Nya Pioneer receivrar
351 svar till detta ämne
Postad 05 May 2007 - 11:14
scenic
  • scenic
  • 1066 inlägg
Info på www.avland.co.uk
Pioneer VSX-917
Dolby Pro Logic IIx Decoder built-in
DTS 96/24 Decoder
HDMI switching
1080p passthrough
Unique Pioneer MCACC (Multi-Channel Acoustic Calibration) audio optimiser
7x110W
On Screen Display
WMA9 Pro
DTS Neo:6
DTS ES
Greater flexibility in speaker arrangement when utilising Front Stage Surround Advance
Front A/V Input With Optical Digital Input
USB input
Learning LCD Remote
Pioneer VSX1017
Built in RDS FM/AM Tuner
HDMI v1.3 (High-Definition Multimedia Interface) switching
USB Host Function
THX Select 2, Dolby TrueHD and DTS-HD Master Audio decoding
Wide Frequency Response for DVD-Audio and SACD
5.1 channel input & 7.1ch Pre- Output
7x150W
96kHz / 24bit AD converters
192kHz / 24- Bit D/A Converters
Video up conversion to component
On Screen Display
Front AV connection
MCACC Auto Setup
WMA9 Pro
LCD Learning remote
Pioneer VSXLX50
iPod Socket, allowing the user to operate the device via the receiver’s remote control and on screen display
USB Host Function
7.1 channel input & pre-output
7x150W
On Screen Display
Front AV connection
MCACC Auto Setup
WMA9 Pro
LCD Learning remote
Pioneer VSXLX60
USB Host Function
7x150W
On Screen Display
Front AV connection
MCACC Auto Setup
WMA9 Pro
LCD Learning remote
Postad 09 May 2007 - 15:35
joakim2004
  • joakim2004
  • 217 inlägg
finns det några bilder på dessa recivrar?
Postad 09 May 2007 - 16:21
Sir Anselm
  • Sir Anselm
  • 1475 inlägg
1017 låter ju väldigt intressant om den hamnar i samma prisklass som 1016....
Postad 12 May 2007 - 07:29
Unregistered4fa1df97
  • Unregistered4fa1df97
  • 80 inlägg
VSX LX-50 verkar hamna på 8 500 kr
VSX-1017 på 6 000 kr
men s-n vilka snygga recievrar, kolla:
Pioneer VSX-LX70 - http://www.avland.co...x70/vsxlx70.htm
Pioneer VSX-LX60 - http://www.avland.co...x60/vsxlx60.htm
Pioneer VSX-LX50 - http://www.avland.co...x50/vsxlx50.htm
Pioneer SC-LX90 - http://www.avland.co...lx90/sclx90.htm
release i augusti på alla utom värstingen LX-90 (jan 2008)
wohooo! Hoppas nu de har fläskat på rejält med HDMI ingångar och två utgångar också på samtliga..
Postad 12 May 2007 - 08:59
  • 80 inlägg
HDMI 3 in 1 ut på LX70 ser det ut som... men å andra sidan kan man kritisera trovärdigheten då man för ett år sedan kunde läsa att Pioneer skulle släppa HD-DTS mm på en rumänsk sida. Den släcktes efter ett tag. Jag skulle inte bli förvånad om denna info försvinner snart...
Postad 12 May 2007 - 10:08
Anthon. A.
  • Anthon. A.
  • 771 inlägg
Fan, vad snygga!! :) :)
Plötsligt så börjar man nog köpa förstärkare för utseendet :P
Postad 12 May 2007 - 10:40
Unregistered5480a0bb
  • Unregistered5480a0bb
  • 886 inlägg
Verkar inte som att bilderna på avland är mycket att gå efter. Står "incorrect image" under dem.
MvH / Andreas
Redigerat av Unregistered5480a0bb, 12 May 2007 - 10:41.
Postad 12 May 2007 - 10:46
Kanelen
  • Kanelen
  • 395 inlägg
MvH / Andreas
Det är bilden för VSX-LX70 som visas på alla sidorna, så den är kanske korrekt då?
Postad 12 May 2007 - 10:47
THXcht
  • THXcht
  • 2340 inlägg
Man blev ju inte lite sugen på LX90, med all dess prestanda. Men det lutar nog mer åt att man köper sig en LX70 som nog blir lite billigare. 5000£ för 90:an är kanske lite i det dyraste laget.
Postad 12 May 2007 - 18:04
  • 80 inlägg
notera att LX70 bilden är klickbar och går att se i lite större bildstorlek :-) neat
och här är mer info och nya bilder:
http://www.areadvd.d...VSX_LX_50.shtml
gissar att pioneer släpper denna "nyhet" snart
Redigerat av Unregistered4fa1df97, 12 May 2007 - 18:06.
Postad 12 May 2007 - 18:15
Unregistered5794a5dc
  • Unregistered5794a5dc
  • 478 inlägg
alla de svarta recievers är av "Elite" serie dvs gjorda för USA marknad, därav beteckningar.
men, klart intressanta iaf. synd att man köpte i höstas en.
Postad 12 May 2007 - 18:16
Holmqvist
  • Holmqvist
  • 167 inlägg
Så jäkla läckra de är alltså! :) Låter de lika bra som de ser ut så är man klart sugen. :)
Postad 12 May 2007 - 18:41
THXcht
  • THXcht
  • 2340 inlägg
Dessa är inte "Elite" stärkare, de kommer att säljas som både svarta och silvriga.
Postad 12 May 2007 - 18:45
Kanelen
  • Kanelen
  • 395 inlägg
Tack för tipset, missade det förut. :) Riktigt läcker är den med stor vill-ha-faktor.
Postad 12 May 2007 - 19:42
Spiritwalker
  • Spiritwalker
  • 704 inlägg
****, var det snyggaste jag sett :) :) Vill ha LX70 NUU!!
Postad 12 May 2007 - 19:58
THXcht
  • THXcht
  • 2340 inlägg
Det är bara LX90 som har THX märkningen på sig, det står visserligen att de andra är THX-certifierade men då borde det ju sitta en lite THX-logga på dem oxå.
Postad 13 May 2007 - 13:16
  • 80 inlägg
Jo, visserligen har du rätt i det. Men å andra sidan tycker jag det är bra att Pioneer vågar ta steget från Logoporren som man ser hos alla andra... men ska det vara nån logga till ska det vara THX :-)
Redigerat av Unregistered4fa1df97, 13 May 2007 - 13:17.
Postad 13 May 2007 - 17:44
mobil.niklas
  • mobil.niklas
  • 523 inlägg
ser att det kommit upp några nya förstärkare på pioneers hemsida (http://www.pioneer.s...5/overview.html)... var länge sen jag var inne dock men 917 modellen finns i alla fall där... men 1017 osv har inte kommit upp än... men skall alla modeller utan något undantag, lx-90, komma i augusti? är speciellt intresserad av 1017 modellen:).
/niklas
Postad 13 May 2007 - 17:53
Kanelen
  • Kanelen
  • 395 inlägg
/niklas
Juli är en nämnd månad för den modellen.
http://www.pioneerel...6139549,00.html
Postad 13 May 2007 - 18:01
mobil.niklas
  • mobil.niklas
  • 523 inlägg
/niklas
okey, grymt. och det gäller även i sverige? det står april på de andra men dem finns inte här på prisjakt?
/niklas
Redigerat av mobil.niklas, 13 May 2007 - 18:08.
Postad 13 May 2007 - 18:16
Kanelen
  • Kanelen
  • 395 inlägg
/niklas
/niklas
Inte en susning - jag letar fortfarande efter "bra" datum. Allting blir ju hur som helst försenat som vanligt.
Postad 13 May 2007 - 19:04
aftersun
  • aftersun
  • 526 inlägg
Antagligen kommer dom väl till hösten.
Den som väntar på något gott...
Postad 14 May 2007 - 12:25
Unregisteredac95974e
  • Unregisteredac95974e
  • 655 inlägg
LX90 kommer i Januari 2008 enligt länk ovan
//erikli
Postad 14 May 2007 - 12:43
snowspace
  • snowspace
  • 636 inlägg
OJOJOJOJOJOJ!!!!! :rolleyes:
Det var dom FULASTE recievrar jag sett på länge.
hur får man dom att passa in i ett rum som inte är inrett som en rymdstation ala Star Trek??
Och detta med blått ljus? Vi har fattat att blåa dioder är dyrare än röda, kan ni snälla byta tillbaka
till röda som både är billigare och bättre för ögat i ett nersläckt biorum.
Ser ju ut som värsta science-fiction leksaken för tolvåringar. Hoppas detta mode i designen
försvinner illa kvickt så vi kan få apparater som passar in i ett trevligt hem.
//Håkan
Ps, här är ett exempel på en snygg förstärkare, lite många knappar på försteget men annars helt ok:
Posted Image
Postad 14 May 2007 - 13:02
aftersun
  • aftersun
  • 526 inlägg
Dom där var väl ändå inte snygga? :rolleyes:
Postad 18 May 2007 - 16:57
  • 80 inlägg
jo, apsnygga :-)
Postad 18 May 2007 - 17:04
  • 80 inlägg
Ett slutligt bevis på att LX-receivers är på väg ser ni i texten till Pioneer BDP-LX70 blue-ray spelare "När man kombinerar BDP-LX70:n med förstärkare i vår LX-serie och plasmaskärm garanteras man detta i en sann HD-nätverkslösning." Mao snart släpper säkerligen Pioneer Sverige snart priser och leveransdatum på nya recievers om jag får göra en kvalificerad gissning...
Redigerat av Unregistered4fa1df97, 18 May 2007 - 17:06.
Postad 19 May 2007 - 08:51
THXcht
  • THXcht
  • 2340 inlägg
Vi får hoppas på det, jag är mycket sugen på en ny stärkare...
Som det har skrivits här på minhembio så är det synd att de inte klarar av att avkoda DTS-HD Master Audio. Gör detta någonting ifall man har en blu-ray spelare som klarar av att skicka ut denna signal och blir avkodad från den? Eller blir det så att man inte kommer att kunna dra nytta av detta ljudformat?
Postad 20 May 2007 - 23:01
Unregisteredb38af287
  • Unregisteredb38af287
  • 2416 inlägg
Aaaah - en klar kandidat som ersättare till Sherwood R-972 i LX70, då man även planerar för en Samsung-plasma borde det ju kunna bli en vacker vy där framme iaf.
Sedan om den nya LX70 kommer att vara bättre än sherwoods alternativ är väl kanske diskutabelt. Mer info nu!
ps: svart med gröna ljus är det absolut snyggaste och mest skonsamma i mörkret, fram för mer grönt!
Redigerat av Unregisteredb38af287, 20 May 2007 - 23:01.
Postad 23 May 2007 - 16:16
THXcht
  • THXcht
  • 2340 inlägg
Var på The Rock i Lund idag och snackade med dem lite om de nya recievrarna. Upp till 1017 så skulle det bli silver och sen var det pianolack svart uppåt. Själv skulle jag vilja ha en LX70 i silver men det kanske inte kommer att gå, vi får se vad tiden har att utvisa. Jag hoppas att det kommer att ändra sig tills releasen.
Postad 13 June 2007 - 20:54
Spiritwalker
  • Spiritwalker
  • 704 inlägg
Nån som har datum på sverigepremiärerna för dessa???
Postad 14 June 2007 - 08:16
aftersun
  • aftersun
  • 526 inlägg
Jag är också väldigt intresserade av dessa, svårt att hitta information dock.
VSX-1017 presenteras på Pioneers svenska hemsida, antar att den är någorlunda ny också?
Postad 18 June 2007 - 16:31
Unregisterede647f0fe
  • Unregisterede647f0fe
  • 84 inlägg
Har kollat på ny reciever länge. Är dax och byta ut mina gamla marantz dvd och reciever. Har varit jävligt nöjd med dom men tror nog inte jag komma köra på marantz igen för de blir för mycket pengar. Tror att de inte är så stor skillnad idag mellan stärkare som jag tyckte de var då. Har fastnat rätt mycket för pioneer stärkarna. har lyssnat lite på äldre modeller som jag tycker är helt okay så de lutar nu åt pioneer och isf VSX-LX 50 eller 60. Tror dom räcker för mig och min plånbok. Om de blir en pioneer stärkare så kommer de också bli deras blueray spelare. Den ska vara ###### grym. Snackade med från usa som har haft den i ett tag nu och han helt lyriskt över den. Men han har iofs inte testat nån annan blueray men pioneer vet vad dom sysslar med när de gäller bild.
Postad 24 June 2007 - 23:38
spindeln
  • spindeln
  • 82 inlägg
Löser 1017 problemet som 1016 har med hd-ljudet att man måste ha ljudkablar + hdmi kablar......ljudet går inte via hdmi på 1016.
Gör det det på 1017 ?
Postad 28 June 2007 - 19:32
THXcht
  • THXcht
  • 2340 inlägg
Nu har man även lagt upp VSX-LX50 på Pioneers hemsida.
Postad 28 June 2007 - 19:54
Unregistered36431
  • Unregistered36431
  • 647 inlägg
Är bra sugen på en LX50 men lite väl dyr för min smak, för det är väl LX50 som ersätter 2016AV?
Får hoppas att 2016AV börjar sjunka i pris så man kan lägga de extra kronorna på lite bättre kablar.
//Niklas
Postad 29 June 2007 - 07:17
frhape
  • frhape
  • 276 inlägg
Precis, det undrar jag med.
Dessutom undrar jag en till sak.
Hur fungerar det med Pioneers USB ingångar?
Kan man spela Mp3 och får man upp mappar på bildskärmen och kan välja fritt hur man vill spela upp?
Samma sak vad gäller bilder?
Postad 29 June 2007 - 13:06
THXcht
  • THXcht
  • 2340 inlägg
//Niklas
Jag tror att priset på LX50 kommer att sjunka rätt fort, den lär hamna nere runt 8000kr inom inte allt för lång tid.
Postad 29 June 2007 - 13:55
Unregistered36431
  • Unregistered36431
  • 647 inlägg
//Niklas
Får hoppas på det för 1500:- extra kan jag avvara men det sa jag när jag gick från 1016AV till 2016AV för som sagt så saknar 1016AV konvertering mellan komponent till hdmi vilket 2016AV klarar av. + att 2016AV har iPod ingång vilket är ett stort plus.
//Niklas
Postad 30 June 2007 - 20:13
tugger
  • tugger
  • 79 inlägg
Man börjar nästan fundera på om LX50 kommer bli något billigare, spanar du andra märken som erbjuder DTS-HD så ligger priset på 40k på 'värstingarna'.
Postad 02 July 2007 - 21:10
THXcht
  • THXcht
  • 2340 inlägg
Jaja, Pioneers "värsting" lx90 ska väl kosta runt 90000kr när den kommer men lx50 är ju inte någon värsting och det kommer att komma fler och fler som klarar de nya formaten och därför så sjunker priset i takt med det.
Postad 03 July 2007 - 17:38
THXcht
  • THXcht
  • 2340 inlägg
1017 / LX50 är ute nu
lx60 / lx70 kommer preliminärt i oktober
lx90 sägs komma i januari
Postad 03 July 2007 - 17:45
aftersun
  • aftersun
  • 526 inlägg
Någon officiell pressrelease från Pioneer Sverige borde ju komma snart tycker man. Hade varit skojj med lite mer information om vad som komma skall.
Postad 03 July 2007 - 18:03
  • 80 inlägg
Vilken källa har du fått den informationen från?
Postad 03 July 2007 - 21:47
THXcht
  • THXcht
  • 2340 inlägg
Av en pålitlig butik.
Postad 07 July 2007 - 08:42
The Blackening
  • The Blackening
  • 165 inlägg
Den informationen är korrekt...
Redigerat av The Blackening, 07 July 2007 - 08:42.
Postad 07 July 2007 - 08:54
THXcht
  • THXcht
  • 2340 inlägg
Här kommer lite rekomenderade priser.
1017: 8000kr
lx50: 12000kr
lx60: 14000kr
lx70: 16000kr
Postad 08 July 2007 - 18:31
Unregisteredcb365a13
  • Unregisteredcb365a13
  • 62 inlägg
Hörde att LX 90 skulle ligga i 50K klassen med realese Jan 2008.
Trots detta är dräggel faktorn hög ;)
Postad 08 July 2007 - 18:40
THXcht
  • THXcht
  • 2340 inlägg
LX90 kommer nog tyvärr bli lite dyrare än så, men man vet ju inte förrän den har kommit.
Om jag inte kommer ihåg helt fel så hörde jag att den lär hamna omkring 80-90.000kr, men det kan vara fel.
Postad 09 July 2007 - 08:40
Unregistered47efd78c
  • Unregistered47efd78c
  • 1554 inlägg
1017 och LX50 är inte ute ännu, kommer inom några veckor.
