Sony KDS 55A/60A2000
536 svar till detta ämne
Postad 31 July 2006 - 13:34
Unregistered36883
  • Unregistered36883
  • 3680 inlägg
Bifogad fil  KDS60A2000.jpg   33.4K   11 Antal nerladdningar
Nu lär det väl dröja ett litet tag innan vi får se dessa skönheter på den svenska marknaden men det finns säkerligen intresse att diskutera dessa produkter vidare...! Finns även i full HD upplösning på 50"-aren...!! Både specifikationerna och priset ser ju lockande ut.
Lägger in en länk till Sony's sida...!
Audio Features
Audio Mute: Yes
Dolby® Digital: Yes
MTS Stereo Decoder: Yes
Sound Mode: Dynamic, Standard, Custom
Speaker On/Off: Yes
SRS® TruSurround® XT Audio Effect: Yes
Tone Control(s): Treble and Bass
A/V Synch: Yes
Convenience Features
Auto Channel Programming: Yes
Caption Vision: On, Off, Program
Channel Jump: Yes
Channel Label: Yes
Channel Skip/Add: Yes
Clock: Yes (with ON/OFF Timer)
Programmable Timer: Yes
Sleep Timer: 15, 30, 45, 60, 90, Off (2 Event)
Picture Freeze: Yes
Favorite Channel: Yes
Info Banner: Yes
Power Save Mode: Standard, Reduced
Program Guide Access: Yes
Speed Surf™ Channel Selection: Yes
Picture Freeze: Yes
General Features
Auto SAP: Yes
Channel Fix: Yes
ID1 Detection: Yes
Video Label: Yes
General
Aspect Ratio: 16:9
Screen Size: 60"1
Inputs and Outputs
Analog Audio Input(s): 5 (1 Front/4 Rear)
Audio Out (Variable/Fixed): 1 (Rear) - Fixed/Variable
Component Video (Y/Pb/Pr ) Input(s): 3 (1 Front/2 Rear)
Composite Video Input(s): 3 (1 Front/2 Rear)
Digital Audio Output(s): 1 (Rear: PCM/Dolby® Digital (Optical))
HDMI™ Connection Input(s): 2 (Rear: 1 with Audio Inputs, 1 without Audio Inputs)
PC Audio Input(s): 1 (Rear)
PC Video Input(s): 1 (Rear)
RF Connection Input(s): 1 (Rear)
S-Video Input(s): 1 (Rear)
Power
Power Consumption (in Operation): 200W (TBD)
Power Consumption (in Standby): 0.5W (TBD)
Power Management: Yes
Power Requirements: AC 120, 60Hz
Video Features
Advanced Iris: Yes
Advanced Video Menu: Yes
Auto Adjustment (PC): Yes
Black Corrector: High, Medium, Low, Off
CineMotion® Reverse 3:2 Pulldown Technology: Yes
Clear White: On/Off
Color Temperature: Cool, Neutral, Warm
Comb Filter: 3D Digital Comb Filter
Detail Enhancer: High, Medium, Low, Off
Direct Mode: On/Off
DRC® Mode: Mode 1, Mode 2, CineMotion® function
DRC® MultiFunction Circuitry: Yes (DRC-MF v1)
DRC® Palette Presets: Custom 1, Custom 2, Custom 3
Game Mode: On/Off
Gamma Compensation: High, Medium, Low, Off
Noise Reduction: Yes
Picture Modes: Vivid, Standard, Custom
Screen or Display Technology: SXRD™ Technology
Video Processing: Yes
Video Signal System: ATSC, NTSC
Wide Mode (4:3): Wide Zoom, Normal, Full, Zoom
WEGA Engine™ System: Yes
Video
Display Resolution: 1920 x 1080
Horizontal Center: Yes
Native Resolution: 1080p
Display Response Time: 2.5 ms (rise and fall)
Vertical Center: Yes
Vertical Size: Yes
Tuner: ATSC/NTSC hybrid with Clear QAM (8 VSB)
Service and Warranty Information
Limited Warranty: 1 Year Parts and Labor, 2 years for optical block
Weights and Measurements
Dimensions (Approx)(WxHxD): 55.6" x 38.9" x 20.2" (1413 x 988 x 514mm)
Weight (Approx.): 94lbs 14oz (43 kg)
Supplied Accessories
Remote Control (RM-YD010)
Operating Instructions
Quick Start Guide
Batteries (AA x2)
Warranty
Product Registration Card
Optional Accessories
SU-RS11X (AV Stand)
XL-5200 (120W Replacement Lamp)
Edit: Lade till en liten länk oxå
Redigerat av Unregistered36883, 31 July 2006 - 13:37.
Postad 31 July 2006 - 13:56
Unregisteredf64a5233
  • Unregisteredf64a5233
  • 14825 inlägg
Det var tänkt att 2 modeller skulle lanseras i sverige i augusti.
KDS-55A2000, 29000:- (SXRD 1080p)
KDS-70R2000, ~68000:- (SXRD 1080p)
Sen en ersättare till KDF-E50A11 -> KDF-50E2000 / KDF-50E2010(3LCD 720p). Ingen ny 42-tummare, men det är väl inte intressant nu ändå.
EDIT: Annat pris...
Redigerat av Unregisteredf64a5233, 22 August 2006 - 13:25.
Postad 31 July 2006 - 14:06
Unregistered36883
  • Unregistered36883
  • 3680 inlägg
En 70" hade ju inte varit helt fel. Visste dock inte att det fanns/var en sån på G när jag startade tråden men där har man ju nåt att tråna efter. Lite väl dyr kanske men den lär väl sjunka i pris förr eller senare...!
KDS-50A2000 (1080p) lär väl dyka upp framöver oxå...
Postad 31 July 2006 - 14:17
diabolo
  • diabolo
  • 3548 inlägg
KDS-55A2000, 35000:- (SXRD 1080p)
KDS-70R2000, 77000:- (SXRD 1080p)
Sen en ersättare till KDF-E50A11 -> KDF-50E2000 (3LCD 720p). Ingen ny 42-tummare, men det är väl inte intressant nu ändå.
Nice ;) ...finns någon länk med info? Skulle inte tacka nej till KDS-55A2000 ;)
Postad 31 July 2006 - 14:31
Unregistered36883
  • Unregistered36883
  • 3680 inlägg
Du kan läsa lite mer om den HÄR
Postad 31 July 2006 - 14:36
diabolo
  • diabolo
  • 3548 inlägg
menade svensk länk med priser...tack i alla fall
Postad 31 July 2006 - 14:52
moparman
  • moparman
  • 11727 inlägg
Dom är inte släppta här än så det är lite svårt....
Har precis kommit ut i staterna för nåra veckor sen ;)
Har läst på avsforum.com där det finns en del ägare som har skrivit om 60 tummaren som släpptes först........Dom verkar då väldigt nöjda ;)
Postad 31 July 2006 - 14:58
diabolo
  • diabolo
  • 3548 inlägg
Ok...jag hoppas att de kommer till Sverige snart...man är sugen på en 1080p ;)
Postad 31 July 2006 - 15:55
Dolph_Lundgren
  • Dolph_Lundgren
  • 1170 inlägg
tror jag läste på ett forum i USA att det bara är 1080i
Postad 31 July 2006 - 16:16
moparman
  • moparman
  • 11727 inlägg
Nopp den klarar 1080p
www.avsforum.com
Postad 31 July 2006 - 16:35
Dolph_Lundgren
  • Dolph_Lundgren
  • 1170 inlägg
oh... då är det andra bullar.
är väldigt sugen på att skaffa en 55tum
tycker att platta skärnar är för långsamma för att köra spel i 1920x1080.
Har ägt, förr förra bakproj från sony, och den hade inget prob med släp.
och då lär ju inte denna ha det.
Postad 31 July 2006 - 16:53
  • 14825 inlägg
SXRD-tekniken har en responstid på runt 2ms. Så det är upp till övrig mjukvara/bildbehandling att hänga med vid 1080p-material...
Postad 07 August 2006 - 22:17
suckerpunch
  • suckerpunch
  • 88 inlägg
Ni som vill läsa lite om vad folk tycker om A2000-serien har verkligen att göra, det finns en matnyttig men ack så stor tråd att sätta sig in i på alltid lika hetsiga AVSForum.com. Klicka här för att kolla in den, men med 94 sidor finns det tyvärr mycket struntprat att jobba sig förbi. Hur som helst verkar det lovande, lovsångerna verkar aldrig ta slut därborta. Nu gäller det bara att hålla tummarna för att priset blir anständigt också, för dom här apparaterna ser ut som riktiga vinnare.
Postad 08 August 2006 - 05:57
moparman
  • moparman
  • 11727 inlägg
suckerpunch
Heh man blir smått galen...Har man inte varit inne på en dag och läst är man många sidor efter...
Nå som gör mig galen är när folk snackar priser 10 sidor ;)
Men 60A2000 verkar helt klart vara en mycket bra tv för pengarna även om en hel del av killarna verkar vänta på XBR2 tror jag det var...Ska väl vara snäppet bättre :)
Postad 08 August 2006 - 16:36
Unregistered36883
  • Unregistered36883
  • 3680 inlägg
Priset på tv'n "over there" är ju iaf rätt vettigt... fast risken är väl att det blir X antal procents påslag när den introduceras i Europa/Sverige....
Postad 08 August 2006 - 16:40
cwp
  • cwp
  • 716 inlägg
Man brukar kunna räkna med ungefär tio gånger dollarpriset.
Postad 08 August 2006 - 19:03
moparman
  • moparman
  • 11727 inlägg
60A2000 kostar med dagens dollarkurs 26466 kronor...
Räknar man 10 kronor per dollar blir det 37000 kronor..
Jag är inte säker att det räcker med 37k när den kommer hit..
Ska bli kul att se vad den kommer att kosta :)
Postad 08 August 2006 - 19:06
  • 14825 inlägg
60-tummaren kommer inte hit! Dock kommer det en 55-tummare och den kommer att kosta ca 35.000:-.
KDS-55A2000.
Redigerat av Unregisteredf64a5233, 08 August 2006 - 19:07.
Postad 08 August 2006 - 19:33
Donmeta
  • Donmeta
  • 1705 inlägg
Helt ok pris tycker jag. Är dock så nöjd med företrädaren så jag kör på den tills jag känner att jag måste uppgradera då den nuvarande tvn får bli sovrumstv eller nått :) Men fortsätter jag vara så här nöjd med sony bakprojektion så är det inte omöjligt att även nästa tv blir en sådan. Sedan får man ju se vad det blir av SED mm.
Postad 08 August 2006 - 19:59
Unregistered36883
  • Unregistered36883
  • 3680 inlägg
Tycker nästan det känns lite sådär om det nu är så att det bara är 55-tummaren som kommer hit... hade ju varit lite mer intressant med 60" iaf...
Postad 08 August 2006 - 20:03
  • 14825 inlägg
Det är därför det även kommer en 70-tummare. :)
Postad 15 August 2006 - 11:23
wolf
  • wolf
  • 482 inlägg
I denna serie introduceras KDS-55A2000AEP först i Sverige, detta är planerat att ske i september. Det verkar som butikspriset kan bli neråt 30.000 istället... När sen leveranserna börjar är en annan sak.
Vi får hoppas att den europeiska versionen inte blir så mycket sämre än den som finns i USA. Personligen skull jag vilja ha en HDMI/DVI-ingång som är optimerad för HTPC (vilket 50A11 inte har). 1080P är ju inte helt fel...
Ganska intressant på marknaden blir det, frågan är hur länge Pioneer kan hålla uppe priset på sin 50 tums HD-plasma, Sony kommer nog att ta ytterligare marknadsandelar.
Postad 15 August 2006 - 15:26
Unregistered36883
  • Unregistered36883
  • 3680 inlägg
Aboslut... och kan dom få till schyssta priser på de större modellerna oxå så skulle jag tro att dom blir tvugna att sänka priserna till en nivå som passar lite fler...
Postad 15 August 2006 - 15:38
volvov70
  • volvov70
  • 95 inlägg
KDS-55A2000
Den kommer att introduceras i September
Rek Pris 29000:-
SXRD projektions-TV 55", Bravia engine PRO, kontrast 10000:1, full HD 1920x1080, 2xHDMI, PC-ingång
Enligt Dealernet ska den finnas tillgänglig 1 sep
Ha det
Postad 15 August 2006 - 17:50
Brainiac
  • Brainiac
  • 281 inlägg
Då borde 50" gå för under 20k, med tanke på att saker brukar säljas under rek. pris.
Blir nog att vänta på denna istället för "gamlingen" :)
Postad 16 August 2006 - 17:00
Gäst_nin_*
  • Gäst_nin_*
Detta är klart intressant och man kan kanske ska göra av med sin ruttna DLP bakprojektions TV och köpa en sådan.
Postad 20 August 2006 - 18:18
Dr Cain
  • Dr Cain
  • 492 inlägg
http://www.cesky-spo...DS-55A2000.html
Bilder där den är utställd.
Postad 20 August 2006 - 18:22
Unregistered36883
  • Unregistered36883
  • 3680 inlägg
Det gjorde ju inte att man blev mindre sugen....
Postad 21 August 2006 - 09:39
Brainiac
  • Brainiac
  • 281 inlägg
Detta måste ju vara EU-modellen, vad jag kan uttyda så kommer den klara DVB-T Mpeg-4 efter uppdatering, då borde den väl klara marksänd HDTV? Eller är mina språkkunskaper åt skogen?
De har iaf inte tagit bort digitalutgången! :P
Postad 21 August 2006 - 22:16
Dolph_Lundgren
  • Dolph_Lundgren
  • 1170 inlägg
fan vad tjock den var.
Jag förvänta mig så klart ingen "platt" tv,
men den här ser betydligt djupare ut än min gamla Lcd bakproj från sony gjorde.
Postad 22 August 2006 - 09:08
Brainiac
  • Brainiac
  • 281 inlägg
Den är 46 cm djup, istället för 40,8 cm, så hela 5,2 cm djupare!!!
Sen att bilden är 5 tum (12,5 cm) större på diametern spelar ingen roll?
Nä, nu har jag bestämt mig, det blir denna modellen, verkar inte som det kommer en 1080p 50" så det blev visst 55" istället :rolleyes:
Postad 22 August 2006 - 12:41
Dolph_Lundgren
  • Dolph_Lundgren
  • 1170 inlägg
Är denna 5cm djupare än förra årets modell?
för förra årets modell var ca 15cm djupare än förr förra.
vilket var den jag ägde.
Någon borde ringa upp Sony och berätta för dom att dom går åt fel håll :rolleyes:
Redigerat av Dolph_Lundgren, 22 August 2006 - 12:43.
Postad 22 August 2006 - 13:12
Brainiac
  • Brainiac
  • 281 inlägg
Har sony gjort en LCD bakprojektionstv som bara är 25cm djup :rolleyes: (40-15)? Tillåt mig tvivla... Den måste varit väldigt lätt att tippa isf..
*Edit* Tackar morlock
Redigerat av Brainiac, 22 August 2006 - 13:27.
Postad 22 August 2006 - 13:16
  • 14825 inlägg
Nej, den tunnaste bakprojektions-maskinen de gjort är KDF-E42A11. ~35 cm. Räknar man med hela foten som stack fram på förrförra maskinen (KF-50SX300) så var den faktiskt 44cm djup (37cm på KF-42SX300 ). Förra modellen (KDF-E50A11) var 39,5cm.
Redigerat av Unregisteredf64a5233, 22 August 2006 - 13:20.
Postad 22 August 2006 - 13:42
Brainiac
  • Brainiac
  • 281 inlägg
Morlock, du som verkar ha "lite koll", vad tror du om den bilden jag länkade till på förra sidan, är min slutsats helt åt skogen eller? Även om det dröjer med marksänd HD så hade det ju varit trevligt. Eller är det bara SD-DVB-T som stöds fast med Mpeg4-kodning?
Postad 22 August 2006 - 14:19
Unregistered36883
  • Unregistered36883
  • 3680 inlägg
En vild chansning utan någon som helst 100%-ig säkerhet är ju att den/dom har ungefär samma djup som sina föregångare och dom är ju tämligen smala...
Postad 23 August 2006 - 19:30
Unregistered4fd183bf
  • Unregistered4fd183bf
  • 535 inlägg
Enligt Sonybutiken i Stockholm så skulle tv:en dyka upp i slutet av september.
Men om andra får in den redan 1:a september så ska jag inte klaga...
Postad 23 August 2006 - 20:03
elorentz
  • elorentz
  • 36 inlägg
Er det noen som vet om det er noen andre merker som kommer 1080p bakprojektor tv'er dette året ? Eller blir sony "ensam" på markedet, skulle gjerne hatt en 60 tums, noen spesiell grunn til at den ikke kommer tilö sverige.
Postad 24 August 2006 - 00:28
  • 14825 inlägg
Enligt de första specifikationerna jag sett på den här maskinen verkar det inte vara en mpeg4-låda inbyggd.(Zapping, MPEG2 MP@ML enligt spec.) Hade det varit det så hade maskinen fått märkningen HDTV istället för HD-Ready.
Jag tror inte vi får någon "HDTV" förrän tidigast nästa år. Vid vårkanten någon gång.
Redigerat av Unregisteredf64a5233, 24 August 2006 - 00:32.
Postad 24 August 2006 - 00:35
  • 14825 inlägg
Jag tror du har fått gammal information av dem. De lär få in den till veckan. Sonybutiken i sundsvall skulle få det tydligen.
Postad 24 August 2006 - 07:07
volvov70
  • volvov70
  • 95 inlägg
KDS55A2000AEP
Finns i lager nu enl Dealernet
Postad 25 August 2006 - 09:06
wolf
  • wolf
  • 482 inlägg
Burken är testad i tyska Video nr 9/2006 (artikeln finns ej på internet vad jag kan se) och får mycket bra betyg, utomordentlig pris/prestanda och "Kauftipp". Tidningen finns på vissa stora presscenter.
Det tyska listpriset är EUR3000 och det borde betyda ett lägsta pris i Sverige på ca 25.000 om ett tag...
Postad 25 August 2006 - 14:17
wolf
  • wolf
  • 482 inlägg
Citat från en Sony pressrelease idag:
"Större bildskärmar och HDTV
Inför framtiden ser Per-Martin Öhman en tydlig trend mot större bildskärmar. Idag är 52 tum Sonys största storlek för flatpanels-tv och 55 tum för SXRD projektions-tv. Redan i oktober kommer dock en modell på hela 70 tum. En annan trend är det ökande intresset för HDTV, som kan ge en ny försäljningsboom om ett par år när HD-sändningarna kommer igång på allvar. "
Det kommer alltså en 70-tummare i Sverige, klart häftigt...
Postad 25 August 2006 - 14:31
  • 14825 inlägg
Japp.
KDS-70R2000 heter den och kommer i oktober; du kan ju alltid läsa om den på den amerikanska siten. Sätt en nolla bakom dollarpriset så har du rekommenderat pris i sverige....
Egentligen borde den här tråden byta namn till "Sony KDS-55A2000 / KDS-70R2000" eftersom det är de SXRD-modellerna som är aktuella på den svenska marknaden.
Redigerat av Unregisteredf64a5233, 25 August 2006 - 14:31.
Postad 25 August 2006 - 15:25
Unregistered36883
  • Unregistered36883
  • 3680 inlägg
70' spänn är ju rätt mycket pengar.... men möjligheten att just den sjunker i pris är väl rätt så stor... iaf inom en överskådlig framtid...!!
Postad 26 August 2006 - 17:42
KingdaKa
  • KingdaKa
  • 37 inlägg
http://www.smarthus....roducts_id=1727
24990,- Nok
Postad 28 August 2006 - 23:14
Rabalder
  • Rabalder
  • 1235 inlägg
I Tyskland kan man förhandsbeställa 55" för under 2600€..här. vilket normalt betyder intro pris i Sverige på 30k och till julafton 25k.
Som det nämndes tidigare i tråden så har den testats i Video med kanonresultat.
Slutkommentaren till testet bygger på...
Vem vill köpa en dyr Plasma när något sådant finns.. Betyget prisvärde blev Utmärkt (högsta betyg).
Postad 29 August 2006 - 16:22
hd-fan
  • hd-fan
  • 480 inlägg
Kollat in denna på Netonnet:
Sony KDS-55A2000:
55 tums HD Ready bakprojektions-TV med Full HD-upplösning på 1920x1080 pixlar, kontrast på 10 000:1 och inbyggd digital-TV-mottagare för perfekt bild. Utrustad med bl.a. 2 HDMI, 2 komponentvideoingångar samt VGA-ingång.
Pris: 29 990:-
Ett klick bort :)
Postad 29 August 2006 - 16:28
Unregistered36883
  • Unregistered36883
  • 3680 inlägg
Mailade in innan idag och frågade om dom vet när eller om dom kommer få in dom lite större varianterna...!!
Postad 29 August 2006 - 18:40
Nybbe
  • Nybbe
  • 490 inlägg
Enligt manualen skall man enbart köra PC via PC ingången som har en max upplösning på 1360x768. :)
