* Officiell tråd - Denon DVD-3910 *
1116 svar till detta ämne
Postad 02 september 2004 - 16:36
Unregistereda0ef723f
  • Unregistereda0ef723f
  • 3 439 inlägg
Posted Image
Posted Image
Posted Image
All info är från Denons hemsida och Hifi-Klubben.
Huvudspecifikationer, Denon DVD-3910
• Powered by the latest DCDi by Faroudja FLI-2310 Decoding Engine - Finest available processing for film, video, graphics or mixed-mode content
• Adjustable Chroma Delay and Level, White/Black Levels, CCS On/Off controls
• Exclusive Denon Picture Image Correction - provides for Vertical and Horizontal pixel enhancement
• New ESS Vibrato "Chroma Bug Free" MPEG/DVD-Audio Decoder
• Sony CXD-2753 Second Generation DSD Decoder
• Dual, discrete, Analog Devices ADV-7310 - 216 MHz, 4:4:4, 12 bit Video D/A Conversion system featuring Noise Shaped Video processing (1 chip each Progressive and Interlace)
• 8x Oversampling Progressive and 16x Interlace output
• Noise Shaped Video™- Interlace and Progressive
• Layer change buffer for skip free layer change: 8 Mb
• Wideband relay switched component video outputs
• Variable Black Level (Setup): 0 and 7.5 IRE
• Passes below-black (PLUGE) on progressive and interlace outputs
• (1) DVI-D (HDCP) and (1) HDMI Multi-Channel Audio Compatible, outputs with selectable 480p/720p/1080i output
• (1) each - Component Video, Composite and "S" outputs
• 2X DVD read speed; 4X CD/CD-R/CD-RW read speed; with 8MB drive buffer memory
• Built-in Dolby Digital, dts, DVD-Audio and SACD decoders with 5.1 analog outputs
• Burr-Brown 24-bit, 192-kHz DSD-1796 Audio DACs (for all channels) that decode PCM and DSD signals discretely with no cross-conversion of DSD
• Full Digital Bass Management for DVD-Audio/SACD (optional), featuring dual Analog Devices Melody 100 'HammerHead' processors (DSD signals are converted to PCM)
• 40/60/80/100/120Hz crossover points with 12dB high and 24dB low pass slopes; Adjustable delay time and Channel Levels
• Source Direct Mode for PCM or SACD, bypasses Bass Management Speaker Configuration, but permits Channel Level and Delay Time adjustments (No conversion of DSD signals to PCM)
• MP3 and Windows Media Audio (WMA 9) Playback
• Plays Audio/Video CDs; DVD-Audio/Video; Super Audio CD; DVD +/-R/RW(conditional); Audio CD-R; Audio CD-RW; Decoders for MP3 (128kbps or greater recommended) and WMA-8 (64 ~ 160kbps) CD-R/RW & DVD +/-R/RW discs
• JPEG photo file viewer, Kodak Picture and Fujicolor CD compatible
• HDCD decoding
• New AL24 Processing Plus for all 6 Channels
• 24/96 compatible digital outputs - optical and coaxial
• DENON Link for connection to AVR-5803/AVR-3805 (compatible with Second Edition Units)
• PCM and DSD Compatible IEEE-1394 Outputs, featuring exclusive DENON Clock Synchronized System (DCSS), a proprietary and defeatable system
• Anamorphic Scaling for 4:3/16:9 Sets
• 4:3 Squeeze and Zoom Controls
• Pure Direct Modes to defeat unneeded portions of player for the ultimate in audio performance
• 3 box, 3 block internal layout to isolate analog, digital and video circuits
• SRS TruSurround
• RS-232C and Remote in/out ports
• Backlit remote control
• Colors: Black and silver
• Construction: Bottom 2 layers, top and sides 3 layers with extra damping and serious screening. 3 separated chambers for: Power, Audio, Video (in. transporter)
• Dimensions: (B x H x D mm) 434x137x403
• Weight: 9.3 kg
• Pris:
https://www.prisjakt...18366&type=.png
Europeisk-, engelsk manual finns att ladda hem HÄR. (Högerklicka och "Spara mål som...")
Produktblad finns HÄR. (Högerklicka och "Spara mål som...")
Mycket genomgående mätningar i det amerikanska s.k. "SECRETStestet" hittar du HÄR.
Test på den tyska sidan Cine4home.de. (Översätt till engelska via Babelfirren.)
Ett test av Essential HiFi & Home Cinema.
Generellt snack om den nya serien av Denons DVD-spelare kan tas i denna tråden.
Frågeställningar:
Tar denna spelare både 50 och 60Hz via DVI- och HDMI-utgångarna?
Svar: Ja!
Vilka signaler kan man skicka via de digitala bildutgångarna?
Svar: Via HDMI-utgången kan man välja om man vill skicka en komponentvideosignal eller en RGB-signal, medans man på DVI-utgången endast kan skicka en RGB-signal.
Problemlösningar för Denon DVD-3910
1. Bilden blir överscannad i 720p via DVI/HDMI-utgången. Vad göra?
2. Bilden blir ryckig när jag spelare upp 1080i via DVI/HDMI-utgången. Vad göra?
3. Vilket Progressiveläge ska man välja för filmmaterial? Auto1 eller Auto2?
4. Varför står det “Others” som vald subtitle i spelarens meny när jag tittar på en film och valt svenska subtitles?
5. Jag kan inte lyssna på 5.1-ljud med SACD-skivor. Vad göra?
6. Jag kan inte välja MLP-spåret vid DVD-Audiouppspelning. Vad göra?
7. Vilken firmwareversion har jag i spelaren? Hur ser jag det?
1.1. Tryck på knappen “Picture Adjust.”
1.2. Längst bort till höger i denna meny finns ett val som heter "SET". Välj det.
1.3. Här kan du nu förflytta bilden i både höjd- och sidled. Försökt få till en bra kompromiss. Ramarna försvinner inte helt med den mjukvara som finns idag.
2. Bilden blir ryckig i 1080i via DVI/HDMI-utgången. Vad göra?
2.1. Gå in i spelarens OSD-meny och till "Video Setup" (tredje fliken från vänster)
2.2. Här finns det ett val som heter "TV Type"
2.3. Ändra till NTSC istället för Multi som är default.
För att citera från amerikanska SECRETStestet så står det så här:
"Auto 2 should be used with PAL or video-based material, and Auto 1 should be used for normal NTSC film-based DVDs." Slut citat.
Alltså Auto2 för europeiska filmer (och från andra delar av världens som använder PAL som TV-system), och Auto1 för amerikanska filmer (och från andra delar av världens som använder NTSC som TV-system). Upp till var och en vad som ser bäst ut iofs. Bara att testa sig fram.
Detta är en bugg som jag tycker var lite dåligt att inte Denon fixade till innan spelaren släpptes på den europeiska marknaden. Jag löste det så att jag manuellt fick gå in i OSD-menyn och ställa in vilken subtitlefil spelaren skall "fånga" då filmen går igång. Man KAN hoppa mellen olika subtitles under filmens gång, men det funkar (som en del kanske redan vet) inte i ALLA filmer. Sen att det star “Others” istället för “Swedish” gör inte saken lättare. Lösning:
4.1. Tryck på knappen “Setup.”
4.2. Den första sedan som visas är “Disc setup” och det är här vi ska ändra lite.
4.3. Gå ner två hack till “Subtitle.”
4.4. I undermenyn som nu kommer fram stegar man ner till valet som är markerat som “Others.”
4.5. Tryck på “Enter” på fjärren och en liten undermeny skådas
4.6. Skriv in koden “8386” med fjärrkontrollens nummertangenter (de andra landskoderna finns på sidan 152 i manualen).
4.7. Tryck på “Enter” och du är klar!
4.8. För att lämna menyn så trycker man på “Setup” en gång till.
Detta kan bero på två olika saker.
5.1. Inte alla SACD-skivor har 5.1-ljud. Kolla att skivan du vill spela upp har 5.1-ljud.
5.2. Kolla i spelarens setupmeny och under fliken som heter 'Audio Setup'. Där skall det stå 'Multi'. Står den på 'Multi' så får du alltid ut alla kanaler som skivan är inspelad med. Har skivan bara 2 kanaler så blir det 2 kanaler osv. Har skivan både 5.1-ljud och vanligt stereoljud så tar spelaren 5.1-spåret först. Vilken SACD-setup man vill ha kan man även enkelt ändra med en knapp på spelarens front.
Lösning:
6.1. Gå in i OSD-menyn och sedan till den sista fliken som heter "Other setup". Här ska "Player-Mode" stå som "Audio". Står den som "Video" funkar inte DVD-Audio alls.
7.1. När spelaren är igång så stänger du av strömmen med huvudströmbrytaren, dvs den lite mindre knappen bredvid standbyknappen.
7.2. Håll inne knappen "Play" och "Open/Close" samtidigt...
7.3. Tryck nu (samtidigt som du håller in "Play" och "Open/Close") på huvudströmbrytaren.
7.4. Forsätt hålla in knapparna tills ikonerna för dessa knappar börjar lysa i displayen på fronten av spelaren.
7.5. Nu kan du trycka in följade knappar i en följd: 3, 2, 6, 5 och sedan knappen "Menu" på fjärrkontrollen.
7.6. För att stega mellan informationen så trycker du på "Menu"-knappen. (ESS, Make day, DRV, System, DSP och CNE)
7.7. ESS är firmwareversionen i spelaren för tillfället.
Mer info kommer med tiden.
Edit 040903: Info om bildsignaler
Edit 040912: Info om konstruktionen och minnet för lagerbyte samt DACar för ljudet.
Edit 040920: Bild på fjärrkontroll och länk till test av Cine4home.de. Tack för tipset Thunderbird! :blink: Prisjägarfunktionen flyttad.
Edit 040923: Länk till europeisk-, engelsk manual.
Edit 041005: Problemlösningar
Edit 041006: Länk till Secretstestet och ett problemlösningsfall
Edit 041029: Info om firmwareversionstest
Edit 050211: Tog bort en del texter som kändes onödiga samt en till testlänk lades till.
Redigerat av Unregistereda0ef723f, 11 februari 2005 - 10:11.
Postad 03 september 2004 - 12:19
Unregisteredf380a49e
  • Unregisteredf380a49e
  • 2 991 inlägg
Jörgen G har beställt den och skulle få den levererad i mitten av september - om HiFi Klubbens leveranstid håller (se denna postning).
Postad 03 september 2004 - 13:34
  • 2 991 inlägg
Pizza... errm... Peter.M; kan du inte lägga till den här bilden med den svarta fronten i första inlägget också?
Posted Image
Här är även en lite närmare bild på kontakterna, och även en bild på fjärrkontrollen:
Posted Image
Posted Image
Postad 03 september 2004 - 20:30
Unregistered94256dec
  • Unregistered94256dec
  • 337 inlägg
Ny tråd på avsforum: Denon 3910 in da house!!! (testrapport). B)
Postad 03 september 2004 - 22:35
  • 3 439 inlägg
C-Quence: Har sett de där bilderna. Tänkte ta med dem, men kontakterna ser man ganska bra på "bakbilden" tycker jag. Fjärren kan jag lägga till om du vill. Nu har ju iofs du redan lagt in de bilderna i tråden... B) Men, men.
Postad 04 september 2004 - 11:52
THXex
  • THXex
  • 151 inlägg
FRÅGA 1: Vet nån ifall den klarar av dvd-mp3?
FRÅGA 2: Finns det reg. crack till den ute vid release?
THXex
Postad 04 september 2004 - 12:11
  • 3 439 inlägg
THXex: Tror inte att den klarar DVD-MP3 då mekaniken är baserad på DVD-A11. Den klarade inte det vad jag förstod. Nåja, den som lever får se. Angående regionsuppdatering så tar det nog inte så lång tid tills det att vi får se nya firmwares som tar hand om detta. ;)
Postad 05 september 2004 - 14:34
  • 19 825 inlägg
Hänger det inte på programvaran om den klarar det?
Hej.
Väntar på min 3910. Skall komma mitten på september.
Vilken förstärkare skall ni ha till denna skapelse.
För att få det mesta ur DVD 3910s prestanda.
En så dyr som möjligt!
Men i rimlig prisklass tror jag Denons 3805 är ett kap.
Postad 05 september 2004 - 18:57
Unregisteredc76d9563
  • Unregisteredc76d9563
  • 1 048 inlägg
Hej.
Har själv en 3805 och det blir väl förmodligen en 3910 vad det lider. Kombon har ju den fördelen att man kan utnyttja DenonLink.
Postad 06 september 2004 - 08:59
Per S
  • Per S
  • 560 inlägg
Intressant och se att hifiklubben denna gången ligger
väldigt nära i pris mot de tyska webshopparna.
Några Tyska priser
Med 2800mk2 och 3800 fanns den diff på ca 15-25% och med 2900
låg den på 10-15%. Nu skiljer det endast några procentenheter.
Skulle i nuläget vilja påstå att det inte finns någon
anledning att ta in den från Tyskland med tanke på
att tyskköpta Denon inte garantilagas i Sverige.
Redigerat av Per S, 06 september 2004 - 09:00.
Postad 06 september 2004 - 09:34
  • 3 439 inlägg
Börjar hända grejer i denna tråd. Det grejer de klagar på (och som jag läst fram tills idag) tycker jag bara är bra. :D Förutom SACD-problemet via DenonLink då kanske. :)
Någon som hittat ett test på internet än då? Alltså inte något amatörtest.
Edit: Glöde ett r. :D
Redigerat av Unregistereda0ef723f, 06 september 2004 - 12:12.
Postad 06 september 2004 - 14:43
Unregistered6203766f
  • Unregistered6203766f
  • 34 inlägg
Finns det någon information om hur bra DenonLink egentligen är? Som jag har förstått det så är det överföring av digitalt ljud mellan förstärkaren och dvd spelaren det handlar om. Det finns ju hur många förståsigpåare som helst som har debaterat kablar här och hur står sig DenonLink i jämförelse med andra kablar egentligen? Och kan DenonLink föra över SACD ljud t ex? På min nuvarande DVD spelare kan jag inte använda digitalkabeln till det ljudformatet. Men det kanske fungerar med 3910:an? *aningen vilsen i denna djungel* :)
/Tomas
PS. Finns det något mer lämpligt ställe att diskutera detta så säg till så flyttar jag frågan dit. DS.
Postad 06 september 2004 - 15:15
Unregisteredfef17be0
  • Unregisteredfef17be0
  • 107 inlägg
Denon-Link har en överföringshastiget motsvarande 3xFireWire hastighet. :)
Problemet som återstår är rättigheter att överföra SVCD digitalt med Linken, men det jobbas på att det ska komma in så småningom.
De som då har köpt en 3910:a kommer då att få möjligheter att uppdatera.
Har själv en 3805:a på ingång och kommer skaffa 3910:an när problemet är löst.
MVH Björn//
Postad 06 september 2004 - 20:01
Drem
  • Drem
  • 1 646 inlägg
Det här oroar mig lite eftersom jag också använder en 10m DVI mellan en Yamakawa 375 och projektorn. Har inga problem med detta i nuläget och det skulle ju kännas väldigt snopet om det uppstod störningar med en ny och dyrare dvdspelare :) Det går väl säkert att lösa men ändå, ytterligare en kostnad om det nu skulle bli på det viset.
"Okie..I had the 3910 for 3 days also. Mine is gunmetal silver..Quite nice looking imo. Previously using the momitsu v880. I had a 10 m dvi-M1 cable since I'm using IF7200. Since using the 3910, I get sparklies. Will have to relocate the player to see whether shorter length cable will rectify this"
Redigerat av Drem, 06 september 2004 - 20:02.
Postad 06 september 2004 - 20:39
  • 1 048 inlägg
/Tomas
DenonLink är ingen kabel utan en typ av överföring (jmfr iLink/FireWire). Vad det är för typ av kabel vet jag faktiskt inte. Ang ljudet så vet jag inte heller annat än det jag läst i tester av DVD-A11; att överföring via DenonLink ska låta bättre.
Vanlig digital överföring (optisk eller elektrisk/coax) funkar inte med SACD och DVD-Audio, utan i det fall man inte har tillgång till DenonLink eller FireWire/iLink, används 5.1 analog överföring, dvs 6 st kablar av RCA-typ.
Själv ser jag det som en bonus om det skulle låta bättre, min primära anledning till att använda DenonLink är billigare kablage. 2 meter 5.1 kablage av god kvalité räknar jag med kommer att kosta mellan 1 500 och 2 000 spänn.
Postad 07 september 2004 - 10:37
  • 3 439 inlägg
joeyua: DenonLink-kabeln är en vanlig Cat-5kabel. Dvs som en nätverkskabel. Tror en sådan kabel ligger med i kartongen till DVD-3910. Iaf vad jag läst på AVSforum.com.
nikkeg: Jobbigt! 3-4 veckor! Börjar bli en ganska populär DVD-spelare verkar det som. :lol: Själv bestämmer jag mig hur jag ska göra med köp när jag får min nästa lön. Annars får jag vänta ett tag tror jag. :o
Postad 07 september 2004 - 18:18
Unregistered38703
  • Unregistered38703
  • 174 inlägg
Är det bara jag som inte har några naglar kvar ?!?! Är verkligen väldigt väldigt spänd på denna spelare. Det här slår min väntan förra året när jag köpte min Panna-ae500. Nu är jag hispigare.
Två saker. Denon Link är jag väldigt nyfiken på. Hur mycket bättre än coax som jag kör idag, märkbar skillnad, vi får se/höra ?
Men framförallt, hur mycket bättre kommer jag uppleva DVI-D från antingen 2910/3910 till min Panna 500 / Kontra progressive component som jag kör idag ?
Det snackas ju om en del störningar i bilden hos avsforum.com, men då gäller det 1910.
Väntan borde klassas som tortyr !!!!
Postad 07 september 2004 - 22:20
Unregistered419b94f0
  • Unregistered419b94f0
  • 481 inlägg
Tja
Tror ni att detta är bättre maskiner än Pioneers 668/868?
Postad 08 september 2004 - 09:23
  • 3 439 inlägg
Tja
Bildmässigt kan jag lägga en kvalificerad gissning på....ja. Pioneers 668/868 har i vissa tester visat sig ha CUE-fel (Croma Upsampling Error) i viss mån och det är något som Denon numera oftast inte har i sina nyare DVD-spelare.
Själv sitter jag lugnt och fint och väntar på Secretstestet då de testar sånt där. Vissa stör sig inte på det och då spelar det ingen roll kanske.
Fast, vi sitter ju alla och väntar på tester på dessa nya spelare så den som lever får se. Pioneerspelarna kan vara bättre på vissa punkter. De spelarna är bra de med. :o
Postad 08 september 2004 - 10:04
Unregisteredad1a5709
  • Unregisteredad1a5709
  • 106 inlägg
Kollade med på 3910 den verkade mycket mumsig.
Men det var en sak jag inte bleb klok på hifiklubben säger ju att 2910 är efterträdaren till 2900.
Men 3910 ligger ju i det priset är 3910 en efterrträdare till deras dyraste dvd för den är ju sänkt till 17000kr.
Det verka ju som om man kan köpa 2910 och spara slantarna det skiljer mellan 2910 och 3910 för det ska ju nästan var idenstiska maskiner.
Postad 08 september 2004 - 10:37
Unregisteredd287695a
  • Unregisteredd287695a
  • 45 inlägg
Tjena!
Har beställt en 3910 B),
En sak som jag undrar över, är om det går typ att stänga den där Hdcp kodningen 3910? Har sett att vissa spelare kan stänga av Hdcp. :o Jag har nämligen en panna pt-300 och den stöder inte det här Hdcp, så det vore ju bra om det gick att stänga av. :lol:
Postad 11 september 2004 - 00:33
bigbadboogie
  • bigbadboogie
  • 819 inlägg
Posted Image
Posted Image
• Burr-Brown 24-bit, 192-kHz DSD-1796 Audio DACs that decode PCM and DSD signals discretely with no cross-conversion of DSD
• HDCD decoding
• SRS TruSurround
• Weight: 9.3 kg
• Pris (på Hifi-Klubben): 10 998:-
Enligt Hifi-Klubben så är releasen i sverige runt mitten/senare delen av september.
Manual finns att ladda hem HÄR. (Högerklicka och "Spara mål som...")
Frågeställningar:
Svar: Ja! Enligt Denon.de så ska den göra det. Citat:
"Scaler (wirkt auf DVI, HDMI) 480p bzw. 576p / 720p / 1080i
(50, 60 Hz)
" slut citat
Vad jag kan komma på förutom nämnda fakta
* DVD-3910 *
VIDEO
+ Noise Shaped Video™- Interlace and Progressive
+ Layer change buffer for skip free layer change: 8 Mb
+ HDMI (HDCP Compatible – SiL9030) - With Selectable Scaling – 480p/720p/1080i
Construction
* Bottom 2 layers, top and sides 3 layers with extra damping and serious screening
* 3 separated chambers for: Power, Audio, Video (in. transporter)
Audio
Audio D/A-converter 2-channel 192 kHz / 24-Bit (Burr Brown PCM1796)
Audio D/A-converter L/R 192 kHz / 24-Bit (Burr Brown PCM1796)
Audio D/A-converter C/Sub 192 kHz / 24-Bit (Burr Brown PCM1796)
Audio D/A-converter SL/SR 192 kHz / 24-Bit (Burr Brown PCM1796)
Regards
Boogieman
Postad 12 september 2004 - 16:12
skum
  • skum
  • 279 inlägg
Har även jag beställt en svart, regfri 3910. Väntar med spänning på att den ska dyka upp. Jag kommer att köra den ihop med Denon AVC-A11SR - en mumsig kombo. Det var helt perfekt att denna spelare dök upp just nu dels för att jag har slantar över till den och att det är det "sista" jag behöver uppgradera :(
Postad 12 september 2004 - 16:40
  • 3 439 inlägg
bigbadboogie: Taget! :( Text tillagd i startinlägget.
Ingen som testat denna spelare hemma än? Finns ju att köpa nu. :P
Postad 12 september 2004 - 17:40
  • 45 inlägg
Jag maila till Hifiklubben i Torsdags och fråga när 3910 kunde börja levereras ut och fick till svar:
(De har tyvärr blivit försenade till runt den 20 september.)
Så det ser ut att man får vänta en ett tag till innan man får hem den. :(
( Hoppas den kommer samtidigt som Star Wars boxen, det vore kul :P )
Redigerat av Unregisteredd287695a, 12 september 2004 - 17:46.
Postad 12 september 2004 - 17:59
Efny
  • Efny
  • 176 inlägg
Jag har testat en 3910 sen igår. Har fått låna ett demo-ex från Hifiklubben till imorgon måndag.
Än så länge kan jag bara konstatera att jämfört med min "gamla" Pioneer DV-656A så är den hästlängder bättre.
Har testat bild/ljud för film och jag trodde inte att den skulle vara så mycket bättre än Pioneeren. Kör den mot en Philips 42pf9965 plasma och bilden är klockren via komponent. Ljudet är också en helt annan när jag ser på film. Sen ska jag inte ens gå in på byggkvalitén.
Jag lägger en beställning på måndag utan att blinka. Tyvärr måste jag köra på Pioneeren ett tag till innan Hifiklubben kan leverera.
:( :P :P B)
Postad 12 september 2004 - 19:01
Unregistered38703
  • Unregistered38703
  • 174 inlägg
:(  :P  :P  B)
Ni testade alltså inte DVI/HDMI ? Personligen förstår jag inte vad man ska med denna spelare med om man inte ämnar använda HDMI/DVI ?!?
Postad 12 september 2004 - 21:07
Efny
  • Efny
  • 176 inlägg
Den har bättre (dyrare) komponenter. Den är sepparerad internt. Byggkvalitén är mycket högre. O.s.v.
Postad 13 september 2004 - 07:37
ljudnisse
  • ljudnisse
  • 2 129 inlägg
Ingen som har ett svar på SWEDs fråga:
Postad 13 september 2004 - 08:23
Drem
  • Drem
  • 1 646 inlägg
Finns det mera bilder på den svarta 3910? Jag skulle vilja se hur den ser ut annat än på produktbilderna.
Edit: Nu är jag så nära att beställa så det handlar bara om modet till att trycka på SEND :( Herregud vilken hobby man har, det kommer att sluta med att man lever på vatten och bröd och jobbar 7 dagar i veckan :P
Edit 2: Jaha, då får man jobba många lördagar i fortsättningen nu då :P
Redigerat av Drem, 13 september 2004 - 09:32.
Postad 13 september 2004 - 11:25
lungan
  • lungan
  • 545 inlägg
Troligen inte. Känner inte till någon större tillverkare där den möjligheten har funnits, bara vissa asiatiska spelare där det går.
Postad 13 september 2004 - 12:33
  • 45 inlägg
Du har nog alldeles rätt lungan att det inte går att stänga av. Har kollat i Manualen som det fans en länk till på första inlägget och det ser ut som det inte går att stänga av :(. Kan ju tänkas att det kan komma någon firmware uppdatering som så att man kan kolla på en icke Hdcp kompatibel produkt.
Postad 14 september 2004 - 09:47
Unregistered38703
  • Unregistered38703
  • 174 inlägg
Aj då,
Den fixar tydligen inte macroblocking.
Är en på avsforum.com som totalsågar den och tänker lämna tillbaka den.
hur göra nu ?
Postad 14 september 2004 - 09:54
Drem
  • Drem
  • 1 646 inlägg
Aj då,
hur göra nu ?
Det där är ju konstigt eftersom andra har testat den för macroblocking i en annan tråd och inte sett det? Det trodde jag iaf :P Hoppas verkligen inte att det är sant, för i såna fall så kommer jag att avboka mitt ex. Jag tänker inte betala 11000kr för en enhet med ett sådant fel :D
Redigerat av Drem, 14 september 2004 - 10:46.
Postad 14 september 2004 - 11:34
  • 45 inlägg
Vad är macroblocking? Vet faktiskt inte vad det är. :P
Postad 14 september 2004 - 11:56
Drem
  • Drem
  • 1 646 inlägg
Jag har inte sett det med egna ögon men det låter ju inte alls speciellt trevligt. Det här var det närmste jag hittade som beskriver problemet, med bild:
http://www.michaeldv...roBlocking.html
Postad 14 september 2004 - 16:01
  • 45 inlägg
Killen som hade sett macroblocking verkar vara rätt ensam att ha sett det. :D
Kan ju vara nått fel på hans spelare eller på skivan han testa med.
Som en skriver där håller jag med om till 100% (varför ska han lämna tillbaka den så snabbt??? :P , det är väl lika bra att prova ut den ett tag och se om det var nått fel som bara uppstår på den skivan han såg det här macroblocking på)
det skulle jag göra i alla fall :D
(Ps; kanske är en Panasonic spion efter som han ska vänta på den ny s97) :rolleyes:
http://www.avsforum....&highlight=3910
Redigerat av Unregisteredd287695a, 14 september 2004 - 16:02.
Postad 14 september 2004 - 17:02
Drem
  • Drem
  • 1 646 inlägg
Jag håller med. Det känns lite väl snabbt och kvickt att avfärda spelaren på det viset han gör. Jag hoppas att någon testar den för macroblocking ordentligt så snart som möjligt för lite orolig blir jag eftersom jag har bokat spelaren (jag har fortfarande inte avbokat den...inväntar vad som sägs)
Postad 14 september 2004 - 17:22
  • 45 inlägg
Det värkar som några ska göra lite tester under kvällen, ska bli intressant och se vad dom kommer fram till.
Om det är så att den har det där buggen så vet i f.n om man ska avboka sin beställning eller om man ska ta hem den och se med egna ögon :P om man blir irriterad på problemet eller inte.
Det går ju alltid att skicka tillbaka den.
Postad 14 september 2004 - 17:41
Drem
  • Drem
  • 1 646 inlägg
Jag tycker iofs det vore väldigt konstigt om Denon skulle släppa en ny spelare som hade DVD-5900 macroblock-felet kvar. Dom har ju känt till det länge och skulle väl släppa en firmware som fixade detta...men som visade sig förvärra problemet och så drogs firmwaren tillbaka?
Hmm, ja detta blir ett dilemma. Jag vill verkligen ha en 3910 men skulle det visa sig att den har felet så kommer jag nog att avboka och invänta någon annan spelare.
Postad 14 september 2004 - 19:16
  • 45 inlägg
Det värkar som att spelaren har macroblocking, flera har visst sett det nu!! :P
Börjar starkt fundera på att avboka min beställning nu!! :D
Postad 14 september 2004 - 20:38
  • 106 inlägg
Hur ser man macroblockningen??
Dagens dvdspelare blir ju bara sämmre eller är vi kanske för kräsna??
Frågan är ju om man ser problemet om man inte vet vad man ska leta efter??
Postad 14 september 2004 - 20:46
  • 3 439 inlägg
Låter tråkigt det här. Blir lite skeptisk nu. Det hela späs på pga att min proje har lite problem med dithering i mörka partier. Blir lite kaka på kaka med macroblocking då. Hoppas på det bästa dock.
Secretstestet är det jag går på. Tar inte personliga kommentarer till mig på samma sätt som Secretstestet.
Kanske ska gå ner lite i pris och välja DVD-2910 istället? :P Blev osäker nu.
Postad 14 september 2004 - 20:47
Efny
  • Efny
  • 176 inlägg
Jag tror nog det blir svårt att hitta en perfekt DVD-spelare som ingen kan hitta något dåligt på. Det bästa du kan göra när du skall skaffa en är att kolla om du kan låna hem den för att testa innan du köper. Jag lånade hem en 3910:a och konstaterade att den var s**tbra i min smak och att den funkade bra mot mina andra delar i systemet.
Postad 14 september 2004 - 22:27
Drem
  • Drem
  • 1 646 inlägg
Ja det var jäkligt synd, jag var grymt sugen på den här spelaren men vågar inte köpa som det är nu. Kanske man skulle kika på en Marantz? Iofs tror jag Marantz motsvarighet kostar mera, är inte lika snygg och har inte lika många features. Kvaliteten på video och ljud skulle däremot vara RIKTIGT bra.
http://www.avland.co...9500/dv9500.htm
Redigerat av Drem, 14 september 2004 - 22:29.
Postad 15 september 2004 - 10:23
lungan
  • lungan
  • 545 inlägg
OT: Du har ju också Marantz DV-7500 som ett alternativ, där de största skillnaderna till 9500 verkar ligga i analogdelarna och uppbyggnaden. Kostar £600 i UK, hamnar väl på strax under 10 loppor här.
Jag har inte "avbeställt" min 3910 utan skall få testa butikens ex innan jag bestämmer mig. Jag tycker allt att man ser MB-liknande fenomen (blockighet i större enfärgade partier) även med andra bra spelare så jag vet inte hur stort problem det egentligen är eller hur specifikt det är för Denon. Jag ser det som en oturlig men naturlig utveckling av att spelare och bildvisare blir så bra att brister i källmaterialet/MPEG-kodningen barmhärtighetslöst avslöjas.
Postad 17 september 2004 - 12:10
mikee
  • mikee
  • 1 638 inlägg
en kompis skall låna hem en 3910 och vi undrar om det är det nån som vet en bra scen i någon film som man kan se macro blocking speciellt mycket i!!!!!!
mvh mikee
Postad 17 september 2004 - 15:12
Gonk
  • Gonk
  • 267 inlägg
Fick följande från HIFI-klubben nyss, spelaren som skulle komma slutet denna vecka är fördröjd. Undrar vilken "software update" dom tänker göra???
Please note that these [DVD3910] have been further delayed. They have had a small software update in Germany but are now ready to be shipped for us. They will be shipped in the beginning of next week so we should receive them mid/end next week.
Postad 17 september 2004 - 17:04
Gäst_nin_*
  • Gäst_nin_*
Alltså, förstår inte riktigt detta. Att EN person på ett forum påstår en sak så börjar folk tror på det, FAST det finns fullt med andra som säger tvärtom. Det är ju trots allt en som påstår detta.
Sedan har jag inte riktigt förstått anledningen att förbok en apparat om man är rädd att det kan vara något fel på den. Varför inte vänta 2-3 veckor, läsa Secrets test, som kommer ge den verkliga bilden, och sedan köpa den? Man kan ju kanske t o m få den lite billigare om mna väntar.
Så jag kommer vänta och läsa deras test.
Postad 17 september 2004 - 18:14
Unregisteredc0247635
  • Unregisteredc0247635
  • 117 inlägg
ojoj...börjar bli en del läsning i denna tråden. För min del får det bli en 2910 det är vad ekonomin o samvetet klarar av :D
JAg sitter ändå inte på nån projje ännu utan lyssnar mest på Musik......fast det suger ju ändå i ha begäret :wub:
  • Pioneer CMX-3000
    Anton
    2025-05-06 19:28:59
  • Nya Hifi-bänken
    joga
    2025-05-02 18:25:13
  • JBL M2 igen…..
    Anton
    2025-05-01 16:07:43
  • JBL M2!!!!!!!
    Anton
    2025-04-30 16:22:03
  • Front Atmos
    Globe
    2025-04-28 19:35:47
