funktionen på dessa, hur mycket kan man flytta bilden, t.e.x på en 2 meter bred bild ? Såg på eran hemsida att man måste ha mellan 3 och knappa 3.5 meter för en 92 tums bild som jag har med Z2, hur är det med TW200, vad har den för Throw Distance för en 92 tums bild ? Mattias.
Redigerat av mattiask, 29 October 2003 - 22:03.
Projektorer
Tonewinner 7300
Perlisten R18s
Philips Discoverer
Ny projektor!
