Nikon D80 + två nya objektiv - pressmeddelande från Nikon idag
2 svar till detta ämne
Postad 09 August 2006 - 12:06
Minhembio
  • Minhembio
  • Nyhetsankare
  • 34 inlägg
Idag har Nikon äntligen släppt all information om den nya digitala SLR-kameran Nikon D80. Fullständigt pressmeddelande finns återgivet nedan. I övrigt hänvisar jag till Digital Photography Review och deras (som vanligt mycket omfattande) genomgång av kameran.
D80 börjar säljas i september med följande UK-priser:
Kamerahus: £699
Kamerahus + 18-135mm DX-objektiv:  £949  (Mer om detta objektiv längre ned på sidan)
Fullständigt pressmeddelande från Nikon
Tokyo – Nikon Corporation is pleased to introduce the D80. Incorporating Nikon's latest digital and photographic technologies, this new high-performance interchangeable-lens digital SLR camera features automated operation and advanced features designed to satisfy any photographer with the passion to create beautiful photographs and preserve special moments.
The D80 features a new 10.2 effective megapixel DX Format CCD image sensor, bringing a new level of high resolution and sharp detail to the class while also providing plenty of freedom to crop creatively and print impressive enlargements. Nikon's DX Format sensor and Nikon F bayonet lens mount design assure unprecedented compatibility across the comprehensive assortment of AF Nikkor lenses and DX Nikkor lenses designed exclusively for Nikon digital SLR cameras.
One of the key advances developed for the D80 is Nikon's own high-resolution image processing engine. Advantages inherited from Nikon's latest professional digital SLR cameras include color independent analog pre-conditioning and high-precision 12-bit digital image processing algorithms, which combine to produce natural-looking images that benefit from faithful color and tone reproduction. A new dedicated high-performance processing chip greatly accelerates performance on all levels, while also achieving lower power consumption, assuring more pictures per battery charge.
Nikon's exclusive 3D Color Matrix Metering II ensures accurate automatic exposure control for ideal exposures, even in the most challenging lighting conditions. Evaluating, rather than merely measuring or averaging the true content of each scene, input from the system's frame-wide 420-pixel sensor is automatically referenced against an onboard database of over 30,000 scenes from actual photography to calculate final exposure value. Variable center-weighted metering and spot metering centered on the active focus area are also available, as are exposure compensation and auto exposure bracketing. Sophisticated exposure automation combined with options for complete user control help to make the D80 an ideal high-performance digital SLR for passionate photography enthusiasts.
Advanced Auto White Balance (AWB) produces natural coloration by measuring the entire frame of each scene and matching white balance to the light source. For those who wish greater personal control, the flexible options include a choice of six specific manual settings, (Incandescent, Fluorescent, Direct Sunlight, Flash, Cloudy, and Shade), as well as a preset option for using a gray or white object as a reference.
Ensuring consistently fast and precise focus lock under varying shooting conditions is the D80's refined 11-area AF system. Adopting a refined version of Nikon's advanced Multi-CAM 1000 AF Sensor Module, this new 11-area AF system adds effective new focusing options that will instill greater confidence in getting the desired shot. For example, while the system is able to use each of its 11 focus areas individually, the center sensor can also be switched to wide-frame operation for broader coverage. New Auto-area AF mode measures all 11 focus areas, automatically determines which of them are on the primary subject, and activates only those areas.
Ready to shoot whenever that priceless expression or special moment presents itself, the D80 takes only 0.18 seconds to power up. And, the shutter's minimal release lag time of approx. 80 milliseconds delivers instant response while shooting, as does the fast and precise focus of the refined 11-area AF system with AF-assist illuminator. Images are processed instantly and recorded quickly to the inserted SD memory card. Preview images are also displayed near instantly.
Continuous shooting at a rapid 3 frames per second in bursts of up to 100 JPEG (FINE M-size or smaller) images makes action photography a reality.
Packing high performance and high resolution into a slimmer, more compact body, the D80 also remains true to Nikon's commitment to intuitive operation. The size, layout and operation of all buttons and controls are designed for maximum ease of use.
The D80 features a large and bright viewfinder with large 0.94x magnification to ensure the clearest view possible for precise composition. Included is a built-in diopter adjustment control knob also makes it easier to fine-tune the view to match eyesight. The viewfinder's integrated grid display can also be turned on to assist composition.
A large new 2.5-inch 230,000-dot high-resolution LCD provides an ultra-wide 170-degree viewing angle from all directions. A new dedicated Zoom button makes it easy to preview images and assess sharpness at up to 25 times magnification. A new RGB histogram display aids in evaluating exposures with greater precision. Other playback options include single frame, 4 or 9-image thumbnail display, an improved histogram display and highlight point display.
The D80 also adds built-in Standard or Advanced Pictmotion slideshow options, which includes style selections that control transitions and background music. Shows can be enjoyed on the 2.5-inch LCD, or complete with audio on a television when connected via the supplied AV cable.
A new menu interface featuring refinements to the carefully chosen color scheme and increased font size makes navigation easier on the eye, easier to understand and easier to use. Menus can be customized to display only selected items using the new "My Menu" set.
Exclusive in-camera image editing features under the new Retouch menu help ensure consistently satisfying results and greater creative freedom without the use of a computer.
D-Lighting automatically brings out detail to enhance results and add creative flair, all while optimizing overall exposure balance. Red-eye correction automatically detects and compensates for the annoying red-eye effect sometimes caused by flash. Trim can be used to produce smaller files for easy sharing or greater efficiency. Image Overlay merges a pair of selected RAW (NEF) files taken with the D80 to create a new composite image. Other options include Monochrome settings (Black-and-white, Sepia, Cyanotype) and Filter Effects (Skylight, Warm filter, Color balance).
Multiple Exposure is a new shooting option that creates a single image within the camera from up to 3 consecutive exposures, producing an effect automatically that resembles multiple exposure techniques used with film.
Creative photography is as simple as rotating the mode dial with the D80's selection of seven automated Digital Vari-Programs. Choose from Auto, Portrait, Landscape, Close Up, Sports, Night Landscape, or Night Portrait and the selected program automatically optimizes white balance, sharpening, tone (contrast), color, saturation and hue settings to best match the shot. The D80 also offers personal control over image optimization settings, with user-selectable menu settings for the Normal, Softer, Vivid, More vivid, Portrait, Custom and Black-and-white options.
The powerful built-in flash employs Nikon's highly robust i-TTL flash control for greater precision in flash exposure evaluation that achieves better automatic flash balance. i-TTL flash control also helps realize built-in features such as Repeating flash function for creating stroboscopic effects and the Modeling Flash, which allows photographers to visually assess overall lighting and shadow conditions prior to shooting. Full support for the Advanced Wireless Lighting System lets the built-in flash function as a two-group remote commander that provides direct control over wireless SB-800 or SB-600 Speedlights.
The inherent advantages of the D80 combine with the empowering and creatively inspiring components of Nikon's Total Digital Imaging System to deliver a new level of operating ease, expanded creative possibilities, and pure enjoyment. This of course begins with the lineup of interchangeable high-quality AF and DX Nikkor lenses. It extends to maximizing the potential of Nikon’s Creative Lighting System, offering benefits such as i-TTL flash control, Advanced Wireless Lighting, highly reliable FV Lock and Auto FP High-Speed Sync, and enabling high-precision flash photography with SB-800, SB-600 and SB-R200 Speedlights.
Convenient and practical Total Imaging System add-ons include the new MB-D80 Multi-Power Battery Pack. Featuring an ergonomic design that blends added stability with extended shooting potential and more comfortable shooting in vertical format. The Wireless ML-L3 (IR) Remote Control and MC-DC1 Remote Cord options provide necessary camera stability when using long exposures, such as for landscape and macro photography.
Nikon’s PictureProject software, provided with every purchase of a Nikon D80, enables easy image importing, editing, organization and sharing. Design templates make it easy to produce prints, tailor images to e-mail, or layout several images on a page to produce creative album layouts.
Capture NX (available for purchase separately) is Nikon’s highly versatile and elegantly simple new photo editing solution designed for those who desire more creative control over post-processing and to help photographers tap the full potential of NEF (RAW) images. Featuring an innovative user interface that provides easier access to powerful and visually intuitive enhancement tools, Capture NX's powerful photo image processing and editing tools can also be applied to JPEG and TIFF files to satisfy a broader range of photofinishing needs and applications.
The Nikon D80 beautifully combines the best of latest advances in digital technology with ease of operation and quick and efficient camera handling. Add to this the advantages of Nikon's Total Imaging System and every aspiring photographer is certain to enjoy the Nikon digital SLR experience as much as the superb pictures produced with the D80.
Major features
Exceptional imaging quality
  • New 10.2 effective megapixel Nikon DX Format CCD image sensor with the power to capture exceptional sharpness and faithful color at 3,872 x 2,592 pixels size.
  • Inherits the industry-leading advanced imaging processing engine of Nikon professional D-SLR cameras. Color-independent pre-conditioning prior to A/D conversion works in harmony with high-precision digital image processing algorithms to produce natural-looking images that benefit from faithful color and tone reproduction.
  • 3D Color Matrix Metering II automatic exposure control ensures ideal exposures in most lighting conditions. Evaluating brightness, color, contrast, selected focus area and camera-to-subject distance, the system references the data against an expanded onboard database created using data from more than 30,000 actual photographic scenes to instantly and accurately calculate the final exposure value for the shot. Variable center-weighted metering and spot metering centered on the active focus area are also available.
  • Refined 11-area AF system packs the same number of focus areas available for the professional D2 series into a space-efficient system that features fast, precise operation. Each of the 11 focus areas can be used individually, the center sensor can be switched to wide-frame operation for broader coverage, and new Auto-area AF mode measures all 11 focus areas, automatically determines which of them are on the primary subject and activates only those areas.
  • ISO AUTO mode automatically adjusts sensitivity between ISO 100 to 1600 to maximize available light and achieve optimal exposure. Sensitivity can also be set manually between ISO 100 to 1600 in steps of 1/3 EV, plus HI-0.3, HI-0.7 and HI-1. Three levels of High ISO Noise Reduction are available when shooting at high ISO settings. Long Exposure Noise Reduction is also available when shooting at shutter speeds of 8 seconds or slower.
Optimized and Predictable Results
  • Seven automated Digital Vari-Programs easily accessed from the Mode Dial provide automatic operation that optimizes white balance, sharpening, tone, color, saturation and hue for crisp and vivid results that match the intended shot. Selections include Auto, Portrait, Landscape, Close Up, Sports, Night Landscape and Night Portrait.
  • Easily accessed image optimization options closely tailor results to the scene at hand or the intended use of the image. Image sharpening, tone (contrast) compensation, color mode, saturation and hue adjustment is controlled by the user-selected choice of Normal, Softer, Vivid, More vivid, Portrait, Custom and Black-and-white.
Immediate response and fast performance
  • Near instant power-up of 0.18 seconds lets photographers respond to any shutter opportunities.
  • A mere 80-millisecond shutter time lag (approximate) promotes fast handling.
  • Swift continuous shooting performance at 3 frames per second* enables the shooting of up to 100 JPEG (FINE M-size or smaller) or up to 6 RAW (NEF) images.
    * Average frame rate with continuous-servo AF, manual or shutter-priority auto exposure, a shutter speed of 1/250 seconds or faster, and remaining buffer memory.
  • Shutter speeds ranging from 1/4,000 to 30 seconds or bulb setting provide full creative control.
In-camera image editing and effects
  • Creative in-camera effects and editing functions available under the new Retouch menu:
    * D-Lighting automatically brings out detail to enhance results and add creative flair, all while optimizing overall exposure balance.
    * Red-eye correction automatically detects and compensates for the annoying red-eye effect sometimes caused by flash.
    * Trim can be used to produce smaller files for easy sharing or greater efficiency for specific end purposes.
    * Image Overlay merges a pair of selected RAW (NEF) files taken with the D80 to create a new composite image that can be saved in RAW or JPEG format.
    * Monochrome settings (Black-and-white, Sepia, Cyanotype)
    * Filter Effects (Skylight, Warm filter, Color balance)
  • Multiple Exposure creates a single image within the camera from up to 3 consecutive exposures to produce imaginative and even surreal results.
Ergonomics for efficient handling and further versatility
  • The D80 features a slimmer, more compact body with the size, layout and operation of all buttons and controls designed for intuitive operation.
  • A large new 2.5-inch LCD monitor with a 170-degree viewing angle and new dedicated zoom button assist accurate and easy assessment of sharpness by enabling image preview at up to 25 times magnification (for L-size images). Convenient displays include RGB information as a single histogram display or as separate histograms for each color channel.
  • Built-in slideshow options include Advanced Pictmotion shows with style selections that control transitions and background music, and that can be enjoyed on the 2.5-inch LCD, or complete with audio on a television via the supplied AV cable.
  • The carefully chosen color scheme and increased font size of the new color-coded menu display makes navigation easier on the eye, easier to understand and easier to use. "My Menu" lets you customize Menus to display only the items you wish to see.
  • Bright pentaprism viewfinder with large 0.94x magnification ensures the clearest view possible for precise composition.
  • Nikon's EN-EL3e rechargeable lithium-ion battery delivers enough power to support the shooting of up to 2,700(1) images on a single charge, can be recharged at any time and features a handy real-time fuel gauge system display that shows remaining charge by percentage, number of shots since last charge and overall battery status.
(1) Achieved under the following test conditions: Fully charged EN-EL3e battery; temperature of 20°C/68°F; Zoom-Nikkor AF-S DX 18-135mm f/3.5-4.5G IF-ED lens; continuous shooting mode: continuous-servo autofocus; image quality set to JPEG BASIC; image size set to Medium; shutter speed 1/250 second; shutter release pressed halfway for three seconds and focus cycled from infinity to minimum range three times with each shot; monitor turned on for five seconds after six shots and then turned off; cycle repeated once exposure meters turned off.
Seamless integration with Nikon’s Total Imaging System
  • Unprecedented compatibility with Nikon’s lineup of AF Nikkor lenses and digital-exclusive DX Nikkor lenses. (When used with the D80 or any DX Format SLR, all AF and DX Nikkor lenses have a picture angle comparable to 1.5x that of 35mm [135] format.)
  • Compatibility with the Nikon Creative Lighting System allows the D80 to work seamlessly with SB-800, SB-600 and SB-R200 Speedlights to deliver the benefits of i-TTL flash control’s advanced monitor pre-flash, accurate measurement for bounce and versatile wireless operation. SB-800 and SB-600 Speedlights also offer a Wide-Area AF-assist Illuminator, which aids flash photography in dim light by projecting a pattern of red light that covers all eleven autofocus areas of the D80’s 11-area Multi-CAM 1000 AF Sensor Module.
  • The optional MB-D80 battery pack adds extended shooting capability in an ergonomic design that adds shooting stability. Able to run on either one or two EN-EL3e batteries or six AA-size batteries(2) , the pack also features an additional command dial and alternative buttons for shutter release and AE-Lock/AF-Lock that make vertical shooting more comfortable.
(2) Compatible AA-size batteries comprise alkaline, Ni-MH, lithium and nickel-manganese batteries.
  • PictureProject (complimentary with camera) software features an intuitive user interface that provides fast and easy access to powerful tools for organizing, editing and sharing images. Auto Enhance and other creative functions are readily available via handy buttons, as are Mail, Slideshow and CD/DVD burning functions. Pictures can be organized using simple drag ‘n’ drop operation, and can be quickly located by name, keyword, or date. Design templates make it easy to produce prints, tailor images to e-mail, or layout several images on a page to produce creative album layouts.
  • Capture NX (available for purchase separately) is Nikon’s highly versatile and elegantly simple new photo editing solution designed to help photographers tap the full potential of NEF (RAW) images. Featuring an innovative user interface that provides easier access to powerful and visually intuitive enhancement tools, Capture NX's powerful photo image processing and editing tools can also be applied to JPEG and TIFF files to satisfy a broader range of photofinishing needs and applications.
Nikon Digital SLR Camera D80 Specifications
Type of camera Single-lens reflex digital camera
Effective pixels 10.2 million
Image Sensor RGB CCD, 23.6 x 15.8mm; total pixels: 10.75 million, Nikon DX format
Image Size (pixels) 3,872 x 2,592 [L], 2,896 x 1,944 [M], 1,936 x 1,296 [S]
ISO Sensitivity (Recommended Exposure Index) 100 to 1600 (ISO equivalent) in steps of 1/3 EV, plus HI-0.3, HI-0.7 and HI-1
Storage Media SD memory card, SDHC compatible
Storage System Compressed NEF (RAW): 12-bit compression, JPEG: JPEG baseline-compliant
File System Exif 2.21, Compliant DCF 2.0 and DPOF
White Balance Auto (TTL white balance with 420-pixel RGB sensor), six manual modes with fine-tuning, color temperature setting (Kelvin), preset white balance; white balance bracketing also available
LCD Monitor 2.5-in., 230,000-dot, low-temperature polysilicon TFT LCD with brightness adjustment, allows up to 170-degree viewing angle.
Playback Function 1) Full frame 2) Thumbnail (4 or 9 segments) 3) Zoom 4) Slideshow (Standard or Pictmotion) 5) RGB histogram indication 6) Shooting data 7) Highlight point display 8) Auto image rotation
Delete Function Card format, All photographs delete, Selected photographs delete
Video Output
Can be selected from NTSC and PAL
Interface USB 2.0 (Hi-speed) (mini-B connector); SD card slot: supports firmware updates via SD cards
Text Input Up to 36 characters of alphanumeric text input available with LCD monitor and multi-selector; stored in Exif header
Compatible Lenses Nikon F mount (with AF coupling and AF contacts)
Picture Angle Equivalent in 35mm [135] format is approx. 1.5 times lens focal length
Viewfinder Fixed eye-level pentaprism; built-in diopter adjustment (-2.0 to +1.0m-1)
Eyepoint 19.5mm (-1.0m-1)
Focusing Screen Type-B BriteView Clear Matte screen Mark II with superimposed focus brackets and On-Demand grid lines
Viewfinder Frame Coverage Approx. 95% (vertical & horizontal)
Viewfinder Magnification Approx. 0.94x with 50mm lens at infinity; -1.0m-1
Viewfinder Information Focus indications, Metering system, AE/FV lock indicator, Flash sync indicator, Shutter speed, Aperture value, Exposure/Exposure compensation indicator, ISO sensitivity, Exposure mode, Flash output level compensation, Exposure compensation, Number of remaining exposures
Autofocus TTL phase detection by Nikon Multi-CAM 1000 autofocus module with AF-assist illuminator (approx. 0.5m to 3.0m) Detection range: EV -1 to +19 (ISO 100 equivalent, at normal temperature: 20°C/68°F)
Lens Servo Instant single-servo (AF-S); continuous-servo (AF-C); auto AF-S/AF-C selection (AF-A); manual (M); predictive focus tracking automatically activated according to subject status in continuous-servo AF
Focus Areas 11 areas; any single area can be selected; center focus area can be switched from normal to wide-frame
AF Area Modes 1) Single Area AF: Focuses only on subjects in the selected area. Selection can be made from any one of the eleven AF spot sensors.
2) Dynamic Area AF: Focuses on subject in the selected area, but follows the subject if it moves from its original position, shifting instantly and automatically to the focus area into which the subject has moved.
3) Auto-area AF: measures all 11 focus areas, automatically determines which of them are on the primary subject, and activates only those areas.
Focus Lock Focus can be locked by pressing shutter-release button halfway (single-servo AF) or by pressing AE-L/AF-L button
Exposure Metering System Three-mode through-the-lens (TTL) exposure metering
1) 3D Color Matrix Metering II (type G and D lenses); color matrix metering II (other CPU lenses); metering performed by 420-segment RGB sensor
2) Center-weighted: Weight of 75% given to 6, 8, or 10mm dia. circle in center of frame
3) Spot: Meters 3.5mm dia. circle (about 2.5% of frame) centered on active focus area (on center focus area when non-CPU lens is used, or if Auto-area AF is selected)
Exposure Metering Range (ISO 100, f/1.4 lens, 20°C/68°F) 1) EV 0 to 20 (3D Color Matrix or center-weighted metering)
2) EV 2 to 20 (spot metering)
Exposure Meter Coupling CPU coupling
Exposure Modes Digital Vari-Program (Auto, Portrait, Landscape, Macro Close up, Sports, Night Landscape, Night Portrait), Programmed Auto [P] with flexible program; Shutter-Priority Auto [S]; Aperture Priority Auto [A]; Manual [M]
Exposure Compensation ±5 EV in increments of 1/3 or 1/2 EV
Exposure Lock Luminosity locked at detected value with AE-L/AF-L button
Auto Exposure and Flash Bracketing 2 to 3 exposures in increments between 1/3 to 2.0 EV
Shooting Modes 1) Single frame shooting mode
2) Continuous shooting mode: approx. 3 frames per second
3) Self-timer
4) Delayed remote mode
5) Quick-response remote mode
Shutter Electronically-controlled vertical-travel focal plane shutter, 30 to 1/4000 sec. in steps of 1/3 or 1/2 EV, bulb
Sync Contact X-contact only; flash synchronization at up to 1/200 sec.
Flash Control 1) TTL: TTL flash control by 420-pixel RGB sensor Built-in Flash, SB-800, SB-600: i-TTL balanced fill-flash (except when using spot metering exposure mode) Built-in Flash, SB-800, SB-600: standard i-TTL flash (when using spot metering)
2) Auto aperture: Available with SB-800 with CPU lens
3) Non-TTL Auto: Available with Speedlights such as SB-800, 80DX, 28DX, 28, 27, and 22s
4) Range-priority manual; available with SB-800
Flash Sync Modes 1) Auto 2) Fill-in flash 3) Red-eye Reduction, 4) Red-eye Reduction with Slow Sync, 5) Slow Sync, 6) Rear-curtain Sync 7) Off
Built-in Flash (Auto, Portrait, Macro Close up, Night Portrait) auto flash with auto pop-up; Manual pop-up with button release Guide number (ISO 100, m/ft.): approx. 13/42
Flash Compensation -3 to +1 EV in increments of 1/3 or 1/2 EV
Accessory Shoe Standard ISO hot-shoe contact with safety lock provided
Self-timer Electronically controlled timer with 2 to 20 seconds duration (2, 5, 10, and 20 second selectable)
Depth of Field Preview When CPU lens is attached, lens aperture can be stopped down to value selected by user (A and M modes) or value selected by camera (P and S modes)
Remote Control Via Remote Cord MC-DC1 (optional) or Wireless Remote Control ML-L3 (optional)
Power Source One Rechargeable Li-ion Battery EN-EL3e, MB-D80 battery pack (optional) with one or two rechargeable Nikon EN-EL3e Li-ion batteries or six AA alkaline (LR6), Ni-MH (HR6), lithium (FR6) batteries, or nickel-manganese (ZR6) AA batteries, AC Adapter EH-5 (optional)
Tripod Socket 1/4 in. (ISO 1222)
Dimensions (W x H x D) Approx. 132 x 103 x 77mm (5.2 x 4.1 x 3.0 in.)
Weight Approx. 585g (1 lb. 5 oz.) without battery, memory card, body cap, or monitor cover
Supplied Accessories(3) Rechargeable Li-ion Battery EN-EL3e, Quick Charger MH-18a, Audio Video Cable EG-D2, USB Cable UC-E4, Strap, Body cap, Eyepiece Cap DK-5, Rubber Eyecup DK-21, LCD monitor cover BM-7, Accessory shoe cover, PictureProject CD-ROM
Optional Accessories Multi-Power Battery Pack MB-D80, Magnifying Eyepiece DK-21M, AC Adapter EH-5, Wireless Remote Control ML-L3, Remote Cord MC-DC1, Speedlight SB-800/SB-600/SB-R200, Capture NX, Camera Control Pro
(3) Supplied accessories may differ in each country or area.
Nikon lanserar även två nya objektiv
I samband med nyheten om D80 så lanseras även två nya objektiv.
AF-S DX Zoom-Nikkor 18-135mm f/3.5-5.6G IF-ED
Objektivet börjar säljas i september till UK-priset £299
Specifications
Focal length 18-135mm (picture angle equivalent to a 27-202.5mm lens in the 35mm format)
Maximum aperture f/3.5-5.6
Minimum aperture f/22-38
Lens construction 15 elements in 13 groups (one ED glass elements, two aspherical lens elements)
Picture angle 76° - 12°
Minimum focus range 0.45m (1.5 ft.)
Attachment size 67mm
Dimensions (approx.) 73.5 x 86.5mm (2.9 x 3.4 in.)
Weight (approx.) 385g (13.6 oz.)
Included accessories 67mm Snap-on front lens cap (LC-67), Rear lens cap (LF-1), Bayonet hood (HB-32), Flexible lens pouch (CL-0915)
Optional accessories 67mm screw-in filters
AF-S VR Zoom-Nikkor 70-300mm f/4.5-5.6G IF-ED
Objektivet börjar säljas i oktober till UK-priset £399
Specifications
Focal length 70-300mm (Picture angle, when used with Nikon DX format digital SLRs is equivalent to a 105-450mm on a 35mm format SLR)
Maximum aperture f/4.5-5.6
Minimum aperture f/32-40
Lens construction 17 elements in 12 groups (two ED glass elements)
Picture angle 34°20’ - 8°10’ (22°50’ - 5°20’ with Nikon DX format)
Minimum focus range 1.5m (4.9 ft.) (through the entire zoom range)
Dimensions (approx.) 80 x 143.5mm (3.1 x 5.6 in.)
Weight (approx.) 745g (26.3 oz.)
Included accessories 67mm Snap-on front lens cap (LC-67), Rear lens cap (LF-1), Bayonet hood (HB-36), Flexible lens pouch (CL-1022)
Länkar:
Information från DP Review - Nikon D80
Information från DP Review - AF-S DX Zoom-Nikkor 18-135mm f/3.5-5.6G IF-ED
Information från DP Review - AF-S VR Zoom-Nikkor 70-300mm f/4.5-5.6G IF-ED
Postad 09 August 2006 - 16:08
KenX
  • KenX
  • 39 inlägg
Bra, men för dyr. Sonys kamera ser intressantare ut i mina ögon.
Postad 11 August 2006 - 19:11
ekke
  • ekke
  • 2466 inlägg
Ja, SONYn är strået vassare faktiskt, men har man redan en massa nikon gluggar så är ju denna kamera bra, men lite dyr kanske ...
förhoppningsvis får vi se prissänkningar på alla kameror i detta segment från sony nikon etc då det verkar vara stor konkurrans just nu ...
