Ny svenskbox snart på marknaden (Lyngbox)
288 svar till detta ämne
LyngBox Media LyngBox LB-ST1 160GB (Digitalboxar) 1 4.5 (1) Inga priser
Postad 07 September 2006 - 09:53
Unregisterede74c2883
  • Unregisterede74c2883
  • 88 inlägg
Lyngbox
Hemsidan för boxen
Kanske kan bli något, men blir den godkännd av CD??.........
Features
The LyngBox is a unique and easy to use product for the world wide market. It solves the most common problems experienced by users. The main features of the LyngBox include the following:
LyngBox is a receiver for HDTV
The LyngBox supports HDTV reception, from both satellite (DVB-S2) and terrestrial transmissions (DVB-T). The box has a DVB-S2 tuner to support the latest standard for satellite transmission.
LyngSat Network
The LyngBox uses a number of services from LyngSat Network, some of them specially developed for the LyngBox:
LyngSat provides the LyngBox with up-to-date channel and satellite information
LyngSat Maps automatically calculates which satellites that can be received from the users location with the available equipment
LyngSat Guide is an extensive TV guide covering all the world
Automatic Channel List Installation
One of the biggest problems with satellite TV is that the channel list in a conventional satellite receiver is static. It requires a lot of knowledge by the user to add new channels, so much knowledge that many viewers avoid watching the ever increasing selection of satellite TV channels.
To know if a channel is receivable with a specific type of equipment, the LyngBox can use LyngSat Network to automatically install all receivable channels.
Automatic Channel Update
A common problem is that channels seem to disappear suddenly. The reason is that TV companies want to optimize their coverage area and/or decrease their transmission costs. The viewer will think that the channel has stopped transmitting, since there is normally no tuning advice or information about the move.
With the LyngBox, all channel information is automatically updated from LyngSat Network, so the viewer is not affected when the channel moves or changes parameters.
Focus on free-to-air TV channels
The LyngBox simplifies identification, installation, and updates of the large number of Free-to-Air channels available. The integration of LyngSat Network let the user identify all channels that are possible to install with the available equipment.
Users with a motorized antenna have an additional advantage from the LyngBox. It might be possible to keep track of all channels at one satellite position, but to do it for all receivable satellite positions is almost a full-time job. Many users don't even know which satellates they can tune in to. The integration with LyngSat Maps automates this work. The channel list is ready and kept up-to-date without any effort.
You can also watch channels with conditional access by installing "pay-TV-cards" in the dual common interface slots of the LyngBox.
A global and interactive TV guide
LyngSat Guide provides the user with a global and interactive TV guide. The guide is integrated into the LyngBox, but can also be used as a standalone website.
One-Touch Recording
The integration with LyngSat Guide makes it easy to schedule recordings. Just press the recording button when browsing the TV guide to record a program. The powerful PVR also give the possiblity to edit recorded programs and to store recordings on an external DVD-recorder connected with USB2.
Control Recordings From Internet
The user can command the LyngBox to record TV programs using the webbsite LyngSat Guide, from any computer with an Internet connection.
You don´t need to be worried if you forgot to set a recording before leaving home. Just log in on the LyngSat Guide website and set new recordings
The receiver is developed with focus on quality reception and ease of use
The sensitive DVB-S2 tuner in the LyngBox can tune in to satellites other receivers can not reach.
Usability for the LyngBox is guaranteed by the intuitive user interface and the automatic channel maintenance enabled by the integration with LyngSat Network. The user can concentrate on the main objective, watching TV
Dual Tuner
Makes it possible to watch and record both terrestrial and (DVB-T) and satellite (DVB-S/S2) channels. A third tuner is possible to add as an option for simultanous watching and recording from the same source.
Photo Viewer
The LyngBox can display your photos in full HDTV resolution. It is possible to connect a digital camera to the USB-connectors and display photos, or copy the photos to the inbuilt hard disk of the LyngBox.
User Profiles
Each user of the LyngBox can have an own profile with separate channel lists. The channel lists for all profiles are of course kept up-to-date with the LyngSat synchronization. It is possible to protect profiles with password (parental lock).
Note: Since the LyngBox communicates with LyngSat Network on Internet, it is recommended to have an Internet connection to the LyngBox.
Technical data
Technical Features
HDTV support (720p and 1080i)
Supports H.264/MPEG-4 AVC and MPEG-2
Inbuilt tuners for both satellite TV (DVB-S/DVB-S2) and terrestrial TV (DVB-T)
Internal slot system which makes it possible to install an additional tuner card
4:3 and 16:9 TV screen format support and teletext decoding
Dual Common Interface slots for usage with pay-TV-channels
PVR functionality with inbuilt hard disk
Possibilities to store recordings on an external DVD-recorder connected with USB2
DiSEqC 1.2 support for controlling LNB and motorised dish
Remote control as standard and a wireless remote keyboard as accessories
Channel selection by typing the name (or the beginning of the name) of the channel on the keyboard
View images from a digital camera connected to the LyngBox
The LyngBox can store up to 50000 channels
LyngBox Special Features
Free access to all LyngSat Network services (LyngSat, LyngSat Guide and LyngSat Maps) with exclusivity to the LyngBox. No other receiver has access to these services
Always corrects channel names, not relying on service names in the DVB stream
Family user profiles and parental lock. Each user can have their own selection of channels based on countries, languages and genres which will be updated automatically
Interfaces
DVB-S2 input
DVB-T input + output (pass-through)
Expansion slot for additional tuner card
2 Common Interface slots
HDMI-output.
Component output
Composite output
SCART output (RGB and composite)
S/PDIF optical output with AC-3 support
Stereo audio (2 RCA)
4 USB 2.0 ports
Ethernet connection (100BaseT)
Hardware Specifications
Size (WxHxD): AxBxC cm
STi7100 CPU (three cores: 1x266 MHz, 2x400 MHz)
96 MB System Memory
160 GB Hard Disk
OLED front panel display
Guarantee & Warranty
The LyngBox has a two years limited guarantee
Redigerat av Unregisterede74c2883, 07 September 2006 - 10:01.
Postad 07 September 2006 - 10:53
phil neal
  • phil neal
  • 2633 inlägg
Ser intressant ut, men kan aldrig tänka mig att den blir godkänd av CD, den verkar kunna alldeles för mycket för det......beror väl lite på nätverksfuntionen också. Oklart om den har inbyggt kodsystem eller CA-plats för satellit? Men den var grymt snygg :unsure:
Postad 07 September 2006 - 11:00
Unregistered25afe1a3
  • Unregistered25afe1a3
  • 1919 inlägg
160 gb hårddisk känns lite för lite om man ska spela in HD matrial via satellit, det borde ta större plats än vanligt digital tv.
Känns som en mycket bra box det man har läst om den, hoppas bara CD och Viasat kan godkänna den för jag vill inte ha 2 st boxar.
// Hifighost
Postad 07 September 2006 - 15:07
andersos
  • andersos
  • 3199 inlägg
Verkar väldigt intressant. Inget Wifi dock <_< . Få se vad priset hamnar på.
Postad 08 September 2006 - 10:30
  • 1919 inlägg
Älskar bara designen på denna box. <_<
Snygg displaylösning.
Synd att man ska få vänta till februari innan den släpps.
// Hifighost
Postad 08 September 2006 - 20:52
phil neal
  • phil neal
  • 2633 inlägg
Lite mer info:
Interfaces
DVB-S2 input
HDMI-output.
Component output
Composite output
4 USB 2.0 ports
Postad 09 September 2006 - 09:56
knugen
  • knugen
  • 29 inlägg
Nej, denna kan aldrig bli godkänd av CD eller Viasat,kan alldeles för mycket och är riktigt snygg också! CD måste först kränga bort sina Sagemboxar och om 2-3 år få oss att tro att dom är först med en världsnyhet: HDTV-box med dubbla tuners och hårddisk! Viasat kommer heller inte att tycka om den då det kan vara möjligt att ta in andra kanaler än deras egna med den. Viasat som startade en gång med TV3 för att motverka monopol-TV......
Postad 09 September 2006 - 19:58
Unregistered29785adf
  • Unregistered29785adf
  • 97 inlägg
Oj, snyggaste boxen jag nånsin skådat! :)
Kommer den på marknaden i februari?
Postad 10 September 2006 - 11:47
phil neal
  • phil neal
  • 2633 inlägg
Nä det skrev dom bara för att vilseleda eventuella intressenter........
Postad 23 September 2006 - 05:23
Jet100
  • Jet100
  • 34 inlägg
Jo,det kommer i februari,priset är mellan 6000-7000 kr.
Redigerat av Jet100, 23 September 2006 - 05:24.
Postad 23 September 2006 - 05:31
Jet100
  • Jet100
  • 34 inlägg
Ser intressant ut, men kan aldrig tänka mig att den blir godkänd av CD, den verkar kunna alldeles för mycket för det......beror väl lite på nätverksfuntionen också. Oklart om den har inbyggt kodsystem eller CA-plats för satellit? Men den var grymt snygg  ;)
Den har 2 CI plats,och ett inbygged kort läsare.
Postad 23 September 2006 - 05:34
Jet100
  • Jet100
  • 34 inlägg
// Hifighost
Jag har en satellite mottagare som är ej goodkännd av CD,men ändå fungerar mycket bra med CD kort,inget problem alls.
Postad 23 September 2006 - 11:13
phil neal
  • phil neal
  • 2633 inlägg
Vilket kodsystem för den inbyggda kortplatsen är det då?
Postad 23 September 2006 - 12:12
Luinmir
  • Luinmir
  • 103 inlägg
Hmm .. låter finfint .. men Funkar denna på Comhems nät??
Postad 23 September 2006 - 12:41
Unregistered6332cbbb
  • Unregistered6332cbbb
  • 882 inlägg
det ska den göra funkar ju med DVB-C, enligt produkt specen
Postad 23 September 2006 - 14:21
Unregistered6810b893
  • Unregistered6810b893
  • 6702 inlägg
Om denna skulle bli godkänd av CD, skulle man då få ett nytt kort från dem? Det nuvarande kortet är väl låst till boxen man använder idag?
Postad 23 September 2006 - 16:19
phil neal
  • phil neal
  • 2633 inlägg
Troligtvis. Låst eller inte, beror på hur gammalt ditt kort är, jag har ett med några år på nacken som inte är låst.
Postad 23 September 2006 - 16:37
Aztecface
  • Aztecface
  • 1194 inlägg
För bra att vara sant men kommer den att säljas i Sverige och klarar av både Viasat, CanalDigital och frikanaler med motorstöd så ska jag ha den. Jag skulle t.om kunna tänka mig att sträcka mig väldigt högt i pris för att äga en sådan.
Postad 23 September 2006 - 17:31
Toneloc
  • Toneloc
  • 102 inlägg
Hmm, var ser du det, det enda jag kan läsa är att den stöder DVB-S/DVB-S2 samt DVB-T, det står förvisso att det går att plocka in ytterligare tuner-kort men om det finns DVB-C kort hittar jag inget om?
Postad 07 October 2006 - 17:23
srna
  • srna
  • 322 inlägg
Drog iväg ett mejl till Lyngbox. Enligt deras pressansvarige skall den släppas Q1 2007, priset är satt till 5995:-
Vad tror ni om denna box i jämförelse med Dreambox 8000? Denna har ett stort trumfkort i att den automatiskt upppdateras dagligen med lyngsat:s hemsida och namn och dylikt ändras automatiskt på kanalerna (enda mottagaren, naturligtvis :P som kommer ha denna möjlighet)....några idéer?
Redigerat av srna, 07 October 2006 - 17:24.
Postad 07 October 2006 - 17:28
  • 1919 inlägg
Den verkar bättre och snyggare enligt min mening än dm8000. Skickade ett mail till Lyngbox samma dag den kom ut och har inte fått något svar. :P
Jag tycker om nätverksfunktionen samt att slippa alla kanaluppdateringarna.
// Hifighost
Postad 08 October 2006 - 23:31
Steppen
  • Steppen
  • 19 inlägg
Låter som precis det man har sökt länge nu :blink:
Ett stort aber med dom andra HD satellit mottagarna som bla. Canaldigital har är ju att man inte kan lägga till extra Ca moduler om man så vill. t.ex dragom cam modul
Jäkligt irriterande att man betalar för en mottagare och bara kan se deras utbud. :)
Då borde dom ju vara gratis om man inte får se nått annat.
Känner ngn. till fler Hd mottagare som har öppna slots för fler Ca platser?
Man vill ju inte behöva använda flera mottagare till en och samma tv B)
Undra bara hur buggig den här mottagaren kommer vara med tanke på att den är helt ny?
CD har ju haft stora problem med sina mottagare.
Postad 09 October 2006 - 00:26
Scrapanatchi
  • Scrapanatchi
  • 1061 inlägg
Boxen verkar helt okej :) lite klen hdd dock
EDit: tog bort en strunt sak :blink:
Redigerat av Scrapanatchi, 09 October 2006 - 00:33.
Postad 09 October 2006 - 08:46
phil neal
  • phil neal
  • 2633 inlägg
Boxen verkar helt okej  B) lite klen hdd dock
EDit: tog bort en strunt sak  :)
Vissa hittar alltid nåt att klaga på......den går säkert byta ut :blink:
Postad 09 October 2006 - 12:31
OZZO
  • OZZO
  • 63 inlägg
Haft mailkontakt med dem ang hårddiskens storlek. De svarade att man kan spela in ca 20 tim i HD kvalitè. Det går oxå bra att byta ut hårddisken till en större.
Redigerat av OZZO, 09 October 2006 - 13:57.
Postad 09 October 2006 - 14:12
  • 1919 inlägg
Låter som precis det man har sökt länge nu  :)
Jäkligt irriterande att man betalar för en mottagare och bara kan se deras utbud.  ;)
Man vill ju inte behöva använda flera mottagare till en och samma tv  :D
Fördelen här är ju att de inte ha behövt stressa fram boxen som CD utan de har nog tagit lärdom av andra HD boxar får man hoppas. Den ständiga internetuppkopplingen gör ju att de kan lägga in små ändringar i programvaran hela tiden utan vi vet det. De behöver ju inte samla ihop alla problem som CD gör med sin box.
// Hifighost
Postad 09 October 2006 - 14:22
OZZO
  • OZZO
  • 63 inlägg
Några fler svar på mina frågor ang Lyngboxen. Maildag 06-09-26
Kommer er box att lämnas till CD för godkännande?
- Vi har för närvarande inget operatörsavtal med CD.
Om inte, kan jag använda deras programkort på Lyngboxen ändå?
- man kan köpa lösa CA-moduler som borde fungera, men det har varit tal om att CD vill låsa kunden till att endast använda egna boxar (som Viasat).
Finns det fläkt i boxen? Om det finns, är den tyst?
- Ja, - ja den är tyst
Har ni mätt upp hur många dbA?
- Inga ljudnivåmätningar ännu. Hårddisken är förmodligen det som väsnas mest och vi har inte valt leverantör ännu. Ljudnivå är naturligtvis en avgörande faktor vid val av disk.
När och var kommer den bli tillgänglig för att inhandla?
- Planerad release är februari 2007, kan då köpas på www.lyngbox.com eller från TV-handlare (vet ej vilka just nu)
Kan jag boka ett ex av er?
- Som privatperson kan du inte boka en box. Möjligen kommer vi att tillåta förbokning i webbshopen på lyngbox.com, men det är inte beslutat ännu
Vad kommer den att kosta?
Indikationspris till slutkund ca €600-€700.
Postad 09 October 2006 - 16:14
srna
  • srna
  • 322 inlägg
Har för mig att det satt flera usb-kontakter på boxen. Man kunde ju koppla till en extern dvd-brännare, så det kanske går att koppla till en fet portabel hdd. Att kanalbyte sker snabbt och att den uppdateras automatiskt är absolut viktigast för mig. Plockar man ett par tusen kanaler är det pain in the ass att bläddra igenom dom med seg kanalväljare.
Postad 12 October 2006 - 20:09
Biggles2002
  • Biggles2002
  • 1276 inlägg
Denna boxen var ju en fröjd för ögat,nästan synd att stoppa in den i tv bänken :D
Hoppas bara den blir godkänd hos CD
Postad 17 November 2006 - 20:18
Jennifer
  • Jennifer
  • 148 inlägg
5995 kr för denna box verkar vara rena fyndet, hoppas den blir godkända av CD.
Postad 17 November 2006 - 20:39
khalnur
  • khalnur
  • 1668 inlägg
Det verkar lite konstigt om CD i längden inte visar intresse för fler boxar att erbjuda sina kunder. När det blir fler aktörer på HD-marknaden borde det vara en konkurrensfördel. Bara en reflektion. :(
Postad 17 November 2006 - 22:22
phil neal
  • phil neal
  • 2633 inlägg
Tror inte CD är intresserade av att godkänna en box som kan bränna ut deras program via USB...
Postad 17 November 2006 - 23:39
Coolg8
  • Coolg8
  • 150 inlägg
Det står att man kan ansluta en DVD-recorder, och det finns att köpa redan nu... :( ...
och CDs HD box kan man ansluta till DVD-recorder också.
Men även jag tror inte heller att de kommer att godkänna den, däremot kommer det att komma andra HD boxar med PVR som de kommer att godkänna vänta och se..
Postad 18 November 2006 - 10:12
phil neal
  • phil neal
  • 2633 inlägg
Jo en DVD-recorder kan du ju ansluta till vilken box som helst vi scart, men Lyngboxen kan anslutas via USB, vilket ger nya möjligheter att skicka filmer från box till tex datorn. Detta beror ju föstås på hur USB-anslutningen är utförd. Det vet vi ju inte än.
Postad 18 November 2006 - 13:26
  • 1919 inlägg
Var finns den att köpa för 5995 kr?
// Hifighost
Postad 18 November 2006 - 21:40
phil neal
  • phil neal
  • 2633 inlägg
// Hifighost
Det gör den inte.....
Postad 18 November 2006 - 21:49
  • 1919 inlägg
Phil neal det verkar som någon har hittat priset någonstans, Jennifer var fick du priset ifrån?
// Hifighost
Postad 18 November 2006 - 22:37
Jennifer
  • Jennifer
  • 148 inlägg
Priset fick jag från tidningen M3, och där stod det att den skulle komma under våren
Postad 18 November 2006 - 23:35
  • 1919 inlägg
Ok då blir det en lång väntan istället. :(
// Hifighost
Redigerat av Unregistered25afe1a3, 18 November 2006 - 23:36.
Postad 21 December 2006 - 11:45
Unregistered33aea5f7
  • Unregistered33aea5f7
  • 1610 inlägg
Det står att man kan ansluta en DVD-recorder, och det finns att köpa redan nu... :unsure: ...
Jag har en HD-box från Canal Digital som jag fick "gratis" med abonnemang. Den är definitivt inte kapabel att låsa något kort till sig, jag tvivlar starkt på att de ens har någon uppdatering klar för den som gör att den kan låsa ett kort. Den här boxens funktionalitet är så basal i dagsläget att det skulle vara en PR-mässig katastrof om de låste sina kort till en box som i dag inte duger till någonting annat än att visa HD-kanalerna. Den har ju inte ens någon programguide!
Det skulle vara ett otroligt smart grepp av Canal Digital att skriva ett avtal med Lyngbox redan nu för att säkra tillgång till en box av den kalibern. Bara detta skulle antagligen kunna döda den framtida marknaden för Viasat, för alla andra än de som nöjer sig med enklast möjliga funktionalitet.
Det skulle säkert finnas sätt att låsa USB-portarna på Lyngboxen så att CD blir nöjda.
Satellitoperatörernas beteende är ju konkurrensbegränsande så det räcker och blir över...
/P-O
Postad 23 December 2006 - 12:10
khalnur
  • khalnur
  • 1668 inlägg
Väl talat politby! :D
Postad 23 December 2006 - 13:07
  • 1919 inlägg
Kan bara hålla med Politby det vore smart att skriva avtal med Lyngboxen det måste komma en riktigt bra box snart.
// Hifighost
Postad 23 December 2006 - 13:37
Unregistered51e43403
  • Unregistered51e43403
  • 279 inlägg
Det står att man kan ansluta en DVD-recorder, och det finns att köpa redan nu... :D ...
/P-O
Kan nämna att även jag har CD:s HD-box som man fick "gratis". Det gamla kortet har nu slutat att fungera och det nya kortet fungerar INTE i min gamla Nokia 9902-s box. Så nog verkar det som om det nya kortet är låst till HD-boxen...
Postad 25 December 2006 - 09:41
gusax
  • gusax
  • 1425 inlägg
Eller så fick du ett media highway-kort till HD-boxen men Nokian kräver ett kort avsett för CA-moduler... det finns (fanns) två typer av kort innan det här tramset med kortlåsning och godkända boxar började nämligen. Ett för Canal Digitals egna boxar (Media highway) och ett för övriga (CA-modul).
Postad 25 December 2006 - 17:29
Jennifer
  • Jennifer
  • 148 inlägg
Är det någon som vet den mer exakta leverans tidpunk för denna dröm maskin,
det enda jag har hört är under våren 2007 och det går att tolka lite olika.
Postad 25 December 2006 - 22:13
  • 1610 inlägg
Jag tror inte ens att Lyngbox själva vet. Den här typen av produkter brukar ju ta tid att få färdiga.
Ett problem är ju den svenska marknaden - med Viasat redan låst och Canal Digital på väg att låsa sina kort kan Sverige ju bli en icke-marknad för Lyngbox. Vi kanske inte får se den alls om den någonsin blir klar.
/P-O
Postad 25 December 2006 - 23:25
kenta2
  • kenta2
  • 900 inlägg
Avseende kort till CD, så finns det egentligen 3 sorter. De avsedda för CA-modul, MediaHighway samt de som är chipsetanpassade till de tex de nyare Comboxarna, Grundig och HD-boxarna. De sistnämnda korten är ofta inkompatibla med andra mottagare än de som numera är godkända av CD.
Modernare boxar (som inte alltid är godkända) klarar dock ibland av dessa, samt faktiskt en äldre CA-modul Conax v.3.x (otroligt nog).
Avseende Lyngbox så måste de klara av rejäla volymer snabbt om det skall vara intressant för CD. De lär ha beställt ca 30-40.000 boxar från Sagem rakt av i samband med fotbolls-VM. Under kvartal 1 lanserar CD HDTV i de övriga Nordiska marknaderna. Då måste allt klaffa. Sverige har varit pilotmarknad för CD med en box var en tillfällig lösning i väntan på en mera genomgripande satsning.
Det är inte egentligen ett problem med HD-boxar och boxtillverkare. Det är istället problem att få fram stora volymer till en given tidpunkt som är nära i tiden. Thomson, Pace och Humax är stora tillverkare som har HDTV-boxar hos sina kunder i tillräckliga volymer som tex hos Sky och Premiere. Allt kräver dock planering och ledtid för att lansera ett erbjudande på hela den nordiska marknaden.
Under hösten har CD planerat och bullat upp för satsningen under 2007. De har redan avtal med de som de vill skall leverera boxar. Det ryktas om en snyggare och stabilare box samt ytterligare en med PVR, båda med mottagningsmöjlighet för bredband. Detta för att kunna köra tex Canal+ Select. Telenor som äger CD vill gärna kombinera så mycket som möjligt.
Redigerat av kenta2, 25 December 2006 - 23:56.
Postad 25 December 2006 - 23:31
Scrapanatchi
  • Scrapanatchi
  • 1061 inlägg
Viasats HDTV box är PVR från start, den påminner också mycket om den SKY använder ... :)
Hoppas bara dem är generösare med hårdisk utrymme ...
Postad 26 December 2006 - 00:00
kenta2
  • kenta2
  • 900 inlägg
Hej Scrapanatchi,
Viasat har inte officiellt varit framme med tydlig info om sitt eventuella inhopp i HDTV-världen ännu vad jag har sett. Det ryktas om vårkanten.
Har du info om eventuell HDTV-box från Viasat, så får du gärna dela med dig av din vetskap om du vill.
Postad 26 December 2006 - 06:26
Unregisteredbcf42efe
  • Unregisteredbcf42efe
  • 878 inlägg
HDTV från Viasat!!?? Finns det verkligen planer på det?
VIASAT är ju kända för att var sist med det senaste och kan ju inte ens erbjuda DD5.1-ljud på sina filmkanaler. De har väl precis lanserat sin senaste "nyhet", film i Widescreen-format. :(
