Äntligen kommer Sony med autokalibireringssystem
92 svar till detta ämne
Postad 13 January 2006 - 22:19
scenic
  • scenic
  • 1066 inlägg
Every room is not created equally and in order to get the best performance from a home theater system, speaker set-up takes on an important role. With this in mind, Sony's Digital Cinema Auto Calibration (DCAC) helps simplify the set-up of a new home theater system while providing optimal performance.
This simple auto set-up feature uses the included microphone to measure speaker distance, level and frequency, automatically calibrating the listening environment to accurately optimize the sound field
Postad 29 March 2006 - 22:10
scenic
  • scenic
  • 1066 inlägg
Sony släpper nya receivrar med autokalibireringsystem. Ser ut att dom ersätter DE serien. Nu har de aluminiumfront.
Sony STR-DG500
STR-DG600
STR-DG800
Reviewed on
03/16/2006 $399
at 1 store
Check prices Find local stores
Sony STR-DG800
CNET previews the Sony STR-DG800, an HDMI-equipped XM-ready A/V receiver that's due to be released in April 2006.
Specs: AV receiver, 770 Watt, Built-in -
Reviewed on
03/16/2006 $184 to $199
at 6 stores
Sony STR-DG500
CNET previews the Sony STR-DG500, the entry-level A/V receiver in Sony's 2006 product line.
Specs: AV receiver, Surround Sound, 600 Watt, DTS Neo:6, Universal remote control (Infrared), 16.9 in x 12.4 in x 6.2 in, 17.6 lbs
Reviewed on
03/16/2006 $299 to $299
at 2 stores
Sony STR-DG600
CNET previews the Sony STR-DG600, an XM-ready 7.1-channel A/V receiver.
Postad 30 March 2006 - 08:46
SonySamppa79
  • SonySamppa79
  • 1832 inlägg
Det var f_n ta mig på tiden! :)
Postad 24 May 2006 - 11:20
Unregistered42562
  • Unregistered42562
  • 385 inlägg
någon som hört nått mer om dessa?
Postad 24 May 2006 - 12:48
dhanjel
  • dhanjel
  • 2495 inlägg
De såg rätt snygga ut faktiskt. Känns dumt att köpa innan de börjat trycka dit hdmi portar på dom dock.
Postad 24 May 2006 - 21:45
Claatu
  • Claatu
  • 162 inlägg
Måste nog erkänna att jag tyckte de såg för hemska ut med sina olika stora och olika högt placerade rattar, som spindelögon ungefär.... men man har ju mörkt när man kollar på film och de kanske låter så bra att man bjuder på det ? :(
dhanjel: Det står ju HDMI på dem med rätt så stora bokstäver? Men det kanske är "Sonyska" för "Har Dåligt Med Industridesigners" ? ;)
Redigerat av Claatu, 24 May 2006 - 21:47.
Postad 24 May 2006 - 22:11
Unregistered1041101d
  • Unregistered1041101d
  • 2015 inlägg
Äntligen kommer Sony med autokalibreingssystem
:( tycker de borde satsa på bättre komponenter istället för att förenkla sånt som man enkelt kan utföra själv.
Den nya designen är jag lite tveksam inför, då jag gillat den äldre bättre. Hoppas att det i framtiden blir mindre synliga knappar och en täcklucka istället ;)
// Passerati
Redigerat av Unregistered1041101d, 24 May 2006 - 22:21.
Postad 25 May 2006 - 17:47
scenic
  • scenic
  • 1066 inlägg
Fyndbörsen säljer de
Sony STR-G500B
Vårt pris: 2390:-
Sony STR-G500S
Vårt pris: 2390:-
Sony STR-G700B
Vårt pris: 3290:
Postad 25 May 2006 - 18:12
Aztecface
  • Aztecface
  • 1194 inlägg
Intressant. Jag har ju kört med Sony receiver i 7 år och varit fruktansvärt nöjd och jag känner ju att det är dags att byta. :(
Postad 31 May 2006 - 01:54
Unregistered42562
  • Unregistered42562
  • 385 inlägg
jag har en Sony STR-DB1080, är sugen som som bara den på att skaffa mig något nytt, med hdmi osv..
är en G700 då ett nerköp för mig? priserna är ju sjukt låga.. eller?
Postad 01 June 2006 - 11:49
scenic
  • scenic
  • 1066 inlägg
Jag är i samma sits som du, har en sony str-db940
Hittade lite info om autocalsystemet, verkar vara ett enkelt sånt.
*Check the connection between each speaker and the receiver
*Adjust the speaker level
*Measure the distance of each speaker to your listening position
Cannot detect the subwoofer.
Therefore all subwoofer settings will be maintained.
Hoppas att QS-serien har bättre system. (läste dock på ett tyskt forum att den här nya DG skulle
ersätta DE och QS serien.........
Postad 01 June 2006 - 23:13
chicken
  • chicken
  • 190 inlägg
Sjukt lågt pris. 3000:-
Vad är haken?!
SONY STR-DG700
Typ Receiver
Färg Silver/Svart
Effekt 6 x 100 Watt
Dekodrar Dolby Digital, Dolby Digital EX, Dolby Pro Logic I/II/IIx, Dolby Dual mono, DTS, DTS-ES, DTS 96/24, DTS Neo:6
Digital ingång 2 st HDMI, 4 st Optiska, 2 st Koaxial
Digital utgång 1 st HDMI, 1 st Optisk
Analog ingång 2 st Komponent, 3 st S-Video, 4 st Komposit, 3 st Stereo RCA, Flerkanals ingång (5.1)
Analog utgång 1 st Komponent, 1 st S-Video, 1 st Komposit, 1 st Stereo RCA
Högtalar-kontakttyp Skruv
Fjärrkontroll Ja
Redigerat av chicken, 01 June 2006 - 23:18.
Postad 02 June 2006 - 06:54
SonySamppa79
  • SonySamppa79
  • 1832 inlägg
Sony tar iaf inga överpriser på sina AVR grejer.
Alla gamla speccen förutom HDMI, som börjar bli standard på nästan allt som kommer nu. Alltså då kostar det inte lika mycket att producera.
Postad 03 June 2006 - 17:55
Unregistered42562
  • Unregistered42562
  • 385 inlägg
Hur fungerar det med HDMI utgången? Kommer man kunna koppla in alla prylar man har i recivern och sedan bara ha en HDMI kabel till tvn?
Postad 05 June 2006 - 18:52
chicken
  • chicken
  • 190 inlägg
Vore ju guld det. Någon som hittar någon bra spec på vad man kan göra med HDMI-porten? Den ska ju klara nån typ av konvertering, frågan är mellan vad.
Postad 06 June 2006 - 21:24
scenic
  • scenic
  • 1066 inlägg
Sony STR-DG1000 Receiver for HDMI, Blu-ray, 1080p
READ MORE: Blu-Ray, HDMI, Home Entertainment, STR-DG1000, Sony, receiver
Sony announced its STR-DG1000 receiver (that’s not it at left but it might look something like that), touting it as the “first AV receiver designed to optimize Blu-ray disc and other HD sources.” Its marquee capability is its dual HDMI active intelligence, where it automatically detects the highest-quality video from whichever sources are connected.
This 120-watt-per-channel receiver smoothly switches HDMI signals, and also up-converts composite, s-video and component video sources to HDMI. It can handle 1080p video along with eight channels of uncompressed audio. There’s no shortage of inputs, either, with assignable HDMI, component and optical inputs along with more AV inputs and outputs than you can shake a stick at. Available in August for $800. Expect other manufacturers to copy this concept soon thereafter; price plummeting will ensue. – Charlie White
Sorry läste texten, det är inte den på bilden....
Redigerat av scenic, 06 June 2006 - 21:28.
Postad 08 June 2006 - 22:22
Unregistered99f076a3
  • Unregistered99f076a3
  • 800 inlägg
http://www.sony.com....p?id=STRDG700B#
Postad 08 June 2006 - 23:01
chicken
  • chicken
  • 190 inlägg
Lysande! Tack för länken.
DG700 kan uppkonvertera Komposit och S-Video till Komponent.
DG1000 kan uppkonvertera Komposit, S-Video, Komponent till HDMI.
Får avvakta till de börjar levereras, då kommer en beställning ganska omgående! En 700:a, om inte 1000 skulle chockera i pris förstås.
Postad 09 June 2006 - 10:42
  • 800 inlägg
Kommer inte ihåg var/när/hur men jag läste att STR-DG1000 skulle kosta 800 Dollar.
Postad 09 June 2006 - 15:05
chicken
  • chicken
  • 190 inlägg
Ett tidigare inlägg kanske? :ph34r:
Postad 17 June 2006 - 23:18
chicken
  • chicken
  • 190 inlägg
DG800 Specs
Dimensions (WxHxD): Approx. 17" x 6-1/5" x 13-5/6" (430x157.5x351.5mm)
Perfekt till min IKEA-hylla jag ska modda! :P
Redigerat av chicken, 17 June 2006 - 23:19.
Postad 19 June 2006 - 15:31
Unregistered5794a5dc
  • Unregistered5794a5dc
  • 478 inlägg
Den här reciever verkar vara mycket lovande för prisklass. Hittade lite mer ifo om den på SONY´s Australiensiska sidan:
RECEIVER HDMI CVSW MULTI CH STEREO 100WX STRDG700S
DIN Power Rating
* 6Ω 1kHz, 0.7%THD:
Reference Power Rating
* 6Ω 20Hz-20kHz, 0.09%THD:
General
* Remote control: Multi-Brand Remote Commands Most Sony and other Brands' AV Products
* Speaker selection: Speakers A or B or A+B or OFF
* Speaker terminals: Speaker Binding Posts (except on Spkrs B )
* Headphone socket: Yes
* AM/FM Tuner: 60 presets (AM or FM)
* Front AV Inputs (Video 3): Yes (Composite Video Input - Video 3)
* AV Sync: Yes (68ms)
Video Converting
* Up-convert: Composite to S-Video: No
* Up-convert: Composite to Component: Yes
* Up-convert: S-Video to Component: Yes
* Up-convert: Composite/S-Video/Component to HDMI: No
* Down-convert: Component to S-Vid/Composite: No
* Down-convert: S-Video to Composite: No
* Down-convert: HDMI to Composite/S-Video/Component: No
Connections
* Total Connectable Sources: 7
* Component Video In/Out (Assignable & HD pass-through): 2 (DVD, V2) / 1
* S-Video In/Out: 3/2 (V1, Monitor)
* Composite Video In/Out: 3 ( DVD, V1, V2) /2 (V1, Monitor)
* HDMI In/Out (Assignable): 2 (DVD, V2) / 1 (Monitor)
* 5.1 Multi-Channel Audio: Yes
* 7.1 Multi-Channel Audio:
* Analogue Audio In/Out: 3 (SACD-CD/ MD TAPE, AUX)
* Phono (for LP Record Player):
* Digital Optical In/Out: 2 (V1, V2, MDTAPE) / 1 (MD TAPE)
* Digital Coaxial In/Out: 0/2 (DVD, SACD-CD)
* Assignable Digital Audio Inputs: no
* Subwoofer pre-out: Yes
* i-Link : no
* RS-232C (for firmware upgrades): no
* Control A1 II (3.5mm Jack): no
* Control S In/Out (3.5mm Jack): no
* IR Remote Signal In/Out (3.5mm Jack): no
* 2nd Zone (Analogue Stereo): no
* 2nd Zone (Composite Video + Analogue Stereo): no
* 3rd Zone (Analogue Stereo): no
* 6 Channel Pre-Outs: no
* 12 Volt Trigger (3.5mm Jack): no
Sound Formats
* Dolby Pro Logic / II / IIx: Yes
* DTS Neo:6: Yes
* Dolby Digital / Dolby Digital EX: Yes
* DTS / ES / ES DISCRETE / 96/24: Yes
Sound Modes
* Cinema Studio EX A, B & C: Yes
* Virtual Multi Dimension: No
* Digital Concert Hall A/B: No
* Church / Jazz Club / Live Concert / Stadium / Sports: No
* Hall / Jazz Club / Live Concert: No
* Multi Channel Stereo: Yes
* 2 Channel Stereo: Yes
* Dual Mono (for Dolby only): Yes
* Headphone 2 Ch / Multi / Theatre: Yes
* Headphone Direct: Yes
* Analog Direct: Yes
Specifications
* Mass (kg): 8.5 kg
* Power Consumption in Standby (Watts): NA
* Power Consumption in Operation (Watts): NA
* Remote Control Model: RM-AAP011
* Dimensions (W x H x D) (cm): 43 X 16 32 cm
Style, Power and Performance - the new STR-DG700 6.1 channel AV receiver, delivers a powerful 600W (100W X 6 RMS 6ohms, 20Hz – 20kHz, 0.7% THD) of sound and superb picture quality.
The STR-DG700 is ideally suited as a control centre for a state of the art AV system with HDMI pass-through switching as well as component video conversion. This technology allows video signals from analog inputs like S-Video and composite video to be up-converted to component video, and be seamlessly output to the display device via only ONE set of component cables, minimising cable carnage between the AV receiver and the TV display. Also included is a pre-programmed, multi-brand remote to operate the entire system and reduce the amount of electronic clutter on your coffee table.
This outstanding receiver also features a 32-bit DSP for DTS-ES / DTS 96/24 / DTS NEO 6 / Dolby Digital EX/ Dolby Pro Logic IIx, Digital Cinema Sound with 38 sound modes, HDMI digital video switching, HDTV compatible component video switching with up convert and A/V Sync switchable audio delay for adjusting lip-sync.
* Digital Cinema Auto Calibration
Key features
* Reference Power Rating - 85W x 6 RMS (6Ω 20Hz-20kHz, 0.09%THD)
* DIN Power Rating - 100W x 6 RMS (6Ω 1kHz, 0.7%THD)
* DTS Neo:6
* Component video switching - 2 In, 1 Out HDTV Compatible (80MHz Bandwidth)
* Full Up Conversion to Component
* HDMI Digital Video Switching
* Total of 7 connectable sources
* 5 Connectable Digital sources
* Multi-Brand Remote Commands Most Sony and other Brands' AV Products
Redig: Bilder backsida och fjärr
Redigerat av Unregistered5794a5dc, 19 June 2006 - 15:34.
Postad 19 June 2006 - 21:30
palla
  • palla
  • 305 inlägg
ÄR det bara jag som tycker sony-DG 700 är en nerbantad version på str-db798 som var en kraftmaskin på 14.5 kg som kunde mäta sig med harmanskardon 2 kanalare. Att DG-700 väger bara 8.5 kg tycker jag är lite klent och att den bara 6 kanaler är rent ut sakt dåligt !
Postad 20 June 2006 - 09:31
Unregisteredb187ace3
  • Unregisteredb187ace3
  • 220 inlägg
Ja, synd med enbart 6 kanaler, det gör den nog ointressant för mig. Jag vill ha 5.1 plus zon två för att dra till ett annat rum. I övrigt verkar den vara ett ypperligt bra budgetval.
Postad 21 June 2006 - 21:05
chicken
  • chicken
  • 190 inlägg
Eftersom det är lite osäker leveransdatum så mailade jag Dustin Home,
Har ni någon aning när
SONY STR-DG700 6.1 SILVER RECEIVER
ProduktID: 5010093846
kommer i lager?
Vi har preliminärt leveransdatum till den 24:e juli.
Vänliga hälsningar
Dustin Home AB
Order | Kundservice
Redigerat av chicken, 21 June 2006 - 21:07.
Postad 22 June 2006 - 09:51
sunnyboy
  • sunnyboy
Jaha, som gnybörjare kan jag inte annat än tycka att det hela låter mycket bra för mitt behov (jag har en Sony 40 LCD) men,
- om jag köper denna burk, kan jag därmed vara säker på att kunna koppla in en Blue Ray-spelare när den kommer så småningom????
Postad 22 June 2006 - 21:35
naukka
  • naukka
  • 81 inlägg
str-db798 har ju ingen HDMI-växlare! :D
Postad 24 June 2006 - 22:58
scenic
  • scenic
  • 1066 inlägg
Manual att ladda ner
http://www.sonydigit...=en&m=STR-DG700
http://www.sonydigit...=en&m=STR-DG500
Finns även en minirecension av DG500 på agoraquestforum
http://www.agoraques...rd2=electronics
Redigerat av scenic, 24 June 2006 - 23:00.
Postad 01 July 2006 - 19:36
reggeman
  • reggeman
  • 67 inlägg
Tjena. vet ni om den kommer att ta i mot flerkanals ljud i HDMI anslutningen? Det måste den väll göra eftersom den är en såpas ny reciver? Annars ser den ju bra ut, förutom att den inte är en 7.1 reciver då.
MVH chrille
Postad 02 July 2006 - 09:15
reggeman
  • reggeman
  • 67 inlägg
NåGON SOM VET?
Postad 02 July 2006 - 09:45
  • 478 inlägg
MVH chrille
Klart att den gör det! HDMI är helt digital överföring av både bild och ljud! Så du kopplar dvd med HDMI kabel till Reciever och vidare men annan HDMI till TV. Reciever avkodar då ljudet både DD5.1 och DTS.
Postad 03 July 2006 - 23:56
JockeO
  • JockeO
Nån som vet om det sitter lågnivåutgångar till samtliga kanaler på denna burk? Aktiva högtalare ni vet... :)
Postad 05 July 2006 - 15:34
Jojje74
  • Jojje74
Enligt manualen till STR-DG700 kan man inte få ljudet från hdmiingången att gå ut i högtalarna utan det går endast ut i tv:n. Vill man ha ut ljudet i högtalarna måste man koppla med en optisk kabel. när man gör det förlorar man väl möjligheten att utnyttja en del av de nya ljudformaten som kräver hdmi?
Postad 14 July 2006 - 07:25
offndr
  • offndr
  • 47 inlägg
det är korrekt. man får inte ut något ljud till högtalarna genom hdmi ingången på denna reciever. Jag får hem den här burken idag då ska jag undersöka saken närmare. Men enligt manualen får man inte ut något ljud och det är ju synd om detta stämmer.
Stärkaren i sig är ju finfin annars för detta låga pris.
Pixmania har många på lager.
Postad 15 July 2006 - 16:59
chicken
  • chicken
  • 190 inlägg
Pixmania har haft dessa på lager länge, iaf enligt deras hemsida. Intressant vore om du får en leverans eller inte. Konstigt vore det om Sony enbart levererat till dem?
Postad 15 July 2006 - 17:07
Aztecface
  • Aztecface
  • 1194 inlägg
Du har varken DVD, förstärkare eller HDMI standard för att kunna stödja dom i vilket fall som helst.
Postad 17 July 2006 - 11:14
offndr
  • offndr
  • 47 inlägg
Jag fick min förstärkare i fredags och den är mycket mycket trevlig. Allt enligt förväntan.
Pluggade i högtalarna och allt fungerar kanon. Kan inte mer än rekommendera denna produkt.
Den finns ju bara hos pixmania verkar det som..?
Postad 17 July 2006 - 14:00
Unregistered8e2ab484
  • Unregistered8e2ab484
  • 589 inlägg
tycker det är tråkigt att dom inte slängt dit 6.1 preout...gör det ju omöjligt att ha lite större fronthögtalare till denna...
Hade varit väldigt intressant annars då jag har sony tv och det är skönt att samma märke på grejerna, slipper man köpa multifjärr ;)
Postad 17 July 2006 - 14:48
dhanjel
  • dhanjel
  • 2495 inlägg
Ta massa bilder som sig bör och skriv en liten recension ;)
Postad 19 July 2006 - 12:50
Caulfield
  • Caulfield
  • 176 inlägg
Ok men hur var det med det där om att ljudet endast gick ut i tv'n?
Skulle den största modellen vara ett tänkbart alternativ till En H/K förstärkare för att driva ett Kef System med tanke på HDMI funktionerna plus priset? eller kommer jag att sakna ngt av HK. Vad finns det för andra alternativ med HDMI?
Redigerat av Caulfield, 19 July 2006 - 12:57.
Postad 23 July 2006 - 18:39
PeterN83
  • PeterN83
  • 13 inlägg
Är det någon som vet var det är för skillnad mellan Sony STR-DG700 och förstärkaren som följer med detta paket: Sony HT-DDW880 ?
Enligt specifikationerna från prisjakt har de olika effekt per kanal, 100 watt mot 135 watt.
En ratt på vänster sida saknas på förstärkaren med paketet jämfört med STR-DG700 samt fjärrkontrollerna är olika.
Postad 29 July 2006 - 17:47
scenic
  • scenic
  • 1066 inlägg
Äntligen en bild på STR-DG 1000
Här är länken till bilden, finns även zoomfunktion
http://www.amazon.co...337447?n=172282
Redigerat av scenic, 29 July 2006 - 17:49.
Postad 29 July 2006 - 22:20
PeterN83
  • PeterN83
  • 13 inlägg
Ser riktigt bra ut. Man ska kanske köpa en Sony DG1000 istället för DG700? Ska inte köpa förrän i slutet av augusti så jag får väl se vad det blir för något tillslut :)
Postad 30 July 2006 - 19:17
manwhore
  • manwhore
  • 124 inlägg
Ser riktigt bra ut. Man ska kanske köpa en Sony DG1000 istället för DG700? Ska inte köpa förrän i slutet av augusti så jag får väl se vad det blir för något tillslut  :D
Den är riktigt snygg, fast jag nöjer mig med DG700, det är trots allt min första maskin sedan jag skrotade farsans gamla Luxor 2-kanalare från 1980 - nu får det bli nya högtalare och en bättre begagnad tv härnäst :)
Postad 07 August 2006 - 11:37
cyberbengt
  • cyberbengt
Köpte en HT DDW880 på Sony Center efter att jag där fått uppgift om att även ljudet gick genom HDMI. Efter många timmars fipplande, läsande på forum och sökande i manualen stod det klart att ljudet inte överföres via HDMI till systemets högtalare. Packade då ihop systemet och återlämnade det omgående. Hann inte bilda mih någon grundlig uppfattning av systemet, och trimmade ju inte inställningaran, men som första intryck var ljudet via koaxial väldigt tunnt och "vasst". Min gamla Panasonic SC-HT 850 tycker jag låter bättre. Det här är nog ett system som är för billigt för att vara sannt....
Postad 07 August 2006 - 15:15
DeeSnider
  • DeeSnider
  • 42 inlägg
Vad skiljer DG-500 från DG-700? Är det bara HDMI ingångarna?
För övrigt tycker jag ljudet är ganska trist i denna förstärkare. Jag har själv DG-500. :)
Postad 08 August 2006 - 12:54
kimpa888
  • kimpa888
  • 446 inlägg
hej funderar på att köpa den här STR-DG700 men jag har lite funderingar, är det någon stor nackdel att den inte kan föra över ljudet med hdmi dom felsta förstärkare jag har blivit rekomenderade har ju inte äns någon hdmi växel. dom vanligaste förstärkarna över för väll ljudet via koaxial ut lr?
skulle den här förstärkaren passa bra ihop med ett Harman Kardon HKTS11 eller HKTS7?
Och vad är skilnaden mellan SRT DG700 och den som följer med till Sony HT-DDW880?
vad är DVD-Audio klar ? , något man kommer att behöva?
MVH KIM
(NYBÖRJARE)
Redigerat av kimpa888, 08 August 2006 - 13:05.
Postad 09 August 2006 - 08:55
pehe
  • pehe
  • 12 inlägg
Såg att Dustin hade fått den svarta STR-DG700 på lager så jag beställde en.
Min gamla receiver har hängt med länge så jag tror att vilket köp som helst är ett uppköp, men priset på denna apparat var ju klart bra.
Så nu blir höstprojektet att köpa nya högtalare med. Happy happy joy joy :)
/ Petter
Postad 09 August 2006 - 20:09
scenic
  • scenic
  • 1066 inlägg
Manual till STR-DG1000
http://esupport.sony...l?mdl=STRDG1000
Schysst vikt hela 15.5kg
Postad 10 August 2006 - 11:50
PeterN83
  • PeterN83
  • 13 inlägg
Skummade igenom manualen och såg på sidan 34 detta:
Notes on converting video signals
You can convert only 480i component video signals into HDMI signals, S video signals or video signals...
Om jag nu har fattat det här rätt så innebär detta att jag inte kan konvertera t.ex. 720p signal från chippat xbox som går med komponentvideo till förstärkaren för att sedan gå med hdmi in till tv:n?
Någon som ge mig lite feedback på det här?
