H/K DVD25 - Uppgradering!
37 svar till detta ämne
Postad 15 februari 2004 - 07:13
Nomad
Nomad
"Justice is coming"
6 401 inlägg
Finns en ny uppgradering på H/K´s hemsida --> DVD25 UpgradeThe "firmware" controlling the functionality of the Harman Kardon DVD 25 is fully upgradeable.
Harman Kardon has released PAL Progressive Scan Video Output for the DVD 25. In case you have a progressive scan compatible video device connected to your DVD 25 and you would like to update your DVD 25 with this functionality, please follow the instructions below: 1. unzip the two .bin files: hkdvd25.bin et dvd25_2.bin, 2. burn the files on a CD-rom in a folder: \hk_dvd25, using the x1 copy speed 3. insert the CD-rom in the DVD player, 4. follow the indications: press "up", 5. wait for the software to be loaded until the unit goes into standby, 6 press and hold the “clear” button on the remote control until the unit switches on, and take out the CD-rom
Besides the update for PAL progressive scan video output, the software update also improves the handling of different camera angles available on certain discs.
Hoppas det hjälper någon. ------------------------------------------------ | 2004-02-20 |------------------------------------------------ Finns en uppgradering som gör din DVD25 Regionsfri och ger PS-Pal! --> UpgradeHarman Kardon DVD 25 Upgrade - Remove Region Coding restrictions. Back This upgrade will:
Remove Region Coding restrictions, allowing DVDs from any region to be played. Provide Progressive Scan to improve resolution, contrast and jitter (digital noise) by around 30% when playing DVDs through PAL Plasma screens and projectors. Very few other DVD players offer this capability, and most that do cost upwards of £1000. This software upgrade has been thoroughly tested and is known to work correctly. It is therefore imperative that you follow the instructions to the letter as we regret that we are unable to offer technical support via this web site. We can accept no responsibility for download errors howsoever caused or errors caused by CD-ROMs burned at incorrect speeds.
Har själv testat den och den funkar kanon!! Tack till gtihenke som kom med länken!
Redigerat av Nomad, 20 februari 2004 - 13:55.
Postad 19 februari 2004 - 09:56
Unregistered989
Unregistered989
456 inlägg
är inte det där den gammla?
det står inte så värst mycket info om uppgraderingen
någon som har provat?
Postad 19 februari 2004 - 10:34
Finns väl bara en släppt firmware upgarde vilket väl ger PS-PAL och regionsfrihet!
Köper man en ny dvd-25 idag på t ex hembiobutiken så behöver man ej flasha om den!
Redigerat av Viggen, 19 februari 2004 - 10:34.
Postad 19 februari 2004 - 14:41
Nomad
Nomad
"Justice is coming"
6 401 inlägg
Fanns en äldre uppgradering, som bara behövdes på vissa DVD-spelare innan ett visst fabriksnummer. Men denna uppgradering kan alla använda. Jag har testat den, fungerar bra. Man får upp en extra rad i menyn angående "angle".
Postad 19 februari 2004 - 15:18
zvedberg
zvedberg
1 469 inlägg
Tappar man inte regionsfriheten om man kör den där uppgraderingen?
Postad 19 februari 2004 - 15:20
Nomad
Nomad
"Justice is coming"
6 401 inlägg
Vet ej. Eftersom Hembiobutiken "glömde" att göra min DVD-spelare Regfri så testa jag H/Ks uppgradering. Får se hur det ter sig när jag får en Regfri skiva från butiken så kan jag prova.
Postad 19 februari 2004 - 17:44
Unregistered989
Unregistered989
456 inlägg
oo, måste uppdatera, har iofs inte använt angle funktionen
Postad 19 februari 2004 - 18:34
Nomad
Nomad
"Justice is coming"
6 401 inlägg
Hehe, inte jag heller, men man vet aldrig
Postad 19 februari 2004 - 23:07
Unregisteredfd2d789c
12 inlägg
Tack för tipset om denna färska uppdatering. Jag var inne och sökte uppdatering den 27/1 och hittade då bara den gamla.
PS PAL funkar utmärkt har iof inte testat angle eller om spelaren är regfri fortfarande. (sålde min enda reg1 - 5th element före jul.)
Uppdateringen har tyvärr inte fixat mitt största problem, att min dvd25 inte läser -RW skivor brända med min pioneer 5100H.
Postad 19 februari 2004 - 23:09
Nomad
Nomad
"Justice is coming"
6 401 inlägg
Kul att kunna hjälpa till! Uppdateringen har tyvärr inte fixat mitt största problem, att min dvd25 inte läser -RW skivor brända med min pioneer 5100H.
Menar du DVD-RW lr vanlig CD-RW?
Postad 19 februari 2004 - 23:13
12 inlägg
Hoppsan!
Min spelare fixar cd-rw (SVCD, mp3 etc) men inte DVD-RW.
Postad 20 februari 2004 - 00:27
Unregistered8ee75b8b
3 283 inlägg
hano: Testa lite olika märken på DVD-RW skivor. Ofta kan vissa läsare ha problem med vissa märken, men funka utmärkt med andra. Ehm...och normalt sett så tror jag att det är mindre problem med DVD+RW skivor. Så om du har en +/- brännare, testa DVD+RW istället.
Postad 20 februari 2004 - 07:23
Nomad
Nomad
"Justice is coming"
6 401 inlägg
Kan nog stämma. Mitt problem med DVD+RW är att bilden "fastnar" och står still, medans siffrorna fortsätter att rulla.. mycket störande. Ska testa med DVD+R och se om samma sak händer.
Postad 20 februari 2004 - 09:36
zvedberg
zvedberg
1 469 inlägg
Postad 20 februari 2004 - 09:45
Unregistered3ecb30f4
675 inlägg
http://www.apache.co.uk/visionuppgradering med PS-PAL och regfritt Mvh Henrik
Postad 20 februari 2004 - 13:59
Nomad
Nomad
"Justice is coming"
6 401 inlägg
Mvh Henrik
TACK!!!! Äntligen kan jag se på T2 med DTS!!
Postad 21 februari 2004 - 10:22
marcus nilsson
marcus nilsson
217 inlägg
alltså när jag körde upgraden verkade det som om dvdn hängde säg när det var klart den ville inte stänga av sig. så efter en kvart tryckte jag av en på knappen och nu går den inte igång vad jag än gör. Finns det någon typ av clear knapp som återställer dvdn eller något liknande?
Redigerat av marcus nilsson, 21 februari 2004 - 10:31.
Postad 21 februari 2004 - 11:23
Nomad
Nomad
"Justice is coming"
6 401 inlägg
Va?! Detta har jag inte varit med om någon gång. Har du föjlt anvisningarna till fullo?
Postad 21 februari 2004 - 11:27
marcus nilsson
marcus nilsson
217 inlägg
ja det har jag. när den hade instalerat det skulle den ju stänga av sig till standby läge men min gjorde inte det så efter 10 minuter stängde jag av den på knappen så det var väl antagligen där den hakade upp sig. hur lång tid ska det ta att uppgradera den?
får väl ringa någon support eller liknande, vad finns det för numren till support och vilka tider har de öppet?
Postad 21 februari 2004 - 11:32
Nomad
Nomad
"Justice is coming"
6 401 inlägg
Ja, den ska stänga av sig, sen ska man trycka in "clear" knappen.
Testa att hålla in "CLEAR" knappen i cirka 5-10 sek innan du ringer, det kanske löser problemet då
Redigerat av Nomad, 21 februari 2004 - 11:32.
Postad 21 februari 2004 - 11:35
marcus nilsson
marcus nilsson
217 inlägg
har testat. det fungerar inte
Postad 21 februari 2004 - 11:37
Nomad
Nomad
"Justice is coming"
6 401 inlägg
Hmm, då vet jag inte vad du ska göra. Bästa är nog om du ringer till dom som du köpte DVD-spelare av.
Postad 21 februari 2004 - 11:48
marcus nilsson
marcus nilsson
217 inlägg
Postad 22 februari 2004 - 15:25
Nomad
Nomad
"Justice is coming"
6 401 inlägg
okej får väl göra det.
Har det fixat sig än för dig med DVD25?
Postad 22 februari 2004 - 21:14
marcus nilsson
marcus nilsson
217 inlägg
Nope. ska ringa till Fyndbörsen och Harman Kardon imorgon och höra vad dom säger. Det är ju bara så ###### surt att det ska skita sig nu när man är som mest film sugen.
Redigerat av marcus nilsson, 22 februari 2004 - 21:14.
Postad 22 februari 2004 - 21:56
Nomad
Nomad
"Justice is coming"
6 401 inlägg
Fan va tråkigt asså. Men hoppas att det löser sig för dig!
Postad 24 februari 2004 - 16:57
tazzi
tazzi
512 inlägg
vilka fördelar är det med att uppgradera min DVD25??
jag hinner inte läsa har lite brottom
någon som kan skriva ihop lite lätt?!
mvh robin
Postad 26 februari 2004 - 20:00
Nomad
Nomad
"Justice is coming"
6 401 inlägg
mvh robin
Om du inte har köpt din DVD-spelare regionsfri så är det nog den största fördelen.
Postad 27 februari 2004 - 10:20
nurfen
nurfen
2 031 inlägg
 Tur att H/K är ärliga iallafall..
Postad 27 februari 2004 - 16:32
Unregistered43b822d3
3 782 inlägg
Det där skrevs väl när DVD 25an var hel nylanserad, H/K var ju tidigt ute med PS för 5500 kronor som den kostade vid lanseringen våren 2002.
Postad 04 mars 2004 - 22:55
Nomad
Nomad
"Justice is coming"
6 401 inlägg
Det har jag med för mig. Men är inte alls säker.
Postad 12 april 2004 - 16:35
675 inlägg
Det där skrevs väl när DVD 25an var hel nylanserad, H/K var ju tidigt ute med PS för 5500 kronor som den kostade vid lanseringen våren 2002. Det har jag med för mig. Men är inte alls säker.
Jo den kostade mycket riktigt 5500:- eller 6000:- beroende på butik år 2002. De var mycket få DVD-spelare som hade progressiv bild då. Mvh Henrik
Postad 27 maj 2004 - 11:12
johannes.w
johannes.w
8 inlägg
Halojj!
Efter att jag handlat en beg. DVD25 nu för någon vecka sedan så vet jag inte riktigt om den är regfri eller inte, och enligt min HiFi-handlare kunde cpu'n i maskinen hänga sig om man uppgraderade till en firmware som redan sitter i (kanske kan vara anledningen till det problemet jag läste om tidigare i tråden). Någon som vet om det finns något sätt att kolla vilken firmware man har i? vore som sagt jävligt surt att låsa hela dvd'n.
Och en fråga till, när jag spelar vissa mp3-skivor hackar det till i låtarna ibland, någon som känner till det? kan det vara vissa skivor bara?
Postad 27 maj 2004 - 11:38
Nomad
Nomad
"Justice is coming"
6 401 inlägg
Halojj! Efter att jag handlat en beg. DVD25 nu för någon vecka sedan så vet jag inte riktigt om den är regfri eller inte, och enligt min HiFi-handlare kunde cpu'n i maskinen hänga sig om man uppgraderade till en firmware som redan sitter i (kanske kan vara anledningen till det problemet jag läste om tidigare i tråden). Någon som vet om det finns något sätt att kolla vilken firmware man har i? vore som sagt jävligt surt att låsa hela dvd'n.
Hur man kollar firmwaren vet jag inte, men ett lätt sett att kolla om den är regfri är att stoppa in en reg1 skiva (om man nu har en vill säga..). Skulle han inte ta den skivan så kan du nog köra en upgrade så du får den regfri.
Postad 27 maj 2004 - 19:32
3 782 inlägg
Ett litet trick, men jag vet inte om det stämmer i praktiken, är att kolla i inställningsmenyn Video. Finns där ett alterantiv kallat PAL-M eller M-PAL är det gammal firmware, heter alternativet PAL60 är apparaten uppgraderad.
Postad 27 maj 2004 - 20:17
Unregistered55e17f65
184 inlägg
smidigt AVR4000
jag har också undrat över min spelare men nu vet jag att min i alla fall är uppdaterad, en lite fråga bara när jag spelar en film jag har som är reg1 så får jag enbart svartvit bild, i inställningarna där PAL60 finns med har jag min DVD på auto ska den vara något annat för att kunna ge färg på tv:n? jag har en helt vanlig 28" tv men på min förra dvd spelare hade jag färg när jag körde reg1 filmer så något med min H/K lär det ju vara?
Daniel
Postad 28 maj 2004 - 07:38
Välj "NTSC" på spelaren och se vad du får för resultat då men klart Auto ska fixa detta! Kan det vara så illa att din TV ej stödjer NTSC men att den förre spelaren konverterade från NTSC till PAL?
Redigerat av Viggen, 28 maj 2004 - 07:40.
Postad 28 maj 2004 - 10:38
184 inlägg
tja fråga mig inte vad jag gjorde men nu funkar det i alla fall, då kan man nog våga sig på att köpa nån sjysst R1 film i cool förpackning som det skrivs om i andra trådar.
Daniel
Media & Mediauppspelning
Bild/Ljuduppspelning (Övriga format & Vintage)
DVD-spelare
JBL M2!!!!!!!
Anton
2025-04-30 16:22:03
Front Atmos
Globe
2025-04-28 19:35:47
The12 Passive
Globe
2025-04-28 19:33:57
Baffelväggen
Globe
2025-04-28 19:31:57
2st Slutsteg till köket
Anton
2025-04-27 22:56:09
