All info är från Denons hemsida och Hifi-Klubben.
Huvudspecifikationer, Denon DVD-2910
• Powered by the latest DCDi by Faroudja FLI-2310 Decoding Engine - Finest available processing for film, video, graphics or mixed-mode content
• Adjustable Chroma Delay and Level, White/Black Levels, CCS On/Off controls
• New ESS Vibrato "Chroma Bug Free" MPEG/DVD-Audio Decoder
• Sony CXD-2753 Second Generation DSD Decoder
• Dual, discrete, Analog Devices ADV-7310 - 216 MHz, 4:4:4, 12 bit Video D/A Conversion system featuring Noise Shaped Video processing (1 chip each Progressive and Interlace)
• 8x Oversampling Progressive and 16x Interlace output
• Wideband relay switched component video outputs
• Variable Black Level (Setup): 0 and 7.5 IRE
• Passes below-black (PLUGE) on progressive and interlace outputs
• (1) DVI-D (HDCP) and (1) HDMI Multi-Channel Audio (SiL9300) Compatible, outputs with selectable 480p/720p/1080i output
• (1) each - Component Video, Composite and "S" outputs
• 2X DVD read speed; 4X CD/CD-R/CD-RW read speed; with 8MB drive buffer memory
• Built-in Dolby Digital, dts, DVD-Audio and SACD decoders with 5.1 analog outputs
• Burr-Brown 24-bit, 192-kHz DSD-1791 Audio DACs that decode PCM and DSD signals discretely with no cross-conversion of DSD
• Full Digital Bass Management for DVD-Audio, featuring Analog Devices Melody 32-bit processor; 80Hz crossover with 12dB high and 24dB low pass slopes; Adjustable delay time(0-15ms)and Channel Levels
• Full Digital Bass Management for SACD; 80Hz crossover with 6/12dB slopes on all channels; Adjustable channel levels
• Bass Management avaialble for all formats on the HDMI output
• MP3 and Windows Media Audio (WMA 9) Playback
• Plays Audio/Video CDs; DVD-Audio/Video; Super Audio CD; DVD +/-R/RW(conditional); Audio CD-R; Audio CD-RW; Decoders for MP3 (128kbps or greater recommended) and WMA-8 (64 ~ 160kbps) CD-R/RW & DVD +/-R/RW discs
• JPEG photo file viewer, Kodak Picture and Fujicolor CD compatible
• HDCD decoding
• 24/96 compatible digital outputs - optical and coaxial
• Anamorphic Scaling for 4:3/16:9 Sets
• 4:3 Squeeze and Zoom Controls, including DVI/HDMI outputs
• Pure Direct Modes to defeat unneeded portions of player for the ultimate in audio performance
• SRS TruSurround
• Remote in/out ports
• GloKey remote control
• Mått: 434x137x403 mm (B/H/D)
• Vikt: 5,5 kg
• Pris:
https://www.prisjakt...18364&type=.png
Enligt Hifi-Klubben så är releasen i sverige i slutet på oktober.
Europeisk-, engelsk manual finns att ladda hem HÄR. (Högerklicka och "Spara mål som...")
Produktblad finns HÄR. (Högerklicka och "Spara mål som...")
Generellt snack om den nya serien av Denons DVD-spelare kan tas i denna tråden.
Frågeställningar:
• Tar denna spelare både 50 och 60Hz via DVI- och HDMI-utgångarna?
Svar: Ja! Enligt Denon.de så ska den göra det. Citat:
"Scaler (wirkt auf DVI, HDMI) 480p bzw. 576p / 720p / 1080i
(50, 60 Hz)" slut citat
Problemlösningar för Denon DVD-2910
1. Bilden blir överscannad i 720p via DVI/HDMI-utgången. Vad göra?
2. Bilden blir ryckig när jag spelare upp 1080i via DVI/HDMI-utgången. Vad göra?
3. Vilket Progressiveläge ska man välja för filmmaterial? Auto1 eller Auto2?
4. Varför står det “Others” som vald subtitle i spelarens meny när jag tittar på en film och valt svenska subtitles?
5. Jag kan inte lyssna på 5.1-ljud med SACD-skivor. Vad göra?
6. Jag kan inte välja MLP-spåret vid DVD-Audiouppspelning. Vad göra?
7. Vilken firmwareversion har jag i spelaren? Hur ser jag det?
1.1. Tryck på knappen “Picture Adjust.”
1.2. Längst bort till höger i denna meny finns ett val som heter "SET". Välj det.
1.3. Här kan du nu förflytta bilden i både höjd- och sidled. Försökt så till en bra kompromiss.
2. Bilden blir ryckig i 1080i via DVI/HDMI-utgången. Vad göra?
2.1. Gå in i spelarens OSD-meny och till "Video Setup" (tredje fliken från vänster)
2.2. Här finns det ett val som heter "TV Type"
2.3. Ändra till NTSC istället för Multi som är default.
För att citera från amerikanska SECRETStestet så står det så här:
"Auto 2 should be used with PAL or video-based material, and Auto 1 should be used for normal NTSC film-based DVDs." Slut citat.
Alltså Auto2 för europeiska filmer (och från andra delar av världens som använder PAL som TV-system), och Auto1 för amerikanska filmer (och från andra delar av världens som använder NTSC som TV-system). Upp till var och en vad som ser bäst ut iofs. Bara att testa sig fram.
Detta är en bugg som jag tycker var lite dåligt att inte Denon fixade till innan spelaren släpptes på den europeiska marknaden. Jag löste det så att jag manuellt fick gå in i OSD-menyn och ställa in vilken subtitlefil spelaren skall "fånga" då filmen går igång. Man KAN hoppa mellen olika subtitles under filmens gång, men det funkar (som en del kanske redan vet) inte i ALLA filmer. Sen att det star “Others” istället för “Swedish” gör inte saken lättare. Lösning:
4.1. Tryck på knappen “Setup.”
4.2. Den första sedan som visas är “Disc setup” och det är här vi ska ändra lite.
4.3. Gå ner två hack till “Subtitle.”
4.4. I undermenyn som nu kommer fram stegar man ner till valet som är markerat som “Others.”
4.5. Tryck på “Enter” på fjärren och en liten undermeny skådas
4.6. Skriv in koden “8386” med fjärrkontrollens nummertangenter (de andra landskoderna finns på sidan 152 i manualen).
4.7. Tryck på “Enter” och du är klar!
4.8. För att lämna menyn så trycker man på “Setup” en gång till.
Detta kan bero på två olika saker.
5.1. Inte alla SACD-skivor har 5.1-ljud. Kolla att skivan du vill spela upp har 5.1-ljud.
5.2. Kolla i spelarens setupmeny och under fliken som heter 'Audio Setup'. Där skall det stå på 'Multi'. Står den på 'Multi' så får du alltid ut alla kanaler som skivan är inspelad med. Har skivan bara 2 kanaler så blir det 2 kanaler osv. Har skivan både 5.1-ljud och vanligt stereoljud så tar spelaren 5.1-spåret först. Vilken SACD-setup man vill ha kan man även enkelt ändra med en knapp på spelarens front.
5.1. Gå in i OSD-menyn och sedan till den sista fliken som heter "Other setup". Här ska "Player-Mode" stå som "Audio". Står den som "Video" funkar inte DVD-Audio alls.
7.1. När spelaren är igång så stänger du av strömmen med huvudströmbrytaren, dvs den lite mindre knappen bredvid standbyknappen.
7.2. Håll inne knappen "Play" och "Open/Close" samtidigt...
7.3. Tryck nu (samtidigt som du håller in "Play" och "Open/Close") på huvudströmbrytaren.
7.4. Forsätt hålla in knapparna tills ikonerna för dessa knappar börjar lysa i displayen på fronten av spelaren.
7.5. Nu kan du trycka in följade knappar i en följd: 3, 2, 6, 5 och sedan knappen "Menu" på fjärrkontrollen.
7.6. För att stega mellan informationen så trycker du på "Menu"-knappen. (ESS, Make day, DRV, System, DSP)
7.7. ESS är firmwareversionen i spelaren för tillfället.
Mer info kommer med tiden.
Edit 040923: Länk till europeisk-, engelsk manual
Edit 041005: Problemlösningar
Edit 041006: Länk till Secretstestet samt en till problemlösningspunkt
Edit 041029: Info om firmwareversionstest.
Redigerat av Unregistereda0ef723f, 30 October 2004 - 09:17.
1
Denon-klubben
59 bilder
303 filmer
